zguy95135 Posted October 19, 2003 Share Posted October 19, 2003 i took off the bumpers w/supports, no AC, coilovers, lightened flywheel, corbeau forza seats. the only thing is it has a sunroof and a rollbar. how much do you think it weighs? i would take it the scales but it doesnt run yet Quote Link to comment Share on other sites More sharing options...
Ivan280zt Posted October 21, 2003 Share Posted October 21, 2003 77 as it sits 2540 with half tank of gas in it. Ivan Quote Link to comment Share on other sites More sharing options...
fl327 Posted October 21, 2003 Share Posted October 21, 2003 I think early 75 is lightest for just this reason alone basically. My 75 (11/ 74) has no kind of door bracing in it whatsoever. Dont know how much mine weighs, but it does ride good. I always thought the Ls1 was only marginally lighter than a cast sbc because the bottom end has so much beef down there, six bolt mains, huge everything and what not??? Quote Link to comment Share on other sites More sharing options...
blueovalz Posted October 21, 2003 Share Posted October 21, 2003 Using good quality corner scales, my '71 (gutted, but add back 100 lbs for the cage) with some big wheels and tires comes in at 2321 without driver and with 10 gallons of gas (SBF and a T-5 with a lot of aluminum). Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted October 21, 2003 Share Posted October 21, 2003 My 77 280 turbo with half a tank of gas weighed in at 2780 with me in it as well (165 lbs). That was on the scales in Reynolds this past SEZS event. Crash bumpers and supports gone, no spare, no heater core, blower motor, a/c etc. I do have a heavy pair of Conquest/Starion seats though... Quote Link to comment Share on other sites More sharing options...
Michael Posted October 28, 2003 Share Posted October 28, 2003 I removed the crash beams in the doors of my '78 280Z; the car has a roll cage with X-bars, so gutting the doors to save weight felt reasonable. Grinding/cutting/chiseling the crash beams and the surrounding metal took considerable effort. When I was done, I took the pile of metal chips and shavings from both doors, put everything in a bag, and weighed the bag. Result (drumroll, please!) - 12 lbs. 12 lousy pounds, for all that work. Two lessons here, I suppose: (1) removal of metal in "non critical" spots will indeed save weight, but (2) the weight savings is very minor. Real weight savings requires a combination of aggressive cutting - and the wisdom to know where to cut! Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted October 30, 2003 Share Posted October 30, 2003 Dude... 280z bumpers dont weigh TWO HUNDRED pounds... come on... Quote Link to comment Share on other sites More sharing options...
ZR8ED Posted October 30, 2003 Share Posted October 30, 2003 Well I weighed my 1978 280z today... 2900lbs without the driver. I do recall weighing my car years ago.. 2780... but that was quite a while ago. car was stripped down a bit (min interior, creature comforts, no stereo, etc..) @2900lbs Currently with: 260 bumper with flat bar mounts (like the 240). no rear bumper. 12 point roll cage. (chromemoly steel) 14 points of additional mild/coldrolled steel bracing... some with adjustable heim joints, some welded permanent. Larger sway bars, larger lsd diff. larger tires, rims. larger brake rotors and calipers. I/C and piping/mounting brackets oil cooler and related hardware. custom driveline mounts and bracing. 1/8 steel. custom driveshaft. Custom body panels/moulding. Full stock interior. carpets and sound insulation (more deadener than stock) mild stereo system with sound enclosure box on the decking. all heater/dash controls/guages. larger dia exhaust and ss muffler. more wiring, aftermarket ign box. ground effects/bellpan, air ducting, etc.. my car has actually gained weight, but the weight is better distributed..(engine sits much lower and WAY further back) No feather weight that is for sure. I blame most of the weight on the bracing and roll cage...but then I need them...so I'll just live with it..at least I can say it is sub 3000lbs hehehehe Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted October 30, 2003 Share Posted October 30, 2003 My '78 weighs about 2620lb with 1/4 tank. I have an intercooled turbo L28, a T5, and a heavy 3" exhaust. I've stripped the A/C, the bumpers and supports, and lost the spare tire. I also run the factory ZXT wheels and fairly small tires - light where it counts, rotating and unsprung. otherwise I have all the stock stuff excepting ZX front calipers and Z31 front rotors. Quote Link to comment Share on other sites More sharing options...
dot Posted October 31, 2003 Share Posted October 31, 2003 3200# Do I win the prize for the Z lead sled? A '71 with over 800# of motor and transmission. 200+ for the Vette rear full frame and boxed sills stock interior…no cage extra insulation for the sound system Full SS exhaust with headers, resonators and a pair of fat cans with resonated tips Wire wheels added 60# over aluminium It’s going on a diet this winter. I would like to shed at least 200lbs. Cheers! :::Glenn Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted October 31, 2003 Share Posted October 31, 2003 You should lose the sound insulation. If you can't hear traffic sounds around the car with the windows up, you make yourself a traffic hazard. Too loud a radio will do the same thing. I'm talking about not being able to hear a police car or emergency vehicle approaching. You don't want to play chicken with a fire engine- pull aside and let them by. If you can't hear it coming, YOU might need emergency service. Quote Link to comment Share on other sites More sharing options...
