TLDR at the end of the post.
Having done some torsional rigidity testing in the past, was curious where exactly the S30 comes in as far as torsional rigidity. Am also doing some things to attempt to improve the rigidity so want a way to test what is really happening. Also wanted to confirm a theory, that any strut brace that has any sort of kink or bend in it is not doing anything except bling and adding weight.
1.5" x .120" wall square steel tube jigs.
The rear is solidly anchored to the concrete, bolted to the mustache bar and diff mount brackets, two studs and four bolts, and this tube frame bolted to the concrete with two 1/2" anchor studs. Rear totally immobilized and confirmed by dial gauge.
The front has the same square tube configured to simulate the front suspension, bolted to the upper strut mounts and the lower arm inner pivots. Designed to introduce the loads into the chassis as close as possible to the existing suspension. This square tube jig is bolted to a 14' long 2"x4"x.120" beam which pivots at chassis center with a dial gauge to measure deflection.
Now add weight to the end of the beam and measure with the dial gauge. Here is where I departed from the norm. Usually the end of the beam is loaded with weights. Sand buckets, barbells, dead batteries etc. But this is problematic for precise measurements and tedious and labor intensive lifting weight on and off. So I positioned a single chassis scale at the end of the beam, bolted a 4x4 beam vertically coming down from the rafters and positioned a hyd bottle jack on top of the scale pushing up against the 4x4. Everything precisely placed and measured for repeatable accuracy.
At this point the chassis (1975) is bare, stripped, and sandblasted. All rust fixed to stock configuration. The first test is bone stock to establish a baseline. All tests are carefully set up and repeated three times to ensure accuracy.
The dial gauge is positioned 12" from the pivot point. So a 12" (torsion) radius circle works out to a linear .2095" per degree (rounded to .210"). The load point (beam to front jig) is 24" from the pivot, and the pivot to beam force point (scale) is 128" so a 5.33 ratio on the weight.
On the first test going to 1/2 degree since I was concerned about permanently distorting the chassis.
.5 deg (.105") deflection @ 200 lbs. x 5.33, -----  .5 deg @ 1066 lbs.
2nd test in the stock configuration going to the full 1 degree, the chassis took a small amount of permanent set, only .010" and it easily tweaked back to zero.
1.0 deg (.210") deflection @ 368 lbs. x 5.33, ---- 1.0 deg @ 1962 lbs.
So the S30 comes in a little on the soft side in stock configuration. Compare to a Dodge Viper a 6,000 lbs per 1.0 deg, a '65 GT40 Ford at 12,000 lbs. per 1.0 deg. A typical F-1 or Indy car at 25,000 lbs. per 1.0 deg.
Then the chassis was fully seam welded. $50 of shield gas and a $40 reel of Mig wire. Four days labor. This is per some threads here on HybridZ advocating welding the seams to improve rigidity. This is also a general thought when any unibody car is concerned.
Torsional rigidity test after full seam welding.
1.0 deg (.210") deflection @ 337 lbs. x 5.33, ---- 1.0 deg @ 1796 lbs.
A LOSS of 8 percent rigidity.
Thankfully this is a test mule car (The 2nd car is still sitting in the yard) as there is no going back on welding the seams.
So the "weld the seams for rigidity" on a '75 Z info is TOTAL MYTH.
Analyzing what happened, if you look closely at all the spot welds and try to surmise/ analyze them from an engineering standpoint they are at least adequate. There's no place on the chassis where they seem to be too far apart. Had a feeling from the start that seam welding wouldn't do all that much. But why did the chassis lose strength? Again just a theory but spot welds introduce very low heat and presumably Japanese steel is either hardened or a harder alloy than plain mild steel. Mig welding however, especially when you are trying to burn through galvanizing and seam sealer is much hotter. The HAZ reduced (annealed?) the strength of the steel, hence the lower numbers.
Further testing will be with an eight point roll cage with different diagonal configurations and with strut top braces.
Believe that torsional and beaming rigidity is just like aerodynamics. The chassis has to be treated on an overall basis. Just adding things here and there without looking at the overall picture is not going to necessarily gain much.
One add on that is very popular is the strut brace. Most of these are not doing anything. The forces are so high and the movement distance you are trying to hold rigid is so small that any brace with any kind of kink, bend, or section change is not going to do anything. This will be tested to give proven results.
TLDR version
1975 280z Torsional Rigidity Test
Stock bare chassis-----  1962 lbs. per 1 degree
Stock bare chassis, fully seam welded-----  1796 lbs. per 1 degree
Don't bother welding your chassis seams on a '75 Z, it's a lot of trouble and expense and it only makes rigidity worse.
Further testing will be with an 8 point roll cage and strut tower braces.
Edited by Chris Duncan
  • Like 1
Share this post
Link to post
Great stuff.  However, we need pictures.
I'd be willing to bet that most of the flex is happening ahead of the firewall.  It would be great if you could get intermediate measurements at the front of the rocker panels.
Keep up the good work.
Share this post
Link to post
Looks like a lot of work to generate what are essentially just two data points.  Then a big leap to draw a very broad conclusion.  An R&D firm would go out of business quickly using this methodology.
What's the error in your measuring instruments, for example?  0.5 degrees is difficult to measure.  You could have a loose bolt here - "The rear is solidly anchored to the concrete, bolted to the mustache bar and diff mount brackets, two studs and four bolts" - giving some deflection.
It's an interesting area that could use more data shared (the racers are still keeping their secrets) but reproducibility is important.  No way to tell if your work is valid.
Edit - didn't mean to sound so negative.  I've done some R&D work though and it's easy to get misled on why the numbers change.  If you can reproduce the work using the same tools, you'll at least get a better idea of the quality of your measurements.  For example, put the car back on your measuring frame and see if you get the same numbers.  Take it off and put it on a few times and see what you get.
Edited by NewZed
Share this post
Link to post
Approximately 2000 lbs for a 1 degree chassis deflection at the wheel hub compares reasonably with what I've experienced in suspension tuning on the 280z. Once you get to spring rates above 300 lb. in. On the front of a stock 280z you don't see improvements in lap times by increasing that spring rate. The chassis is now flexing and absorbing spring rate.
Share this post
Link to post
This is great-and a ton of work just to help the team. Thanks a million!
I think it is important to note that the 240z (at least mine) and the 280z are two totally different animals structurally. I got a chance to look at Z-Enthusiast's 280z after he removed the interior. Lots more spot welds per square inch, lots more overlapping panels and lots more metal overall in a 280z. I recently had to have my tunnel scabbed in places due to tearing (fatiguing) of the metal around the big, very spaced factory seam welds in the tunnel. If I look over the car, lots of these welds are broken. And there seem to be NO spot welds in these areas. I simply can't imagine that additional welding would not be beneficial on my chassis-there just isn't much holding it all together. .
Share this post
Link to post
I hear you.
But I think torsional rigidity is maybe the one key factor when it comes to chassis suitability. There is no standardized test for say beaming. And weakness in beaming would show up in torsion.
In the past on the torsion tests I've done I have experienced several problems with repeatability. With this new rig took the time to address all those problems. Specifically the rear jig being rigid. The accuracy of all distances. The tightness of all fasteners. The accuracy of the weight and it's placement distance. Rear rigidity was confirmed with the dial gauge, less than .002" of movement.
The dial gauge has .001" increments. Half a degree at this radius is .105".  200 lbs before welding pushed it to .105". After welding 200 lbs goes to .123" a difference of .018" All tests were repeated 3 times or more and all went to + or - .001" compared accuracy. I can try unbolting everything and re-bolting.
I can agree though without going back to the before welded condition (which isn't possible) that there could be some overlooked variable. In addition the sample size being only one is not that great.
I don't think this steel is hardened by treatment, but I'm sure it's a harder alloy than say 1018. The HAZ will cause migration of alloying elements. The HAZ of this type of MIG weld (3/4" long stitches) compared to a spot weld is probably 4 or 5 times larger. Not necessarily hotter just way larger because of the time duration of the weld. And it could be hotter also if heat soak is considered.
All that said can agree though, take it for what it's worth. But for all the trouble and expense of seam welding it seems like it should have gone in the positive direction. Anything negative or neutral for me says it's not worth it.
Share this post
Link to post
Pics when I have time and maybe Solidworks models of the jigs. This project did not take all that long. Not counting design time probably 8 hours tops to build the jigs, and the weighting method makes testing much easier and more accurate. The only expensive part of the equation is the chassis scale, and with a longer beam you could test with lower weight and a good bathroom scale might be adequate.
I haven't looked closely at a 240Z recently so can't discuss the differences although I am aware there are some. There are even notable differences between the '75 and the '77.
Share this post
Link to post
Damn, awesome job! Thank you for doing this and sharing the info!
If I may hypothesize: strut tower braces won't do crap no matter how they're shaped UNLESS they're triangulated to the firewall.
Thanks again for your efforts! :2thumbs:
Share this post
Link to post
Thanks for taking the comments in a positive way.  Considering RebekahZ's comments, you could probably qualify your statement about S30 seam-welding to the 280Z body only.  Maybe the 240Z benefits from it, but Nissan improved things in the 280Z to where messing with them lowers stiffness as you've shown..
Share this post
Link to post
I had STB's triangulated to the firewall and I connected to the firewall in an unsupported area on one side (early cars only had a support in the cowl on one side, I never opened up the cowl, just assumed the supports were there on both sides). The STB made a FRIGGIN HUGE difference, to the point when I tested it I literally drove two wheels off of the INSIDE of "the corner" on my test road. I don't know what effect having one side attached to the firewall where it matters and the other crappily attached would have, but I can say the difference did not take dial indicators to measure. It was very very obvious.
Share this post
Link to post
Seam welding is more for being able to fix crash damage.  If the car is old and many of the seams are split you may see an improvement but I wouldn't expect it to help and now there's hard data showing that.
My only complaint with your fixture is loads should be put in via the strut towers with the suspension.  Take a look at this post for what I'm talking about.  http://www.locostusa.com/forums/viewtopic.php?f=36&t=3241&start=75
Thanks for the work.  I will do the same on my shell when it's done (240Z with full cage).
Cary
Share this post
Link to post
Nice project.  Thanks for sharing the results.  Like the others, I'd love to see some pics.
I agree with 74 5.0, it would be interesting to see how much of the flex is in the cab and how much is in the front clip.
jt
Share this post
Link to post
Did that in the front but not in the rear using a jig but not the suspension itself. Wanted to eliminate the bushings from the test. The jig bolts to the strut tower top and the inner pivot of the lower front arm (front crossmember in place). Most of the load it going to the strut tower top.
Share this post
Link to post
This is a really interesting thread and I hope it keeps on.  It's pretty early to draw any firm conclusions though.  The initial determination that seam-welding is ineffective could really be about the method and quality of welding more than just welding itself.  No offense, but maybe, as you kind of inferred, you just used the wrong technology.
I hope you'll do some strut bar testing before the roll-cage.  Work up from cheap (things that most of us can do and afford, the really interesting stuff) to expensive (things most of just read about).
On the test jig- if the rear is only attached at the top of the tower and front transverse link attachment point, then the pivot point will be at the top of the strut tower (edit - "pivot" is not the best word since that's a key word for the test.  Flex might be better.  Might show up as a sideways deflection where the measurement point is.  Learning.).  The rear link attachment point won't be in play and the whole back section of the car could be bending at the strut tower.  There's no triangulation, right?
I hope I actually understand what you're doing.  Like any other anonymous forum member, I may not have a clue what I'm talking about.
Edited by NewZed
Share this post
Link to post
Chris:
Have given a great amount of thought about torsional stiffness to my 240Z.  After mounting a good Roll Cage to the rear of the vehicle, use that portion to transfer torsional stiffness to the front of the vehicle.  Weld in a thick wall round tube laterally above the floor hump between the main hoop uprights.  Then add another thick wall round tube between the seats from the lateral hump tube forward to a thick plate on the rear of the firewall that extends upward.  Then add another such thick plate on the forward side of the firewall in the same position as the one on the rear of the firewall.  Then weld a thick wall short round tube to the top of the plate on the forward side of the firewall.  Then fab some substantial rectangular tube angling down to the integral frame rails.  Weld these rectangular tubes to the short tube and to the frame rails.  This would transfer some of the rear torsional stiffness to the front end.  Also fab and add rectangular tube to the bottom of the frame rail from about the firewall forward to where the front suspension is located to increase the vertical depth of the frame rail in that area.
Share this post
Link to post
I did something kind of like this. I don't think you want a bar across the floor on the main hoop and then go forward from there. You would be putting the loads from the front struts into the middle of this bar across the main hoop, and the bar is most flexible in the middle of the span. What I did was a V to the diagonal in the main hoop, a bar from there straight down the middle of the car, and then a V from the front struts that hits the dash bar in the same spot. Dr. Sideways did the same thing but better. Rather than have a single bar straight down the center, he has an X between the dash bar, the diagonal, the A pillar bar, and the main hoop. The problem with his solution is that it completely eliminates the possibility of having passengers, and I love giving rides.
In the book Chassis Engineering by Herb Adams he does some scale model testing with balsa wood frames and something close to what I have is used and found to be effective.
This relates to what others have been saying both in that the strut tower loads are tied together front to rear, and also the notion that the front clip is the weak part of the chassis. On my 70, when I put jackstands under the TC rod buckets and let the jack down, you could SEE the front end of the car droop about 1/2". You have to figure that the same thing is happening when you step on the brakes; essentially the car is trying to fold at the firewall.
With regards to the STBs, I don't think their main objective is to increase torsional rigidity per se, it's to tie the strut towers together. When the outside tire takes a lateral load it tries to pull the strut tower outward. When both tires hit a bump simultaneously they try to push together. Tying both strut towers together even without an attachment to the firewall should help both of these situations. I have doubts about the benefits of tying to the firewall unless the firewall is reinforced.
Edited by JMortensen
Share this post
Link to post
It is possible I'm using the wrong welding technique. I did 3/4" stitch welds but left no gaps between them. Welding 3/4" beads then leaving a 3/4" gap, then another 3/4" bead, then a 3/4" gap. Then when a full section with gaps was done and cooled off going back and welding the 3/4" gaps so the weld ended up continuous on each section/area. Thinking back the original plan was small stitches spaced with bigger gaps between. Then the plan changed to the full weld to effectively "seal" the seams as it would be a PITA to reseal the chassis after burning all the existing sealer out. But more is not always better.
I think it's problematic adding tubing for chassis rigidity. If it's done it has to be well thought out and the best way would be complete from front strut towers to rear strut towers.
Something like this... http://s160.photobucket.com/user/psanders240/library/BSR-260Z-IMSA?sort=3&page=1
This car is probably getting up in the 6000 lbs/deg range.
There may be some benefit to a single tube across as a STB, and a triangulated one to the firewall is even better. (Where the bottom of the cowl structure perpendiculars into the firewall is pretty strong.) The key is STRAIGHT tubing. Bends or kinks defeat the whole purpose. It's too much force and too small of a movement you are trying to hold rigid. This is difficult with a Z because the valve cover sticks up too high. There have to be rigid "raisers" on top of the strut towers so the tubing can go straight across.
Out to the garage now to unbolt and rebolt to check repeatability and also to get some readings at each end of the rockers as requested. The cage isn't going in until the seat gets here next week, then there will be another test.
Share this post
Link to post
Oh!  You you welded all the seams with a (essentially) continuous bead.  That's not the normal practice when stich welding a chassis.  Normlayy the gaps are left between the short welds.  I don't know how that would affect your results but it does mean that the entire seam has gone back to the original yield strength of base steel if there was any hardness added via alloying or after the initial rolling.
Share this post
Link to post
Jon:
Thanks VERY MUCH for your comments.  It's really nice to have a discussion on this level.  Agree with you totally on the STBs with the same thoughts.  In reading your comment, the longitudinal tube you installed from the diagonal in the main hoop must have been elevated such that it intersected the firewall near the top of same and onto the strut towers via a "V".  This is a much more DIRECT approach to increasing the "Y" axis torsional rigidity especially the front struts towers and structure.  I used an indirect method by having the tube just above the floor hump then extending upward the inside of the firewall with steel and then downward and outward on the front of the firewall to the framerails.
I have also purchased the Chassis Engineering book by Herb Adams and read it thoroughly.  I want to keep the original Datsun 240Z dash.  That is why I may place the longitudinal tube just above the hump.  Also want to beef up the forward frame rails by adding rectangular tube to the bottom of the existing frame rails forward of the front towers and far enough to the rear to gain rigidity in the "X" axis of the vehicle.
Share this post
Link to post
If you're looking for easy things to do to increase torsional strength try gluing in the windshield.  We did that to a chump car to save a gasket and I was amazed at the change in handling.  It was similar to what you'd see with a strut tower bar.  For fun windshield related trivia, aluminium and glass have almost identical Young's modulus and density. Glass has a yield strength about 10 times higher than plain aluminium and obviously less allowable plastic strain.  A 5 mm windshield is equivalent to an almost 2 mm thick steel sheet.
Cary
Share this post
Link to post
Cary
I wonder if those figures apply to safety glass, I would imagine it would be quite a bit weaker. Windshield adhesive is no joke.  I have experimented with filling factor motor mounts with 3M windshield adhesive, it is amazing.
Share this post
Link to post
