Spark plug reading
skirkland1980
I pulled the BPR7ES plugs in my L28 turbo today and I noticed 2 plugs appeared rich. I'm not really sure what's going on. These plugs have about 1000 miles on them and probably 20 eighth mile passes. I gapped them to.....030" or about .035"...I don't quite remember (6 months ago). The car runs great, no misfires, especially under boost (15 psi). I'm just not quite sure why only 2 plugs look like this, #2 & #6 Which I've noticed problems before with deformed head gaskets on those cylinders. Any ideas? Thanks.
The plugs with the white insulators clear back are actually running hot enough to stay self-cleaning...the ones that are all carboned up except for the very tip are not getting hot enough to stay clean...but they're getting hot enough to not foul out. If your AFR's are good, then I'd say let'em run. You're not hurting anything with plugs like that, and the white tips with the light tan markings show that the mixture is pretty close to right. The carbon further back in on the ceramic is from the plug running a little too cool. (or perhaps those two are the only correct ones...and the other four are running a little too hot? You'd have to ask a spark plug manufacturer or someone who really knows plugs.)
Try one step hotter plug. There is a lot of deposit on the threads that would indicate a slightly cold plug. There should only be black on the first 2-3 threads. And it looks like your timing is a little too advanced. The color change on the ground strap should be right at the bend. Yours is almost to the base (threads).
Edited by 30 ounce
You've got some good advice in this thread. If it were me, I'd be thrilled to see plugs that close together!
You might be seeing differences as small as intake manifold flow inconsistencies. Generally if I run a plug for over 1k miles and I've got any amount of whitish porcelain I'm pretty happy with the way it's running.
7 is colder than the factory recommended 6.  As I understand heat range, you want to be hot enough to keep things clean (no carbon fouling), but cool enough to avoid damage.  You've got a pretty good coating on your electrodes.  Might be better of with the factory 6.
I just had my plugs out last night and noticed that #1 porcelain is very white and clean compared to the rest, 3 and 4 seem a little brown and the rest look "normal".  This has been common for the only two engines I've had, both with the same N42 intake manifold, one an N42/N42 head/block before and N42/N47 now.  Seems like cylinder 1 might be getting extra air, making it a little lean or it runs hot.  It's hard to tell which, or how to confirm.  The flow imbalance idea seems reasonable, I've often wondered why my idle seems rougher than it should be.
In my experience the threads getting fouled up is typically caused by not sealing, try putting a torque wrench on them to check to see if they are tight enough.
I find it hard to read plugs after too many miles as there is too much cruising, cold starts, and short trips to tell me what I need to know for mixture.  Throw an engine with oil consumption and all they will tell you is your engine is worn out.
The way I read plugs is to start with clean plugs, run it at full temp and WOT and shut it down ASAP.  Pull the plugs and read.
What are your compression numbers?
When replacing the head gasket did you notice any oil in #2&6 intake?  Could be as simple as inlet valve seals letting go.
Me too. Driving around and then reading plugs is worthless. You have to do a WOT run. I used to bring a ratchet with me and pull the plugs by the side of the road. Then I got an O2. If you really want to know what is happening in each cylinder, EGT will do that.
I still think there is nothing to worry about.
