Bartman Posted August 18, 2007 Share Posted August 18, 2007 I finallly got the car on the ground with the new wheels installed. It was a real b*tch, but I think it was worth it. Here's a link to a thread describing some of what was involved to get these wheels to fit: http://forums.hybridz.org/showthread.php?t=124054 It fits extremely tight everywhere! I had to trim part of my airdam to allow room for the front wheels to turn. The rear has 8" springs and rolled fenders. Here's some info: Front Tires 245/40R18 Falken Azenis OD 25.6" Tread width 9.1" Rims 18x8.5 +35 Offset Spacer Techno Toy Tuning 25mm Net Offset +10mm ______________________________________ Rear Tires 275/35R18 Falken Azenis OD 25.6" Tread width 10.0" Rims 18x9.5 +35 Offset Spacer 5/8" 15.875mm Net Offset +19.125mm Quote Link to comment Share on other sites More sharing options...
dat240zg Posted August 18, 2007 Share Posted August 18, 2007 Man, Bart! Those look nice. I really like the way they're tucked up in the fenders. Big props! Bryan Quote Link to comment Share on other sites More sharing options...
TONY C Posted August 18, 2007 Share Posted August 18, 2007 WOW! alot of work but looks great! now. how much of a spacer will I need to fill ZG"s probably too much.? Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 18, 2007 Author Share Posted August 18, 2007 None of the pictures of the back came out very good, so I finally adjusted the brightness on a couple: Quote Link to comment Share on other sites More sharing options...
getZ Posted August 19, 2007 Share Posted August 19, 2007 That is awesome! It looked like a lot of work, but you really nailed the stance and fit. When's the paint job now that you got the fenders rolled? Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 19, 2007 Author Share Posted August 19, 2007 getZ said: That is awesome! It looked like a lot of work, but you really nailed the stance and fit. When's the paint job now that you got the fenders rolled?Thanks, it does seem worth all the work and hassle now that it's done. It's a good thing it wasn't painted before I rolled the fenders as most of the paint flaked off the inside of the lip during the process. The paint and body work will start very soon. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted August 19, 2007 Share Posted August 19, 2007 Looks great Bart! Glad you finally got it all figured out! Guy Quote Link to comment Share on other sites More sharing options...
TravRMK Posted August 19, 2007 Share Posted August 19, 2007 Looks SWEET! Quote Link to comment Share on other sites More sharing options...
DRTY260Z Posted August 19, 2007 Share Posted August 19, 2007 Nice! Very Nice! Quote Link to comment Share on other sites More sharing options...
Clifton Posted August 19, 2007 Share Posted August 19, 2007 Looks good. I'm glad you went with the 275's. If you hadn't, you probably would have wished you did. Quote Link to comment Share on other sites More sharing options...
big-phil Posted August 19, 2007 Share Posted August 19, 2007 man those look good, makes my 16's look small. Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted August 19, 2007 Share Posted August 19, 2007 Looks really nice. I'm really wondering on these wide tires and wheels how much rubbing you will experience? Did you have to raise up the car for clearance of the wider wheels? This does seem like a great value for a wide street wheel combo! Justin Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 20, 2007 Author Share Posted August 20, 2007 I'm happy I went with 275's and thanks for all the help Clifton. I don't think rubbing will be an issue on the back as I moved the wheel throughout it's travel range without a spring on and didn't have any interference. I don't think the rear is raised too high, and I can still bring it down farther if I want to. It would definitely sit too high if I kept the 10" springs. The front tires are extremely close to the front air dam, and rubbing may be an issue there when the front suspension is compressed in a turn. A smaller diameter tire, raising the front, and using a smaller spacer are all possible solutions. Using a different air dam could potentially resolve the problem as well, but I like the one I have. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted August 20, 2007 Share Posted August 20, 2007 all the beauty needs is PAINT! it would be amazing w a nice coat of paint! im jealous Quote Link to comment Share on other sites More sharing options...
aziza z Posted August 20, 2007 Share Posted August 20, 2007 thats gourgous. good job. Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted August 20, 2007 Share Posted August 20, 2007 damn, looks good Bart! congrats, all the hard work paid off finally. Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 20, 2007 Author Share Posted August 20, 2007 Thanks for all the positive comments. I will definitely get her painted soon...or at least relatively soon. Quote Link to comment Share on other sites More sharing options...
S30 SPL Posted August 20, 2007 Share Posted August 20, 2007 good job man!! looks great, inspiration to all of us! what kind of brakes in the front? caliper looks nice... Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 20, 2007 Author Share Posted August 20, 2007 S30 SPL said: good job man!! looks great, inspiration to all of us! what kind of brakes in the front? caliper looks nice... Thanks, the front brakes are the Toyota 4x4 s12w vented brakes. Quote Link to comment Share on other sites More sharing options...
nullbound Posted August 20, 2007 Share Posted August 20, 2007 They make your brakes look tiny:mrgreen: Congrats, man. It looks really good with the 18's. That car's gonna look amazing when you're done. Quote Link to comment Share on other sites More sharing options...
