D1t Posted April 28, 2021 Share Posted April 28, 2021 Quote And ideally use a toe-link rear arm design. Just a thought. Expand The forward rod end on that arm uses a concentric double adjuster (RH male thread on outside, LH female thread on outside) so I can avoid using a separate toe link while still being able to adjust the toe on the car. This avoids creating a buckling load in a toe link and allows the lower control arm to react some of the torque of the engine/brakes instead of passing all that load up to the strut mount and putting additional bending load into the strut. Quote Link to comment Share on other sites More sharing options...
tube80z Posted April 28, 2021 Share Posted April 28, 2021 On 4/28/2021 at 2:19 PM, 280Z-LS3 said: Honestly, I had no input on new knuckle design as my mechanical engineering knowledge is like zero, lol. Expand Makes perfect sense to me. If they haven't been built maybe something to look at. Cary Quote Link to comment Share on other sites More sharing options...
Ironhead Posted May 2, 2021 Share Posted May 2, 2021 I really like your design for the hub uprights. While there is nothing inherently wrong with the TTT ones, they are needlessly heavy, and in fact I have noticed on their website that they now have a new design with a lot of metal removed to reduce weight. Yours look even lighter. Part of me hates seeing better designed parts, because it makes me want to bin mine and trade up. But I have to stay the course or this damn car will never be "finished".... Just a few notes about the TTT rear control arms/uprights....and I think would apply to your design as well.... I have been driving my car around quite a bit trying to iron out all the little details. One thing I have noticed is a fairly loud clunking from the back of the car as the rear suspension loads and unloads going over bumps. I "think" I have narrowed the source down to the long bolt on the outer end of the control arms....it goes through the two Heim joints and also through the tube at the bottom of the rear hub uprights. I didn't initially have this bolt super tight, just snug, because I figured it only needed to function in shear and I also didn't want to put a bunch of side loading on the Heim joints. But I think the clunking noise was caused by the uprights moving up and down on the bolt when driving over bumps. The bolt is a fairly precise fit in the Heim joints but pretty loose where it passes through the tube at the bottom of the uprights. So I carefully shimmed the long bolts to fully tighten them without putting a bending load on the Heim joints. I'm hoping this sufficiently stabilizes the hub upright tube and gets rid of the clunking. I was going to do a test drive today, but the potentiometer for my electric power steer decided to crap out, and the car is fairly undriveable without power steering....so I have to sort that to know if I succeeded in eliminating the "clunks" or not. Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted May 3, 2021 Author Share Posted May 3, 2021 On 5/2/2021 at 9:25 PM, Ironhead said: So I carefully shimmed the long bolts to fully tighten them without putting a bending load on the Heim joints. I'm hoping this sufficiently stabilizes the hub upright tube and gets rid of the clunking. Expand While talking with Noah the other day I mentioned something about bolt sizing and strength in shear. I think it was for the 10mm bolts I used for my trans mount. He said there is a common misconception on how things are "held together" with fasteners. It's the friction created between the surfaces the fasteners are connecting which provides the vast majority of the apposing force in the shear plane. So I think the carefully shimmed play between the rod end and upright and having the through bolt torqued to spec for diameter will solve the chatter you are experiencing. "Finished" is a relative term right, lol. I say get the car sorted, have some fun then tackle a few "quick and necessary" upgrades during winter months. I thought while prioritizing the next build task it was to be the DIY headers. While examining the driver's side area noticed that the OEM steering coupling bushing needs to go, it takes up too much space and need all the possible space for header tube routing. Planned for a Saturn Vue EPS column to swap in case I needed assist after test driving with 275 front tires. Well, looks like I should tackle the EPS first since your opinion is effort is high with that wide a front tire. Quote Link to comment Share on other sites More sharing options...
D1t Posted May 3, 2021 Share Posted May 3, 2021 On 5/2/2021 at 9:25 PM, Ironhead said: The bolt is a fairly precise fit in the Heim joints but pretty loose where it passes through the tube at the bottom of the uprights. Expand I reamed the pivot tubes out to be a light sliding fit on the 5/8" pivot bolts with a hand reamer, they're ~0.627 right now and I'll do it again after welding to make sure they're still straight and cylindrical. The bolt shouldn't ever see the shear load unless the nut becomes loose, but it also helps make sure that your alignment doesn't change every time you take the rear end apart and put it back together. Quote Link to comment Share on other sites More sharing options...
Ironhead Posted May 4, 2021 Share Posted May 4, 2021 On 5/3/2021 at 5:30 AM, 280Z-LS3 said: While talking with Noah the other day I mentioned something about bolt sizing and strength in shear. I think it was for the 10mm bolts I used for my trans mount. He said there is a common misconception on how things are "held together" with fasteners. It's the friction created between the surfaces the fasteners are connecting which provides the vast majority of the apposing force in the shear plane. So I think the carefully shimmed play between the rod end and upright and having the through bolt torqued to spec for diameter will solve the chatter you are experiencing. "Finished" is a relative term right, lol. I say get the car sorted, have some fun then tackle a few "quick and necessary" upgrades during winter months. I thought while prioritizing the next build task it was to be the DIY headers. While examining the driver's side area noticed that the OEM steering coupling bushing needs to go, it takes up too much space and need all the possible space for header tube routing. Planned for a Saturn Vue EPS column to swap in case I needed assist after test driving with 275 front tires. Well, looks like I should tackle the EPS first since your opinion is effort is high with that wide a front tire. Expand Dude! We're in Cali....I drive my project cars in the winter more than the summer.....LOL. As far as the steering....keep in mind that in addition to the 275 tires....I also have a significantly quicker than stock rack (can't remember the ratio)....the shorter Apex steering knuckles.....and 6.5 degrees caster. The steering is go-cart quick....maybe a bit too much, really.....but even once up to speed it takes a lot of effort to turn the wheel. My initial plan was to have the power steering go off at 15 MPH....but after driving it.....nope....power is staying on. I thought I wouldn't like the feel of the EPS....but it really isn't bad at all. You are right that there is a lot of confusion about bolts used in tension vs shear. In aircraft many bolt applications are pure shear, and AN bolts are designed to actually be used as such. That's why you can get 1/2 height AN lock nuts...because the tensile strength is irrelevant. But yes, on the TTT arms it is different, as the pivoting takes place in the Heim joints. I should have realized that failure to fully tighten the bolts would lead to clunking. Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted May 4, 2021 Author Share Posted May 4, 2021 On 5/4/2021 at 12:04 AM, Ironhead said: Dude! We're in Cali....I drive my project cars in the winter more than the summer.....LOL. Expand Yes, absolutely right. Summer is the down season for Cali, I stand corrected! Here in SLO county it gets into the triple digits for weeks on end during summer. Without A/C it's brutal. I had the opportunity to drive a friend's right hand drive 1966 Ford GT40 in July a few years ago. Such a rare iconic Super Car couldn't pass the offer up. After 20 mins with outside temp of 105F had to call it quits hoping for an ice bath while pulling into the garage. As I pulled in literally soaked with sweat he asked me to take his nephew who couldn't drive a stick for a spin. Kids these days, lol. I almost declined it was that hot in the car. The 2006 GT my wife got to play with is much more refined being fitted with the modern convenience of A/C. Two years ago worked on his application (yes applications to buy GT cars are mandatory now because of speculators purchasing cars then flipping) for his newly delivered GT. Covid has pushed back the promised piloting of that car which will surely be a blast! Quote Link to comment Share on other sites More sharing options...
Ironhead Posted May 4, 2021 Share Posted May 4, 2021 If your "Z" turns out similar to mine, you will find it equally unrefined. I'm actually a bit surprised how hot it gets inside. I have Lizard Skin temp control on the inside, and reflective heat shield in the trans tunnel, and it still gets really warm inside. Let's just say, a heater is unnecessary. I guess just a function of too much engine/HP/exhaust in too small a space. It's all good though. I knew I wasn't building a luxury car. Quote Link to comment Share on other sites More sharing options...
Ironhead Posted May 4, 2021 Share Posted May 4, 2021 On 5/3/2021 at 12:55 PM, D1t said: I reamed the pivot tubes out to be a light sliding fit on the 5/8" pivot bolts with a hand reamer, they're ~0.627 right now and I'll do it again after welding to make sure they're still straight and cylindrical. The bolt shouldn't ever see the shear load unless the nut becomes loose, but it also helps make sure that your alignment doesn't change every time you take the rear end apart and put it back together. Expand Sorry D1t...I don't completely follow. Did you precisely ream the TTT control arms, or arms of your own construction? Quote Link to comment Share on other sites More sharing options...
D1t Posted May 4, 2021 Share Posted May 4, 2021 (edited) On 5/4/2021 at 2:54 PM, Ironhead said: Sorry D1t...I don't completely follow. Did you precisely ream the TTT control arms, or arms of your own construction? Expand I'm referring to the knuckles I'm building for 280z-LS3 and myself. I reamed out the pivot tube on the knuckle not the arm. Edited May 4, 2021 by D1t Quote Link to comment Share on other sites More sharing options...
Ironhead Posted May 4, 2021 Share Posted May 4, 2021 On 5/4/2021 at 2:56 PM, D1t said: I'm referring to the knuckles I'm building for 280z-LS3 and myself. Expand Ahhh...that makes sense then. Good work BTW. Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted July 7, 2021 Author Share Posted July 7, 2021 House remodel has me stalled in the garage, ignoring work on the Z. With the arrival of the new rear knuckles/up rights today getting super motivated to get back at it. Noah's work is top notch as usual! Really have to see these in person to appreciate the design. Going to get them on the car ASAP for some measurements. The rear strut tube mount flanges will have to be redesigned to move the strut deeper into the strut well for 315 tire fitment using Marugen Shoukai extra wide flares. More on that soon... Quote Link to comment Share on other sites More sharing options...
DonH Posted July 23, 2021 Share Posted July 23, 2021 Dude - your build needs more attention! Amazing job so far i cant wait to see it done man! Who is the contact that designed the rear end? Im currently a LS base build but will eventually add a supercharged and I know my Z31 CV's will take a shit Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted July 23, 2021 Author Share Posted July 23, 2021 On 7/23/2021 at 4:56 PM, DonH said: Dude - your build needs more attention! Amazing job so far i cant wait to see it done man! Who is the contact that designed the rear end? Im currently a LS base build but will eventually add a supercharged and I know my Z31 CV's will take a shit Expand I know! House remodel has garage play time sidelined. That said have little time right now so started installing the Griffin 1.25" dual core radiator and C7 Spal fan. Will post up some progress photos soon. The basic Super 8.8 swap kit is Invincible Extremes. You can find him in the vendors section. D1t is the guy who designed my front end and new rear knuckles. He responded to this thread a few posts back, private message him. Quote Link to comment Share on other sites More sharing options...
DonH Posted July 23, 2021 Share Posted July 23, 2021 On 7/23/2021 at 6:00 PM, 280Z-LS3 said: I know! House remodel has garage play time sidelined. That said have little time right now so started installing the Griffin 1.25" dual core radiator and C7 Spal fan. Will post up some progress photos soon. The basic Super 8.8 swap kit is Invincible Extremes. You can find him in the vendors section. D1t is the guy who designed my front end and new rear knuckles. He responded to this thread a few posts back, private message him. Expand Nice call on the C7 fan! Its what im using Will keep their contact noted. Quote Link to comment Share on other sites More sharing options...
Dwayne_The_Rock_Datsun Posted May 12, 2022 Share Posted May 12, 2022 Maybe I overlooked it but what length axles did you end up going with for the super 8.8? Build is premo and I enjoyed reading through the process. Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted May 12, 2022 Author Share Posted May 12, 2022 Not sure the exact length. I think mine are a bit longer (0.125”?) than the original to help accommodate for T3 adjustable control arms. Invincible Extremes (aka Vlad) will know since I purchased the axles from him with my kit. I assembled the axles into the cv joints otherwise would measure for length I will be getting back to working in the Z soon. Life has been slammed busy with house remodel the last year Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted May 13, 2022 Author Share Posted May 13, 2022 And by original I mean the first axle designed for this swap by D1t Quote Link to comment Share on other sites More sharing options...
Dwayne_The_Rock_Datsun Posted May 13, 2022 Share Posted May 13, 2022 On 5/12/2022 at 11:55 PM, 280Z-LS3 said: Not sure the exact length. I think mine are a bit longer (0.125”?) than the original to help accommodate for T3 adjustable control arms. Invincible Extremes (aka Vlad) will know since I purchased the axles from him with my kit. I assembled the axles into the cv joints otherwise would measure for length I will be getting back to working in the Z soon. Life has been slammed busy with house remodel the last year Expand I am also running T3 lower control arms. Appreciate the response! Quote Link to comment Share on other sites More sharing options...
