Cable
Everything posted by Cable
  1. If these will work just as well on a R230 as they do in the R200 pictured, count me in for a set too!!
  2. Digging up an old post..... Did you have to cut/notch the subframe to clear the diff? Also, did you space the diff forward at all? Lastly, did you have to modify the lower control arms to clear the CV's? Thank you for your time.
  3. For those interested, here is a R230 on ebay: http://cgi.ebay.com/ebaymotors/JDM-Nissan-Fairlady-Z-Z32-300ZX-Twin-Turbo-R230-VLSD_W0QQitemZ110084289727QQihZ001QQcategoryZ33731QQrdZ1QQcmdZViewItem
  4. What are Q45 R200 diffs going for these days?
  5. Hey guys, well my torque converter died and I am replacing it this weekend. The new piece is a low end ATI unit. While its not ideal for drag racing, it will serve me well until I figuire out if I am going to go through all the trouble (and cost) of upgrading to an overdrive trans like a built 2004-R or 4L80.
  6. If I end up buy a Autopower bolt-in cage I will end up welding up the cage to the floor after installing bolting it in anyway, just for good measure. So far the cheapest I can find the Autopower bolt in cage is $550 w/o shipping. Anyone know of a place cheaper? Thanks!!
  7. That's awesome!! Thank you for the pics and it looks like the bar held up pretty good considering the damage to the car.
  8. I have considered serveral times of going the solid live axle route instead of messing around with a R230 w/CV's. I love the draglites!! If I were ever to go the solid axle route, I would keep the axle wide and run a 15x12 rims with TONS of backspacing so the wheel face would be in the same location as a IRS setup. That way unless someone looked way low and from the rear, no one would notice of the huge amount of meat tucked under the car. Sleeper..... Then again, my 4" cowl on my car doesn't exactly say sleeper either......
  9. Digging up an old post, but do you have any pics of your Autopower cage? I am interested in one for my little Z, but wanted to see one installed first. Thanks!!
  10. Digging up an old post, but does anyone have pics of the Autopower 6 point bolt-in cage in their Z car? Thanks!!
  11. Geez, I can't believe I missed this topic!! I have lots of pics on my Car Domain link in my sig. If you or anyone else wants help, please ask!! Thanks!!
  12. Hey guys, I finally updated my Car Domain page with new pics and details. Just click the link in my sig!! Thanks guys!!!
  13. Thank you for your kind words. You can put a BBC in a '62-'67 Chevy II, it just requires fenderwell headers or a complete sub-frame swap. I would think that your shipmate would be more accepting of a Chevy motor into an import instead of an import motor into a Chevy. Thanks again. You'll get your ride Gary, no worries. I just gotta get a few things worked out first..... Agreed, especially about the tuning part. I bet I am leaving at least 50 hp on the table rioght now because of the little tuning I've done. I still need to upgrade my fuel system, including a larger carb. I also want to play around with a few timing curves, although I am seriously thinking of running locked-out timing in the 32*-36* range. It will be one less thing to worry about. Then I'll need to invest in a decent converter. The one I am running now is a no-name 10" and my rough math is telling me that the converter is slipping about 12-15% on top end. It doesn't owe me anything, I picked it up for free and it would be fine if I had 350 ft or torque instead of 500+. A good converter from a good company like ATI or Coan will only slip 5-7% on a bad day with hot ATF.
  14. Well guys, you might have to wait for those pics. I think the front pump or my converter in my TH350 just died..... I am sure it will be weeks before I'll get around to yanking the motor/trans and have a tranny shop replace the pump, then finding time to put everything back together. Oh the joy!!
  15. Chevelle/Camaro/Vette had 5 on 4.75" bolt patterns. Changing the rears to a 5 on 4.75" is pretty easy, the front is another story. Modern Motorsports sells the setup for the rear to be a 5 on 4.5" pattern (Ford/Mopar) and using a front Z32 hub is also 5 on 4.5". Hope this helps.
  16. It only does it in gear, moving or sitting in place. It is definately a squeal, almost like a belt slipping. I have been debating on going to an overdrive anyway, I might go that route soon anyway. After reading a recent topic that you posted in, it looks like the 4L80 would be my best course. I don't want to run a computer and I've heard there is a way to set it up that I will just have to manually shift it, is this correct? Besides shorting my driveshaft, what else is required for the swap? Thanks for you help!!
  17. I am seriously considering the 4L80 too, what years/models did they come in? Thanks!!
  18. Hey guys, I am having alittle problem with my TH350 in my little 454 powered Datsun. About a week ago I starting hearing a slight squeal around 2000 RPM while cruising and in all gears. I thought it was just the alt belt slipping. I replaced the belt and then removed the belt and the noise is still there. Then on Saturday I did a 3/4 thottle pass for about 10 seconds. Afterward I can really hear the squeal and it is loud. I popped the tranny into neutral and the noise is gone instantally. It only does it in gear (including reverse) and stops the instant it is in park or neutral. Its really loud between 1000-2000 RPM and gets alittle quieter as RPM increases. Yesterday I chocked the wheels and engaged the e-brake and put the car in gear and then tried listening for the source. The noise is not coming from the motor. It shifts fine and there are no other issues when driving. I checked all flexplate bolts and the fluid is clean. I had the tranny looked at 500 miles ago, and everything was great. The converter is a used piece I bought from another member. Its a 10" unit and seemed to work fine. I talked with a few guys I know and they think its one of three things..... 1. Converter 2. Front Pump 3. Sprag I am curious to know what you guys think. Any help is thanked in advanced.
