ZT-R
    4
Everything posted by ZT-R
  1. keep it up.. i need motivation too.. i will be doing my progress soon.. maybe tomorrow or tonight i will start posting in a different thread. looking good...
  2. is this a sard tank? i can build it no problem, but i cant seem to find a lid like that. i dont have any milling equipment or i would attempt to make my own lid
  3. mack, i think this was a one time run, i plan on using a steel freeze plug and tigging a steel an bung on it... i would assume you can do the same
  4. did you cut your stock diff front mount and use the bushing caps like that or what?
  5. sorry to bring up the dead, but would it hurt to run 10 an feed and a 10 an return? i hear some stories of surge tanks splitting due to rising pressure. ie not big enough return. is there any downside to using a big return line?
  6. i have one of those prc ones with the oil cooler... should i put a drain on the oil cooler too?
  7. they can also add an led to the RPM if you want a check engine light or whatever
  8. im gonna find a steel freeze plug and tig a fitting to it. if it works i can make some, but im not at that point yet. anyone know the size of that plug off hand?
  9. if they are not available, would there be any downside to me just tigging a bung in this location? anyone see any reason not to do that?
  10. ready to buy both pm me please
  11. need the windage trays that bolt on to the bottom of the engine block. Rb26 please pm me thanks
  12. does anyone have the OEM windage trays from a rb26? trying to find parts to get this motor back together. Please PM me also i have one of pats pans i will be selling if anyone is interested, please pm me.
  13. ok, but just to be clear, i can ditch that hard line that runs from the front of the car (charcoal, number 9 in this pic) http://www.classiczcars.com/forums/attachment.php?attachmentid=9503&d=1128801645 so i will endup with something like this, but with the pictured line running from the tank back to the charcoal canister blocked off. http://www.classiczcars.com/forums/attachment.php?attachmentid=9504&d=1128801645
  14. i am removing my fuel lines on my 240z (feed, return, and the other small one that goes from the drivers side to the rear under the fuel cap). do i need to keep this small one to the fuel cap?. i see you removed it but what if you have a full tank in the summer. i know my plane weeps like a mo on hot days.... but i dont know what this hose is for either...
  15. ahh great thanks just wanted to see the inside of that thing before i plasma cut it
  16. 1972 240z with R33 rb26 and R34 rwd box, mckinney kit. trying to get the speed sensor to clear the passenger trans mounting tab. i saw some pictures where someone notched it but for the life of me i cant find it again. i plan on using an electric speedo. so if there is another way lets hear it. thanks
  17. do ya want me to send you my 280z pillar?
  18. i have everything now except the cv's, how much for those? pm me if ya would
  19. can someone update a link.. 32x12x3 31x12x3 30.5x12x3
  20. well pretty much all the lines on this thing are crushed to all hell. i was hopeing someone that has upgraged their turbos had the stock water and oil lines. i know this isnt the classified section but if you could let it hang out here for a few that would be great. thanks lee
  21. where can i find a clear cam cover? i am being told they are discontinued... also, how much room do you have between your ATI crank pulley and your fan? i need to know if i can fit a shroud or not. my radiator isnt hear yet. also if your center valve cover emblem is available ill take one
