HarrisonTX Posted September 23, 2005 Share Posted September 23, 2005 Hey guys, i plan on replacin my r180 for an r200. I have searched, and failed where can i find some gear for an r200? i want something lower than 4.11 (t56, motor that dosnt like to run at anything below 2k) any linkS? Quote Link to comment Share on other sites More sharing options...
evildky Posted September 23, 2005 Share Posted September 23, 2005 well then your in luck, pretty much every Nissan/Datsun product running the r200 ran a lower ration than a 4.11:1 most Z's from 75?-89 ran the long snout R200, with 3.54 being the most common ratio and 3.7 being a bit more rare but quite popular, search around you'll find all sorts of applications and ratio's Quote Link to comment Share on other sites More sharing options...
Guest iskone Posted September 23, 2005 Share Posted September 23, 2005 So nobody reading is confused "lower" refers a numerically higher number. Isk Quote Link to comment Share on other sites More sharing options...
Leith280zlt1 Posted September 23, 2005 Share Posted September 23, 2005 Well, the only thing I know of that is higher is the r180 out of a datsun pickup 4x4. It was a 4.37. I have never seen a taller gear ratio in a r200 yet and if there was one I would probably have it. The tallest that came stock is the 4.11. Sorry. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted September 23, 2005 Share Posted September 23, 2005 the 4.11 is from an 85-86 200sx turbo i believe, just adding.could a 4.33 be made by matching the ring from a 3.9 (has 39 teeth) tot he pinion of the 4.11 (9 tooth). Or did i just commit the biggest sin in my mind (mixing ring and pinion sets) Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 23, 2005 Share Posted September 23, 2005 the 4.11 is from an 85-86 200sx turbo i believe, just adding.could a 4.33 be made by matching the ring from a 3.9 (has 39 teeth) tot he pinion of the 4.11 (9 tooth). Or did i just commit the biggest sin in my mind (mixing ring and pinion sets) That is indeed the biggest sin. if there were a 4.33 from the factory that would be great, but there is not (to my knowledge anyway) and the 9 tooth pinion would have would not mesh properly with a 39 tooth ring gear, resulting in the quick and total destruction of both gears. Nissan did make 4.44's and I believe some shorter gears like 5.17. Nissan Comp can tell you what is available. Mixing rings and pinions is not a good idea. Quote Link to comment Share on other sites More sharing options...
wpnmkr Posted September 23, 2005 Share Posted September 23, 2005 Or did i just commit the biggest sin in my mind Only if your catholic! HAHAHAHA! Quote Link to comment Share on other sites More sharing options...
zguitar71 Posted September 23, 2005 Share Posted September 23, 2005 R-200 with a 4:375 from a Skyline (r33 I think). I have one with a LSD in my garage right now. It needs to be set up (gear whine), then it goes into a race car. I ran it on the street for a while but the gearing is just too low. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted September 23, 2005 Share Posted September 23, 2005 Why not look to subaru? Or do they not make an r200 only r180's and 160's huh. How hard would it be to get a say ford 8 inch and then from there simply redrill the bolt holes. Well other then the whole pinion won't work out thing. Well i just answered that one..... Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted October 3, 2005 Share Posted October 3, 2005 Here you go...NOS 4.375 R200 gears http://cgi.ebay.com/ebaymotors/R200-4-375-Gear-Pinion-NOS-Datsun-240z-280z-280zx-510_W0QQcmdZViewItemQQcategoryZ33731QQitemZ8004607148QQrdZ1 Quote Link to comment Share on other sites More sharing options...
blueovalz Posted October 3, 2005 Share Posted October 3, 2005 Just an opinion - My solid roller SBF is geared at 4:11 and it doesn't begin a good pull until the 3500-4000 range. But with the light weight of the Z, I have no problem with the lack of low-rpm torque even at 2K. Highway RPM with a road-track geared 5-speed transmission (5th gear is .80) is 3K at 70 MPH. I wouldn't want it to be geared any lower. Quote Link to comment Share on other sites More sharing options...
Phantom Posted October 4, 2005 Share Posted October 4, 2005 I hope that motor revs pretty high because 1st gear will be nearly useless with the high numerical rear ends. My LS1 (6,000 rpm redline) with the T56 is at the limit with 3.70 in the rear. Quote Link to comment Share on other sites More sharing options...
Guest PROJECTRB240SX Posted October 4, 2005 Share Posted October 4, 2005 Too Bad Those 4.375 Gears Are So Expensive.... Thats Half What I Paid For My Lsd With Install And Shipping. Anyway, The R33 Skyline Gts-t Have A 4.36 Ratio Rear But They Are Short Nose R200's.... But They Are Mechanical Lsd's Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted October 4, 2005 Share Posted October 4, 2005 Remember, that is a new ring and pinion set. It's still half of what a new ring and pinion for an R200 is from Nissan... This is the first time I have even seen a set of 4.375 gears for an r200. Of course I would not have a use for them anyway, but perhaps on a short autocross course with an na car... Quote Link to comment Share on other sites More sharing options...
DaEvil Posted October 5, 2005 Share Posted October 5, 2005 I just saw on ebay a ring and pinion set for a r200 it was 430 something I'll try and find the link Quote Link to comment Share on other sites More sharing options...
DaEvil Posted October 5, 2005 Share Posted October 5, 2005 Hey here is the link http://cgi.ebay.com/ebaymotors/R200-4-375-Gear-Pinion-NOS-Datsun-240z-280z-280zx-510_W0QQitemZ8004607148QQcategoryZ33731QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted October 5, 2005 Share Posted October 5, 2005 Yes, see the link 7 posts up... Quote Link to comment Share on other sites More sharing options...
doublexl240z Posted November 24, 2006 Share Posted November 24, 2006 I just pulled the diff out of my future race car(SCCA prod) and low and behold an R200 with a 4.375 gearset, ran great around the neighborhood, no whining!!! It is welded though. Problem is that I can't/don't want to run anR200. So, my dilema is that I need an R180 with either 4.11 or 4.375 gears in it. I wonder if someone out there might need an r200 and would be willing to swap? Quote Link to comment Share on other sites More sharing options...
