Guest swivisti Posted November 11, 2009 Share Posted November 11, 2009 I accept with information: Motor is '05 GTO LS2, had 3509 miles on it. Tranny is T56 from said GTO Used JCI kit, also fan, AC kit, and drive shaft. JTR radiator, and Sanderson headers. ECU programmed by Diablo Sport and use their tuner. B&M shifter now with my own shift lever with custom knob. Just last night welded in BAD DOG frame rails. R200 clsd on the bench right now installing new R&P, bearings, and seals. Tockico adjustable shocks, and springs. Quote Link to comment Share on other sites More sharing options...
Kbhead Posted November 18, 2009 Share Posted November 18, 2009 In progress (LS2 engine swap) 1973 240z 2005 GTO LS2 (4044 miles) T56 Six speed transmission B&M Short Shifter JCI's Engine & Transmission Kit JCI's Sandersons short hugger headers R200 diff 3.9 gears with Torsen Gleason limited slip 280z Stub axles, Modern Motorsports CV adapters, CV Joints with 280z Half Shafts Front Suspension shortened 1.5", powder coated red Koni adjustable shocks 8" coil overs with 250 lb springs Toyota 4x4 calipers, 300zx vented rotors Adjustable lower control arms Adjustable Tie Rods AZ Front Camber plates 7/8" Front sway bar Rear Suspension shortened 2", powder coated red Tokico illumina 5 2ay shocks 8" coil overs with 225 lb springs Modern Motorsports disk brake adapters 240 sx rear calipers, 280 zx rotors Modern Motorsports Adjustable rear control arms 3/4" rear sway bar Wheels Enki 16x7.5" -20 offset 225x45x16 Yokohama V710 tires Replaced frame rails with 2x3" boxed steel, extended the frame rails from the front to the rear suspension. Still need to add rear camber plates, finish painting the engine bay. I have already dry fitted in the LS2 and transmission. Hope to have it on the road this summer! I love reading everyone's builds and love the creative ideas people come up with, some of thes I hope to implement on my car. I call him Frank short for Frankenstein. Quote Link to comment Share on other sites More sharing options...
280Z76LS2 Posted November 26, 2009 Share Posted November 26, 2009 hi guys can you post some pic for your setup for LS2 to: comp773@hotmail.com Quote Link to comment Share on other sites More sharing options...
zed240au Posted December 6, 2009 Share Posted December 6, 2009 (edited) Well think i can join club at last been long time coming but just did first motorsport event with car so think i can claim it 99% finished car is 71 240z engine and gearbox are from 98 commodore hsv clubsport r8 or Gto as you know them in states ls1 with t56 6 speed with 70,000 km started install in april 2005 got engine running june 2008 used jci install kit made up gearbox cross member myself say as jtr specs Used jtr radiator used jtr header on left hand side as its rhd car had to make my own right hand side header running twin 2.5" exhaust into single muffler at rear had std computers securites burnt off and tuned mafless raised rev limit to 6800 and had mild tune done on computer Had guy modify std wiring loom adding wires i needed to connect along with identifying wires for gauges Had tail shaft made up to suit fitted internal walbro fuel pump into tank Fitted r200 lsd from dr30 skyline 28 spline stud axles along with 300zx cv axles went bit crazy with arizona zcar buying there camber plates,coil over its ,lower front suspension control arms, diff moustache bar , alloy rear suspension hangers and bump steer knuckles usd modern motorsport rear control arms along with bilstein struts plus i sectioned 45 mmm from struts along jtr idea using vw rabbit struts in front and old fronts in rear ow and just love the power of the ls1 is just amazing so happy i went with the ls1 thats all i can think of now Edited December 6, 2009 by zed240au bit more to add Quote Link to comment Share on other sites More sharing options...
CCS200SX Posted March 9, 2010 Share Posted March 9, 2010 1. Year of motor/mods 2004 LS1 GTO / headers daft in..coils msd,tb big, maf vette,intake..predator.. 2. Tranny clutch RAM hd. aluminium flywheel,T56 , rear end 300zztt R230 custom shaft, 3;69.. 3. Kit used or explanation of your custom mounts. daft motor mount ,transmition cylinder clutch, line steering ...headers. 4. Any special accessories or parts needed for the swap, including fuel, wiring, etc. wiring current performance stand..filter vette..cooling system cxracing radiator.. 5. Date you started on the project, date finished 2009..2010..in progress stroker383 blower 112 magic.. 6. Other car mods (suspension, brakes, etc.) coilover megan racing, brakes 300z calipers 4 piston front 2 piston rear..disc front 13" brembo, pads hawks.. Optional: Pictures and miscellaneous info! saludos, desde Caracas Vzla. Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 8, 2010 Share Posted May 8, 2010 Please include: 1. Year of motor/mods 2. Tranny 3. Kit used or explanation of your custom mounts. 4. Any special accessories or parts needed for the swap, including fuel, wiring, etc. 5. Date you started on the project, date finished 6. Other car mods (suspension, brakes, etc.) Optional: Pictures and miscellaneous info! 83 280zx turbo 2000 ls 1 stock 6 spd. trans. i fab. all mounts . using nissan oe motor mounts got it done in 6 weekends . running and street legal last month . had to lower the front 1.5 in , lost a lot of weight , and 1 in. rear Quote Link to comment Share on other sites More sharing options...
260DET Posted July 8, 2010 Share Posted July 8, 2010 Well think i can join club at last been long time coming but just did first motorsport event with car so think i can claim it 99% finished car is 71 240z.......................................... Pics? Particularly of the right side headers/steering area. I'm looking at converting my 280ZX which would have similar problems I guess. Quote Link to comment Share on other sites More sharing options...
280-ZeD Posted October 7, 2010 Share Posted October 7, 2010 (edited) Just starting project... Just got car this weekend 78 280z "ZeD" 1 LM7 5300 v8 Turbocharged Nitrous injected 2 4L80 or 85e 3 will do all custom mounts/welding/fab in garage at home 4 Not sure yet 5 Start now-Finish never 6 4 piston calipers, ordered already- cv axles and lsd in r200 for sure- full cage will be required with 700-800hp on the bottle- 5-3/8" spoiler rear- simple chin spoiler in front- 16" rewinds and zg flares on silver paint. No bumpers cuz I dig that on these lol Edited October 7, 2010 by 280-ZeD Quote Link to comment Share on other sites More sharing options...
Ls240sx Posted December 9, 2010 Share Posted December 9, 2010 1. 91 240sx 07 Corvette LS2 360whp/390tq 2. 02 Camaro t56 3. Fab'd my own mounts 4. Nothing to special about it. pretty easy swap 5. Started some time in the summer and got it doing burnouts at the end of summer. 6. J30 Diff, HKS Hypermax coilovers. Just out of the shop: Quote Link to comment Share on other sites More sharing options...
woodboxer Posted February 19, 2011 Share Posted February 19, 2011 (edited) hey guys well I joined the team of the 350 swaps, but sorted cheated, I bought it that way, It is a 78 280z, with a 96 corvette motor (LT1) with the vette trannie, then it has a LSD rear end. Not sure on a lot of the specs as I just bought it and am having the interior professially done. It has a fuel cell installed and dual flowmaster exshast.To stop her , it has disk brakes off a 350 Z. Bought it from a fellower Zer who is going throu a divorce. When I can find more info I will post at that time. I can't wait till sumer to take her out on a run. Later bob Edited February 21, 2011 by woodboxer Quote Link to comment Share on other sites More sharing options...
woodboxer Posted February 27, 2011 Share Posted February 27, 2011 I have a question, I know its taste bud what r the thughts on the rear end colour.I Liked when it was all black and the last owner changed it to silver as the pic shows , any ideas. bob Quote Link to comment Share on other sites More sharing options...
LSXZ31 Posted June 5, 2011 Share Posted June 5, 2011 I know this is only my second post on this forum but for what its worth the replies to this topic are worthless without photos of your rides. Just sayin Quote Link to comment Share on other sites More sharing options...
drvrswntd Posted July 25, 2011 Share Posted July 25, 2011 1. Year of motor/mods 1998 Camaro Z28/SS, 38K miles, stock 2. Tranny T56 out of the same car 3. Kit used or explanation of your custom mounts. JCI mounts (motor, Trans) JCI radiator, vital fluids, speedo conversion, headers 4. Any special accessories or parts needed for the swap, including fuel, wiring, etc. Electrical: ECU/Harness out of the same donor camaro, reqired and programmed by Wait4me. Painless 7 fuse block, additional relays and two circuit breakers for switched and constant power. Fuel: -6AN stainless braided fuel lines connected to the stock 240Z gas tank with summit sump kit, prefilter, walbro 255 in-line pump and Corvette FPR - lines and plumbing with the help of Nate at Nasty Performance at LS1tech. 5. Date you started on the project, date finished Purchased starter Z in 9/09. Purchased replacement chassis June 2010. Took delivery of finished chassis 4/11, first drive 7/21/11 6. Other car mods (suspension, brakes, etc.) Brake rebuild kit, new pads, shoes, rotors. New end links for front sway bar. Rota RB-R 16x8 +10ET, 8MM spacer up front, 225/50/16 Dunlop Direzza D-Spec tires. Optional: Pictures and miscellaneous info! Please include: 1. Year of motor/mods 2. Tranny 3. Kit used or explanation of your custom mounts. 4. Any special accessories or parts needed for the swap, including fuel, wiring, etc. 5. Date you started on the project, date finished 6. Other car mods (suspension, brakes, etc.) Optional: Pictures and miscellaneous info! Up next (in no order): Suspension (all new bushings, Tokico spring/strut combo) custom exhaust finish interior urethane type 1 air dam refresh bumpers Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted July 25, 2011 Share Posted July 25, 2011 Would you consider doing a thread on the sump pump set up you did (with pictures and everything)? Modifying my 240z for fuel injection has been a major headache. Quote Link to comment Share on other sites More sharing options...
drvrswntd Posted July 26, 2011 Share Posted July 26, 2011 Would you consider doing a thread on the sump pump set up you did (with pictures and everything)? Modifying my 240z for fuel injection has been a major headache. in my build thread per your request: http://forums.hybridz.org/index.php/topic/100144-1973-s30-1973-s30-1998-z28ss-the-over-my-head-project/page__view__findpost__p__949587 Quote Link to comment Share on other sites More sharing options...
Dans toy Posted December 2, 2011 Share Posted December 2, 2011 1. 74 260z 6.0L LQ4, 112 Magnuson supercharger. 2. 4L80E trany w/Lokar floor shift 3. Homemade engine/trans mounts/ 9 3/4 ford sterling rearend / Competition Engineering 4 link & adjustable coilovers / full frame 2x3 boxed steel & 4 point roll bar. Original rear inner fenders sectioned & filled to allow for a 275+ series tire. 4. Summit 12 gallon poly fuel cell / all stainless braided lines / 2005 silverado pcm & engine management wiring harness(reworked). 5. started early 2010 / On going as of 12/01/11 miscellaneous finishing & changes. Plenty drivable. 6. Firewall sectioned & moved back 3 3/4" to allow engine to set back further / Custom steel cowl hood made from 2 stock hoods to accommodate supercharger / Summit pro pack aluminum radiator, shroud & electric fan / Sanderson 1 3/4 shorty headers / 2 1/2" dual exhaust with magnaflow mufflers / battery relocated to back of car / full insulation & interior. Quote Link to comment Share on other sites More sharing options...
sq_creations Posted December 5, 2011 Share Posted December 5, 2011 I'd love to see some photos of your monster Dan. Quote Link to comment Share on other sites More sharing options...
mxgsfmdpx Posted December 6, 2011 Share Posted December 6, 2011 hey guys well I joined the team of the 350 swaps, but sorted cheated, I bought it that way, It is a 78 280z, with a 96 corvette motor (LT1) with the vette trannie, then it has a LSD rear end. Not sure on a lot of the specs as I just bought it and am having the interior professially done. It has a fuel cell installed and dual flowmaster exshast.To stop her , it has disk brakes off a 350 Z. Bought it from a fellower Zer who is going throu a divorce. When I can find more info I will post at that time. I can't wait till sumer to take her out on a run. Later bob This is Darius's old Z isn't it? Quote Link to comment Share on other sites More sharing options...
Dans toy Posted December 7, 2011 Share Posted December 7, 2011 'sq creations' There's a few in Gallery . I haven't mastered the picture thing with my IMac. I'll get with my daughter soon and post some of my build. Quote Link to comment Share on other sites More sharing options...
Fuzzydicerule Posted May 4, 2012 Share Posted May 4, 2012 1. Year of motor/mods: 1999 Firebird LS1. Currently going to be bone stock with the exception of longtubes and some Trick Flow fuel rails. FAST EFI and FAST XFI. I MAY turbo it but im not sure 2. Tranny: T56 Out of the afformentioned firebird 3. Kit used or explanation of your custom mounts: Unsure of the direction ill be going. I will probably make custom mounts 4. Any special accessories or parts needed for the swap, including fuel, wiring, etc: single High mount alternator accessory system. Car has a fuel Cell and a walboro 255LPH fuel pump already. 5. Date you started on the project, date finished: Date started= i guess technically 5/2/2012, obviously its not finished as the LS1 is currently in my Van... 6. Other car mods (suspension, brakes, etc.) Cut Tokico lowering springs, toyota 4x4 Front brakes, S13 rear brakes, Tilton Floor mount Pedal set with 7/10 Masters, Summit Fuel Cell with a walboro 255 Pump. I am just now starting this project, but im aiming to get it done very quickly. Quote Link to comment Share on other sites More sharing options...
