Blown77Z Posted November 14, 2007 Share Posted November 14, 2007 Here are some before/after pics of the work I've done to the passenger floor board to my car I got 2 days ago from NV Before: After: I only removed the sound deadening material which covered the rust. Once the rust pattern stopped, I didn't remove anymore. Should I remove ALL the sound deadening material just to be safe? Should I do some more sanding before I primer/paint it? Any other opinions/concerns are greatly welcome. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted November 14, 2007 Share Posted November 14, 2007 You call THAT removing rust??? Congrats for having a Z that is that rust free. As to removing the sound deadener, you see how it only rusted around the edges of where that crap was? Well, if you leave it in, where do you think it's going to rust next time? I'd take it out and use Zero Rust or POR15 to lock out the rust. Quote Link to comment Share on other sites More sharing options...
Blown77Z Posted November 15, 2007 Author Share Posted November 15, 2007 Thanks for the advise jmort The "rust" color you see is stained on the sound deadening material and not the metal itself but, I will be removing the rest of the sound deadening material and coating the entire floor with the good stuff. Keep the opinions coming in guys ! Quote Link to comment Share on other sites More sharing options...
deja Posted November 15, 2007 Share Posted November 15, 2007 . Should I remove ALL the sound deadening material just to be safe? Should I do some more sanding before I primer/paint it? Any other opinions/concerns are greatly welcome. Yes get rid of all that sound deadener. If there was rust under what you removed, odds are there's more. If there are no rust through places sand off as much as you can and then treat it with POR-15. IMHO I wouldn't rely on regular primer and paint. Then you can install sound deadener over the POR-15. The stuff is expensive but it is awesome stuff to stop further rusting. http://www.por15.com/ You can get it on EBay too, but it will get to you faster if you order straight from POR15.com. You can brush this stuff on or spray it, but trust me don't get any on you! Quote Link to comment Share on other sites More sharing options...
bjhines Posted November 15, 2007 Share Posted November 15, 2007 That is a nice set of floorboards you have there!!!!! I can't express how nice those floors really are. You have a one in a million Z-car with that little rust. Quote Link to comment Share on other sites More sharing options...
capt_furious Posted November 15, 2007 Share Posted November 15, 2007 Wow, those really are CLEAN floors...if the rest of the car is that way, you shouldn't have to worry much about rust at all other than preventive measures. Quote Link to comment Share on other sites More sharing options...
nbesheer Posted November 16, 2007 Share Posted November 16, 2007 By the way i don't know how you're removing the sound deadener but like others have tried on the forum, get some dry ice crush it up and put it on the sound deadener, wait a few minutes and start chipping it away. Doesn't take long, I did a whole 510 in like 15 minutes. Quote Link to comment Share on other sites More sharing options...
Blown77Z Posted November 17, 2007 Author Share Posted November 17, 2007 Thanks all for the advice. I've been working on the passenger floor board mainly right now. I pulled the carpet out of the drivers side and you should see the floor, 99% rust free !!! I was shocked The drivers side floor: I did find some bad rust under/around the battery tray last night and started on that. Seems like the passenger side rust on the floor originated from the leakthough from the battery tray area, hince there being no rust on the drivers side... I removed the sound deadening material with a hammer and large flathead screwdriver. It wasn't as bad as I thought it would be doing it that way. The material chipped easily when I hit it probably due to the condition of that side. Quote Link to comment Share on other sites More sharing options...
Vintage Posted November 19, 2007 Share Posted November 19, 2007 Haha, even that battery tray isnt bad rust, I wish mine was half that nice. Mine is just a big hole, I can stick my head through it. Mint Z you got there, good luck with it. Quote Link to comment Share on other sites More sharing options...
naviathan Posted November 19, 2007 Share Posted November 19, 2007 You don't have rust. Even my least rusty Z has more rust than that. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 19, 2007 Share Posted November 19, 2007 Sheesh. You guys are making me feel good with the rust situation on my Z. I thought that battery tray looked pretty bad. Quote Link to comment Share on other sites More sharing options...
Vintage Posted November 19, 2007 Share Posted November 19, 2007 If you think that tray looks bad, you dont HAVE a rust situation on your Z. Thats nothing more than some surface rust. The best tray I've seen in person was the one on the 260Z parts car I got this weekend, and it had a baseball sized hole in it. Quote Link to comment Share on other sites More sharing options...
zmaster Posted November 19, 2007 Share Posted November 19, 2007 i wish my z had floor pans like yours.... you are one lucky sob to get a z like that Quote Link to comment Share on other sites More sharing options...
Blown77Z Posted November 19, 2007 Author Share Posted November 19, 2007 Thanks guys ! And here I was stressing over the rust issues on the floor and battery tray. Some POR-15 will cure that. I will need my passenger frame rail fixed though: Any suggestions on what to do with the frame rail? Cut and patch the hole along w/ http://www.baddogparts.com/bdp.htm or leave the small hole there with the baddog rail in place? Quote Link to comment Share on other sites More sharing options...
Vintage Posted November 19, 2007 Share Posted November 19, 2007 Depends on your plans for the car. If your power goals arnt too crazy, I'd just patch the rail and forget about the baddog rails. Judging from your username, it sounds like you want to go with a boosted V8, if so, might as well replace with baddog rails on both sides. Quote Link to comment Share on other sites More sharing options...
bjhines Posted November 26, 2007 Share Posted November 26, 2007 Hey, Think about paint application INSIDE the rails if you replace them. I had a local Z-car guy ask for a quote to install Baddog rails. I figured in 10 hours of work to install the Baddog rails. I would remove the old rails and address any rust issues inside. I also included some time for painting inside and out(before and after welding). I also included some time to remove the tar padding on the inside of the floorboards where welding would be done on the underside. Anyway the guy got them welded on at a muffler shop for $50. I can only imagine what was done. LOL!!! Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted November 26, 2007 Share Posted November 26, 2007 Now, thats Fuc#ing scary....I have all kinds of images going through my head. I would love to see that work. lol Anyway the guy got them welded on at a muffler shop for $50. I can only imagine what was done. LOL!!! Quote Link to comment Share on other sites More sharing options...
Blown77Z Posted December 2, 2007 Author Share Posted December 2, 2007 I finally got a chance to put on the POR-15 today and I also hit some misc stuff such as behind the door weatherstrip, it had some little rusty spots and the rear deck area where the hatch closes down on. I love this stuff !!! Quote Link to comment Share on other sites More sharing options...
frldyzpimpn Posted December 4, 2007 Share Posted December 4, 2007 Very rust free z compared to what ive seen. Congrats!! Quote Link to comment Share on other sites More sharing options...
