TimZ Posted October 20, 2008 Share Posted October 20, 2008 Well, I finally got a chance to get my car back to the dyno, just to confirm my suspicions on the E85 conversion I did over the winter. Very pleased with the results. The major changes since this thread consisted mainly of: actually dialing in the cam correctly (it appears to have been retarded quite a bit before) Switching to E85 - actually more like E70 now (winter mix) I made a few other changes, mostly with high rpm longevity in mind: Kameari chain tensioner Ferrea super alloy valves titanium retainers lightened/balanced/polished the rockers fresh set of rings/bearings The blue lines were from today on E85, the red from last year on Sunoco 94 Just to put things into perspective, here it is vs. a stock Z06 on the same dyno... Quote Link to comment Share on other sites More sharing options...
TravRMK Posted October 20, 2008 Share Posted October 20, 2008 WOW, those are some big numbers! Congrats! Quote Link to comment Share on other sites More sharing options...
mark Posted October 20, 2008 Share Posted October 20, 2008 That is amazing! Congrats. Quote Link to comment Share on other sites More sharing options...
jt1 Posted October 21, 2008 Share Posted October 21, 2008 Holy Crap!!!! That's twisting the pump. Still at 25 psi? jt Quote Link to comment Share on other sites More sharing options...
TimZ Posted October 21, 2008 Author Share Posted October 21, 2008 jt1 said: Holy Crap!!!! That's twisting the pump. Still at 25 psi? jt This particular run peaked at ~29psi, trailing off to 27 at redline At roughly the same boost level as before, power peaked at ~628hp, with 528 lb-ft Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted October 21, 2008 Share Posted October 21, 2008 wow!! those are excellent numbers!! possibly the highest documented on an L series?! I'm sure this has been covered on this forum before.. but would you be willing to describe what is necessary to convert your Z to ethonal?! Quote Link to comment Share on other sites More sharing options...
big-phil Posted October 21, 2008 Share Posted October 21, 2008 man thats allot of HP. Nice going. Any video? Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted October 21, 2008 Administrators Share Posted October 21, 2008 Thanks for sharing Quote Link to comment Share on other sites More sharing options...
texis30O Posted October 21, 2008 Share Posted October 21, 2008 I too would be interested in the changes. I would like to be able to run E85 in my draw-thru turbo setup.....I am concerned with the octane rating. I was told not to go above 15lbs of boost on pump gas, but I believe that I might be able to go to 18lbs or even 20lbs. where my cut off is..........I know my motor was built back in the late 70's early 80's to run up to 21lbs of boost. But I was told to only go that high with 110.... I am jealous of your #'s that is off the chart!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Bernardd Posted October 21, 2008 Share Posted October 21, 2008 Great numbers Tim. Is this a twinscroll turbine housing/header or the same sfp header you used in previous setups? Quote Link to comment Share on other sites More sharing options...
TimZ Posted October 21, 2008 Author Share Posted October 21, 2008 Bernardd said: Great numbers Tim. Is this a twinscroll turbine housing/header or the same sfp header you used in previous setups? Thanks everyone. It's the same evil SFP header, slightly modified to allow the GT42 to fit in the engine bay, and with stainless expansion joints added to fight the tendency for warping. I also added bracing to take some of the stress off of the flange area. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted October 21, 2008 Share Posted October 21, 2008 TimZ said: It's the same evil SFP header, slightly modified to allow the GT42 to fit in the engine bay, and with stainless expansion joints added to fight the tendency for warping. I also added bracing to take some of the stress off of the flange area. AWESOME numbers! BTW, that crappy exhaust manifold will never work You need one of those exotic, equal length bag-of-snakes Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted October 21, 2008 Share Posted October 21, 2008 Hot damn! Awesome man, I found a buyer for my injectors. Now I have to get off my butt and get my monsters. Evan Quote Link to comment Share on other sites More sharing options...
Careless Posted October 21, 2008 Share Posted October 21, 2008 gaht dangit! Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted October 21, 2008 Share Posted October 21, 2008 Nice Tim!! I'd be jazzed with those results. Quote Link to comment Share on other sites More sharing options...
TimZ Posted October 21, 2008 Author Share Posted October 21, 2008 texis30O said: I too would be interested in the changes. I would like to be able to run E85 in my draw-thru turbo setup.....I am concerned with the octane rating. I was told not to go above 15lbs of boost on pump gas, but I believe that I might be able to go to 18lbs or even 20lbs. where my cut off is..........I know my motor was built back in the late 70's early 80's to run up to 21lbs of boost. But I was told to only go that high with 110....I am jealous of your #'s that is off the chart!!!!!!!!! The changes that I made to my fuel system consisted of the following: Anodize the aluminum bits remove any brass fittings and replace with either anodized aluminum or stainless steel Used E85 compatible hoses Viton o-rings for the injectors Two fuel pumps, each with a Kenne Bell Boost-a -Pump for good measure 150lb injectors Pulled the fuel tank and modified it with a bottom sump and two -8 outlets, one for each fuel pump Also hot tanked the tank and had it internally coated with an Ethanol resistant coating (red-kote) I already had the two pumps and injectors from the previous setup - there was enough headroom left for the addition of E85. Quote Link to comment Share on other sites More sharing options...
jgkurz Posted October 21, 2008 Share Posted October 21, 2008 Congrats Tim. I calculate 762bhp. Simply amazing... I sure would like to see what your car would do at Milan.. Quote Link to comment Share on other sites More sharing options...
510six Posted October 21, 2008 Share Posted October 21, 2008 Those are very impressive #`s, congrats! Makes me want to get my E85 setup up and going . Tim, do you have any pics of your fuel system? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted October 21, 2008 Share Posted October 21, 2008 NICE numbers tim. You keep settin the bar higher and higher for me! Whats the most HP you have run on Pump Gas? I "plan" to get to the dyno next month and get 700 RWHP on pump gas, but we shall see. I am eying a larger set of turbos to get me to the 1000 RWHP mark too! The main thing I lack in life is time though. Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted October 21, 2008 Share Posted October 21, 2008 Gahdamn! Quote Link to comment Share on other sites More sharing options...
