280zex Posted March 26, 2013 Share Posted March 26, 2013 So my brand new heater core went bad, lasted a month. I ordered it from auto zone, but it will have to go back to manufacture (china?) to get fixed/replaced.. Atleast its not dumping coolant all over the new carpet, just a very small spray during high loads on the engine. The realy odd thing is that the coolant somehow started showing up on the passenger side of the windshield, on the inside of the car!! Last month it was a leaky radiator cap (new also)..... I realy should be checking parts over realy well before installing them. Just because its "new" don't mean jack. 5 years ago I got 6 badly remanufactured master cylinders from 3 different local parts stores, come to find out they all source parts from 1 warehouse!! Quote Link to comment Share on other sites More sharing options...
Domzs Posted March 27, 2013 Share Posted March 27, 2013 Amen to that . New doesn't mean good , I've been in the car bus. long enough to know . Imagine replacing an elctrical part that you know is bad and still have the same problem with the new part , it'll make you scratch head and doubt yourself ( did i misdiag. the problem ? ) . Quote Link to comment Share on other sites More sharing options...
Miles Posted March 27, 2013 Share Posted March 27, 2013 It does happen. I had a run of three bad 240SX rear calipers. Two from Napa leaked out of the box. One Cardone remanufactured unit had a frozen piston. Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted March 27, 2013 Share Posted March 27, 2013 Just a little word of advice, make sure you don't have any problems with the head gasket. I've seen many times where cooling system components keep failing (when new) and its all due to excessive cooling system pressure from a blown head gaskets. Just something to think about. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted March 27, 2013 Share Posted March 27, 2013 Miles, I had the same exact problem. I needed brakes on all 4 corners of my 240sx and my driver front calipers kept leaking. I had to do 3 returns before I got a good one. I brought it to my mechanic after the 2nd one because I thought I did something wrong, so he replaced it and it leaked and he had to do it again. Quote Link to comment Share on other sites More sharing options...
ISPKI Posted March 27, 2013 Share Posted March 27, 2013 I had a string of issues with remanufactured CV axles on my civic. Replaced both front axles twice before I got a good set, and of course one of them got punctured by a tree branch weeks later. At least they have lengthy warranties. One of them didnt even have the right splines on it! Quote Link to comment Share on other sites More sharing options...
Miles Posted March 27, 2013 Share Posted March 27, 2013 Miles, I had the same exact problem. I needed brakes on all 4 corners of my 240sx and my driver front calipers kept leaking. I had to do 3 returns before I got a good one. I brought it to my mechanic after the 2nd one because I thought I did something wrong, so he replaced it and it leaked and he had to do it again. I am on my fourth rear 240SX caliper and the piston is already sticking after five months of use. I did some research on the Nissan and 240SX club sites and those guys do report a lot of problems with 240SX rear caliper pistons sticking/leaking. At this point I am considering replacing the 240SX calipers with something else. It is too bad because the 240SX rear calipers do work ok with stock front calipers. Quote Link to comment Share on other sites More sharing options...
Gollum Posted March 28, 2013 Share Posted March 28, 2013 My favorite was when I got a clutch master cylinder that was OBVIOUSLY assembled incorrectly... You gotta wonder how some of this stuff passes QC.... Quote Link to comment Share on other sites More sharing options...
putmattaway Posted March 28, 2013 Share Posted March 28, 2013 I was given a cv half shaft with the wrong size splines for my 94 sentra. Drove just fine for about 100 miles, then stripped out. Luckily the diff didn't get ruined. Quote Link to comment Share on other sites More sharing options...
280zex Posted March 29, 2013 Author Share Posted March 29, 2013 I was given a cv half shaft with the wrong size splines for my 94 sentra. Drove just fine for about 100 miles, then stripped out. Luckily the diff didn't get ruined. damn, now I don't feel so bad about the leaky heater core!! Quote Link to comment Share on other sites More sharing options...
78Z/250GTO Posted March 31, 2013 Share Posted March 31, 2013 Ipressure tested my new core before install..it leaked.. sent it back and tested the 2nd one ok to prevent this problem. sorry to hear of the mess JIm Quote Link to comment Share on other sites More sharing options...
