Guest TeamNissan Posted May 29, 2007 Share Posted May 29, 2007 You know i was with you on thinking someone has tried it but I have used 4 search engines to look for even a hint or word on the topic and i cant find jack s@#t so I'm actualy inclined to believe this is new ground. On the other hand though none of the big wigs with thier insain wealth of info and experience have chimed in either so Idk. Quote Link to comment Share on other sites More sharing options...
Shuyun Posted May 29, 2007 Share Posted May 29, 2007 I have found that the Journals for the H30 crank are:Main 2.4780-2.4785 in. Rod 2.0457-2.0462 in. or Main 63mm Rod 52mm form http://www.motorpowerinc.com/specs/h30.html Quote Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted May 29, 2007 Share Posted May 29, 2007 VERY nice pull on that Shuyun Quote Link to comment Share on other sites More sharing options...
Chewievette Posted May 29, 2007 Share Posted May 29, 2007 While its good that you found that info and I'm totally thrilled btw, its not all good. The bore and stroke are conflicting with the original info. That link lists 87mm bore and 83mm stroke making 2.9605 Liters. However going back to the original specs, 83mm bore and 100mm stroke makes 3.246 Liters. An engine that would NOT be called H30, it would be H32 or H33. So which engine does have this mythical 100mm stroke? The SD33, which has the same specs as were given as the original H30 specs. So theres a problem solved right, WRONG. looking at the motorpowerinc specs, the SD33 has a 1-4-2-6-3-5 Firing order while the L series uses 1-5-3-6-2-4. So where does that leave us? The H30 DOESNT have a 100mm stroke. The SD33 DOES have a 100mm stroke BUT is has the Wrong firing order. So basically your only hope now is that the crank and cam from the SD33 fit the L series. which is unfortunately unlikely. I hate to say it, but we are doomed to have a 3.2L cap on our engines. Quote Link to comment Share on other sites More sharing options...
Shuyun Posted May 29, 2007 Share Posted May 29, 2007 Here are some specks on the H15, H20, and the H25 the 4cyl OHV Versons of the H Series. http://www.enginepowersource.com/html/nissan_h15ps.htm http://www.enginepowersource.com/html/nissan_h20ps.htm http://www.enginepowersource.com/html/nissan_h25ps.htm I have talked to some Remanufactures and there are different stroke cranks for the H30. I am trying to get some more Numbers. Not the H30 but a 6 cly http://www.enginepowersource.com/html/nissan_tb42.htm Quote Link to comment Share on other sites More sharing options...
Chewievette Posted May 29, 2007 Share Posted May 29, 2007 I'm starting to grow tired of information that doesnt match up. Even simple research on the L series is frustrating! I'm getting rod bearing diameters of either 50mm or 53mm, both from sources that I consider reliable. Its just aggrevating thats all. Heres some more info gained from that site.. P40 Bore-85.7mm Stroke-114.3mm!!!! Main-69.3mm Rod-57.15mm PPU Bore-85.7mm Stroke-114.3mm Main-68.23mm Rod-57.15mm TB42 Bore-96mm Stroke-96mm I need more info on these engines. Especially if the TB42 is OHC because that would be killer to use for a block, stock bore is massive and with some tinkering you might be able to hit 100mm BORE combo that with either the P40 or PPU crank and you have an unbelievably Massive engine at 5.4L. That would be INSANE in a Z car! Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted May 29, 2007 Share Posted May 29, 2007 ^ya, what dave said about that TB42 (!) Quote Link to comment Share on other sites More sharing options...
Chewievette Posted May 29, 2007 Share Posted May 29, 2007 That was a strange post, I went from depressed and aggrevated to totally hyper about building an engine like that! Too bad the nissan dealer is already closed or I'd be over there in half a heart beat bugging them about it. Quote Link to comment Share on other sites More sharing options...
Shuyun Posted May 29, 2007 Share Posted May 29, 2007 More on the Nissan TB42 http://www.frontierpower.com/nissan/nissanTB42.htm Quote Link to comment Share on other sites More sharing options...
Chewievette Posted May 29, 2007 Share Posted May 29, 2007 Seems to be another OHV engine, but with that kind of displacement and a flow through head it could be worth it. It also seems to be a bit bigger than an L series, anyone have exterior dimensions for an L series? Quote Link to comment Share on other sites More sharing options...
Shuyun Posted May 29, 2007 Share Posted May 29, 2007 So Does the SD33T Crank Fit the L block? A Custom Cam is a lot less than A custom Crank. I have been looking at a billit crank 89mm $3,850.00 US. A welded out LD crank at 83mm to 87mm was $1,200.00 with all the RISK of a welded strocker but still it is half the cost with a LD Crank running $350.00+. Quote Link to comment Share on other sites More sharing options...
Chewievette Posted May 30, 2007 Share Posted May 30, 2007 SD33? no idea.. I stopped looking because of the firing order but if I turn up anything I'll post it. Crower will build you a custom rotating assembly to your specs for $5,500. Which could be quite a bargain once you start pricing individual custom parts. Especially if you feel like pushing the outer limits of what the L block can hold. Quote Link to comment Share on other sites More sharing options...
Chewievette Posted May 30, 2007 Share Posted May 30, 2007 I have contacted the local nissan industral dealer and tomorrow I will be going over there to check out the TB42 and P40 engines in person. I am also going to take a look at the manuals for the engines and hopefully there will be nice shots of the crankshafts in there. In case they have the cranks in stock I am bringing along an L series crank to compare. Quote Link to comment Share on other sites More sharing options...
Sven Posted May 31, 2007 Share Posted May 31, 2007 I think the important thing that has yet to be mentioned is the bore spacing of any of these engines. If anyone has access to tow motor manuals, or a Nissan engine "master" book with full engine specs, please chime in. You can make almost any crank work if the bore spacing and rod throws are in the right place. If they aren't ... it might as well be a Chevette crank, because it just won't do us any good. Quote Link to comment Share on other sites More sharing options...
Sven Posted May 31, 2007 Share Posted May 31, 2007 I suppose if the head gaskets matched up, my question was answered -duh. Quote Link to comment Share on other sites More sharing options...
Careless Posted May 31, 2007 Share Posted May 31, 2007 lol, im reconsidering my RB30 build. L52? WICKED. hahaha. LS1's for breakfast, and LS7's for dinner so if the firing order is altered, one would need a custom set of cams, and to reposition the distributor/spark plug wires, correct? Quote Link to comment Share on other sites More sharing options...
Chewievette Posted May 31, 2007 Share Posted May 31, 2007 Careless said: also if the firing order is altered, one would need a custom set of cams, and to reposition the distributor/spark plug wires, correct? Thats basically it. I'm sure theres something else but I cant think of it right now. The main bearing locations and rod throws are what I'm trying to figure out right now. hopefully at least one of them will work. Hopefully we will know more soon. Quote Link to comment Share on other sites More sharing options...
Mack Posted May 31, 2007 Share Posted May 31, 2007 scew the TB42, get yourself a TB48DE. 24 valves and 4.8L of displacement. Go and search Youtube for TB48DE. It comes in a big, honking nissan offroad SUV. Well, some people in the middle east turbocharge and build the ♥♥♥♥ out of them. Lets just say it shows a Gixxer 1000 its tailkights on the FREEWAY, from a ROLL. here are a few videos you have to search for nissan partol and add turbo to get the good videos. bike race dirt drag race Quote Link to comment Share on other sites More sharing options...
Shuyun Posted May 31, 2007 Share Posted May 31, 2007 Here is a lot of info on Nissan engines http://www.msi-motor-service.com/intern_msi/download/asiaprogramm/data/as_nissan_web.pdf Page 27 has info on SD30-33T edit I found a New SD33T Crank for $1215.00 US Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 1, 2007 Share Posted June 1, 2007 Chewievette said: So basically your only hope now is that the crank and cam from the SD33 fit the L series. which is unfortunately unlikely. I hate to say it, but we are doomed to have a 3.2L cap on our engines. Regrind the L-Camshaft with welded lobes, and the crank then matches the L-Cam, firing order is as simple as swapping wires on the cap (or in the ECU). Diverse firing orders aren't anything new to the Buick Guys. Internally/Externally Balanced engine would be the question I would ask---if the firing order changes it's usually for a reason...operating rpm, vibration harmonic, etc... Why the order is different is worth exploring, making an L-Engine work with that crank setup is just a matter of having the lobes reground to match the crank configuration. And I doubt anybody doing this kind of swap wouldn't have a custom ground cam already... Quote Link to comment Share on other sites More sharing options...
