rudypoochris Posted October 15, 2007 Share Posted October 15, 2007 Does anyone know of a source of dry sump pumps and equipment that can be harvested from cars in the junkyard? Quote Link to comment Share on other sites More sharing options...
johnc Posted October 15, 2007 Share Posted October 15, 2007 Porsche. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted October 15, 2007 Author Share Posted October 15, 2007 johnc said: Porsche. Such as old 911's or 944's? Maybe the 928? Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 15, 2007 Share Posted October 15, 2007 911 has 21 qt dry sump oiling system Quote Link to comment Share on other sites More sharing options...
olie05 Posted October 15, 2007 Share Posted October 15, 2007 the 993 had 11qts and 2 oil filters Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 15, 2007 Share Posted October 15, 2007 I mean, for all it's worth, why not buy used NASCAR stuff of E-Bay? Much better quality and you can get rebuild parts reasonably enough. What is the impetus behind Dry Sump? "Dry Sump on a Budget" is kind of an Oxymoron. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted October 15, 2007 Share Posted October 15, 2007 The 928's, 944's, 924's and probably most other non 911 porsches were wet sump. The 911's are dry sump but the oil pump is inside the crankcase, so not the easiest thing to adapt to another car I'm guessing... Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 15, 2007 Share Posted October 15, 2007 jmortensen said: The 911's are dry sump but the oil pump is inside the crankcase, so not the easiest thing to adapt to another car I'm guessing... Kinda why I'm suggesting NSACAR spares... The stuff in the 911 is pretty much set up for that engine bay. The NASCAR stuff is standard Aftermarket stuff that is decently sized... the tank is going to be in the passenger's footwell anyway, so why use the odd shaped Porsche stuff (which, BTW is not easily cleaned...the aftermarket stuff is! A prime concern when reusing oil system goodies!!!) Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted October 15, 2007 Author Share Posted October 15, 2007 Good points guys. I was just hoping that there might be certain cars to look out for that I might score a cheap pump and components off of. Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted October 15, 2007 Share Posted October 15, 2007 any NASCARS in your junkyards? Quote Link to comment Share on other sites More sharing options...
mark Posted October 15, 2007 Share Posted October 15, 2007 Try competitive used parts. Used Nascar parts. I've bought parts from them before. About 15 minutes from me if you need me to eyeball anything for you. 800.560.9311 Concord, NC Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 15, 2007 Share Posted October 15, 2007 e_racer1999 said: any NASCARS in your junkyards? Don't know what that is supposed to imply, but I thought I made it perfectly clear that searching E-Bay for NASCAR cast-off parts is a place to get whatever you need cheaply. So I guess the answer to that question would be 'Yes, there are NASCARS in my junkyards...right here at my fingertips via E-Bay!' For instance: http://cgi.ebay.com/ebaymotors/SMALL-BLOCK-CHEVY-NASCAR-DRY-SUMP-PAN_W0QQcmdZViewItemQQcategoryZ107063QQihZ014QQitemZ330175644204QQrdZ1QQsspagenameZWDVW http://cgi.ebay.com/ebaymotors/Peterson-Dry-Sump-Oil-Tank-NASCAR-Chevy-Ford-Dodge_W0QQcmdZViewItemQQcategoryZ107066QQihZ007QQitemZ170157267805QQrdZ1QQsspagenameZWDVW http://cgi.ebay.com/ebaymotors/NASCAR-Dry-Sump-Breather-Tank_W0QQcmdZViewItemQQcategoryZ107058QQihZ007QQitemZ170157280280QQrdZ1QQsspagenameZWDVW http://cgi.ebay.com/ebaymotors/Barnes-6-stage-dry-sump-oil-pump-NASCAR_W0QQcmdZViewItemQQcategoryZ6778QQihZ020QQitemZ300160938074QQrdZ1QQsspagenameZWDVW http://cgi.ebay.com/ebaymotors/NASCAR-JONES-DRY-SUMP-OIL-PUMP-CRANKSHAFT-GEAR-cv_W0QQcmdZViewItemQQcategoryZ38656QQihZ017QQitemZ270175200801QQrdZ1QQsspagenameZWDVW http://cgi.ebay.com/ebaymotors/NASCAR-MSD-PRO-BILLET-SBC-DISTRIBUTOR-SHAFT-DRY-SUMP_W0QQcmdZViewItemQQcategoryZ33690QQihZ004QQitemZ140066912498QQrdZ1QQsspagenameZWD1V Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted October 15, 2007 Share Posted October 15, 2007 i was being silly, not malicious Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 15, 2007 Share Posted October 15, 2007 I figured... I just wanted to punctuate about the cheapest way you could make up a drysump. Guys with Chevys can do it CHEAP. Most of this stuff crosses no problem (tanks, pumps, coolers, etc). The A.R.E. and Aviad pans for the L-Engine just don't show up on E-Bay for some reason... And those will cost you dearly new! Quote Link to comment Share on other sites More sharing options...
Careless Posted October 15, 2007 Share Posted October 15, 2007 rudypoochris said: Does anyone know of a source of dry sump pumps and equipment that can be harvested from cars in the junkyard? we got a toyota previa here that we use to haul all our metal and engines/work supplies. going on 410,000 km this week. everything on the engine is original, except for the alternator and battery. we sold another 400,000 km previa with rod knock for 1200 and got this one for 700 and it's quiet and runs like a charm. The engine on the previa is on a slant, and my roommate (mechanic) tells me it's got a dry sump system, but I haven't looked underneath. Junkyards are usually littered with them. best van I've ever had the joy of using. Shares a lot of land cruiser specific parts (ball joints, random links here and there), wouldn't be surprised if the dry sump system is overbuilt too. what surprised me about the previa is that the engine is directly underneath the passenger and driver's seat, and it gets all the salt and dirt and road grime from all those 400,000 km, and it hasn't skipped a beat. It doesn't even burn oil. I'm willing to bet the bearings on the engine are still usable. LOL. Toyota stopped making the previa because it was a proprietary platform and they had to downsize their model line-up when they axed it. So being that it had a wealth of previa-specific parts, and it was too costly, I wouldn't be surprised if the sump system is fairly heavy duty. Probably not racing standard, but who knows. The Previa's 2TZFE and 2TZFZE engines are positioned on an 85 degree angle. so that's virtually sideways. so much for a "flat four" cheggit'out Quote Link to comment Share on other sites More sharing options...
e_racer1999 Posted October 16, 2007 Share Posted October 16, 2007 ^the stock exhaust manis on those previas are hottness, too Quote Link to comment Share on other sites More sharing options...
Mikelly Posted October 16, 2007 Share Posted October 16, 2007 Porsche 996TTs have them... I have to make sure not to crack the pipe on the oil tank on mine every time I change oil! Mike Quote Link to comment Share on other sites More sharing options...
Tony D Posted October 16, 2007 Share Posted October 16, 2007 From what I can see, the Previa Engine is Wet Sump. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted October 16, 2007 Author Share Posted October 16, 2007 I highly doubt the previa uses a dry sump system, but I'll check it out next time. Quote Link to comment Share on other sites More sharing options...
Careless Posted October 16, 2007 Share Posted October 16, 2007 Yeah I doubted it at first too. I can see it being a combination of both. Perhaps an crank driven oil pump and a remote filter pickup location. still worth a look. Quote Link to comment Share on other sites More sharing options...
