Gollum
    19
Everything posted by Gollum
  1. Yea, you know it's a serious lack of effort when someone born and raised in the USA can't form a sentence better than most of the FOREIGN members we have on the boards... In all seriousness, how are there people who speak English as a 2nd, 3rd, or even 4th language, whom obviously don't have a firm grasp on our grammar, that can still be better understood than one born in this country?
  2. Aww, sorry for the disconnection of terms between pound feet and foot pounds. My mistake! But in regards to straight line thrust, your math is exactly accurate. But let me take it from this route (I must admit everything you say is the truth, just the way we think about it seems different), as per this site here (I know, quoting the internet can be doddgey at times) http://www.car-videos.net/articles/horsepower_torque.asp We see it explained that WORK is simply torque causing movement, or torque applied. Torque without speed, I agree, will do nothing cannot be felt. This is probably where the difference of our semantics comes from. But as even stated there on that site, rotational movement power cannot be calculated as horsepower, but must be calculated from torque over time. An engine is a rotational device, as well is the transmission, rear gears, and wheels. These are all torque over time forces, and that's how they're calculated, even if it's an eddy current dyno with resistance that calculates the torque over time required to move it at a certain rate. But a car goes in a straight line, and as it goes in the straight line we can calculate the horsepower required to do so, such as calculating the HP of an engine from 1/4 mile times.
  3. Heehee, we're spinning in circles here and in my eyes you're almost arguing my point. HorsePOWER is a misleading name in my opinion. But to some degree I can agree that knowing the POWER is a more concrete way of knowing the FORCE involved, but it has NOTHING to do with understanding the engine force in question. We humans are just using the term horsePOWER to bypass knowing all the facts and just knowing again "how much work will get done". But very sadly, people have taken this "how much work will get done" figure and assigned it to a FORCE, a law of physics. And the dyno meter example is not a true "mechanical" device like a torque wrench or a mechanical watch. It's an mechanical device with an electrical counterpart which requires at least a basic logic controller to do the equations. We might be able to "feel" what you call "power" but you can't actually feel work load. Going back to my wood stacker analogy, the weight, or stress, the worker will feel will be the weight of the wood in his arms and the stress this places on his body. This would be a TORQUE measurement. You hold out your arms, you put weight in your hands, it has a leverage on your arms. That's torque. The POWER, or WORK, in this equation is how much they'll move in the day. That has nothing to do with the FORCES involved, which are what are directly felt. I can agree though, that if I was going to be given only ONE figure in an equation, I'd want the workload figure. If you're given two of the three you can always calculate the third, so it doesn't matter which two you receive. And there lies why we always rely on the horsepower figure, because it's the COMBINATION of the FORCE over TIME, thus it's more meaningful to us. That' doesn't make it more meaningful to the laws of physics. And I disagree about 240hp at 60mph meaning you have 1500lbs of thrust at the wheels. By the very definition, FOOT POUNDS is directly related to TORQUE applied. Your transmission and rear gears MULTIPLE torque at the expense of SPEED. If you're in 4th gear (1:1 ratio) and you have a 4.11 rear end, being at 60mph and at a RPM that would yield 240HP at say, 4000rpm. That means the engine would have 315 FOOT POUNDS of torque. You then multiply that by 4.11 and you get 1294.65 pound feet of torque working at the rear wheel centerline on a 12" radius. If that 240hp engine had that power at, now lets say 6000rpm that means it's only applying 210 pound feet, multiplied by 4.11 would be 863.1 pound feet. Both cars would accelerate at the same rate if the given HP curves where the same. Why? Because the one that's applying less pound feet of torque is doing so at a HIGHER rate of speed. The one with more torque at the wheels wouldn't be faster because it's gaining it's torque through the sacrifice of speed. Thus the equations of work done would come out to be the same. Both cars would tie at the finish line.
  4. I probable am just arguing semantics, so hopefully we can keep this lighthearted as we have thus far. But I do realize that the calculation from HP to watt is simple, but I was talking about the calculation to such from amps and volts in a circuit, hence why I mention cheaper meters don't measure watts. Measuring an amp or volt is easy, but most sub $20 meters won't have that slightly more complicated calculation to measure both at once and form the conversion. I think my point still stands, which is that HP isn't truly a power we see or feel, but simply a number we use to define something. You can very easily create a mechanical device to measure torque, as seen as how simple it is to make a torque wrench, and it's very easy to make a simple mechanical device that can keep time. But measuring horsepower or watts has always been more complicated and requires more complex calculations. You can make a torque wrench that measures it's own scale that's not accurate to foot pounds, but at least it's accurate to itself. You can make a time piece that might not follow exact seconds but will be extremely consistent in it's own right. You're not going to make a "simple" device that measures the watts used by a light bulb that has any bearing on reality, even by it's own scale, unless you can measure the force (torque/amp) and the time (rpm,volt) to some level of accuracy of relative scale from each other. To some extent I do agree that when you feel a car accelerate you feel the "power" of the engine, but what I'm getting at is that much of what we actually experience is a calculation that happens in our own heads without us even realizing. Instantaneous HP rating of an engine at a given RPM will be felt at corner exit, but I'm still not certain it's "HP" we feel, but rather TORQUE that's given momentum with time. Again, this is just based on the fact that torque is a much more real force in the world we live in.
  5. I disagree, the FORCE the dyno sees IS the torque, you just can't know what the engine's torque is unless you also measure the RPM, thanks to the torque multiplication factor of the transmission, final drive ratio, and wheels. As you've just said, power is a measurement of work done over TIME. Thus you HAVE to actually CALCULATE only AFTER you know the torque measurement involved. It's the same as measuring a WATT. Most meters don't measure watts because it has to be calculated and cheaper meters aren't going to have that slightly more complicated ability built into it. You CAN however convert HP directly into WATTS. In this calculation AMPS is like the TORQUE, the FORCE involved that can be directly measured. The VOLTS is like the RPM which tells us how many cycles we have in a time frame. From having those two basic measurements we can then calculate the watt of a force over time. That's what I'm trying to get at though. Any measurement is going to measure a FORCE, which can only be described as torque, not HP. When you drive a car you don't ever feel the horsepower, you feel the torque. When a Honda hits Vtec you don't all of the sudden feel the peak HP of the car, you feel the huge bulge of torque that shows up out of nowhere. You can kinda of "prove" this in a sense when you consider that the force of that Vtec engine after it hits Vtec is a very even and consistent pull that keeps you in your seat. Looking at the torque curve on the dyno you see that it's very flat after Vtec, varying usually less than 10%. Getting into a muscle car like a pushrod mustang, you feel the loads of torque off the line, and it seems to put you into your seat MOST before the 3k mark. Look at the dyno on most "stockish" V8's and you see that torque drop off gradually after the torque peak and be way low by redline, thus they give you a long smooth HP curve. The only thing we can do in our mind to conceive the HP of a vehicle we're in, is to factor in our head how fast we're going, and then consider the variables of the weight of the car, road conditions, etc. We do this in our head so well we don't realize it. But in the end, SPEED is a direct relation to TIME. When you drive a Subie STI and you realize how amazingly easy you just got to 150mph on a freeway on ramp, you know in your mind there's a lot of power beneath that right pedal. Your mind has just done a calculation of the force involved in a matter of time. So again, horsepower is not a force, it's a figure we use to figure out how much work will get done. This is the common misconception that people bring into the age old torque vs hp debate. Because in the end we all know that you can't move a car without torque, or HP. It's just a matter of where people prefer the HP to show up in the RPM band, low down, or up high, or evenly across.
  6. Actually that's a very good point I hadn't thought about John. And looking at the ratios they offer for the T5, they're a bit tighter than the nissan ratios anyways. And I know those things sure can take a beating.
  7. And I think that in this case Jon, you're probably right. I think the common ZX 5 speed paired with one of the common 3.545 or higher rear diffs would be fine for almost any of the high strung street L engines out there. It's not until you get into competitive racing or have one of those 400+HP monster L engines that the stock tranny options just don't really cut it. And looking at Dan's dyno you can see he probably has nearly 200 ft/lbs anywhere once he puts his foot into it. That bottom curve of the dyno is recording before WOT I think. But looking at the HP curve of that motor, at a race track you wouldn't want to be under 4500 after shifts as there's a decent difference in torque there. Using the stock later ZX 5 speed IF you take that engine to the 7200 redline you land 2nd at 4450, which is about perfect, 2nd to 3rd lands at 5k, 3rd to 4th at 5500. Overall pretty good match. But I'd like to see a clean pull to 8k and see what the curve does. I bet it levels off a bit, and though he might only gain 15-30hp a shift from 8k lands 2nd at 4900 which is a possible 40hp disparity. That's enough to make a considerable difference. Now, the later gears would be more like a 20-30hp difference, but that's more of a HP difference than he might gain peak. This is why "area under the curve" is such a touchy topic as it can be so conditional to how the car will be used. If Dan's car had an ever so slightly milder cam he might loose as much as 10 peak hp, but really smooth the torque down low. Worth it? Totally depends. And the worst part is that in the end only the owner's opinion matters, because the customer is always right. People are allowed to want whatever they want. That's why they're free to have their own opinion in the matter. But overall, I'm with Jon. Build an engine/head capable of higher RPM and go for the aggressive cam. It sounds wicked, still will have plenty of torque for a tiny Z car, and really put you in your seat up top. Just don't expect to do much passing on the freeway in 5th unless you've got super short gears, or enjoy down shifting like all the rest of us gear heads love anyways.
  8. Bah, the age old "hp vs torque" debate. I know Jon M probably knows all what I'm going to share, so nobody take this as me pitting him against the wall in a corner, just me sharing what I can while the topic's come up. HP, is impossible to DIRECTLY measure, but is in actuality directly CALCULATED. What I mean is that HP is just an EQUATION, not a force. HP is how much work can get done. RPM is how fast work load moves. Torque is the base multiple factor. Here's an analogy to put into your mind before I really get going here. Think of two huge wood stacks that need to get moved. There's two guys that are going to move their stacks. They both have identical wood stacks that need to go identical distances. One guy can move 10 pieces at a time and takes 60 seconds to move those 10 pieces from one place to the next. The second guy can only take 8 at a time, but only takes 45 seconds to move those 8. This means that the first guy can move 10 a minute, or 600 an hour. The second guy can move 10.4 a minute, or 624 an hour. In this analogy, the load that can be taken is like the torque abilities of an engine. This is what we use as the foundation of what work can be accomplished. With a measurement here of 0, no work would ever get done. It doesn't matter how fast a guy can run from one pile of wood to the next if he doesn't carry any wood with him. How fast they move that wood is like the RPM of an engine. The first guy taking 10 would move a lot more if he could just squeeze his time down a few seconds, or increase his RPM. Notice that this measurement is 100% time based. So in this analogy you can see that we can't physically see or measure how much work will get done, we have to CALCULATE it in order to figure out the outcome. This is what makes HP such an elusive object and so impossible to define with our senses. Our nerves/feelings will never be able to tell us what HP is. We can only feel force and perceive how fast something might be happening. So onto the real meat of the matter. The cold HARD fact is that if we only ever used engines at ONE RPM all the time (meaning a 100% continually variable transmission) the only thing that would matter would be PEAK HP, how much torque and RPM we can extract for one small moment of the RPM RANGE. But the reality is that no engine really gets to see these circumstances except maybe in industrial application like generators. But in cars it's just not a reality. In our actual reality we find that there is no "magic engine" that's perfect for all application. We have huge torque monster diesels for 18 wheelers, and we have little 3 cylinder metros that get 50mpg. But when it comes to racing.... It's all about AVERAGE USABLE HORSEPOWER (at least that's what I call it). Some people might also think of this as "area under the curve" which is much more vague I think. Average usable HP is the average of horsepower that you get when you cut to top of the HP curve on the dynograph like a knife scrapping the top of the mound of butter. What's the average you get when you take a given range of RPM. A motor that is very "peaky" as they can be called, is one that usually climbs HP until redline and is very linear. It's usually called "peaky" because you need to be at the top of the RPM range for the motor to be worth anything to you. As a general rule of thumb, high RPM motors tend to be more peaky simply for the sake that it's harder to get a cylinder head and valvetrain to breathe extremely well at the bottom and middle of the RPM range. There's many more factors, but this is a big one. Then we have "torquey" motors. What I find most comical about motors described as torque monsters is that many times they actually have very little torque for their displacement, and have very miserable horsepower for their size as well. But they're known as "powerful" because of how they "feel" and sometimes it can be a tough call. But now we'll get into my favorite motor comparison which I think many will find enlightening and hits the core of why this was brought up to begin with. Okay, two motors will be discussed here. The Ford pushrod 5.0, which was rated at 225hp, and the Honda F20C rated at 240HP. Going back to our wood stacker's analogy, the Honda motor here would be better, because it's getting more work done. It might have less torque, but it has RPM that makes up for it, meaning it has more peak HP. But in the real world it gets much more complicated than that. In reality those engines have to be behind transmissions, which transfer power to the ground. And a key in this to remember is that gears in transmissions are always RATIOS, so a gear change will never have a RPM difference, but a RATIO difference. This is why at redline going from one gear to the next might move your engine down 3,000 or more RPM, but yet you can make that same gear change at only 2,000 to begin with and it only drops a little bit. It's a ratio. Keep that in mind here. So make this a drag race with two identical cars and transmissions. Both cars take off. The 5.0 gets off the line better thanks to it's much higher torque threshold meaning it has a lot more HP down in the lower RPM range where the cars launched at. But this lead doesn't last forever, the 5.0 has to shift much sooner from 1st to 2nd while the honda keeps climbing, not even into it's power band yet really. Now the Honda is really coming alive as it nears redline, but then it has it shift into 2nd, and the 5.0 just walks past it since it's already back near it's peak HP, while the honda is way bellow. This story continues but the 5.0 will increase it's lead consistently as the race goes on. Now, why does the 5.0 win when it has less HP? Is it because it has more torque? No actually. Not at all. It's because it has a FLATTER HP curve that shows up at LOWER RPM. Let me explain this too, if both motors had JUST AS FLAT of HP curves, but one had double the peak RPM, meaning it's flat HP curve shows up twice as "late" into the powerband, it'd still be slower behind the same transmission. And here's a big key. That higher RPM motor will drop FARTHER down it's HP curve with every gear change, because it has more RPM to give up to the RATIO of the gear change. This mean it has more RPM to climb back up to it's HP curve again. Now, going back to our two cars with different engines. If we do this race again, but give the Honda a transmission with 6 gears that are very close to each other, and give the 5.0 a wide 4 speed, everything changes. As they come off the line they might actually be neck and neck this time, but as both cars shift around the same time, the honda will start to walk away, as it's very near it's MAX HP still, while the 5.0 dropped well bellow. So we start to see that the transmission you're going to use in the real world has JUST AS MUCH to do with everything as things like CAM selection, displacement choice, etc. You can choose to build a HIGH RPM MAX HP L series motor that might make 400hp, but if the transmission you're using drops you from 10k to 6.5k between shifts, you might very well be SLOWER than a L series with 300hp at 8k that will only drop to 6k at the same shift, because he'll have more HP at 6k than the higher RPM motor at 6.5k most likely. Why do you think the F20C in real life comes with a close ratio 6 speed? Look at the gear ratios in motorcycle engines. 6 or more gears and they're all ridiculously close. Shifting at lower RPM in those combos show almost now RPM drop, but then again those motors are barely moving at 3k. Those gear ratios would be a complete waste on a broad HP motor like the 5.0 But that's not all!!! Because let's not forget that you can take that 5.0 motor and completely build it for MAX HP and get it to 550 crank HP which takes loads of RPM and high end heads with detailed port work and such. This motor would no longer have a "flat" HP curve. The reason it had a "flat" hp curve to begin with was largely due to the fact it was making so little HP for it's displacement. This motor can easily make 200hp by 4k, so to peak it off at 225 with a redline of 6.5k gives you one fat HP curve. The new 550hp curve will probably only have 400hp at 5k. It's not like this motor will now magically make 500hp at 4k and then redline at 6.5k still. It's a completely different HP curve. What it comes down to is how much power you're extracting out of the limitations of the heads in your application. At your head's MAX flow condition, you've probably maximized the conditions for peak HP which means you're trying to get it to flow BEST in higher RPM so you have torque AND RPM on your side, but by doing this you've given up flow potential at lower RPM. This is true for ANY cylinder head. There's no magic bullet for this, except maybe removal of the valve entirely like through rotational valves that were banned from F1 not long ago. So I've said all this, just to get to the point of saying, choose wisely. Know what you want. A high strung L series might be a lot of fun, but it won't be much fun on the street without the right gears to go with it, which can be as expensive of an endeavor as the engine build itself. I believe this is why so many people just do a V8 conversion. It makes lots of torque with very little effort, and makes for a great street car with almost no work. And in the long run you're able to run a wider transmission with longer gears making the car easy to enjoy. Hope that helps some of the "torque" versus "HP" debate some people have had through the years. Personally, I like both, and prefer certain motor types for certain application.
  9. Well the stock wastegate should be getting up to 7-8 psi, so you're down an entire 2 psi somehow. Either the wastegate has been modified or it's sticking open. The manifold you have is desirable to run mostly because it looks cleaner and deletes the EGR (exhaust gas recirculation). I've seen guys make plenty of power on them, so I'd just keep it. Seems like a lot of this engine's setup might be decent, but could also have been done by someone who knew just enough to get himself in trouble. First thing I'd do (if I were you) would be to download a 81-83 280ZX FSM and read up on the stuff pertaining to the turbo engine and do your best to understand how the factory system worked. Read all the stickies you can on this site, and with the knowledge gained go over your car with a fine toothed comb (figuratively) and find out what's working and what isn't. Make sure the things that were done were done RIGHT, otherwise you'll be hunting those problems either until they've forced you to find them or until you get so pissed off you either sell the engine or the car. I've noticed that many times the "problems" a car comes with are due to improper mechanical know-how from previous owners getting in the way.
  10. Get a junkyard flat top block and use that while building a forged piston bottom end. Forged pistons are GOOD, I'm just saying many people end up with too agressive of a tune because the pistons will take it in the moment but then fail over time. Cast pistons break suddenly and overall hold heat very differently. This makes them better to tune with imo because they'll tell you when the piston is getting too hot or you're right at the detonation threshold.
  11. SDS is perfectly fine. Garrett on here has put over 400 to the wheels with SDS. Higher compression doesn't actually change the curve much at all, but it will cause the engine to detonate a bit easier, but the flat tops with a P90 will have more quench. So in the long run this will mean you can run a DIFFERENT timing curve, which means you need programmable spark control. But regarding fuel control, you want to make sure to have GOOD injectors that are decently flow matched, and you want a GOOD EFI system with precise control. Even megasquirt is fine, despite it's very "budget" appeal. Stepping up to the 300ZX is hardly much of an "upgrade" imo unless you're going to add a programmable eprom, which after all that you might as well have MS. Detonation issues generally (not always) show the MOST in HIGH LOAD situations at LOWER rpm. F1 engines could run on pump gas just fine without detonation, because they're literally outrunning it. The combustion process is happening faster at higher RPM, making detonation less likely to show up. So if you run insanely high compression ratio, you're more likely going to have to back the timing out more in the 2k-6k range. If you've got a honda B engine redlining at 10k, you most likely will be running plenty of timing still at redline with 13:1 comp than 11:1. You also want to pull timing with boost, which will help you keeping from blowing up your engine. Timing also needs to get pulled in relation to intake air temperature too. Timing is by far the most complicated part of tuning as it needs to be completely tailored to THAT engine, not just "this engine" with "this head" with "these parts". You need to tune to THAT engine and find out what IT wants with it's timing. Distributors are prone to wandering over time, they can be irregular from unit to unit, etc. They're fine if you understand them and know how to "tune" them in the ways they can be, but they're much like carbs. Older car guys prefer them for their "simplicity" but the modern alternatives can be much better in some ways and almost essential in high performance applications that you still want to be livable on the street. They might still have carbs on top fuel dragsters, but those engines would never be livable on the street. You can make a 1500hp big block chevy that IS drivable on the street, thanks to modern fuel and timing control. If you're gonna throw old parts on a car, be ready to deal with rebuilding them. If you want to go fast with old parts, be prepared to know how to engineer them.
  12. Are you sure those injectors are black? They might be brown, covered with a bit of dirt. Scratch one a bit with a flat head screw driver and then check the color with a flashlight on it. The turbo injectors are brown, which is probably what you have. The other common colors where green and white, both much smaller NA injectors. You might have a genuine turbo block that had flat tops put in. Or it could be someone took the NA block from 81-83 and put all the turbo bits on it for the same reason very many people on here do, more compression, more power, etc. Either way, unless you've got low compression during a compression test, or abnormal leakage with a leakdown test, I see a rebuild as a waste of time and money. But if you really want to, go ahead. As we say on hybridz, "there is no best". Therefor there is no "best" way for you to go about this, so take my advice as just that. Advice.
  13. If you're going to run less than 300 whp on a stock EFI and dizzy then keep the flat tops. If you're going to run more than that, then switch to dish. But if you're going run a REAL, modern EFI system and use a more controllable spark trigger then just keep the flat tops. You'll still be well under 9:1, and though there's so much talk about this very issue, it's really not that big of a deal. We also need more info though, as it's already been said. 1.What color are the injectors? 2.What block code is on the block, does it say F54? 3.Pics of the intake please, I can tell you if it's a turbo one or not. 4.Valve cover hack the big, block style lettering that says turbo? Don't be so concerned with having a "L28ET". Any number of L engine combinations can make great turbo cars. So unless you're wanting something that's 100% "accurate" for concourse show reasons then just be concerned about how well what you have will work together. And in all honesty, flat tops with a P90 is a great combo that's been well proven. Keep a nissan head gasket, or felpro if you desire to risk it (I have), and pour your money into EFI and spark control and of course a wideband with laptop to tune it with. You can spend over $500 easily on even a "basic" rebuild. You can do it all yourself, but even the machine work alone will be a couple hundred bucks. You can spend much, much more to have the bottom built by a quality shop that does it all well. But all that being said, you can take a junkyard bottom end and throw a good head on it with your intake and exhaust parts and put over 400hp through it all day long if your tune is good. So forget rebuilding it and just put money into other stuff. I personally wouldn't even worry about building a bottom end until I was 110% sure of my tune and pushing the 600hp crank mark. At those levels the smallest tuning problem will show, where forged pistons will mask it. Get your tune RIGHT, not just mask your tuning issues with a strong bottom end.
  14. Mike, best wishes for you and yours for the new year. Let it be a fresh start, not a continuation for unfortunate events.
  15. Amen! I also wonder how much detonation issues people have stemmed from fuel or cooling issues, even if they're inherent to the design of the parts people were running. We all should know about the cooling issues of the L head, which can be numbed with more pressure, or extensive drilling and rerouting as seen in the sticky. But then we have fuel issues too. Many people are running carbs which aren't exactly known for wonderful atomization. Plus you're also having to balance them, otherwise you could have lean chambers which are more detonation prone while the others might be chocking rich. I'd love to see studies of the quality we've come to expect from people like Ron and Paul (like regarding the trigger wheel testing) in regards to fuel and timing control in high compression L engines and when ping is detected and under what circumstances. There's enough conflicting stories by trusted people that it makes me think there's more going on than we realize.
  16. I was proof watching it last night before subjecting the wife to it (who loves the brit version). I'm gonna make her watch some this weekend, we'll see how it goes...
  17. I'm not sure what turbo I'll eventually be going with, but I'll be sticking with the stock T3 for a while. Wouldn't mind seeing where this thing really does run out of breathe since the reports are so wildly all over the place. I guess $130 for one done locally isn't that bad either. I would just build it myself, but I don't have access to a welder, nor do I have any experience welding, yet. I know several people that do weld, just that most of them do it for a living for companies and don't have welders at home. I'll call around some local shops and see what people say. Thanks guys.
  18. Yea, the fact it isn't stainless kinda makes it seem cheap, but then again for the price... I wonder how well it would hold up to jet hot coating or wrapping.
  19. I'm not usually one to hunt around MSA's site, but I've been working on spreadsheets for my projects to try my best to organize and prioritize the funds coming in to make sure things get done, and done in the right order. So I've been doing a lot of shopping around, and I saw that MSA is now selling downpipes, and only for a single Benjamin. Considering that I want/need a wideband, I wanted to have a downpipe made anyways, but this looks almost too good to be true, which with MSA's reputation might be the case. So has anyone tried it? Is it worth the cash, or will I just be spending another hundred bucks just to make it usable? It looks like it can't be much worse to work with than the stock downpipe. Here's a link for those that haven't seen it, or know how to navigate to what I'm talking about: http://www.thezstore.com/page/TZS/PROD/PTC15/15-6037
  20. I wouldn't put that in a Z. It'd throw off the perfect weight balance.
  21. if you stop think bout it iz amazin how many peoples do that thing here
  22. If you just build it yourself like everyone is saying, with a machine shop prepping the block and a specialist porting the head, I can see you reaching over 250whp and coming in under budget. But the key, as it's been stated, is being frugal. The crank and rods are out there, in the junkyards, waiting to be saved. The only big ticket item for the bottom end would be pistons, and you'll want them to be fairly lightweight. Something that hasn't been touched on, and the only real reason I'm posting, is that you mentioned going EFI. I'd advise against this for a budget build. The stock EFI intakes don't breathe well top of the RPM range, and a custom manifold or itb's combined with the price of injectors, ECU, ect just makes for a whole elephant of a problem to overcome with the budget. That can easily be a $1,000 decision. Just stick with carbs, even though there's plenty of reasons to hate them. They work, they're simple, easy to find, and affordable.
  23. Fuuny so many have mentioned the UK show disliking american stuff. I find it kind of the opposite. If you read between the lines, they find it very easy to make fun of us, so they do, but the really do like a lot of our cars. Sure they have their gripes, but they do about every vehicle on the show. I bet the Italians think that top gear hates their cars too!
  24. Bought my 75' from a kid that thought it "needed too much work to get running", and I drove it to work for the next 6 months straight. Had a nasty exhaust leak that turned out to be a head gasket. Pulled the head and swapped on a new one, just to find I did a real bang up job with the timing cover and now I've got a water leak. So it's still down, waiting for $10 worth of gaskets and a full spare day of my time.
  25. i think the reason there isn't a full write up is because it's actually just that easy. The only tough part could be the wiring, and there IS a thread dedicated to JUST that. Step 1: Remove old engine/trans. Step 2: Install new engine/trans. Step 3: Wire up engine harness. Step 4: Convert ignition control as shown in other thread Step 5: Wire power for fuel pump with cutoff relay Step 6: Fire her up! Step 7: Have exhaust made at local muffler shop (I'd recommend getting a custom downpipe made too, simply because the stock downpipe is a pita to work around and sits too close to the TC rod) Done. It uses the same engine mounts, bolts to the same transmissions, it IS the same engine! I'd hardly call it an "engine swap". More of just a "turbo conversion". But that's not a bad thing! Good luck with the swap. Just take it nice and slow and you'll be fine. Don't get discouraged at the first thing you can't figure out. Simply looking at all the pictures around here you'll find the answers to most of your questions.
