Toysport Posted October 20, 2004 Share Posted October 20, 2004 Hey guys, I'd like to know what brake set ups you all have in your Z? If you have a conversion...what m/c and brackets. Your inputs will be greatly appreciated. Front: Rotors Calipers Rear: Rotors Calipers Quote Link to comment Share on other sites More sharing options...
zcarnut Posted October 20, 2004 Share Posted October 20, 2004 OK. I’ll go first. (Car is a 1974 260Z) Front Rotors: 1984 Z31 front vented Calipers: 1990 Toyota 4x4 SW12 Misc: Using 240 hubs with custom spacer to mount rotor Rear Rotors: 1984 Z31 rear solid Calipers: 1983 200SX Bracket: 1983 Maxima Master Cylinder Nissan Hardbody Truck 1" diameter Booster: 1983 280ZX Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted October 20, 2004 Share Posted October 20, 2004 The Hulk Front: JSK Hats & Mounts, Custom made Wilwood S.S. Brake lines with fittings, Wilwood Superlite NDL Bullit Calipers, Wilwood 12.3inch vented rotors, Wilwood Racing Pads. Rear: Modern-Motorsports Caliper Mounts, Modern-Motorsports E-brake Bracket, Silvia S14 Rear Calipers, KVR Carbon Fiber Brake pads, Goodridge S.S. Brake lines, 300zx Z31 Rear rotors. (going with the JSK/Wilwood Rear package soon, and putting this setup i have on the Blue Z) 280zx Master Cylinder Ole Blue Z Brakes.... what brakes? just new nissan motorsports pads and shoes.. thats it. mike Quote Link to comment Share on other sites More sharing options...
datsunlover Posted October 21, 2004 Share Posted October 21, 2004 Not on yet, (will be instaling this winter) but fwiw; Toyota calipers, 300zx rotors+spacer up front, 280zx M/C, and stock (for now) drums in the rear. Quote Link to comment Share on other sites More sharing options...
auxilary Posted October 21, 2004 Share Posted October 21, 2004 15/16mc, toyota vented 4x4 swap up front, ross 240sx in the rear, removed stock prop. valves. T line to the front, wilwood valve for rear bias adjustment Quote Link to comment Share on other sites More sharing options...
Trevor Posted October 21, 2004 Share Posted October 21, 2004 Front: 5-lug hubs, spacer plate, vented 300ZX rotors, RX-7 4-piston aluminum calipers. Rear: 5-lug (re-drilled stubs), vented MX-6 (front) rotors, RX-7 1-piston aluminum calipers. MC - any suggestions? Quote Link to comment Share on other sites More sharing options...
innerware Posted October 21, 2004 Share Posted October 21, 2004 Just received the set up from Ross at modern motorsport yesterday. So in a couple of weeks I will have the Toyota 4x4 set up in front. I am just rebuilding the drums in the rear for now. I still am an inliner so that will suffice for a while. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted October 21, 2004 Share Posted October 21, 2004 Booster: 1983 280ZX How'd you get that to fit in an early Z? I'd be interested in hearing what everyone's opinions are on their current setup as well. Front Rotors: 73 Stock Calipers: 73 Stock Misc: Semi-metallic brake pads Rear Rotors: None Calipers: None Bracket: Stock Backing Plates, drums, organic shoes Master Cylinder Stock 7/8" bore Booster: Stock Brake feel is overall decent. Pedal is firm. Good modulation. Brakes tend to heat up quickly in autocross/mountain driving, but with fresh high temp fluid, fade hasn't ever been a huge issue. Stops from 100mph+ are pretty poor. Braking with R-compound rubber could be stronger overall, but I'm probably still not braking to the stock brakes full potential. The drums are a pain in the butt, requiring constant adjustment... and the bias changes with adjustment. That's the biggest reason I am upgrading. Quote Link to comment Share on other sites More sharing options...
Clifton Posted October 21, 2004 Share Posted October 21, 2004 71' older AzZcar 4 lug kit, 15/16 MC 73' AzZcar current 5 lug kit, 15/16 MC I did run the 79-85 Toyota calipers before this with the stock MC. Pedal pressure was perfect. Quote Link to comment Share on other sites More sharing options...
Guest AlsoRanFPrepared Posted October 22, 2004 Share Posted October 22, 2004 Front: Wilwood 11.75" straight vane rotors Wilwood Dynalite forged calipers 2 piston 1.75" bore Hawk HP+ pads Custom hats to fit 240Z hubs Rear: Custom 9" rear rotors on stub axle hats (inboard) SRP (similar to dynalite single only forged) 1.38" pistons Hawk HPS pads Master Cyl: Front Tilton 7/8" Rear Tilton 13/16" Wilwood pedals with adjuster bar. Definitely not for street use... Quote Link to comment Share on other sites More sharing options...
zcarnut Posted October 22, 2004 Share Posted October 22, 2004 zcarnut wrote: Booster: 1983 280ZX How'd you get that to fit in an early Z? It was easy! Actually my 260Z shares the larger bolt pattern for the brake booster with the 280Z and the 280ZX. So the ZX booster just bolts in. Although you have to turn it upside down which does not affect its operation. Quote Link to comment Share on other sites More sharing options...
Toysport Posted October 28, 2004 Author Share Posted October 28, 2004 Sounds like a good convertion, less expensive. Problem is the custom spacer.....what is the size of that spacer...maybe I can have someone make it for me. Last but not least.....were you able to retain your e-brake? Thanks a lot. John OK. I’ll go first.(Car is a 1974 260Z) Front Rotors: 1984 Z31 front vented Calipers: 1990 Toyota 4x4 Misc: Using 240 hubs with custom spacer to mount rotor Rear Rotors: 1984 Z31 rear solid Calipers: 1983 200SX Bracket: 1983 Maxima Master Cylinder Nissan Hardbody Truck 1" diameter Booster: 1983 280ZX Quote Link to comment Share on other sites More sharing options...
zcarnut Posted October 30, 2004 Share Posted October 30, 2004 Sounds like a good convertion, less expensive. Problem is the custom spacer.....what is the size of that spacer...maybe I can have someone make it for me. Here’s the spacer I used. It features a lip that centers the rotor. This makes it more difficult to make but all the other spacers I have seen just use the mounting bolts for rotor centering which is not good engineering practice: http://home.comcast.net/~zcarfan/Spacer.jpg Last but not least.....were you able to retain your e-brake? Yes. In fact that was the reason for using the 200SX calipers. The angle of the parking brake cable after attachment to the caliper is much better suited to the early Z cars than any other rear caliper, 280ZX and 240SX ones include. The 200SX brake pads are the same as used by the 280ZX rear caliper. Just be sure to use only the 1982 or 1983 rear 200SX caliper. Other years will not work. This will mount to the later 1982-83 Maxima (the one everyone is looking for) rear brake caliper bracket. Quote Link to comment Share on other sites More sharing options...
Toysport Posted November 1, 2004 Author Share Posted November 1, 2004 thanks steve. did you use the same spacer for the front? john Quote Link to comment Share on other sites More sharing options...
hanomon Posted November 1, 2004 Share Posted November 1, 2004 Arizona Z car's 13" fronts wilwood pistons/pads. rear rotors, again Az Zs between wilwood Tilton 7/8" m/c The guy's name is Dave. He has been playing with these Z cars for over 20yrs. I was impressed with his knowlege and service. Quote Link to comment Share on other sites More sharing options...
Toysport Posted November 1, 2004 Author Share Posted November 1, 2004 I believe Arizona discontinued making the spacers. Quote Link to comment Share on other sites More sharing options...
Toysport Posted December 1, 2004 Author Share Posted December 1, 2004 anyone using 240sx rear calipers w/ 300zx rotors? Quote Link to comment Share on other sites More sharing options...
zemus Posted December 1, 2004 Share Posted December 1, 2004 Front:5-lug hubs' date=' spacer plate, vented 300ZX rotors, RX-7 4-piston aluminum calipers. Rear: 5-lug (re-drilled stubs), vented MX-6 (front) rotors, RX-7 1-piston aluminum calipers. MC - any suggestions?[/quote'] Very interesting, never heard of anyone doing this yet, are these FC 4pots or FD 4pots? Did you make the brakets custom? Let me know Quote Link to comment Share on other sites More sharing options...
231Z Posted December 2, 2004 Share Posted December 2, 2004 Stop Tech Quote Link to comment Share on other sites More sharing options...
Mikelly Posted December 3, 2004 Share Posted December 3, 2004 http://www.thelapd.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=thelapd&Category_Code=bpksgs The rear brake kit in this link are the brakes I just installed on the rear of my vette. I'm going to run stock 13inch front and 12inch rotors and calipers on the Z... When we sort that out, Ill then be able to run the Baer brakes as well... In the pics you can see the Z06 brake ducts...Just got those off a recked Z06 as well and I hope to have those in as well. Mike Quote Link to comment Share on other sites More sharing options...
