Exhaust Sound Clip Thread
jknc90
What do you guys think about starting a thread with clips of exhaust so that if somebody is wondering how something would sound, they could come here. I think we should inculde: Engine, mods to engine, and exhaust components with each post. I'll post mine in a week or two when I finish.
Thanks everybody
F54 block with flat top pistons
N42 head with stage IV schnieder cam
stock roundtop SUs
MSA 6-1 exhaust
open header
no high RPM vids 'cause this was right after i replaced the head and it was still breaking in. i will get more vids with the MSA 2.5" exhaust bolted up with the super turbo muffler
Guest 280ZForce
this was my previous engine setup...
3.0L L-series Stroker Turbo
stroker crank
ross forged pistons
minor head work and a nice cam
holset hy35 turbo
Holset 4" dp - 3" straight back exhaust w/ apexi n1 turbo muffler
yada yada...
on with the vids of the old...
Stroker Idle
Rev from the Back
Rev from the Front
Quick lil pull then release on 8 psi (my turbo doesnt start breathing good till after 12 psi, but i was still tuning at this point)
New setup....yet to be fired up but read sig... and you thought my previous setup sounds gnarly, can't wait to fire up this bad boy.
76 fairlady
f54 block
n42 head
msa stage 3 cam
triple 40mm mikuni's
msa 6 into 1 open header
http://s88.photobucket.com/albums/k165/red66chev/?action=view&current=100_1073.flv
This one sounds *juuuuuuuuust* right.
Don't get me wrong, all those turbos sound incredible... but theres special noise that a weber makes, or something. The SUs sound good, but not enough to make it preferable over the turbos like the triple webers or solexes or whatever..
Wish I had something to post to add to the discussion.
76 fairlady
f54 block
n42 head
msa stage 3 cam
love the idle.
here's mine when we fired up the engine for the first time. just a lot of noise really cause it's on pipes only. i was more impressed with the response of the engine but you should've seen my grin when i heard it fire up. blew me away.
(newest of the three)
I can't seem to figure out what is causing the popping. It is really bad now with the Mallory 6a ignition box but the same thing happened with the MSD 5900 and with the stock unit. It sounds as if one more backfire will blow the muffler off the back of the car...I did figure out that my oil pump shaft was off by 2 teeth which was the timing thing.
I'm guessing something is up with the dizzy? The spark plugs, wires, cap, and rotor have aout 11k miles on them...
  • 4 weeks later...
