for all of you s130 (280zx) guys
rwdawg2
i didn't know whether to put this post in here or not so please forgive me if i am doing wrong.
thanks
i was just wondering who is doing what to there s130.
what type of motor are you doing/ what types of body mods/ you know just to get up a friendly post. this way every one just talks to one another w/out any kind of mean post.
any way just to start things off
i am just starting an s130 N/a block to Turbo swap with some heavy suspension mods.
o yeah if any of you guys have any help or know how on what i should do with this swap please let me know.
thanks alot guys and i look foward to hearing from alot of you other guys
I'm planning on urethane suspension, light build of the L28 (I have an '82 non-turbo), silver paint with a black center stripe and trim, and mild body kit/blending to make the bumpers stand out less.
I will probably do something to the taillight area, but I haven't decided yet.
This car will be less radical than my S30, because I want it to be a decent daily driver, good mileage, "take the t-tops out and go on a date" sort of car.
It also might turn out to be a birthday present to my dad...no one tell. :P
Ben
I have an '83ZXT...the list of mods are:
1) Walbro 255lp/h fuel pump (running stock injectors)
2) JSK Billet Fuel Rail polished
3) Aeromotive Boost sensitive FPR
4) HKS SSQ BOV
5) Isuzu NPR IC
6) All mandrel 2.25/2.5" IC piping
7) 60mm KA24 Throttle Body
Full mandrel 3" exhaust, no cat, no emissions crap
9) Lightened OE flywheel to 17lbs
10) Duel 10" electric fans
11) Removed AC
Boost set at 10psi
My car is pretty damn quick....and I figure hp to be in the 225hp-235hp range - conservatively.
Soon to come....
1) Megasquirt EFI
2) 15psi
3) Custom exhaust manifold
4) Heavily reworked intake manifold
5) T3T4 turbo
6) Fully ported and polished head with no sure which cam to use....
Looking for 300+whp
Suspension:
1) Custom made at home coilovers frotn and rear
2) Suspension Techniques sway bars front and rear
3) Poly urethane bushings front and rear
4) All new tie rods ends (inner, outer), ball joints AND steering rack!
5) Corbeau A4 Seats
Autometer Gauges for boost, oil temp and oil pressure
17" Wheels
pics:
http://www.picturetrail.com/slownrusty
Yasin
i have an 82 280zx with a bunch of body junk on it that some people call a body kit. haha.
She has 16" wheels. with 245/45 tires, Ground Control 7 way adjustables in the rear, and a turbo xs blow off valve. I'm eventually going to use a VR4 intercooler and using a 3 in straight pipe exhaust. also neon lights asap. :]
where are all of you guys getting your coilovers and for how much.
if it isn't that hard to build i would like a little insight on that.
thanks guys and everyones s130 sounds awsome
i just get sick and tired of hearing about everyones crazy S30 and how you can do this and do that while i am in the corner wondering how the hell am i suppose to work on my s130 when all everyone ever talks about is an s30.
it seems to me there needs to be an s130 section so that way no one will be confused on what car you can do what on.
but that is just my opinion.
anyways thanks and look forward to hearing from some other guys.
The boost controller on my car is a grainger style manual boost controller that only set me back about $40. I couldn't justify the extra cost of an Electronic one, but they do have their benefits.
As far as the Coilovers go I know Modern Moterspports sells them for the rear(not sure about the front) But if you call Techno Toy Tuning they can make you some, but coilovers are going to be expensive, a good amount over $1,000. I am about to order all my suspension stuff, Cusco strut bars, Sway bars and because money is tight I will probably end up going with Tockico springs and shocks(only $350 shipped).
My personal opinion is that if we had a S130 section it would be dead, maybe it would work though?? Zdriver.com has a pretty could 280zx forum but there really isn't too much tech talk over there, but it is still a real good site. And besides the S130 and S30's have a lot of similairities.
Rob
Ok not sure about listing every mod But, here are most of them
1. t4/t3 clipped turbine wheel
2. Ported stock exhaust manifold
3. 3" downpipe and 3" manderal bent all the way back
4. Weber throttle body with manifold ported to match
5. HKS intercooler kit (I may sell this and do something larger soon)
6. JWT computer and maf good for about 15 psi on the street and 20 on
race gas
7. 420 cc injectors
8. High flow high volume fuel pump
9. Magnecore wires
10. Basic engine rebuild with some extra support from ARP studs
11. Lightened stock flywheel
12. High pressure clutch
13. Profec B
14. JSK Wilwood adapter kit
15. Wilwood superlite with Porterfield RS4 pads
16. Custom mount rear kit, Uses stock rear caliper and 300ZX rotor 11.5"
17. Front and rear camber kits
18. 17" rims with Yokahoma AVS 235/45/17 front and 245/40/17 in the rear
19. Corbeau seats
20. Autometer gauges boost, oil temp, oil pres, EGT
21. Pro 5.0 shifter
22. MSA body kit that needs to be replaced body work starting soon
23. Braided stell brake lines
24. MSA lowering springs
25. Tockico "blues" shocks and struts
I lost almost all the pics of the car when it looked good. Hit my website, it has some more stuff on it.
i have a 1981 5 speed
have done the following:
-full repray
-RB20DET conversion
-3" stainless dump and 3" stainless straight through
-FMIC
-Haltech E11 ECU
-Heavy Duty clutch
expecting around 220rwhp
unmodified chassis, skyline mounts.
am in the process of:
-bigger turbo (Garrett)
-GTR or Tomei injectors
-brake upgrade (any hints?)
-full overhaul of suspension
thats about it i think
Here are a couple of sites where the S130 has been worked over a bit http://www.datsun-280zx-lt1.com/ http://www.angelfire.com/extreme/280zxt/
Have been trying to get a S130 two seater for about six months, not easy when Nissan AU never brought any in. Got a few serious mods planned too, including five stud 16 x 10" wheels all round, so its quite frustrating.
Here's a link to a page on my car.
http://www2.nissanofwichita.com:8080/website/NissanOfTheMonth.htm
There have been some changes since this article (or you can check out my car in Sport Z Magazine in the fall 2005 issue. The biggest changes to the car were an upgraded cam and springs, along with some head porting and one of my companies intake manifolds. I only made 3 passes or so at the track before I burned up a sprakplug wire. All 3 were on street tires and the first 2 I was onl low boost. The 3rd run I went12.08@125 (bogged it off the line horribly).
Well i seem to go backwards more at the moment then forward with my project, so hopefully i can make some good progress this year, below are some of what i have done so far, well more like what i have brought as the car is still basically a bare shell.
Willwood front brakes with 12.75" rotors,
Koni fully adjustable coil overs all round,
urathane bushes for everywhere,
Racetech 4000 race seats,
Trust/greddy egt, boost and temp gauges,
Trust/greddy 100mm thick intercooler,
Trust/greddy type R B.O.V,
Trust/greddy type R waste gate,
Trust/greddy stainless manifold,
Garrett GT3540 turbo.
This year i have to get the body work done and get it rolling on some new wheels, so maybe that could be my new years resolution. haha
