OverkillZ Posted May 17, 2018 Share Posted May 17, 2018 Here’s a buddy’s 1jz in the crossmember Quote Link to comment Share on other sites More sharing options...
seattlejester Posted May 17, 2018 Share Posted May 17, 2018 ^Huh that seems to have a bit of an interesting tilt to it. Like leaned over to the passenger side and the center line tilts from towards the driver side front to back. Is it because the transmission is not in or the picture is off center? Quote Link to comment Share on other sites More sharing options...
OverkillZ Posted May 17, 2018 Share Posted May 17, 2018 Its not welded in just mocked up Quote Link to comment Share on other sites More sharing options...
Geno750 Posted May 22, 2018 Author Share Posted May 22, 2018 More progress on this stupid gear box. Finally found a shop that can help, they're quite unsurprisingly in Australia. They hooked me up with an input shaft which I'll have in my hands sometime next week. Also, after more comparing, my tail housing, per Tick Performance, is one they've never seen before, but all the castings on the Magnum when it comes to where stuff goes, lines up with what I've got. The only exception being the shifter rail, due to the better for me shifter placement. The TUET7270C gear box has an almost identical mainshaft, it's a tad under 20mm longer. Which matters not one bit, because you need a custom driveshaft when using one of these in a Datsun anyway. Here's a better set of pictures explaining why I think OverkillZ's picking up the late John C's mount is helpful. I'm running an almost bigboy turbo, and you can see the issues I'll run into as I start the downpipe and inlet for the turbo. The motor needs to lean towards the driver side if it's going to lean at all, and needs to shift more towards the driver's side. Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted May 23, 2018 Share Posted May 23, 2018 Geno, I'm curious what exhaust manifold you are using. Quote Link to comment Share on other sites More sharing options...
Geno750 Posted May 23, 2018 Author Share Posted May 23, 2018 1 hour ago, Nelsonian said: Geno, I'm curious what exhaust manifold you are using. Greddy large runner manifold from their T88 turbo kit. I cut the 4 bolt wastegate flange off and welded a 50mm v-band on it. Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted May 23, 2018 Share Posted May 23, 2018 Even though I am not at the point of choosing my turbo just yet, I am always keeping an eye out for what works on others builds, Thanks. Quote Link to comment Share on other sites More sharing options...
Geno750 Posted May 23, 2018 Author Share Posted May 23, 2018 10 hours ago, Nelsonian said: Even though I am not at the point of choosing my turbo just yet, I am always keeping an eye out for what works on others builds, Thanks. The Suprastore manifold is basically a copy of what I'm using with the option to use whatever wastegate you want, or none if going with an EFR turbo. Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted May 24, 2018 Share Posted May 24, 2018 Thanks Geno, I will have a look at their offerings. It's always good to get first hand experience opinions and advice on tried parts. Quote Link to comment Share on other sites More sharing options...
Geno750 Posted May 28, 2018 Author Share Posted May 28, 2018 Gearbox fun continues. Removed the stock transmission mounts on the car. Need to at least buy the correct shift rod. The current one is too long to let the Magnum housing seat all the way. So no test fitting for a bit. Quote Link to comment Share on other sites More sharing options...
Geno750 Posted January 12, 2019 Author Share Posted January 12, 2019 Two foot surgeries later, I can work on the car in spurts before having to take a break. Here's what I've done over the last few weeks. Finished making the TR6060 from Oz into a T56 Magnum (only better). Got my twinplate clutch in. Went with a Spec twin, and I'll be using a Tilton slave to avoid the disaster that plagues the Spec TOB's. The Spec and like most other twin plate clutches use a thin flywheel that isn't compatible with the standard bolts we buy. Not wanting to grind on ARP flywheel bolts, or buy a set that someone else ground away on I went through the ARP catalog and found these. ARP Part number is 204-2801. Requires a 12mm triple square to install. They're the ideal bolt for this flywheel. Standard bolt is the 12pt, Overkill Z's reproduction of the Betamotorsports crossmember. It required a bit of flex on the factory motor mounts to get it to bolt in all the way, but it fits much better than the CX Racing mount. However, install on a 280Z is a little trickier than I initially thought. Turns out the cups for the tension arm are a bit different on the 280Z and interfere with the crossmember quite a bit. The driver's side isn't too bad, and requires a small trim. The black sharpie tick mark you see is 13.5" away from the firewall. I wanted to get as close to that mark as possible. The passenger side on the other hand, required a lot of trimming. I would have to cut into the reinforced area to get to my 13.5" goal, instead I'm settling for 14" from the firewall, which will put the back of the block 1" away. Now I'm off to get some more c-clamps because my harbor freight wood working clamps aren't going to cut it on the next step of the project. Quote Link to comment Share on other sites More sharing options...
Exposed Posted January 18, 2019 Share Posted January 18, 2019 are you welding that in? how close to the firewall will the engine sit? Quote Link to comment Share on other sites More sharing options...
Geno750 Posted January 19, 2019 Author Share Posted January 19, 2019 23 hours ago, Exposed said: are you welding that in? how close to the firewall will the engine sit? Yeah I'm going to weld it. I've put the motor about 2cm off the firewall. Quote Link to comment Share on other sites More sharing options...
Geno750 Posted August 6, 2019 Author Share Posted August 6, 2019 New job has had me busy till recently. Might have to do some work on the hood latch. If I wasn't running IGN1A's this wouldn't be an issue. Main thing is it's in there and it's straight. Also started on the rear end. Quote Link to comment Share on other sites More sharing options...
