Max_S Posted December 4, 2018 Share Posted December 4, 2018 Hello everyone As part of my planned 240/260-project I want to do a 5-lug-conversion, to increase the choice of wheels and brakes on the very restricted German market. what are good options that let me use the stock chassis (no tube frame car) and as few custom self made made parts as possible? I heard that 300ZX-Hubs are a good option, and someone told me that RX7 FD hubs (or even the whole front axle assembly) can be transferred too. Any other options you heard of/can recommend? Thanks in advance, Max Quote Link to comment Share on other sites More sharing options...
Neverdone Posted December 4, 2018 Share Posted December 4, 2018 Z31 300zx front hubs can be used, but in the rear you'll still need some sort of custom option. Some people re-drill the rear stub axle to accept 5 studs. Other than that, you're looking at a billet stub axle or some sort of new rear upright to accept a completely different kind of axle (like the Techno Toy Tuning Shortnose R200/R230 rear end swap) Silvermine motorsports can re-drill your stock stub axles if you send them to them if you can't find someone to do it locally. Quote Link to comment Share on other sites More sharing options...
jhm Posted December 4, 2018 Share Posted December 4, 2018 https://technotoytuning.com/nissan/280z/5-lug-front-hubs-datsun-260z-and-280z Quote Link to comment Share on other sites More sharing options...
clarkspeed Posted December 6, 2018 Share Posted December 6, 2018 As stated above. Wilwood also offers a front hub that will fit. But the rear is either expensive custom stub axle or redrill the stock Quote Link to comment Share on other sites More sharing options...
scca Posted December 16, 2018 Share Posted December 16, 2018 Which wilwood front hub fits? early mustang is close with the .25" added width over a stock hub- but thats still less track width than a 240/280 hub. F and A body GM will fit if you turn the inner hub down a bit to narrow the width between bearings. I actually tried a billet gm hub yesterday on a strut and needs about 50 thou to make the outer bearing sit fully on the machined bearing surface, but the offset isnt that great to make it worth doing- I have ( i think) z32 front hubs now and was looking to get a little LESS track width than these have as im trying to put 17 x 8.5 on the car all around and if i get the hub/rotor hat TH. correct then all 4 wheels can have the same BS. I already have the rear fit to what i think is perfect and now working on the fronts. This will have to be custom wheels with 5.75 BS, right now the fronts could use 6" but with the existing Z32TT calipers they have a overhang of 1.5" and thats limiting how much BS i can run to make the wheels fit Hubs tried- to compare Track width changes 240z 280zx z31 penta style bolt on rear rotor face z32 floater front mount rotor GM A/F body billet hub 60s Ford 5 lug hub I have measurements for all the above as far as offset from rotor face to rear of caliper mounting ears- last to try is a Fox body- i have to bring one from work - Quote Link to comment Share on other sites More sharing options...
Cable Posted June 18, 2019 Share Posted June 18, 2019 Which Wildwood hub? Quote Link to comment Share on other sites More sharing options...
Chopshop280zx Posted December 17, 2020 Share Posted December 17, 2020 (edited) I have a 1982 280zx with a stock 6.0 ls with a powerglide. The car works great out of the whole but I need to put more power down how can I get this rear end to handle more horse power. If I could get this car to hold about 500 horses out the whole it would be a killer. Some body help me remove these stock axles please. The Z car world has forgotten about the 280zx Edited December 17, 2020 by Chopshop280zx Quote Link to comment Share on other sites More sharing options...
G-Tech Posted December 17, 2020 Share Posted December 17, 2020 (edited) 9 hours ago, Chopshop280zx said: I have a 1982 280zx with a stock 6.0 ls with a powerglide. The car works great out of the whole but I need to put more power down how can I get this rear end to handle more horse power. If I could get this car to hold about 500 horses out the whole it would be a killer. Some body help me remove these stock axles please. The Z car world has forgotten about the 280zx i have a 280ZX with LS swap that has 400WHP and a 6-speed. i have the stock r-200 with Quaife internals. that has held up flawlessly. there are other options for internals for the r-200 also. that diff should handle it fine.The problem you will have is if you still have universal joint half shafts and then stub axles was the week link i found. Mine beeing a stick shift though is harder on the drivetrain. you might be fine if you just upgrade to 280zxt CV joints and you will have to switch the stub axle companion flange also. (both of which i have that i would sell if you decide to go that route). if you can afford it, i got custom Chromoly stub axles and companion flanges made to switch to 300zxt CV joints (gonna be close to $2k). when im at the drag strip i dump the clutch at 4k RPM and run 11.8's all day. it takes it fine. And yes, the Z car world still does not appreciate the 280zx. There are a few of us going the extra effort to make them work however. And to keep this on track with this 5-lug conversation topic, shops that are making custom stub axles and custom front hubs are willing to make them 5-lug for you. i found that F-body Camaro wheel studs are almost identical so i bought ARP wheel studs for the Camaro and i run them with my 4-lug set up with no issue Edited December 17, 2020 by G-Tech Quote Link to comment Share on other sites More sharing options...
jhm Posted December 18, 2020 Share Posted December 18, 2020 You guys may want to move this discussion from current sub-forum ("S30 Series - 240Z, 260Z, 280Z") into the "S130 Series - 280ZX" sub-forum....might have more visibility in the correct sub-forum. Your call. Quote Link to comment Share on other sites More sharing options...
