Dat73z Posted January 10, 2025 Author Share Posted January 10, 2025 48 minutes ago, calZ said: That looks very tidy. Are you planning on adding some slip on insulation to those eventually? I'd imagine the stainless tubing will sweat a ton without it. It's actually AL tubing but I was using stainless instrument benders to bend them. That's a good point on the sweating, I actually had the same question and emailed Vintage Air tech last year here was their response: "The only line that should sweat would the #10 suction hose/line, make sure this branch is insulated on the hardlines or metal sections of the hoses that are inside the cabin." So it doesn't sound like any of them should sweat but I'm not AC expert. I'm sure some insulation on the appropriate branches would increase efficiency so I may consider it at some point but I'm just trying to get the car back on the road first. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted January 11, 2025 Author Share Posted January 11, 2025 My workspace is a mess so this evening I started cleaning up before proceeding so I threw the intercooler back on to check clearances for the AC and oil cooler sections. I think everything looks good to continue fabrication. My welding station is currently set up for AL which it never is so I've been contemplating also hard piping the intercooler with aerospace wiggins clamps. Not sure if it's worth it for this ebay special as the clamps and separate weld ferrules are eye bleeding expensive but I'll simmer on it over weekend projects. 1 Quote Link to comment Share on other sites More sharing options...
calZ Posted January 11, 2025 Share Posted January 11, 2025 (edited) Yes, sorry, aluminum. I somehow missed that you had flexible lines running through the fresh air duct that are already insulated. That's genius. I was already planning on running my wiring harness through the passenger side duct, but hadn't thought of doing the same with the AC lines. I might have to copy you. Edited January 11, 2025 by calZ Quote Link to comment Share on other sites More sharing options...
Dat73z Posted January 11, 2025 Author Share Posted January 11, 2025 @calZ I actually got the fresh air duct idea from the v8 subforum here a few years back when brainstorming the AC setup. I don't recall the thread but it was a super clean silver Z and they ran the lines across the rad support to the pass side. HybridZ is an absolute goldmine of info so maybe someone will stumble across our discussion too and get some inspiration. There's a lot more going on with the AC install on this build I've been working in the background including inside the cabin (I'll update that ongoing thread in the Interiors sub sometime) but I've been trying to keep this thread mostly dedicated to the turbo aspects. For the cooler packaging I intentionally wanted to keep all the AC componentry all on the DS and the oil cooler all on the PS with the intercooler in front of and crossing between the two instead of single sided. So that's why I went through all the fabrication work so far...it would have been a heck of a lot easier to mount the oil cooler in front of the intercooler, run the AC lines much longer onto the other side of the car, etc. but that wasn't the vision Quote Link to comment Share on other sites More sharing options...
Dat73z Posted January 18, 2025 Author Share Posted January 18, 2025 (edited) Things got super busy again but this evening I went ahead and hardlined the oil cooler. I'm a bit out of practice on stainless so I accidentally put a couple of tooling marks in the tubes. The line sections are short so I'll work them out with a hardened rod when I wash everything out and rebrush the finish for final assembly. It's one of those things where I need to remind myself to slow down and think things through otherwise I end up making more work for myself or waste material. I also hit the AC Hardlines with some steel wool and wd40 to get a uniform finish but it's is a bit bright for me. I may go back and redo those in brushed as well. I realize I keep getting busy so this weekend I'm going to try and dedicate a solid half day to wrapping up the turbo cooler packaging updates. Edited January 18, 2025 by Dat73z 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted January 19, 2025 Share Posted January 19, 2025 You are being VERY detail oriented. It is paying off. Really looks great. Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted January 20, 2025 Author Share Posted January 20, 2025 Thanks it feels good to be working on it semi-consistently again. I still haven't had my half day this weekend, but I had an hour tonight so I started final shaping the lower condenser mount. I drew what I had conceptualized on a piece of cardboard a few weeks ago but decided to freestyle it as I was filing things down. I could do a lot more but I think I'm going to punch some speed/air bypass holes on the bottom of the mount and call it. The mounting is Setrab sandwich style soft mounts with high temp silicone sheet. I'm going to try to wrap this tomorrow and weld in the top soft mounts to the intercooler air plate. 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted January 21, 2025 Share Posted January 21, 2025 It's a handy place to put stuff. That area is where my water/meth tank is. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted January 21, 2025 Author Share Posted January 21, 2025 My plan is to eventually put a couple gallon anti detonant tank in the spare tire well area for volute or direct port injection. For my setup it hasn't been needed at 10psi on 91 CA pump gas and 8.5:1 CR but I want to double that with the new G series turbo. I measured everything out and few years ago for likely candidates around the engine bay area in front of the rad support would be taken up by the oil cooler and AC...which is the case now. The other area I evaluated was the washer bottle/clutch master area which could work but I really wanted at least 2-3 gallons of volume for convenience. Yesterday turned into a nice all day date with my wife so I didn't get much done. After soliciting some opinions from FB groups I decided to leave the lower condenser mount as-is to force air through the coolers. Doing nothing at all is less work and eventually I may redo the air ducting when I do a v3 cooler packaging update in another 5 or 10 years 😆 I considered serviceability when fabricating all of this, with good access to the rad hardware. The easiest location for a top soft mount without making new holes in the chassis seems to be bracketing off the top and/or bottom rad bolt(s), especially if I want the top intercooler air plate to remain independent but this would affect serviceability. Not sure what the best path forward is but I'll think about it over the week. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted February 6, 2025 Author Share Posted February 6, 2025 Got super busy and had to take a break, but this week I got covid so I get to catch up on some unboxing and setup. Unboxed my shielded vband special PTZ and hot side components. Also my custom cnc intake manifold is in production so I should have that in soon. I'm changing directions a bit on the build. After years of keeping it a clean patina driver, I've decided to rotisserie restore the car at a local shop that does a lot of high end work for GTRs and other really sick JDMs. The target date to get it in is this spring so I'm going to finish all the bespoke fabrication work so everything goes together like Legos when I get the shell back in. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted February 9, 2025 Author Share Posted February 9, 2025 Still feeling terrible but I'm trying to get all the parts back onto the engine to make space for shell tear down. Today I put the hot side parts onto the engine, and like most custom setups clearances are exceptionally tight so assembly order and angles all matter. I think if I'm feeling better next week some buddies will come over to help strip the rest of the shell. I should probably also find some roller suspension for traveling to and around the bodyshop. Quote Link to comment Share on other sites More sharing options...
A to Z Posted February 10, 2025 Share Posted February 10, 2025 (edited) I hope the insulation you have on your turbine and exhaust header is sufficient. Its going to get super hot. Neat that you found a cool way to spend $50K dollars! Might as well add spoilers and flares and get some big meats for the car.....give it an hourglass figure! Edited February 10, 2025 by A to Z Jesus Is Lord Quote Link to comment Share on other sites More sharing options...
calZ Posted February 10, 2025 Share Posted February 10, 2025 18 hours ago, A to Z said: I hope the insulation you have on your turbine and exhaust header is sufficient. Its going to get super hot. Neat that you found a cool way to spend $50K dollars! Might as well add spoilers and flares and get some big meats for the car.....give it an hourglass figure! I can't tell if this is snark because Eric has pointed out actual issues with stuff you've done or if it's just a very poorly worded compliment. Quote Link to comment Share on other sites More sharing options...
rossman Posted February 10, 2025 Share Posted February 10, 2025 I'm with @calZ. I was scratching my head, thinking wtf kind of response is that? The man wants to have his car restored properly. What could possibly be wrong with that, and what do flares and spoilers have to do with it? It's his car he can do whatever the hell he wants. I'm just glad he takes the time to share it with us! Quote Link to comment Share on other sites More sharing options...
A to Z Posted February 11, 2025 Share Posted February 11, 2025 Not negative at all! I like the direction he is going. We live in a world where guys are all sensitive these days. I am old school, raised old school. If you are going to do the body up, it seems like now is the best time to do it wild if you like them like that. There are ways to blow 50K and ways to spent 50K and enjoy it. I said it sounds like he found a good way to spend 50K. So, no offense meant......I'm not good at explaining myself.....I generally do what I want, and feel no need to explain my actions to anyone. Id like to see updates of the car as it progresses. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted February 12, 2025 Author Share Posted February 12, 2025 (edited) Thanks for the discussion guys, and no offense taken @A to Z. In terms of the scope, chassis modification such as full length frame rails will be carried out for strengthening among other aspects I'll cover later. I see 50k being repeated a lot not sure where that's coming from but this will be done to a high standard regardless. I don't think I've really posted much about the car itself or what it means to me but it'll remain frozen in appearance as a clean narrowbody car, without bodykits, big wheels, etc. It's more nostalgic for me that way and I've already shown early in the build thread, tucking 245rcomps under the factory arches. Not much to update here as I'm recovering from the rona but a lot of irons in the fire. Cnc intake manifold is in production, got some updates and very excited for that. Waiting for my water meth tank to get in and determined the location. Waiting for news on getting a Nissan Comp OEM style rollbar imported so I can weld the floor plates in for that. Also met with the bodyshop guys today to look over the car and the target date to get it in is May. Basically do all the remaining cutting, welding, and drilling before the shell goes on rotisserie. Edited February 12, 2025 by Dat73z Quote Link to comment Share on other sites More sharing options...
A to Z Posted February 13, 2025 Share Posted February 13, 2025 (edited) Man it sounds great! Fun stuff! I hope you are feeling better. I have had that twice and it took my mom. is there any rust that needs to be addressed? Seems like rust likes to hide in the rear hatch under the window weatherstripping at the bottom. Intrigued about the CNC intake. What will it offer than you don't have now? Just looks? Serious question. The $50K came from me. I am big believer in setting a budget. IMHO 50K is safe budget. If you come in less....GREAT! A lot of little things you haven't thought of, will need to be replaced since the body is fresh and all. The internet has a way of showing the worst in people. I am actually a nice guy! The other day having my engine start and hear the turbo whistle was a moment of feeling 1/2 ton of weight fall off my back! Edited February 13, 2025 by A to Z Quote Link to comment Share on other sites More sharing options...
calZ Posted February 13, 2025 Share Posted February 13, 2025 13 hours ago, Dat73z said: Thanks for the discussion guys, and no offense taken @A to Z. In terms of the scope, chassis modification such as full length frame rails will be carried out for strengthening among other aspects I'll cover later. I see 50k being repeated a lot not sure where that's coming from but this will be done to a high standard regardless. I don't think I've really posted much about the car itself or what it means to me but it'll remain frozen in appearance as a clean narrowbody car, without bodykits, big wheels, etc. It's more nostalgic for me that way and I've already shown early in the build thread, tucking 245rcomps under the factory arches. Not much to update here as I'm recovering from the rona but a lot of irons in the fire. Cnc intake manifold is in production, got some updates and very excited for that. Waiting for my water meth tank to get in and determined the location. Waiting for news on getting a Nissan Comp OEM style rollbar imported so I can weld the floor plates in for that. Also met with the bodyshop guys today to look over the car and the target date to get it in is May. Basically do all the remaining cutting, welding, and drilling before the shell goes on rotisserie. Where's the rollbar coming from? I looked into getting one from VA Engineering in the Netherlands a few years ago since Tony had sent them an original set of brackets to copy, but they said it would be a one off and never actually gave me a price. I see Mizukami in Japan offers them now. It's a good time to buy with the current exchange rate. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted February 13, 2025 Author Share Posted February 13, 2025 @calZ I'm working to import the Mizukami Auto one and yes the exchange rate has been phenomenal 😁. Nils at JDMJunkies is running one on his Swiss s30 build and when I messaged him he had nothing but great things to say about the build quality, fitment, and how complete the kit was down to the weld-in floor plates. I also went down the rabbit hole of investigating other available option(s)/what is historically accurate/made some friends along the way lol and settled on the Mizukami bar as the most viable option for my needs. @A to Z The manifold is a novel clean sheet design from a very talented designer and friend. I'll dedicate a post to discuss the design philosophy and aspects when it's time to refocus on the driveline. Quote Link to comment Share on other sites More sharing options...
Dat73z Posted February 15, 2025 Author Share Posted February 15, 2025 (edited) A busy start to the weekend due to the holidays but the plan is to get the mounting locations for the water/meth tank set and finish stripping out the interior. For the water/meth tank, I think the cubby area on the pass rear works well and it'll basically blend into the black interior when it's all back together. Edited February 15, 2025 by Dat73z Quote Link to comment Share on other sites More sharing options...
