Gollum
    19
Everything posted by Gollum
  1. Well, if you both show up to the August 30th meet... I just really hope by some magical event that this car is on the road by then. (just seems like there's still going to be so much left to do in such little time)
  2. Gollum
    GM 6.2L Diesel
    Sure, it can get 35mpg with tons of power, but how does it drive off boost? There's a reason it gets 35mpg. Power takes fuel. That mpg figure tells me it's as guttless as any other commuter box until you put your foot deep into it. Nothing necessarly wrong with that though, if that's what you're going for.
  3. You must be racing in a class that doesn't allow aftermarket air dams, those bumpers are HEAVY!!!!
  4. Lurk the archives, it's been done... if we're talking 300 crank HP then that's EASY. 300 rear wheel hp has been done on the stock turbo and fuel as well. Not very often though. At 10PSI though... not unless the head has been modded, but scout already cleared that up. 300 crank hp will only be about 255 wheel hp, which will need about 13psi on the stock turbo or so to make depending on air temp, elevation, etc. Stock fuel injectors will be fine at that point. Maybe raise the fuel pressure a couple PSI. 300 wheel hp will need about 15psi, which has been done on the stock turbo. At that point the fuel pressure will need to be about 60-70psi or higher. I can't say how reliable it would be though... One interesting setup I saw a long time ago, was a guy running his fuel at 100 psi!!!!! He was using several stock nissan fuel pumps to supply the extra fuel. (two pumps in series or parallel will supply twice the fuel, or be under half the stress at the same flow) My point is that there's been some insane things done in the past, and I've learned to believe nearly anything is possible with some creative engineering.
  5. And as the thread author I'd like to thank you wiki D. You live up to that name. You obviously know what you're talking about and contributed honest experience to the thread. And you kept it pretty unbiased in the political sense, and for that I thank you. It was a worthy contribution. Don't fear it that those words will fall on deaf ears.
  6. This is a rough sketch based off the Ford Modular engines. I have bore spacing and journal specs, but I honestly had no clue how wide to make them. So I guess on some of the figures, but the overlap from the journals should be extremely close to what it would be in the real world with a 3" stroke. Here's a better image without the rods
  7. Well when Chris recieved the samples for the RB they weren't what was expected. The style the group buy was going after to begin with was the RB-R, and the distinction wasn't made apparently. So with that change request, along with some other design change requests the factory went to work making NEW molds for us, in the RB-R style. Those prototypes should be in.... this week? Hopefully I didn't screw up any of those details for chris. This group buy has been his baby, and he doesn't need me speading misinformation...
  8. It was kinda hard to tell how far away they were from the A-pillar. It looked like they floated there a bit, which to me seems like a compromise. Idealy it should extend FROM the A pillar I'd imagine, not just float above. Nismo: He wants to see your rack!....
  9. Hey, I might be young, but I've "heard" a lot in my life! (sorry for my poor interweb grammar/spelling) The only I4 I can think of that shares a valve train with a V8 is that GM engine that uses SBC parts, and is basically a SBC cut in half. Oh and also Question for OTM, who seems like the person to ask right now. Does the rod bearing being closer to the main bearing cause more load on the main bearing leading to more severe wear? It seems like the rod will be pushing very directly on the crankshaft and be putting a lot more force on those bearings. If so, much larger main bearings might be REQUIRED, and might rule out many block options as custom bearing sizes would be required. I could be wrong, please say so. Today I'm going to try to find the highest reving street driven Ford Mod motor. They seem like a hopeful option. Their prices have really been falling since the 3 valve debut. They might very well be the next "5.0" engine out there. Given enough time they'll be everywhere, and they're an extremely solid foundation to build on. And the DOHC heads are easy to come by, if we're talking the lincoln and SUV variety.
  10. What I meant is that the notches look like they were put there befor the drilling. But now that I'm looking at it again, they do seem to taper too one side. So they probably are just drilling through the counter weights. Though I gues it might be possible to come at multiple angles for added reduction. One thing that really worries me about the DOHC V8 setups, is that most of them have a fairly small bore size. So unless we're only looking for the 250-300hp range, the engine build would have to be pretty extreme to make good power levels. With a SBF or SBC setup, a 4" piston is standard, and with a 2.5" bore we're still WELL over 4 liters, and 400hp should be easy to come by with the right head/cam/intake combo... as long as you figure out how to get it to rev up to the required RPM without falling apart. To be honest, I've never heard of any pushrod engines OTHER than nascar getting to those 8k rpm levels. How many people produce parts over the counter that would allow performance like that?
  11. Yea, mine can read anywhere from 13 to WAY above 16 on the stock guage. Been running just fine for 6 months + now. It's a guage issue, not a voltage regulator issue. At least for me it is. You should still check the battery with a multimeter when it's running though. Just to make sure.
  12. Sorry for the double post. Didn't see this post at first due to it being on a different page. I choose the SBF for many reasons, chiefly among them because I'm a ford guy. Hey, at least I can admit it. I'm sure others will prefer the SBC for various reasons, all very valid. But my reasons are just as valid and if they don't see that then they're purists. Everyone should be able to respect another's engine choice. Oh, and the RPM limits of the SBF and SBC are a moot point. Everything I've seen suggest the block has nothing to do with the limits. Stroke, crank, rods, pistons, rings, and valve train are all major players.
  13. But what DOHC options are there that are affordable and fit in our Z cars? These are the only ones I can think of off the top of my head: 1UZFE (fitment is iffy. doable, but poorly documented) VH45DE (doable, probably best option) VK56DE (we all love the VK, but how many swaps have been done. and $$$?) Ford DOHC 4.6 (not TOO expensive, but huge and hard to find in the junkyards) News Flash I was going to mention this in my last post but forgot about it. Coates Internaional Ltd. - Makers of the patented spherical valve technology are finally going to be making an effort in racing. They're going for a landspeed record. They havn't announced what class yet, but it will most likely be Section 5. As they outlined that section in their press release. This is big news. If Coates finally starts to break through in the performance market, and we see someone team up with them, like edelbrock, we could see heads to make a SBC or SBF rev to 15k (if the crank will do it) and make more power than ever. But at what price??? Only time will tell. But for the high RPM crowd this IS interesting news. Edit: To Olderthanme ~ Check this out. I think the notches in the couterweights are to gain clearence to be able to remove more weigh from the rod bearings, yes??? Will it really be that hard to remove weight from your crank design? Another added benefit I was just thinking about, is that though your crank weight might not be too much lighter, won't the shorter stroke mean the weight is closer to center, thus it should still "feel" lighter due to the lower rotational inertia. Do I have that right?
  14. Well, I'm not sure I'd really call just any FFR daytona couple replica a "race car", but that's certainly the emotion they're trying to evoke. I've seen several in person, there's nothing back there to be sure. Had I read this a few months ago, I could have asked brock why he designed it that way. I'm sure he would have gladly answered. But the key point I'm going to make here, is that when he had the chance to redesign the car for superperformance and give the car his update and stamp of aproval, he retained those scoops on the side. New daytona coupe from superperformance: So they obviously mean somthing. If they were for looks they'd probably be done in metal, and painted the color of the car. The fact they're clear plastic on most of these cars suggest to me that they're function over form. They're not nearly as pretty as the scoops on the GT500.... Though those scoops don't have a function. I'm kinda interested in seeing a S30 with taller metal pieces added to the drip rails. The image in my mind is pretty dorky.
  15. Gollum
    GM 6.2L Diesel
    "Too much torque to be usable" Sorry Pete85, though I might agree with what you're trying to convey, I don't agree with the general statement. Too much torque is never a BAD thing. It's POWER BAND that matters. Diesel engines generally have a very narrow POWER BAND due to the fact that they usually have such a low redline they need more gears. Torque is almost meanless unless you put it into a HP calculation with RPM. If you have two engines, one with 200 torque, one with 400, the one with 400 can simply use less gearing. Remember that in 1st gear most cars are increasing torque by cutting RPM to about a power of 12+. A 81-83 280ZX in 1st gear is putting nearly 1500 pounds of torque to the wheels. ====calculation proof===== 145 torque X .85 for drivetrain loss = 123.35 123.35 X 3.062 for first gear = 377.3915 377.3915 X 3.9 for rear diff ratio = 1471.82685 And you can imagine that with only 200+ torque from a turbo engine that those numbers sky rocket. What I'm getting at is that torque doesn't really matter unless you're trying to move a lot of weigh. What makes diesel's great for towing is the fact they make so much torque to work with that if you just keep adding gears for various speeds they can carry a load up nearly any hill. Gasoline engines don't generate torque at those low RPM and need to keep their speed up to be in their operating RPM. Most engines now days are turning around 2k rpm at 65mph, that's far too high for towing. When you're towing you want there to be massive power at the lower RPM so you can keep chugging along up the hills. You'll notive that 18 wheelers don't get near redline when going up a hill. There's no power up there for them. Diesel engines just don't have the RPM band when they're designed for towing. Now... diesels are all the rage in europe, and I wish we had more of them. But if I were going to put a diesel in a Z I'd want it to be one that's designed with a 4k+ rpm power band in mind. That's not to say I don't think abram should be interested in this swap. I think he's entitled to do what ever he wants. But I'd recommend to him that if he does do this swap, to find a transmission with lots of gears. Either that or find a very narrow geared transmission and use a tall rear end. That IS a heavy motor though. That's weight realm of the jag V12.
  16. R160? I hope it doesn't break man. What's your curb weight goal? Might want to keep away from wider tires.
  17. No... Ummm, that crank design was made in about an hour wasted at work (I'm such an evil man I know) using inventor. I was semi-copying the Hartley V8 3.0 liter crank. The dimensions are based off of the stock pieces in inventor (con rod, crank, etc). I wanted to use the stock rods, so I just built it to those specs. I figured once I get the specs I'm looking for on the ford small blocks (5.0 in particular as they're everywhere) then I'll spent some time at home working on replicating the block and designing a flat plane crank. I wouldn't really be doing this to actually put it into production, but simply for the entertainment and education factor it presents. It's something interesting enough to keep me working with software I don't completely understand and helps me grow in many ways. Your design is in many ways far superior to mine. I must say I still wonder if a 100% counterweighted crankshaft would be necessary, though I understand why it's much safer. Though if we're taking an american V8 and shortening the stroke down to 2-2.5 inches then it can be a pretty light crankshaft ANYWAYS. Reving to 15k shouldn't be limited by the crank...
  18. Nutty Buddy. And I'm starving. That was rude. Ultima GTR w/700 hp SBC or Mclaren F1
  19. Maybe this will help stirr up some ON TOPIC thread discussion... ...just because I can:
  20. Discovery Cup of noodles or ramen?
  21. Danica American Le Mans Series or Grand Am Rolex?
  22. I've never seen a single post of 1 Fast Z talking about taking the liners out, but seen plenty of threads in which he's preached about how his heads with liners flow just as well than without. But most of the work of his I've seen has been on NA motors, not turbo. It would be interesting to hear his input on the risks regarding heat and such. I'm betting he'd say to just leave them in. As long as they don't start falling apart they should be fine. I don't think at street boost levels that will be a problem.
  23. HAHA. We'll have to wait and see, but I'll have to guess RB-R Moped or go kart?
  24. Ok, so to tie this discussion back to Z cars. I'm thinking that for myself I'm going to start hunting for a MN47. Putting that on my turbo bottom end will give me around 9:1 compression. I think that should be fine for the sub 10psi realm on our current gas (E10)... IF there's really close to 10% ethanol. The pumps say "Up to 10% ethanol by volume", but that means it could theoretically be 5% too right? Then once E85 is more widely availible I can just swap out the block for one with flat top pistons. That should leave me with about a 11:1 compression. Not as high as I might want for E85, but certainly much better than the budget options of using a P90 head. (custom dish pistons or major shaving requiring much more work) Now I just need to find a MN47 for under $100...
