Gollum
    19
Everything posted by Gollum
  1. The problem with just using a bent (by design) TC rod is that the mount point and angle doesn't change. You'd still need to cut off the old tie in and weld in a new one at a different angle, and most likely closer to the LCA. In order to keep the mounting points stockish on both sides, the TC rod would haveto have two bends in it, in order to get the plane back to where it would have been stock. It'd be more like: --\_/- If it's like: --\___ Then you've completely moved where the rod ends up, and if you bend it in such a way that it makes it back to the original hole then the angle is all fubar. Adapting some of those nice 944 LCA's fixes the issue entirely. Though I personally don't think that's a "full proof" fix to your issues. You'd still be battling limited camber gain and other suspension limitations. But it'd definitely be the cheapest solution to get you on the right track. (haha, get it?) EDIT: Oh, and I would never pay $400+ for LCA's I'd have to do custom fab work for in order to make work. You can find virtually identical LCAs in a PLETHORA of cars in the junkyard. In fact I was just working on my wife's accord and it's very similar up front.
  2. If you really want to do this "right" then you'll end up tube framing the whole front end of the car and ditching the stock suspension design all together. Adding a steering rack with more max turning angle (shorter turning radius) doesn't get you ANYTHING since you'll just end up with rubbing issues. Even if the tie rods are moved a much as possible, which won't be a ton, you still have the frame to contend with as well, which is just as much of an issue. You really want to convert to a double wishbone or SLA type setup. This will not only get you much more control over inherent camber gain, kingpin angle, caster, etc. You might end up with a car that drives like crap on the street, but is awesome when it comes to wide slide angle control. IF you wanted to go this route the "easy" way (which is obviously relative) and keep part engineering as simple as possible, buy a donor car like a miata and design the front tube frame around it's mount points to match it's geometry. You'll need to pick a vehicle with roughly the same track width though.
  3. Most people learn this lesson pretty quick. When I see those car ads with a million parts listed all I read is blablabla blala balala bla bla.
  4. I believe that's your friend's car, yes. I actually didn't do too much work to it at all, just filters and such. I didn't have a ton of time to spend on it. I attribute most of the look to the angle. I purposely played with angle width of the lens to get the right about of distortion I wanted on the pic. Though I did change the license plate for privacy's sake. I'll email the pics to you from the event, but fair warning, there's quite a few and might take a few emails.
  5. Should check out this thread I just posted, has pics from both of your cars. If you want I can email you the full size originals. http://forums.hybridz.org/index.php/topic/101252-4th-annual-norcal-hybridz-bbq/page__p__948783__fromsearch__1?do=findComment&comment=948783
  6. Hey itzgoten, you and your buddy with that blue S30 didn't happen to be at Infineon Raceway a year ago in June where you? I was attending the Sonoma Classic races and got pics of two really nice S30's that sure look AWFULLY similar.... If that was you I'm quite disappointed I didn't get a more detailed look at this WONDERFUL build of yours.
  7. For the record though, you should note that very few LS motors ever have issues with reliability regarding the head, or anything else relating to the fact it's a pushrod design. And the LS motor CAN reach 300k like most other modern engines. The LS is not a SBC in the slightest, even when it comes to durability.
  8. Why are people so eager to ditch the semi-trailing arm? There's been so many successful race cars in history using semi-trailing arms I often wonder if people just get caught up in what's "best" and just assume everything else just sucks. I understand that given the option we'd all have better suspension options in our cars, but the reality is that it simply costs too much and is too complicated for most of us to tackle. So I say learn to live with what you have, and learn to make it better.
  9. And my headlights work a lot better too! Who would have thunk?
  10. The thing is tony, it wasn't really a cut. It'd rev to 7k just fine. It'd rev to 7k in gear just fine too! It just didn't like it much. The power dropped off CONSIDERABLY over 4k. And I know peak power is only arond 5000,5500 anyways, as I've owned 5 of these dang cars now, but this one had been the most gutless up top. Now that I've fixed some of these electrical gremlins it's the STRONGEST up top NA L28E I've owned!
  11. I agree with many here that doing a SBC, though very cool, isn't the wisest thing for you to do right now. The shop the car is at seems questionable, and they don't seem interested in working on your car. Get it home, whatever it takes, even if it's a $300 tow bill. Then find a used motor and throw it in. It'll cost you less than $300 in tools MAX and then you'll have your start to having what you need to work on a car. Sure it'll be a used motor, but if you hunt around long enough you should find one in good enough shape. For example my '81 burns oil, and I'm fairly certain it's the rings. Smokes pretty bad on decel. I got the car with 205k on the odometer and now it's got over 240k in less than 3 years. I have to put in a quart of oil about every 1500 miles or so, but I decel with the clutch in and watch my oil levels. It's amazing how long bad rings can last when you're taking care of the car. Oh, and this car was FREE. Not because I knew the owner or anything, he just needed it gone. FREE This is why most of us own datsuns, they're CHEAP, easy to work on, and FUN! So get on the cheap bandwagon and go hunting on craigslist. You'll be a better man to your car by knowing how to work on it. Find a cheap motor and see how it goes. If the new cheap motor burns just as much oil then you now have a spare motor to rebuild if you wish. Have a machine shop do all the hard work and assemble yourself.
  12. I always find it ironic that someone can talk about doing custom suspension work and the be asking about motor mount kits in the same thread... People have tried to make S30 drift cars in the past. It can be done, but it's certainly not easy and the attempts I remember didn't listen to the advice given freely from those wiser around here. My advice would be to throw out all the things you thought you knew and listen to those around here that seem to know what they're talking about, because many of them have more race car experience in their toe nail than I have in my entire being.
  13. When I had my cars on the same scale back to back, I was shell shocked as to how true Tony's statement here is. Mostly stripped '75 280Z with NO bumpers front or back, no interior, no spare tire, etc was less than 100 pounds lighter than my '81 with power steering, power windows, power mirrors, etc. The clincher is that my '81 is a slick top, and the '75 has a turbo, so that adds some weight, while the slick top '81 is fairly light compared to the common t-top cars. For years I've wanted to find a clean black on black '79 base model to through a SR into along with a subie R160. That'd just about be my dream S130 once suspension was well sorted. I'd keep the tires fairly conservative, don't let escalation get the best of me and keep it light. Could end up with a 2300 pound street car that's got some good pep to it.
  14. You never DID specify what trans you switched to. T5 or Datsun 5 speed? If it's the T5 try a different fluid first, that's a cheap fix. Also make sure you've got enough in there to begin with. The good news about having the T5 is that just about any transmission shop can rebuild it and parts are readily available, unlike datsun tranny parts which can be a little more of a hassle.
  15. +1,000,000,000,000 to the power of 9,999,999,999,999 Even short nose R200 prices are ridiculous by many standards. Cheaper than longnose R200 isn't saying much. Jon points out hard points to argue, and there's no real reason not to other than to "keep it nissan" which to me is like insisting on marrying a cousin, which will just lead to bad genes. Cross-company relations is a good and healthy thing.
  16. So in my current '81 I knew I needed to replace the battery terminal clamps and was just lazily putting it off. Sometimes I'd have to fiddle with them quite a bit to get the car started, but I guess I'm just lazy about some things. So I finally buckled down and spent $5 on new clamps, and $7 on a terminal and clamp cleaner. A previous owner had replaced one of the clamps at one point, and when unraveling the mess of electrical tape I found that the old job hadn't ever been connected correctly and was just shoved together... Problem? There was enough length left to cut it back down bellow the old splice and attach the wire correctly to the new clamp. It all buttoned up nicely and when I went to start the car not only did the car start up great, but I noticed my clock worked... The clock hadn't worked at all since I've owned the car... So I started going through everything and noticed the blower motor for the heater worked great, unlike before it wouldn't stay on full blast... And other little things here and there seemed to be better as well. Upon taking the car for a drive I noticed that the engine was more responsive, and was much more willing to rev through it's upper range. Before it kinda ran out of gusto over 4,500 that I just attributed to old rings with low compression. The engine DOES have over 250k now. What's more, is I was normally getting around 350 miles on a tank in mixed driving if I let the tank get dangerously dry. I could reach maybe 400 tops if I was on a road trip. This tank will easily see 380 by my guess and that's mostly around town driving, with plenty of spirited fun with the new power up top... I'm betting by the looks of it I could reach 450 per tank highway like my first ZX I owned. So, it all just goes to show you how much good clean electricity means to your car and all of it's systems. It always amazes me how sometimes fixing the littlest things can yield such huge rewards.
  17. Mind sharing a view details for the record? I'd like to reference this post in the future when this topic comes up. 1. What boost levels were you running? 2. What EFI system is the engine on? 3. Intercooler yes/no, size? 4. What fuel where you running? 5. What was your timing configuration and settings? 6. Any difference between max timing?
  18. Didn't we just cover this topic??? Seems like we need to have a Smog Specific section or something. To the OP - Consider vortex generators? Might look dumb to some, but I bet they'd help at least partially for ANYONE having fume smell issues in the cabin. Combined with the logical longer tail pipe you should be able to get those gases under control. Now, if you're smelling the car in the drive through that's a whole different issue, and is partially part of life.
  19. Yea, that's basically the advice I just gave you... But what I said regarding power and economy are still true. With a fully programmable unit like megasquirt you'll end up getting more power per PSI of boost and better economy off of boost. Either way, you'll want to tune your RRFPR on a dyno once you've gotten it into the ballpark. Last thing you want is to have it running a bit lean under boost and think it's fine, but then have a severe detonation meltdown first time you go racing on a hot day. And I personally believe that an aftermarket pump isn't necessarily a "requirement" for your goals. People have made 300 to the wheels on the stock pump.
  20. For 250 wheel HP, you can certainly get away with the stock EFI setup, but just as long as you know that you'll be leaving some power on the table, and also leaving some economy on the table as well. I'd leave the turbo stock unless it's needing to be rebuilt, then you might as well find a T3/T4. The stock T3 will make all the way up to 300 wheel hp when forced with a decently sized intercooler and plenty of fuel. My recommendation though, is to leave the injector stock so that you can still get good economy, warm up, and low end driveability. Use a rising rate fuel pressure regulator, and don't buy one that's a fixed 1:1 ratio. Buy one that can be adjusted via adjustment washers, because you'll most likely want something more like 3:1. Running just 10psi can get you to your goal if everything is running right. It'll just be a matter of getting it on a dyno with a O2 sensor so you can tune the RRFPR for full boost conditions. Don't **** around with adjusting the air flow meter, or adding resistors to the coolant temp sensor. Those are good ways to just get everything out of whack and turn your EFI system into a crude digital carburettor. Both of those can be used as tools to fine tune, but for such modest power goals, I see no reason to go screwing something up. And also, if I recall correctly, the ECU for the L28ET has maps that go to 10psi stock and won't hit a brick wall, so to speak, with injector duty cycle, when going beyond 7psi. The main reason you'll be wanting to dyno tune with some adjustability is because prolonged duration of 10psi might require more fuel to keep the engine from detonating, and with modified exhaust on the stock T3 you might be hitting 10psi much sooner than the ECU would expect, which could cause some tuning issues. Overall it's a well designing map for it's day and can take some abuse. You just want to make sure it doesn't blow up. Also, just plain don't use the knock sensor. Pretty much all of us with the stock ECU just leave it unplugged.
  21. I can see a lot of potential upsides, but the cost and time investment for fabrication is nothing to scoff at. I think the point that people are bringing up is that the rear suspension in a S30 is rarely a handling hindrance. You can fit a 245 in the rear just fine, and converting to disc brakes isn't difficult. And even with stock drum brakes people have put out some amazing lap times around the world in these cars... The biggest problem facing the rear area is the diff and stub axles holding huge torque numbers from a big V8. Obviously the R200 will hold the power, so that's not a issue to upgrade to, but LSD options are expensive. But frankly so is a corvette suspension setup. So for most of us, it just doesn't make a ton of sense.
  22. Who ever said I did a brake stand? And comparing the S13 and S30, and both most likely modified from stock regarding suspension, in how well they hold a circle is like comparing cheese and moldy chicken in how they stick to the ceiling. I'm not saying you're wrong. I'm saying that we really don't know what's in it, and to MY EYES (which could certainly be wrong) if he does have LSD it's not terribly great. But then again his whole rear suspension setup looks questionable from where I'm sitting.(says the guy who needs all new bushings still...)
  23. Funny, I've laid down twin strips of rubber with my open R200....
  24. Hmmm, I guess he's tapped out now....
  25. Actually didn't look like he had a LSD to me, but that's just my opinion. Would be interesting to get some specs of the car from the builder.
