himself Posted March 16, 2021 Share Posted March 16, 2021 It's not 21334-R2400, please read below. I have a 1982 L28ZXT engine from a 280zx with a 5-speed manual transmission, which (as some may be aware) did not come standard with oil coolers. The cars with automatic transmissions did come with oil coolers but the manual transmission versions had to be requested from the dealer and as such they are exceptionally uncommon. The annoying part about this is the MT's oil cooler is different than the AT's oil cooler and uses a completely different O-ring on the engine side. The AT oil cooler everyone is familiar with mounts at a 45-degree angle downward while the MT oil cooler mounts horizontally. Does anyone know the part number of that O-ring? (Again, it's not 21334-R2400, that's the AT version.) I've attached a photo of the oil cooler mounted on the engine and what the O-ring against the engine looks like, it's about 1/4-inch thick, ~67mm inner diameter, and has a square cross-section. I have found two Nissan O-rings that looks similar (part numbers 21304-JA11A and 21304-JK20A) however I cannot find their dimensions to see if they would fit. Quote Link to comment Share on other sites More sharing options...
lowrider Posted March 16, 2021 Share Posted March 16, 2021 If you have the dimensions from the original it would be fairly easy to look up a comparable o-ring from some where like McMaster Carr. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted March 16, 2021 Share Posted March 16, 2021 Have you looked at nissanpartsdeal.com? Quote Link to comment Share on other sites More sharing options...
himself Posted March 18, 2021 Author Share Posted March 18, 2021 On 3/16/2021 at 12:42 PM, lowrider said: If you have the dimensions from the original it would be fairly easy to look up a comparable o-ring from some where like McMaster Carr. Ah, I had not considered MC, thanks I'll check that. On 3/16/2021 at 3:27 PM, Mayolives said: Have you looked at nissanpartsdeal.com? I did and they only have the AT version. Thanks though. Quote Link to comment Share on other sites More sharing options...
tioga Posted March 23, 2021 Share Posted March 23, 2021 Have you tried the o-ring from a new oil filter? Quote Link to comment Share on other sites More sharing options...
NewZed Posted March 23, 2021 Share Posted March 23, 2021 Is it a Nissan part or aftermarket? Seems like you could peel the gasket out of a filter and it would work, if you find the right filter. A sensible engineer would design the seal to match an oil filter seal, since the sealing surface is the same. Quote Link to comment Share on other sites More sharing options...
NewZed Posted March 23, 2021 Share Posted March 23, 2021 p.s. the Nissan filter would be the obvious starting point. p.s. 2 that gasket would not normally be considered an "O-ring". It's a gasket. O-rings are more complex, although a quick Google shows that the term is being dumbed down (no offense) to refer to any gasket that is round. https://www.parker.com/Literature/O-Ring Division Literature/ORD 5700.pdf Quote Link to comment Share on other sites More sharing options...
ETI2K Posted March 24, 2021 Share Posted March 24, 2021 @NewZed Very good reference material. I always prefer to rely on experts, and Parker certainly qualifies as such. I have set up inventory systems using McMaster's naming conventions and they use "square (as well as others) o-ring". I'll be sure to alert them tomorrow!😁 Quote Link to comment Share on other sites More sharing options...
NewZed Posted March 24, 2021 Share Posted March 24, 2021 Did you win? It's a gasket. https://www.google.com/search?q=oil+filter+gasket&rlz=1C1SQJL_enUS862US862&oq=oil+filter+gasket&aqs=chrome..69i57.3881j0j15&sourceid=chrome&ie=UTF-8 Quote Link to comment Share on other sites More sharing options...
himself Posted April 3, 2021 Author Share Posted April 3, 2021 To close out this topic for anyone else looking for this part, the oil cooler O-ring from a 2003-2006 350z (Nissan part# 21304-JA11A) is a perfect fit replacement for a 1982 L28ET with the rare horizontal oil cooler option for manual transmissions. Quote Link to comment Share on other sites More sharing options...
