7
Everything posted by EvilC
Phantom a clean 2 door 510 from your neck of the woods would be great
Leon thanks! Rob very clean setup there! Question - does you intake box become oily with the valve cover breathing into it? I have to some up with a system for mine, along with the block vent because I am getting oil in the engine bay! At higher revs I can see it misting out the two vents even with the small filters on them.
Nice read, I remember having this discussion a few yrs back with someone I know. One thing to keep in mind too is why the vented rotors work "better" in real world driving if used at the track, they have better capabilities to dissipate the heat. I had a small laugh to myself with the earlier mention of big brake kits being sold for newer cars because it is true. Factory bias is normally not changed and how often do you see aftermarket prop values thrown into newer factor cars that have plug N play kits. To make sense out of non-sense let us take Arizona Z car brake options into play. Keep tire compound and pad compound the same here is how it plays out. The 12.2 inch rotor/4 piston setup technically would have nearly the same clamping force of the 13 inch rotor/ 6 piston setup based on the piston sizes from the part numbers that were supplied years ago and sorry for a half a$$ effort to find the exact numbers. So if clamping force is nearly the same, the only advantage is the rotor size. In theory and depending on the bias desired, the 4 piston calipers should be used on a 13 inch rotor. Only the mounting bracket needs to be changed. Stopping distance vs pedal effot vs pedal travel – can be confusing when trying to dial in brake setups.
Able to snap more pics of the car? Interested also here in NY. If not, I can pm for a few parts needed. lmk
Jack the front of the car up and get all the air out of the system.
Need Help With LS1 Swap in NJ
EvilC replied to davidsecrest's topic in Gen III & IV Chevy V8Z Tech Board
If you are going to have a shop around here do it, expect $10k in labor for sure. Part sourcing and detail of swap is another thing to keep in mind when doing this swap. -
Been holding out on you guys :-)
EvilC replied to Z-Gad's topic in Gen III & IV Chevy V8Z Tech Board
Very nice!!!!!! Hope to see it soon. Enjoy! -
HBZ - Before I place an order wanted to see if anyone had TTT front setup for sale - front control arms and tc rods? Let me know what you have and price you are looking to get. Thanks.
Valve to Piston clearance issue?
EvilC replied to EvilC's topic in Gen III & IV Chevy V8Z Tech Board
Thanks Nexgen - I have the 1.8s up for sale, they will not work for me. -
I would like to see 260z emblem that looks like the series 1 240z for the quarter emblem. What you have so far looks great.
Handy Wilwood Brake Plumbing Product
EvilC replied to z240's topic in Brakes, Wheels, Suspension and Chassis
Nice, I will be giving this a try within the next 2-3 weeks -
The 1.8s came with the used heads I bought - I am going to sell them and get 1.7s. -
Buying a CA car - has anyone gotten someone to act as a "broker?"
EvilC replied to rturbo 930's topic in Non Tech Board
Are you only looking at 240z cars? That car you posted a pic of looks like a NY car that has seen lots of snow. I know of a 280z that is for sale in your price range and maybe a 260z. -
http://www.ls1gto.com/forums/showthread.php?t=446872 fyi There are broken items all over the net so don't be afraid to try something that works. Hell I remember reading the FAST intakes weren't that good and the factory LS6 intake was better When do we get vids of the track runs?
Very nice numbers! All that power needed in a sub 3000lb car?
zfan1 - nope I didn't know thanks for the input. So I should check the contact patch and should have 0.060 to 0.080? I think I see why this measurement will help me answer my question but also weather the contact area is towards the intake or exhaust side will tell me if the pushrod length is correct? The video I watched talked about shimming and milling the pedestals so I am trying to follow their theory. Checking the preload would also help determine is the pushrod is the incorrect length? Just watch this video -
I figured I would post here before I went posting on LS1TECH and keep this thread updated once I come up with an answer. So my "new" setup: 5.3 Patriot heads stage 2 - bought used no specs 1.8 Terra Yella rockers stock GM 2002 LS1 head gasket Cam Specs: 228/232 111 .632/.600 So tonight I put clay on the first piston and bolted down one head onto the block and turned the engine over by hand to see how close I was getting to the piston. The clay was squashed but not broken through. It did look very close though so then I put red grease on the intake and exhaust valves and tried it again with no clay in place. There was no grease left behind by either valve on the piston. The 1.8 rockers are really my concern and I am thinking I would be safe with 1.7s. I am thinking with so much lift from the cam, once the rods stretch and higher rpms come into play, I may have an issue. Tomorrow I plan to search around on the LS1 site to find the specs on a stock 5.3 head so I can know for sure if these heads have been shaved or not. Knowing that, HG thickness, cam specs and rocker specs - I should be able to mathematically see where I am and if I have any buffer room.
LSx mounts can be bought for $600, Mike already has the efi system ready to go - the real cost is a pull out which can really range from $2k-$10k crashed car vs brand new crate. The engine and trans takes a weekend to install and get running. Rags and I have set our personal best record time swapping one in last yr - started on a Friday night pulling a dead L28ET/Z32 trans out and had the LS1/t56 installed and fired up open header by Sunday night. Time vs Money vs Happiness I agree with you guys saying that the 383 could be ran with no issues and so on but we are talking about this engine itself and all the time lost working/fixing it and money spent towing the car around which should be time spent racing. Either way I am sure Mike will get it figured out, just don't sell the car!
Btw, show me 2 Hybridz guys who have had their LSx swapped cars break on them. My opinion is my opinion and doesn't count for a damn thing but personally 5 LS1 swapped S30 cars I have been around since 2007 and none have had issues and we are talking about cars that do see track time. If the machine shop made a mistake and it won't cost you anything to fix then of course fix it..........if it will cost you money out of your pocket again, I would really have to think about it.
You have just proven my point. It has nothing to do with LSx vs 383, it is about time and money. Why keep throwing money and time at an engine that has not worked for how man years now? Not throwing shots at Mike here but why not buy something turn key from factory that will be just as good as the "built" 383. You are talking about numbers, and I am saying dollar for dollar the two just don't compare in the long haul. Say it with me......turn key! =)
I will just state again what has been stated before ditch the 383 and buy ANY LS series. The money spent will be forgotten in about one 3 day DE. The feelng of missing so many track days just isn't worth it and honestly the money lost has to pay for a LS by now. We need longer vids! Take a few days and think about it, unless there is any issue that the machine shop will be picking up the cost and labor I wouldn't sink anymore into this setup. Sometimes trying to get ever ounce of HP and track setup makes us miss the main goal - driving.
Joe beat me to it, I would do the test right now then in their parking lot! Mike is this the same shop who did the short block the first time?
