  • Replies 168
  • Created
  • Last Reply
Top Posters In This Topic
That is a nice pan. Was there any warping of the gasket surface area due to the welds?
I need to do something similar on my build, but the BMW OEM pan is aluminum and I'll probably use more than just the gasket plate.
I did some minor modification on an aluminum pan in my previous build and the gasket area warped to the extend that I needed to machine it straight. And this happened even though I had the pan firmly bolted on a metal table while welding.
@Boben Thanks, it does look spiffy! If I remember correctly it is a little warped but I don't foresee a problem with it after bolting it down as it's pretty slight. I could be wrong but I haven't done a pressure test yet!  I would agree that if you're able to use more of the original pan material then you'll probably have less chance of warpage!
I can keep you updated after the pressure test for my results though!
This tip does not help If you have leaks on the gasket seam due to warping, but otherwise, If you have a leak on a welding seam, you can apply Glyptal engine internal red enamel. It is intented to close any porous on the internal walls of an engine block. Also works on the oilpan internal surface since it can endure oil and temperature upto 130 degC. I once sealed my modified steel oil pan with that stuff, when it was leaking from a welding seam.
  On 3/2/2020 at 10:07 PM, Jboogsthethug said:
@Boben That is really good to know. I just looked it up! Do you not have to worry about the paint coming off inside?
Expand
Well, as many times is the case with these kind of classic restomod project cars, they don't see a whole lot of miles. So I cannot say whether it is bullet proof, but it is the right stuff for the particular environment and designed to endure oil on the surface.
So as of yet, I still haven't finished polishing up the paint job. Truth be told, I'm not a great painter I found out haha. I think painting in the winter definitely had it's drawbacks.. One of them being my coats didn't dry very evenly and I have plenty of orange peel! Luckily, I have a ton of clear coat too ha. Some panels actually looked pretty good, some not so much. Here are some pictures of me hating sanding.
large.IMG_2532.jpg.5816ea1a81522dd3cf32621ba3eaa317.jpglarge.IMG_2533.jpg.a6ea0500eea6367c4ed8a77cd4ac146a.jpg
Freaking orange peel....
Anyway, plenty of that left to do. I'll save it for later though.
Now for some fun parts! About a year ago I made a website for a fabricator in exchange for a roll cage in the Z. I've been procrastinating buying the supplies needed but finally it all got figured out and planned! The only unfortunate thing is now I needed to remove the windshield to make things easier ha. That was a brand new gasket. I'm sure there are ways to save it btu I've already broken my last windshield so I figured I'd rather buy a new gasket. Out it came!
large.IMG_5622.jpg.1a62aa665b23fcf4821baf13909a2955.jpglarge.IMG_5623.jpg.0afb18d95504cc09fef51c0794497edc.jpg
I threw the engine back in as I knew he'd need it to see clearances. No tranny though so I strapped it all over the place to hold it ha.
Ready for pickup!
large.IMG_5977.jpg.a8f44d71dc93696da5e8496f7b1163f6.jpglarge.IMG_5981.JPG.6cbc266e97435aba51ec22f428eb8b5a.JPG
large.IMG_5986.jpg.9cda749ee2f356a519bc101ae0ff6101.jpglarge.IMG_5984.JPG.78d0a8374349c5da317c4cf0bec1d3b2.JPGlarge.IMG_5987.JPG.83988eeb4d8ee88a6bccc501d021a22c.JPGlarge.IMG_5990.JPG.492bb67ce7b2f5862a51b53abaf69636.JPG
And she's off! At this point I am stoked and can't wait! Getting closer! I did want to initially do the cage myself but I figured I'd let it be done by a professional and it wouldn't be any less cool.
  • 11 months later...
Man I need to update this, I am so much farther along than this shows ha. I'll get on that.
For now, hoping someone can help! I'm almost done with swapping the RB25 in and I'm at a loss for a few of the plugs on the harness. My guess is they go to things that I don't have connected but I'm hoping for clarification!
Here are the pics:
First: this is coming off the alternator, my guess was maybe the fans or something?
There's s 3 way split where the MAF and the Exhaust sensor lines split off with this last guy.
These two cylinder shaped pieces, not sure.
This 6 hole plug close to where the harness comes out of the firewall.
large.1443549615_IMG_3484copy.jpg.aff284e49215fa0181b53dbd4fa20013.jpglarge.2027692610_IMG_3483copy.jpg.4d7e9187ee90e5f440a5fbc41d6b7ac6.jpg
This 8 hole plug that comes directly from the firewall split.
Any insights? Eventually I plan on taking the harness out and removing things like this that aren't needed but I want to get it running first. I'm guessing one of these go to the transmission as there are a few plugs down there that I'm not sure where they end up.
It is time to get caught back up for good! I figure I'll start where I left off. So before sending this off we went over all that I wanted done to the car cage wise and gave him (my boi Thomas Meiser with Fabn801) a good idea of my goals. Once he got there I worked even more along with him via pictures and drawing things out ha. Ghetto but it worked pretty well! Here are our "blueprints".
large.60201233438__1D63AAE2-3A42-445A-8205-DB3B7819CF6D.JPEG.e56c7668f263e941f652e053fc21ed33.JPEG
From here, things started taking shape. He started with the  main hoop as it was the most important part. He bent them perfectly around the interior to really hug the walls, nailed it perfect. But after closer inspection of the rules we realized the bends probably exceeded the amount fo bends we could have. Total of 180 degrees between it all. So he was super cool and tore it out and redid it for me.
large.IMG_6865.JPG.d5691008449c6f66e3bb45df4b21b2da.JPGlarge.IMG_6864.JPG.c3966c680730d057e3de4d3501b955a1.JPG
large.60315801537__CE1D87AD-E695-484C-9357-72C879B64415.JPEG.5d76dd199434636caba3ce84cffaa869.JPEGlarge.60313972809__452D6772-5D77-4118-8408-BA7E5ACA303B.JPEG.0a2ff8b7b35f53faa82050e09ff3b678.JPEGlarge.60235562338__CEB77FF0-3872-4ED9-95DC-4EF742F9DFAC.jpeg.jpg.93c6d29f83985ad2323a2956eb7979a3.jpg
Things beginning to take shape and working through it together:
large.60323575861__7389FC14-A43F-4E15-B0DE-4B5B52712369.JPEG.5ebc3716c4ebe420aa82f9f2611e86f7.JPEGlarge.60323190564__64707A55-C02F-4279-B22F-A5BA50A14AD8.JPEG.67495cb61d1eb3322b7219d801159004.JPEG
large.60436885595__33BBA84E-8D19-4EF0-92F5-565D3B935DA4.JPEG.bc6b1e2da1057a6bc3cfdaef737d97a8.JPEG
large.RenderedImage(16).JPEG.37b2ddccfc9baeb893f736152faab05b.JPEGlarge.RenderedImage(14).JPEG.2f797941b6ad68bbe3a5c7ddf04ff2f4.JPEGlarge.RenderedImage(13).JPEG.8c8f358b1f9e73dc22e3544b4824de39.JPEG
large.60323578753__05419D07-8C7C-4744-BDD6-8F5694E97532.JPEG.2eb073e6256c73e811042cf937e58b9b.JPEG
large.60339037176__A96FF9F0-4B26-4D79-BEC5-68A000D2BCC4.JPEG.9bb0db5a4f6415409073f66ccfb0ae98.JPEGlarge.RenderedImage(12).JPEG.fde2abbe04a003150c69628f1c80a030.JPEG
large.60340008619__C08D6D84-41D9-4F72-B347-43259BFF7B97.JPEG.b1c56395859cadbd4c73cc296137ebf9.JPEGlarge.60339929456__2DD37C3F-915F-42B2-AC8E-0D0812D3DA86.JPEG.bafdb3c7fd74c8dc4bf0ac26c0057dbe.JPEGlarge.60339832984__48852756-263D-4C6D-A21B-E0F41A62B6AB.JPEG.3d0a65af8ce8f5de06be147980b2e6c1.JPEGlarge.60339828151__5B6CFC87-A653-4035-B1FC-A9CF9D3DE727.JPEG.3e4e460373d187028f9236b5ff92d8b0.JPEGlarge.60339825893__7C321CE9-BF71-4FE7-9DAF-420FF7B04818.JPEG.33f8bef2f747a78ddfc1bcc0e2518fd3.JPEGlarge.60322114703__06BA15CA-A014-4604-9BAC-79DD412AADA7.jpeg.jpg.ff0d290feea967f82d98511ccd765040.jpglarge.60322114703__06BA15CA-A014-4604-9BAC-79DD412AADA7.JPEG.9f591e355563e0a734a7ef7bb31a5dda.JPEGlarge.60211776592__5A8D0475-FE5F-495B-A051-506D5901D51C.JPEG.1c2a298b8e3f8e044358e8fe0d43c4a7.JPEGlarge.60211002606__D600D0BC-2677-45CA-B145-F6134CB50ADC.JPEG.a2014a7cd78eb6229eedf0bc7658824a.JPEGlarge.60210576440__BE8D3A1C-8BEA-4041-A550-CDB46C90E111.JPEG.fea573f68cb97038ad5592bec8e44f51.JPEGlarge.60210575395__4E15688C-F838-4529-9A5F-15B8DDF7BDB4.JPEG.dd20ed2cbc4adf13c38b96d411cb2b62.JPEGlarge.60210574324__AAC11A29-BB29-4F8D-A3CD-E47417646559.JPEG.47747c2c9e60b7e7359634fab2ad2027.JPEGlarge.RenderedImage(9).JPEG.2fcca55254753b7d8ea6309aa4184d77.JPEG
The final outcome before it was shipped back home. Looking super sick!! Man, Thomas really killed it and I couldn't be more stoked on the outcome. Can highly recommend him as a builder for anyone in the Utah area. I caught him when he was still young in his career and I can only imagine as he grows his company he will be a huge name.
large.60376018633__60C12160-3CE4-4F65-B6A4-B1CB8535BA8A.JPEG.982ff129c3b8bb189ce487a71472088e.JPEGlarge.60376016625__8A5176C5-A907-4BD8-8007-E13645C2780D.JPEG.6790612f3bf1b0d11c3d733eef2eebf8.JPEG
large.60444999511__78B778B9-CD30-4A4F-BB0A-E83FF65BDA24.JPEG.147c602d8f215f71d998716b22022e9c.JPEGlarge.60444998103__4C2EA3F3-4B89-4FD3-9EE1-E92BB3C09CF2.JPEG.6207b691eb51d7b9d0cc65f8c5c36707.JPEG
After all was said and done, he went above and beyond what was owed. We initially had the deal for him to gusset things out but he was already over what we agreed on hours wise and so I told him to not worry about these adn I'd fix them up later.
And here are some of the highlight pics after getting her home safe and sound! There was a snowstorm on the way home and she got a bit wet so I wiped all the raw metal down but the car was still pretty wet overall.
large.IMG_7247.jpg.05afe39f3e0ff1c2b7dc832f7ee30184.jpglarge.IMG_7246.jpg.904b25a782b73bce2426c21a37e0861e.jpglarge.IMG_7245.jpg.7117e70c50d2d0b9e9f73087a7c8ba44.jpglarge.IMG_7244.jpg.289691aee4b09e8fca5510863468b236.jpglarge.IMG_7243.jpg.8c792b45ded5bfa72fe4deea152443c2.jpglarge.IMG_7242.jpg.ba50738cef76154973afb2b2c760fe75.jpg
More to come!
Edited by Jboogsthethug
  On 2/11/2021 at 3:45 PM, Exposed said:
Great update, good amount of pictures.
What are you planning on doing with the dash, something custom? Do you have plates on the other side (inside) of the firewall or are the tubes all connected to one another?
Expand
Thanks mate! Yeah I'm debating on whether to do just a flat dash or to do a fiberglass/CB dash. Regardless I plan on using a digital gauge rather than gauge pods but for now I'll probably just clamp an iPad to the bar or something ha.
And all the tubes connect through except the triangulated dash portion. I wanted that to make the firewall a bit more rigid to help with my dual master cylinder setup. Who knows if it will actually help but I like to think it will ha.
Thanks @jhm!
SO after I got the cage back home, even after wiping it dry the rain had done it's worst and the cage started to rust pretty much instantly (no real shocker ha). So I got to work and gave the entire cage a sanding with some 2000 grit if I remember correctly? Sanded it all real nicely. Wiped it off with paint prep, covered up all the paint (that hadn't been ground off) and taped it all off and gave her a nice white coat to prevent it from rusting again! Just some paint+primer rattle cans from walmart. I actually wish I picked up a different brand after seeing how easily it comes off. Eventually I'm sure I'll sand and paint it again because of that but for now I've got some protection and I'm happy!
large.IMG_9087.jpeg.12ea272ce5db8e8503a0bc31162ce0e2.jpeglarge.IMG_9084.jpeg.c1905d5f47aea0876873cfd45268fe18.jpeglarge.IMG_9085.jpeg.2f029172c915307828bb0d42b0c7869a.jpeglarge.IMG_9086.jpeg.e4ead7bd8d89c2ce62d31e48faace785.jpeglarge.IMG_1152.jpeg.e0a9f8f63791110a695e69752bb93edb.jpeglarge.IMG_9083.jpeg.cff464cc4e929d0589acc91629e234a5.jpeg
Also, picked this TDI Audi up for a great deal as my daily about a year ago now ha. Thought I'd share. Great little car!
More to come!
  On 2/13/2021 at 3:57 AM, Zetsaz said:
That tdi wagon seems like a great dad-mobile and it makes me want one.
If I wasn't such a sucker for marketing and wanting a new Tacoma or the new Frontier after it releases I'd be driving some kind of awd wagon.
Expand
It's a great dad mobile for sure ha. I picked it up for 7800 and it had 96K miles on it. I get 40 miles to the gallon, can fit a ton of crap in it and it's pretty quick so overall I'm happy for sure! The new Tacomas are awesome though. We bought my wife a new 4runner in 2016 and I love it! It is not cheap though ha. I know I can trust it to always get her where she needs to go though and it will last forever! I actually really love Toyotas. My next project is probably going to be an 80 series Land Cruiser, those are awesome!
@Zetsaz Here she is with the tint done up next to the 4Runner! Both great cars!
Next up, I decided to throw the engine back in and start getting it all buttoned up. Before I did that, I needed to get the oil pan and oil pickup tube finished. I bought a $20 engine stand and went to work! Removed the tranny from the back:
New bolts all around!
I covered up all the ports and plugged it up then wire brushed the old gasket off and cleaned it all up. I know some people frown on that and a razor would be better but this was faster and I've not had problems yet doing it this way.
large.IMG_0802.jpeg.cd7e66a9418f386e1d323c77c8646595.jpeglarge.IMG_0804.jpeg.fb9a0a1a03f7c39606bc9ec7a9439461.jpeg
All cleaned up, nice and pretty! You can see the problem with the stock oil pickup tube angle vs where it needs to be.
So cutting was needed.. The straight piece was from some pipe I bought from a local metal store, perfect fit!
Tacked in place to make sure it is all good. A LOT of measuring happening here to make sure there is the optimal clearance between the bottom of the pan and the tube opening. More on that here:
It all looked great except one problem... My oil pan was slightly too deep for the mounts I already made! This is it sitting on the crossmember, no clearance unfortunately.
Too much gap for washers IMO.
So with that, I made the decision to just start from scratch. I wasn't completely happy with my tranny mount anyway and I had different ideas for the new one! So, I ripped it all back out again, cut up these mounts and started from scratch. That's where we'll pick up in the next post!
When I did the first set of mounts I learned a few things but also did them in ways that I wasn't excited about per se. I later learned more and so I tried to apply my new knowledge with the second set.
Firstly, I didn't know how to keep the motor straight. I learned a bit via the internet and found a nifty trick of using a string tied in the direct center front to back. So after a few measurements and marks, here we go! I also did my best to level out the engine beforehand but it ended up being a 1 degree downslope towards the rear. I would've preferred the opposite (1-3 degrees sloping forward) but with my oil pan being bigger it didn't allow my engine to drop forward as much as I'd like. That's ok, I have future plans that will make this oil pan obsolete so I'll get it perfect then! Of course, the engine does still have a slight lean to match factory.
Here's a thread I started that might help anyone interested in learning more about that.:
large.IMG_1734.jpeg.dbec7e6233758a4fd9ec9e949d5f674f.jpeglarge.IMG_1651.jpeg.4f083d7366398aaf7730e8d822407ff6.jpeglarge.IMG_1652.jpeg.b34fd78eb4a6b500613342e3c3c9655c.jpeg
Using the rubber mallet to get things dialed in before fabbing. You can see I have a piece of MDF board sitting on my cross member giving me a tiny (1/8" or so) gap from the bottom of my oil pan to the top of the crossmember. I also removed the stock mounts as I decided to go straight solid mount on the motor and tranny mounts.
large.IMG_1654.jpeg.d0f2505dd568b376924374c4a0aa9b73.jpeglarge.IMG_1655.jpeg.8d733deb68772f60346aa4de8ba9b545.jpeg
I cut these piece off the first set of mounts as I knew I could easily reuse them.
Gearing up for the measurements.
large.IMG_1714.jpeg.ae9f73b82393286f4f59c074fa838041.jpeglarge.IMG_1715.jpeg.5bfd245c7422b35f625fa1c988b0cfd5.jpeg
First, I made these as the base for the mounts to the crossmember. I then put a bolt through and tightened them down so they wouldn't move. Did the same with the engine side of things too.
Then, I made measurements and got it perfect with cardboard! Not the kind with the air pockets in them. The kind that is thin and stiff works best! I just did my best with measurements first then took my time and got the pieces perfect. You can see the passenger side  is longer and skinnier than I would've liked but that's also due to the oil pan size. Should be plenty strong still!
large.IMG_1717.jpeg.097ae722530e7f819b0f59b3b13b31e0.jpeglarge.IMG_1719.jpeg.98bab4554ddb5d1e24efefbbb363180f.jpeg
Transferred to some 1/4" (if I remember correctly) thick metal. Plenty strong I'd think!
Cut out! The tabs, rectangle bar and the two squares on the left are for the tranny.
Cleaned up the rust ha, looks much better!
I put the pieces in place and tacked them up, here they are before the back plates were added.
Then fully welded! My welds are getting better. Not perfect but I'm happy with my progress in that realm.
large.IMG_1738.jpeg.188ad27cde803a7cf8d5f3ddf660629a.jpeglarge.IMG_1736.jpeg.809b4de4530889a89e9555e18258b885.jpeglarge.IMG_1741.jpeg.93a5619dd5a058f2dfea0236a00de2c7.jpeglarge.IMG_1742.jpeg.80157ab29b98642c37bfc1138495e9d4.jpeg
In place and bolted down to check for warping. Fits great!
large.IMG_1743.jpeg.d3e862fa996818af160ce8eed7992f97.jpeglarge.IMG_1744.jpeg.dfc69959fed5e52e20bfc852b157edcb.jpeglarge.IMG_1746.jpeg.98cb6a65ff579f55a227a25f5790b6c9.jpeg
Then on to the tranny. The RB25 tranny causes problems with the stock tranny mounts as far as fitment goes. The speed sensor is in the exact spot of the mounts and just hits it. Plus, as you saw from my first mounts you have to add extensions to mount up and it puts undesirable leverage on the stock mounts. So instead, I cut those completely out and used the tabs and the bigger squares I fabricated earlier to weld on new tabs. I welded the squares in the place I'd want the tabs to spread the load a bit across the thinner metal. Then I welded the tabs to those squares.
I used the rectangle bar, drilled it out and bolted it up to the tranny. I removed the stock bushing mount from the tranny and bolted to that mount. I drilled big holes on one side and small holes on the other to access the bolts easily. You can see I accidentally drilled those backwards and since I had no more bar left I cut tabs and welded over the big holes then reversed it. You can also see the side holes that allowed my bolts to go straight through the tabs and old it in place. My welds are less good here as I am not great at overhead welding yet ha.
large.IMG_1747.jpeg.54a2b871dc80d27a91785b21e41630e6.jpeglarge.IMG_1748.jpeg.e106113c06c7874fd579ed3b9c4a4265.jpeglarge.IMG_1749.jpeg.023cb131e2ea589eaa79de142412b3ee.jpeg
Oops!
Welded up a bit. They will hold but they are not pretty ha. I'll clean them up later when I get under to paint.
large.IMG_1751.jpeg.4d6a981a5f2ad4db4ab07474a77bbbcd.jpeglarge.IMG_1771.jpeg.cc56d68c8fdc602f69b3b86d19869e4e.jpeg
All in and solid! I am feeling much better with these mounts. More to come!
