Z-Monster Posted December 15, 2005 Author Share Posted December 15, 2005 can yall not view the pix??? if not then go to my gallery i have uploaded all the pix there. Quote Link to comment Share on other sites More sharing options...
Z-Monster Posted December 15, 2005 Author Share Posted December 15, 2005 here is a hyper link to my gallery... go past the car pictures and th diffs are next. http://album.hybridz.org/showgallery.php?cat=500&ppuser=14097 Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted December 15, 2005 Share Posted December 15, 2005 R32 GTR is a 5-speed from the factory....however, I know Hollinger and OS GIken both make a 6-speed for the 32. I also know that the R34 transmission externally isn't much different than the R32. The shaft to the front diff is a tad bit longer on the R34 6-speed and the clutch assembly is a push vice pull....I believe. Sean at RBMotoring has done this relatively easy conversion on an R32....he can give you the goods on how to do it..... Quote stony... in regards to the r32 gtr with rb26dett... we do get lots and lots of crashed track/drift/highly modded personal cars from japan' date=' so i cannot confirm if it naturally comes with a factory 6 speed or the half cuts have been modded like all labors of love should be... anyhow, i have spotted a number of them with 6 speed attessa's as well as 5 speed's... no concrete confirmation plus i'm not as studied on the matter as most of you here are. cheers... enjoy the pics and feedback in more then welcome. its all here. http://album.hybridz.org/showgallery.php?cat=500&ppuser=14097 Quote Link to comment Share on other sites More sharing options...
AdrianZ Posted December 15, 2005 Share Posted December 15, 2005 Quote here is a hyper link to my gallery... go past the car pictures and th diffs are next. http://album.hybridz.org/showgallery.php?cat=500&ppuser=14097 that's a lot of sexy diffs. alright i guess my only question is what does it take to get this into my Z? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted December 16, 2005 Share Posted December 16, 2005 Quote R32 GTR is a 5-speed from the factory....however' date=' I know Hollinger and OS GIken both make a 6-speed for the 32. I also know that the R34 transmission externally isn't much different than the R32. The shaft to the front diff is a tad bit longer on the R34 6-speed and the clutch assembly is a push vice pull....I believe.Sean at RBMotoring has done this relatively easy conversion on an R32....he can give you the goods on how to do it.....[/quote'] There is a 6 spd kit for the GT-R 5 spd box. Here are the part #'s... 3200A-RR580 - R32 6 speed trans kit 3200A-RR595 R33 6 speed trans kit Quote Link to comment Share on other sites More sharing options...
Z-Monster Posted December 16, 2005 Author Share Posted December 16, 2005 what model z do you have??? if its a 280zx 2+2 then it bolts on except for the input shafts.. as you can see i had to machine the input shafts so that it would match my cv joints... thats why i took a picture of the diff under my car.. after installation... you will have to take the cv joints which comes with the diff and chop it off wherever you need the connection to be made to bolt up with your driveshaft/cv. if you have a 240-280z then you will need a diff cover which has the horizontal mounting screws to bolt onto your mustach bar..... i will replace or get you a diff that fits.. dont worry just tell me or take a pic of your current diff and i will get you the right thing. but the shipping cost is yet to be confirmed... so all of this might be for nothing anyway... sad but true. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 16, 2005 Share Posted December 16, 2005 Z-Monster said: if you have a 240-280z then you will need a diff cover which has the horizontal mounting screws to bolt onto your mustach bar..... i will replace or get you a diff that fits.. dont worry just tell me or take a pic of your current diff and i will get you the right thing. If you are sure it will match up with the 240z-280z u-joint half shafts I would be very intrested in getting one. Can you check shipping to Oakland, CA 94618? Thanks! Quote Link to comment Share on other sites More sharing options...
Z-Monster Posted December 16, 2005 Author Share Posted December 16, 2005 I Am Very Very Sure It Will Not Link Up To The Half Shafts Quote Link to comment Share on other sites More sharing options...
stony Posted December 16, 2005 Share Posted December 16, 2005 For the record those long nose r200s are bolt in and all you need are the stub shafts that go in the r-200 with the halfshafts. (78 280Z with the r-200 stock) just chuck the CV axles and plug in the haftshafts and your good. But shipping on a r-200 (85LBS) from overseas is gonna be killer.. If you could get a crate of say 15 -20 at 100-150 bux a peice together someone could sell the ones they dont need and make some money out of it. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 16, 2005 Share Posted December 16, 2005 Im lost stony is saying they will bolt in with the u-joint halves and z-monster says they won't? Z-monster what 1/2 shaft do you use w/o modification, the ZX shafts with cv's? Quote Link to comment Share on other sites More sharing options...
stony Posted December 16, 2005 Share Posted December 16, 2005 You pull the CV axles out of the diff then get the stubs that go into the diff that bolt up to the halfshafts. they are the same spline count and work great you just need to make sure you get them on the right side. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 17, 2005 Share Posted December 17, 2005 stony said: You pull the CV axles out of the diff then get the stubs that go into the diff that bolt up to the halfshafts. they are the same spline count and work great you just need to make sure you get them on the right side. But then how do I bolt the CV shaft to the 240z/280z companion flange, or can I use a different companion flange in the 240z rear strut tubes? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted December 17, 2005 Share Posted December 17, 2005 rudypoochris said: But then how do I bolt the CV shaft to the 240z/280z companion flange, or can I use a different companion flange in the 240z rear strut tubes? Here are 1 pair of what I belive are 84 to 89 stock z car CV's and a pair of custom CV's I had made up using the 88ss VLSD diff stubs, and 81-83 turbo z car outboard wheel side CV portion, as described by James Thagard with his part #'s. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted December 17, 2005 Share Posted December 17, 2005 Quote Are those welded together in the center? Or did they just swap around parts to make what you needed? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted December 17, 2005 Share Posted December 17, 2005 Cody 82 ZXT said: Are those welded together in the center? Or did they just swap around parts to make what you needed? Cody, those are "AMC" oem shafts if I remember James parts list correctly. I would have snapped welded shafts pretty easy I think.... Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 17, 2005 Share Posted December 17, 2005 In reference to an 87-89 300zxt CLSD now, those stock 84-89 cv's look like they would bolt right up to a 280z companion flange with the four bolt pattern, is the issue on the diff side with the splines then? Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted December 17, 2005 Share Posted December 17, 2005 J. Soileau RB26zcar said: Cody, those are "AMC" oem shafts if I remember James parts list correctly. I would have snapped welded shafts pretty easy I think.... I thought welded shafts would be a proublem but, the ridge in the middle of the shafts made me wonder? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 17, 2005 Share Posted December 17, 2005 rudypoochris said: In reference to an 87-89 300zxt CLSD now, those stock 84-89 cv's look like they would bolt right up to a 280z companion flange with the four bolt pattern, is the issue on the diff side with the splines then? The 300ZX came with two different shafts. The NA 300ZX came with a outboard end with a 6 bolt pattern. THE NA SHAFTS ARE TOO LONG AND WON'T WORK IN AN S30. This is why Ross doesn't make an adapter for them. The TURBO came with the 4 bolt outer end, and it is the only one you can use. It does require an adapter, because the bolt pattern is totally different than the stock halfshaft bolt pattern. Quote Link to comment Share on other sites More sharing options...
t-tom Posted December 18, 2005 Share Posted December 18, 2005 Man I love this Web Site!!! Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted December 18, 2005 Share Posted December 18, 2005 Quote The 300ZX came with two different shafts. The NA 300ZX came with a outboard end with a 6 bolt pattern. THE NA SHAFTS ARE TOO LONG AND WON'T WORK IN AN S30. This is why Ross doesn't make an adapter for them. The TURBO came with the 4 bolt outer end' date=' and it is the only one you can use. It does require an adapter, because the bolt pattern is totally different than the stock halfshaft bolt pattern.[/quote'] Thought the stock pattern was 4 bolt also... oh wait it is rectangular or something silly isn't it? Can a 300zx turbo companion flange attach to a 280z stub axle or is there spline count issues there. Quote Link to comment Share on other sites More sharing options...
