RB20/25/26/30 Links
Zhadman
RB links, it seems, are hard to come by.
There are several individuals on here who have installed, or are installing, RB motors in thier Z cars. I am picking up my RB25DET in January (ignore my sig) and have been scouring the internet trying to find information on parts, availability and information.
Let's pool our links and share resources!
Phase 2 Motortrend [RB25/RB26]: They cary some maintenance parts (Belts, waterpumps, head gaskets, pilot bushings and such) as well as performance parts.
http://store.yahoo.com/phase2motorsports/rb25det.html
RB25DET.org [RB25]: Specs and tech on the RB25DET. Includes a forum (but I never checked it out)
http://www.rb25det.org/
Meggala [All RB]: Specs on the various RB engines produced. Information on how to convert to an RB30. Some RB26 Performance information
http://www.meggala.com/nissanrb3css.htm
Turbo Calculator [RB20/25]: Stainless Steel Turbo Manifold for the RB20/25
http://www.turbocalculator.com/sale-headers.php#ss_rb25det
Japanese Performance Parts [New Zealand] [RB20/25]: Another Stainless Steel Turbo Manifold
http://www.japaneseperformanceparts.com/product_info.php?products_id=731
Stewart Wilikins Motorsport [Australia] [RB20/25/26/30]: Replacement Internals (bearings,rods,pistons...etc). I've E-mailed them and they can get things not on their website and they have no problems shipping to the US.
http://www.swmotorsport.com/engineprb.htm
Stony's Site [RB25(some)/RB26]: Shows off Stony's car and some of his install. [note: plugged without Sony's permission :)]
http://www.geocities.com/stonehac/
  • Replies 69
Mckinney Motorsports[RB25/RB26]: Mckinney is starting to stock more and more parts for the RB25/26. Here is a list of what they have on thier site (subject to change):
RB25DET:
Transmission
Oil Pan
Gasket set
Exhaust gasket
Water Pump
Timing Belt
Oil Pump
RB20 Rear Sump pan
MAF's (type 1 and 2)
MHG
Starter
Downpipe
RB26DETT:
Water Pump (same as RB25)
Gasket Set
Timing Belt (same as RB25)
Downpipe
Starter (same as RB25...I'm assuming)
http://mckinneymotorsports.com/sale.php
Courtesy Nissan in Texas[RB25/26]: Sells water pumps and timing belts.
http://www.courtesyparts.com/Merchant2/merchant.mvc?
This is really great, thanks!
I would like to know (maybe in another thread) where you guys sourced JDM motors - assuming you considered them a place you'd go to again. I've read about what seems like hundreds of untrustworthy resellers. Who are the good ones?
Zhadman, if you are indeed in Ontario CA, let me know when you need the help. I know of someone within an hour drive of you (Carson CA) that has this very swap already accomplished, and know of many local sources in the LA area that already have gone through the ringer on this particular conversion and can help you out!
E-Mail me and I can send you some photos of his conversion, now that they are on this laptop. He has already had his RB30 shortblock gone through, so you know where he is heading already...
Thanks for the links.
I would like to add two more:
For RB and SR engine parts from a USA located company:
http://www.jspec.com/stocksrparts.html
One of the 240SX forums has a sub forum called “Engine Swaps”. Some useful info. Good FAQ.
http://www.club240.com/forums/
I joined the RB25 swap forum group at http://www.rb25det.org/ and although they are mainly concerned with RB swaps into 240SX’s, they have a few generic posts worth reading. Very little traffic so it’s easy to keep up.
  • 3 months later...
  • 3 weeks later...
  • 1 month later...
The 200zr oil pan, oil pickup and o-ring and the mounts are all available from http://www.nismoparts.com here are the part numbers for what you need:
Oil Pan/Parts
11110-20P00 RB20DET Oil Pan (Rear Sump)
15050-20P03 RB20DET Oil Pickup
15059-V5001 RB20DET Oil Pickup O-Ring
11232-41L00 Z31 Right Hand Side Motor Mount
11233-41L00 Z31 Left Hand Side Motor Mount
11220-01L10 Motor Mount Insulators
  • 3 weeks later...
The 200zr oil pan' date=' oil pickup and o-ring and the mounts are all available from http://www.nismoparts.com here are the part numbers for what you need:
Oil Pan/Parts
SORRY, THE ARP# WAS WRONG
  • 1 month later...
I borrowed this from a RBMotoring site.... THANKS!!
Nissan - Nismo Parts
Oxygen Sensor:
22690-85E10 R32 O2 sensor ($140 each)
22690-F6600 R32 O2 sensor (82.50 retail) Infiniti
22690-48P10 R33 O2 sensor (71.58 each)
J38751-11 - 4 pin connector for O2 sensors ( maybe Kent Moore)
Nissan
24820-98U10 - 0-180 mph R33 speedo
Nismo
17042-RR580 R32 Fuel Pump assembly
17042-RR595 R33 Fuel Pump assembly
22670-RR580 Adj Fuel Pressure Regulator
15010-RRB26 Pump Assy Oil
Radiator
21010-RRB26 - Pump Assy Water - block mods required
21051-RRB26 - Pulley Water pump - aluminum - Group A
12303-RRB26- Dampener Pulley - Damper tuning
11010-RR931 - Block Assy Cylinder - RB30
10103-RR930 - Block Assy Short - RB30
11044-RR590 - Gasket Cylinder Head - 0.9 mm x 87mm
11044-RR591 - Gasket Cylinder Head - 1.2 mm x 87 mm
11044-RR592 - Gasket Cylinder Head - 1.5 mm x 87 mm
11044-RR593 - Gasket Cylinder Head - 1.8 mm x 87 mm
13212-RRB26 - Guide Valve Intake 12 pc
13213-RRB26 - Guide Valve Exhaust 12 pc
13203-RRB26 - Spring Valve Intake and Exhaust 24 pc
13201-RRB26 - Valve Intake 12 pc
13202-RRB26 - Valve Exhaust 12 pc
11200-RS580 - Motor mounts - trans mount - kit
11220-RS580 - Motor mount -
11320-RS580- Trans mount -
Clutches - Too much Japanese to understand
Transmission parts -
32201-RRR45 - 200kgmf Y65,000
32201-AA400 - 165 kgmf
32201-05U11 - 135 kgmf
3200A-RR580 - R32 6 speed trans kit
3200A-RR595 R33 6 speed trans kit
ST206-RS040 - S.S.T Nissan Y5,500
ST206-RS080 - S.S.T. SAE Y5,500
30620-RS520 Y13,000
30620-RS580 Y13,000
30620-RS540 Y13,000
Clutch cylinder
Oil coolers
Bushings and links
Floor mats
74902-RN021 - Nismo Floor mats
Steering wheels and adaptors
Shifter
Shift Knobs
32865-RN009 -carbon fiber Y7,600
32865-RN005 -engraved metal Y6,800
32865-RN008 - engraved metal w/ shift pattern Y16,000
32865-RN006 - plastic white Y4,000
32865-RN007 - plastic black Y4,000
32865-RN003 - leather(?) Y4,000
Gages
Nismo badges and stickers
Strut towers
54420-RN581 - R32 front strut tower Y27,000
54420-RS596 - R33 front strut tower Y69,800
55420-RN580 - R32 rear strut tower Y27,000
55420-RN590 - R33 rear strut tower Y27,000
Maintenance Items
Timing Belt
Gasket sets
Belts
Oil Filter
Air filter
Fluid
Glass
400R Exhaust Manifolds
14004-06U01 - Manifold - Exhaust (need 2)
14440-24U10 - Outlet - Exhaust
14440-24U00 - Outlet - Exhaust
Bosch Fuel Pump - 386
0580 254 044
1407-RA017 - HKS Part #
I saw this info and wanted to add to this. Its for the RB25 block, but I think the 26 should be the same. If not, please let it be known...
( cut & pasted as I read it)
RB25 freeze plug part# maybe 26 also?
"which plugs are you looking for? the ones in the block are 0091331301a. it's a usdm part.. nissan should be able to get them quick."
  • 2 months later...
  • 5 weeks later...
Just found this part number for Eagle forged rods for the RB26dett; >> PART # crs4780n3d
phase2motorsports_1872_4047262
Newly released by Eagle is the RB26DETT chromoly piston rods, now offer in shelf production!
Availability: Usually ships in 5-7 business days.
CRS4783N3Dtrans_1x1.gifMSRP price: $600.00trans_1x1.gifSale price: $540.00trans_1x1.gif
http://store.yahoo.com/phase2motorsports/eachrorbsk.html
j.
