19
Everything posted by Gollum
280zx turbo failed smog. need advice to pass on retest
Gollum replied to stravi757's topic in S130 Series - 280ZX
This site agrees with what I'd said earlier, you're allowed +/- 3 degrees. http://www.smogtips.com/functional_inspection.cfm I still wonder if he has a vacuum leak. Judging by the high HC he's probably running lean until the O2 kicks in (which takes a good 5 seconds after the test starts, I've watched it kick in). The high nox is REALLY off the chart for an engine running well. I can only presume that it has to be EGR related. I know in my '81 which has dying rings and thus will only compression test just over 100psi in some cylinders, has a hard timing getting the EGR diaphragm fully open. My NOx is usually near the limit, but my motor also has obvious signs of nearing the end of it's life and the fact I get it to pass is almost a miracle. If you can find a nice smog tech, I'd ask for some time with the car on a smog test run. Take a vacuum pump and when running at 15mph pump the EGR into vacuum and see if the NOx drops dramatically. If it does, then you're not getting enough vacuum to it from the engine, or if it doesn't move at all, you might have a clogged EGR system. I agree though that fiddling with the AFM isn't the solution here. The engine isn't running right without the O2 is my bet. You need to find out why. My suspicions lie in the EGR from the high NOx. -
You can legally cap off the intake manifold plumbing for the Heat/AC control system, which is prone to leakage. I'd bypass that whole system first and see if your vacuum readings change. And though the tech rev'ed your engine to 3,000 for a few moments before the test, that might not be enough to really heat up the CAT enough to "cheat". The real cheat is to stab the throttle over and over right before the test. This will richen the mixture and thus be blowing unburnt fuel into the exhaust, thus heating up the CAT very quickly. I wouldn't go telling smog tech's to do this though... Your numbers are really close though. There's a good chance your car is working 100% fine, just a little tired. Couple that with a CAT that's going out and it's a recipe for smog dyno failure. If the cat isn't welding in on either car, I'd swap it over. Bypass the air system vacuum system like I said, and then retest. Make sure your timing is what it should be (I think you can go 3 degrees from it, in which case to 2-3 degrees retarded), and go ahead and change your oil and such as you're planning on doing. Don't go crazy moving the AFM and such. That only changes transients for the most part. Another interesting tidbit, is that the numbers you have to pass aren't totals for the time of the test, but rather an instantaneous rating (for one second I believe). So if the 15mph test goes really long it's likely you're failing. What will normally happen is that at the beginning of the test the numbers will be high, and then drop as the EGR and CAT start to do their work under a constant load. Then as the numbers drop the machine sees what's happening and passes you onto the next test. Quick smog tests are a good sign. Its usually those first few seconds that will fail you, and when you're over the smog machine keeps going for a full test to see what the engine is going to do, to see if they can reach higher peak numbers. -
I'd double check the starter is the right part. Compare it to the previous starter and see if the teeth are the same dimensions. But also check to make sure you've got good battery connection. If you're not getting solid contact on the battery terminals you might be getting the same symptoms. I know I have.
Changed my tires with cheap tools
Gollum replied to Gollum's topic in Brakes, Wheels, Suspension and Chassis
Honestly I'm quite concerned that the balance won't be sufficient. But getting tires balanced locally still saves me quite a bit of dough, and the static balance should get me safely around for the time being. Regarding local prices, I know those seem high but that's really what they've gotten to be in the bay area. I need to check some local shops and see what it looks like. I had a pretty good local hookup for a while at a wheel works and they'd do a full tire job for me at around $120 total iirc. That would include dismount, mount, recycle, new stems, balance, etc. And that was a good 50% or more discount. I recently had my wife's Accord in to replace all 4 tires at the local costco and that still came out to at least $130 total cost over the tire prices alone. I was quite happy with that, as that's the best I'd found for her car yet! I will be doing some more tires in a few weeks once the weather clears up again. I'm going to take some quality pics and revisit this thread and rewrite it. Maybe I'll get rewarded my first sticky. -
So yesterday I got the pleasure of changing my first tire! I'd done lots of reading and watching youtube videos and was honestly quite scared of how much work it would be. I was expecting a minimum of an hour per tire from what I'd seen, if I was lucky. But I knew that this guy I know now would help me out. He's one of those very typical old guys that knows all those stupid little tricks that make life easier. The type I highly respect, which this forum seems to be full of. He offered me to let him use his tools, and I just asked he'd tell me what to do to help me along. Luckily, it was WAY EASIER than I'd ever thought, and even for my first time went very smoothly. I had to pull tires off other rims to put on the rims I wanted the tires on, so we had two tire removals and one tire install for each wheel, and it only took about 30 minutes per wheel at most and then they were ready for balancing. So here's the tools used (for the most part) Basic tire changer platform http://www.northerntool.com/shop/tools/product_18863_18863 Bead Breaker (the one on the cheap tire changer above was crap according to the guy helping me) http://www.harborfreight.com/bead-breaker-92961.html (the one we used was a vintage american made variant. Similar design, not sure how the actually perform from one another. Bubble Balancer http://www.harborfreight.com/portable-wheel-balancer-39741.html (the one we use looked like it was about 100 years older than this, but same exact principle) Basic Tire Iron http://www.harborfreight.com/24-inch-general-purpose-tire-iron-93230.html We also had some other basic tools, like a wrench for pulling off wheel weights that also clamps them back down and acts as a hammer for weights. Another nifty tool was used for pulling the core out of the valve stem. It's about the size and shape of an audio coupler, but metal and has a little fork on the inside of one side that grabs the core. So here's the steps we followed, that hopefully helps someone out there. Step 1. Remove air. Just removing the core from the valve stem is way easier than bleeding the tire, though the guy helping me said the tool used is getting harder and harder to come by and used to be a dime a dozen growing up. It's just a little tool that grabs the core. A slim needle nose plier would do the trick I'd imagine. Just twist the core and it'll come right out, just be careful of those threads when putting it back in. Doesn't need to be wrenched down like crazy, just enough not to leak. Step 2. Break the bead. Put the tire onto the bead breaker tool above, one the ground. This will be the first time you use some tire lube, which is extremely important in making this an easy job. Just use some water with dish soap (generous proportion). Putting it into a spray bottle of sorts makes it easy to apply. So put some lube all around the bead and then stand on the rim so it doesn't move on you. Put the bead breaker's arm onto the tire and put your weight on the upper arm. The trick to make this easy is to keep putting lube on as you push the bead down with the breaker. Having someone else apply the lube will make it much easier. At my 170 pounds I had to bounce pretty hard on the upper arm to get the bead off quickly. One you've gotten the bead off in the first section, push down the rest of the tire bead into the drop section of the rim (where it goes inward to give you space). You can now flip the rim and do the same thing on the opposite side. Remember, you can't over-lube. A wet tire is much easier to work with. If it's a hot day I'd recommend finding shade as the lube will evaporate quickly. Step 3. Remove the tire. This is one of the most complex parts, but it doesn't need to take long at all. Take your rim with loose tire and mount it onto the tire changer. You'll have to unscrew the top of the tire changer, and then put the wheel on, and put the top back on which clamps the rim down. If you're worried about scratching your pretty wheels put something down to protect the rim. Good piece of rubber would be nice, but you can use anything, like wood shims. Now that the wheel is clamped nice and tight (right??? go check) you can use your tool you used to tighten the clamp to get under the bead and pry it over the lip. If you're worried about your rim, they make plastic protectors to go over the lip, but I didn't bother and didn't seem to hurt my rims. Now that you've got the bead over the lip at a point, you have to work your way around the wheel. Using the center post as a leverage point you can rotate your bar around, but the bead will just move with you, and you won't make any progress. So what you have to do is put that basic tire iron above side the gap you've made and then work in the opposite direction. This can be a bit difficult with two hands, but it doesn't have to be hard. Lots of lube. Once you see the bead sit onto of the lip between the iron and your main pry tool, you're set. The bead will now apply enough pressure on the rim lip that you don't need the basic tire iron, you can pull it out. The key in getting all the way around without struggle at this point is just lots of lube, and MAKING SURE that the tire bead bellow the lip is still in the drop center of the rim. If the bead isn't in the drop center then there won't be the slack to get the bead over the lip. So just keep watch on everything and add lube and this whole process should only take 5 minutes at most. Once you get the bead completely over you can start working on the other bead going over the same lip. Get the other side started can be a little tricky because the tire is in your way slightly, but it's all the same methods and doesn't need to be too difficult. Just take your time and don't force anything. Once you get it started it does take some serious force, and I was banging the pry bar tool against the center post pretty hard, but I made VERY short work of it with that kind of energetic effort. Step 3.5. Clean Rim Apparently many slow leaks are cause by poor bead seal from dirt and grim between the rim and bead. You should take this moment to clean the bead area of the rim with a wire brush. This doesn't take much work or time and is probably just good practice. My rims look like they hadn't been cleaned in several tire changes. Step 4. Install tire. This is probably the most difficult part, but I think with practice it doesn't have to be extremely hard. First make sure you're putting the tire on the right direction you want. Most tires now days have directional tread so make sure you know which way is which, and which side of the car you want the rim in question to go on. Once you've figured that out you can put the tire over the rim and start getting the first bead over partially. You'll be using the other end of the pry bar here which you'll notice isn't symmetrical. One side has a hook, and one side has a buldge on it, that's thinner on one side than the other. You can only work this tool one direction around the center post, thin edge leading. So to use this side, you have to get the bead in the valley of the outside end, and force the inside of the end over the outer lip of the rim. To do this I had to keep the opposite end of the bead relatively close to the rim lip, not way down in the drop center. Once you get the tool in place to start working the bead over, you might find it easy to make progress to now put the bead over the lip into the drop center to give you some slack. Don't forget to keep adding lube! Once you're most of the way around you can just lift the bar you're using to roll the bead over the edge and tada! It'll pop over. The second side is pretty much the same story. Just getting the tool into place will be the hard part. After that just make sure to add lube and keep the bead in the drop center and it should work it's way over with some elbow grease. Now that you have a tire back on the rim, you need to add air. But you need your bead onto it's home on the rim before it'll seal and hold air. This is where it's handy that you've removed the core from the valve stem. Fire up your compressor and just leave the quick release by itself on the end of your air hose. The quick release will grab the valve stem just fine. This allows a very free flow of air from compressor to tire to set the bead nice a fast. Just make sure to release the air as soon as you hear both beads seat. No reason to over inflate the tire and blow it up in your face. Pulling the air hose off the valve stem will be leaking though, so put your finger over it and grab your core to put back in and then thread it back in. It doesn't matter if you loose a ton of air, because the beads are set now. You can can attach a tire filler with gauge onto your air hose and fill the tire up to desired pressure. Step 5. Balance The bubble balancer works, but the guy helping me went on and on about how you just can't beat the newer fancy digital balancers shops use now days, and that they're idiot proof. But learning to use a bubble balancer is an art worth learning as it doesn't take much, just time and patience. All you have to do really is set the wheel onto the balancer and make sure it's set down nice and square onto the balancer. Try to do this in an alcove if there's any wind, as the wind will make it very hard to get a stead reading on the bubble. The principle is no different than using a carpenter's level. Note where the bubble is going, then set some weight on the lip towards the bubble and watch where the bubble goes. Was it enough? Too much? Did it not go in a straight line towards the center? Try move it side to side to find the true high spot. If you're adding more than .5 of an ounce you can put half on one side of the rim, and the other half on the other side give more equal balance. You could also run into a situation like I did. The tires I had where fairly decent quality tires, and one only needed .25 of an ounce, and the other was as good as it was going to get without any weight added at all. We'll see how it is once I drive it though. And that's it. It might be a lot of reading, but it isn't nearly as much work as it can be made out to be. Just have to take your time and really understand what's happening and you'll figure out how to make it easy on yourself. Once you've made it easy you can then work on doing it quickly. I only did two tires, and have 6 more to do. One of the times I make it out there I'm going to drag a camera with me and take some pics and maybe do a little better of a write up. I know I haven't used all the correct terminology here, but hopefully I've gotten the points across. So hopefully this helps someone out there. I know that before I was one the fence on buying all this stuff to do it myself, but I'm not POSITIVE I never want to pay to have a tire mounted again. Shops are charging as much as $65 here locally PER TIRE to mount and balance the new tire, and recycle the other tire. Even the cheaper places still end up charging almost $200 total in installation fees for a full set of a 4. I now know what I need to buy, and that all those tools will be paid off in just a few new tire sets.
Love the DIY air system! I must have at least 3 of those injector coolers lying around...
Instead of starting a new thread I'm going to bring this one back, since this is the topic it's regarding. So I still have this wonderful N42 sitting here, and every day that goes by I realize I just don't want to get rid of my S130. And to make it so much worse, my smog buddy whom I grew up with had gone into a different avenue of mechanical work, but is now doing smog again. And now he's training my brother to get his license as well! So I won't be in short supply in help getting my cars to pass. This winter then I'll be building up a motor with my parts on hand with the N42 and turbo block. Should get me compression over 8:1 and enough grunt to get me around. The tough decision still is this damn fuel injector issue. I either have to grind the head to fit the stock EFI manifold, or I have to convert to a carb'ed setup, or go with a custom manifold. None of these options sound all that appealing to me honestly. I'd love to make a custom manifold, but I don't want the added EFI costs on top of that. The carb options looks really good, but they're not exactly cheap either unless I just want to hunt for some junkyard SUs and rebuild them. Taking a grinder to the head just seems like such a waste as the head was freshened up by guys that know a heck lot more than me about these engines. The other option would be to find some flat top pistons and rebuild this turbo block and put my spare P90 on it. The head could use some love though, and I could have it shaved while getting it cleaned up and looked over. I'm not looking for a 250+hp hot street motor, just something to get me around (even 150 at the wheels would be more than enough). Might spring for a nice header and exhaust down the road. Keeping it simple should keep costs down, but the benefit of keeping the stock EFI setup would be saving the money spent on the rebuild, pistson, and machine shop work I'd be having done if I shop around enough. On the same token though, I really don't like the stock EFI and have only had problems with it concerning my S30. So maybe going carb'ed might be the better option for me, if I can score a good deal. As always, any input is appreciated. I've got all summer to figure this out. In the mean time maybe I'll try my hand at fiberglass this summer and shed some weight off this baby.
Yea... That'll work. Keep the posts coming!
Oh, and on the octane note, I'm still running the OE ECU in my L28ET and I run 87 KAMIFORNIA gas. Probably more like other states 85 octane if they sold it. I get away with it only because I'm still running stock boost levels, and I rarely run the engine hard long enough to get the engine heat soaking. If I did then detonation would be a problem on such crappy gas. Going with SU's might be better if you're going for max power, because they can flow more air up top, but the EFI offers nice driveability and more worry-free driving. For the power levels you're looking at, I'd start with the stock EFI since you have it, and see how you like it.
The front half isn't bad, and the rear half isn't bad... but all together it just looks fugly to me. I can see that it's "well styled" and that people might like it. But it just doesn't do it for me. I'd rather have a more hardcore ferrari, or if I wanted something practical I'd get a STI Wagon.... Everything is always a compromise, but I fail to see where this car's compromise has an audience. Redo the happy face, cut out the rear two seats but keep the wheel base the same, make it MORE like the roofline of a austin, jag, daytona coupe or what have you and I think it'd have a market.
No, it's because we think your user is a troll of John C or grumpyvette or something.
Just when you thought you saw brazen Smog Scams...
Gollum replied to Tony D's topic in Non Tech Board
The good news is that the system for finding the offending shops is getting more and more automated. Not only has this helped some of the shops be a little less suspicious but it also means that the blatant offenders get caught easier. BTW, on the topic of smogs, anyone here the news about the possibility of the dyno's not being used in OBD-2 cars soon? Might make me interested in some newer cars finally... -
It all depends on the differences between the FWD platform and the RWD platform. If they use nearly or identical blocks then it'd be an easy swap. The challenge is that many times companies change some things here and there to make the motor better suited to their drivetrain application. Those are details that few here will probably know about, and you'd be needing to talk to some people with experience with those engines.
Dang it!!! Nevermind... it uses a 90 degree split pin spacing, not 180 degrees. Why would they do that for a V4?
WHOA WHOA WHOA!!!! If they actually keep the transmission as a separate piece of equipment like it looks like in the pics I'm ordering two!!! Flat plane crank V8 anyone? The main thing that's stopped me from pursuing designing a flat plane crank out of a bike V4 or ever V-Twin is that all of the interesting motors have intergrated transmissions, and would thus be a bit complicated to mate together and to a transmission. The lower rev range of this would be perfect for widely available transmissions.
I think this has all been well covered, but as much as I think the MN47 combined with flat tops has some killer potential it sounds like it might not be for you. EFI is certainly wonderful, and programmable EFI is a must for anyone wanting to do some hot-rodding, like you're wanting to do. My advice would be to either bite the bullet and go for megasquirt with a hotter cam, or instead sell the head and get a P79/P90 and take the money you'd spend on megasquirt getting the head worked over a little and maybe get some decent carbs for the sucker. And in both those scenarios dyno tuning should be on the to-do list. In short, only use the factory ECU if you're shooting for factory horsepower, in which case you should go with a factory compression combo.
Super High Output 4G63 (link to thread, not mine!)
Gollum replied to Canadianz's topic in Other Engines
Hmm... I don't proclaim to be an evo expert, but there's several 1000+ wheel hp evos out there, and I wonder if they're using the stock iron block, or a custom aluminum block like that. Seems strange that so many people would go through all the trouble.... -
Well the weather was decent today. Cold, but dry at least. So I finally got out there and changed the fuel rail, took about 45 minutes or so taking my time. And surprise surprise, the engine is running a ton better. It coughed a little bit as the injectors were getting used to being used again, but after a short engine warm up it was revving better than it has yet. So I took it for a drive and WOW. Pulls strong all the way to redline again. Yay! When I pulled the vacuum line off the FPR before it didn't spit fuel, but the engine was running. This time the engine had been off a good couple of hours and the FPR spit fuel. Strange eh? Existing problems still: Engine is backfiring under in gear decel, and I still can't get the motor to easily rev up heel-toeing between shifts. This might be TPS wiring, but I also noticed that off the line the engine wanted to die again, probably due to the AFM having been tweeked to make the car drivable. So I've put the AFM back a bit so it's still a little loose, but closer to where it should be I think. We'll see how that drives tomorrow. Overall that seems to have been the BIG problem that was making other issues completely masked. Now I should be able to troubleshoot the other issues better.
That's really what I'm not getting about your argument hoov, the VG requires almost NO WORK to get to 300hp. It's about equal in what's required at that level as a L28ET, and those dominate these forums as the luck buck king to the 300hp mark. Doing something "right" is always subjective to the person and their goals. And my counter point to your argument is based off of what people ACTUALLY spend, not on what we can dream to spend. Even people here on these forums spend quite a pretty penny building SR motors. Just because there's lots of availability for parts doesn't make them cheap motors. It just means you have options. The core items of making power on any stock motor are always going to plague ANY motor. Such as: Wideband Injectors Propper ECU tuning capability Time to tune it all the best it can be All of us here know that just throwing parts together doesn't make power. There have been guys that have gotten very impressive results just by taking their time and doing something meticulously and maybe thinking outside the box. Like the guy who made over 300hp on stock turbo ZX injectors by running multiple fuel pumps with over 100psi fuel pressure. Building a cheap motor isn't something always inherent to a motor per say, but rather a mindset of the builder. And I personally believe (which people are allowed to disagree with) that the VG is a good route to go for someone who's practicing the art of budget HP building. The SR isn't a bad choice either, but the low buy in for the VG makes it specially appealing as plenty of people have made over 400hp on stock longblocks. What really cracks me up is that you made comments about onesickZ's car and he himself corrected you about what he said and you still haven't acknowledged that correction. That's the truth man, people like him HAVE build HIGH hp VG's for VERY cheap. He CHOSE to have it rebuilt at tuned by someone else AFTER he'd already proven the motor capable, not the other way around.
Why did you decide to stay with the Datsun L6 motor?
Gollum replied to logan1's topic in Nissan L6 Forum
True'r than true. Many people get really caught up in the whole weight balance thing and forget that an integra type R's only handicap at a track isn't it's handling, but it's limited ability to put power down being a FF platform (which still isn't bad with the right setup). That car is over 60% front biased if I recall correctly and handles great. So do well prepped CRX's which again, have almost no weight in the back. Porsches have insane rear weight bias and can still be made to handle like a dream, and do well enough from the factory from most accounts. Point being, setup is far more important than weather or not your engine is 350 or 450 pounds, or three inches farther back. And that's where the SR can really shine. It's a fairly easy and affordable swap that doesn't have many downsides. People often say - cheap, fast, reliable, you can only pick two. But what most people don't think about is that those are ALL relative terms. Cheap... compared to what? On what budget? Fast... Compared to a stock Civic or a Zonda? Reliable... Compared to a stock 30 year old Z, or a 90's Honda? So all three of those factors are "meters" in a sense. The SR does well in all categories. It's not the budget of the budget, but for how much power it can make, while being light and compact, and being reliable enough it's doesn't break the bank. The are other options out there, but it's a good one to consider if you're wanting a swap that makes the car easy chassis-tune to handle well. That said, the L6 motor is a road well paved and the setups have already been done time and time again. -
I'm planning on going megasquirt soon enough, probably next winter. And a LM1 is part of my budget for it. But I can't really justify it right now where I'm at with the car. I got it running a bit better today, to where it only hiccups every now and then if I'm cruising bellow 2k. I measured the CHTS at the ECU and it's showing about 10% high, which should be slightly rich, but it's still close to FSM specs. I'm about 95% sure it's not a PCV related issue, and I'm about as sure that I don't have a vacuum leak. The PCV wasn't even hooked up when I got the car 2 years ago, but now I've got the valve cover going to pre-AFM (so if anything it'd be causing it to go rich) but the lower block opening isn't hooked up to anything, and the PCV valve has been removed and has been replaced with a plug. Nearly everything on the intake has been plugged. The only think left on it is the FPR and boost gauge. And just for good practice I checked it today and couldn't find any leaks. All that being said, I think I've concluded that my compounding issues have come down to poor electical signals and me futzing around with the AFM too much. I think my grounds are in poor shape, and that's lead me to having the AFM way out of adjustment. I'm going to work on some grounding solutions tomorrow and then see how it runs and adjust the AFM for how it runs at that point. If the car runs alight but the AFM seems extremely loose then I'll have to keep looking into it, but I have a feeling that after it ran so well today it's going to come down to making sure all my electrical connections are 100% perfect. It wasn't pulling 100% clean WOT from low RPM, but it's certainly workable from here. In conclusion I think something that's mucked this thing up from the beginning was that the car didn't run well at it's first start with the new head for many reasons, and I'd been adjusting the AFM trying to figure out if it was lean or rich in certain conditions, and I've adjusted it so much now I'd almost forgotten where it should be in good working order. More to follow soon enough.
Finally did some more troubleshooting today. Checked the CHTS and it's maybe a little low in resistance at low temp, but at operating temp it's right in the middle of the graph in the FSM. So it seems this part should do the job well enough. I cleaned the AFM traces with alcohol and when I was running it again I was noticing it couldn't be the AFM because when I move the AFM open it very consistently richens up and runs smoother, not erratically as though the traces are bad/cutting out. BUT!!! I noticed that if I pull the vacuum line from the FPR that NOTHING CHANGES.... Idle doesn't change at all, full throttle doesn't change (though it shouldn't) and light throttle doesn't change a bit... Bad FPR? I'm gonna change out the whole fuel rail for one I have sitting around with another set of turbo injectors and different FPR on it. I'll see if that changes anything. Maybe I've been tuned for a bad fuel pressure all this time I've had the car? Or could it have gone bad in the last year sitting around my garage?... Strange question to have to ask, if you ask me.
Are any of those turbo AFM's? I believe the turbo AFM's were a bit different, at least I'm certain there's minor differences, not sure how it affects the tune. Maybe we can work out a trade or something.
All good advice, and stuff I've thought of as you suspected. I think it's going to have to come down to actually testing components via FSM standards. I'll test the CHTS tonight on the stove with a cooking thermometer. I'm not sure how I'll test the AFM, but the traces might very well be the main issue here, as it's never had a cover in the length that I've owned it and my engine bay is QUITE oily. Maybe I should pull that too and check for continuity on the traces.
The AFM had been right up against the turbo since I got the car, ran fine like that but I knew it was too close. In trying to troubleshoot I've now moved it just behind the radiator core support. I checked for leaks on the intake and actually had one, but fixing it didn't change anything. Timing hasn't been checked with a light, but I know it's close just by ear, which is how I've timed all my L6 motors for the last 6 years. I'll double check the TPS wiring again. Maybe the ECU thinks the TPS is closed 24/7? That could be bad maybe. I'm pretty sure the CHTS is ok, since the one from my other car did the same thing and that car is running fine.
