RB26powered74zcar Posted May 29, 2009 Share Posted May 29, 2009 (edited) I received my custom powder coated sump, made by Rips in NZ today. It's a definite work of art, and I'm confident my oil pressure drop during braking, will now cease.I have a alum Thagard pan, which is a nice piece to base from, but I failed to set up the sump portion of it properly, causing oil pressure drop on braking. I saw a example of Rob's work when member gmac708 posted pics of his pan being fabbed by Rips, so I went ahead and bit the bullet and had mine made.My pan is some what of a out of the ordinary design, due to the fact I am using a fitting off the Greddy oil pump I'm using, to make it external pick up. This way, my pick up tube exits the side of the pan (AN-12) then connects to the pump under the air con bracket to pull the oil from the pan.Below is some pic's of my new Rips pan.CLICK EM Thanks Rob!!Contact Rips is interested in a custom RB pan.e-mail rips@inspire.net.nzwww.ripsracing.com Edited October 13, 2014 by RB26powered74zcar dead pic url Added pics Quote Link to comment Share on other sites More sharing options...
RS Speed Posted May 29, 2009 Share Posted May 29, 2009 Looks great, it's truly a work of art. Quote Link to comment Share on other sites More sharing options...
gmac708 Posted May 30, 2009 Share Posted May 30, 2009 I like the turbo return/scavange fittings on left side. Very nice! Quote Link to comment Share on other sites More sharing options...
jonnyringo Posted May 30, 2009 Share Posted May 30, 2009 That is a great looking oil sump! Looks like oil pressure drop under braking, conering or anything short of being upside down will be stopped or at least brought down to a bare minimum! =) Your setup is similar to mine, I too have a Greddy/Trust oil pump with a -12 fitting installed for an external pick-up. Right now my sump is a 200zr sump with a Moroso oil pick-up welded inside. How many quarts is your new R.I.P.S. sump supposed to hold? Would you mind divuldging the price? It may be something id be looking at picking up. Great sump and great car. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted May 30, 2009 Share Posted May 30, 2009 Awesome Joel! Yasin Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 4, 2009 Author Share Posted June 4, 2009 I finally got the RIPS custon oil pan installed, and got a few pics while it was up on jack stands, waiting on a couple fittings to arrive from Summit.I did not get a shot once all the hoses were hooked up, but it is completed. I drove it around a bit, testing the results of how well it holds oil pressure while under decel, and acceleration.It absolutely performs flawless!! It holds oil pressure under every condition I could throw at it. I'm 100% satisfied with the results of the sump!!Thanks R.I.P.S.You guys rip! Quote Link to comment Share on other sites More sharing options...
Almighty Wez Posted June 4, 2009 Share Posted June 4, 2009 One very nice piece, wish I had the $ for it. Quote Link to comment Share on other sites More sharing options...
Careless Posted June 7, 2009 Share Posted June 7, 2009 what do you think the reason for the thagard pan's starvation issue was, based on how you set up the pickup and all that jazz, what do you think you did incorrectly. this would be good to learn from for ppl deciding to have a go at it. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 10, 2009 Author Share Posted June 10, 2009 what do you think the reason for the thagard pan's starvation issue was, based on how you set up the pickup and all that jazz, what do you think you did incorrectly. this would be good to learn from for ppl deciding to have a go at it. I had to much wide open area around the -12 screened pick up fitting inside the rear corner of the pan. If I would have wanted to make the Thaggard pan work properly, I would just add a round oil containing device, made up like R.I.P.S. and most others do. Even with the trap door on my previous pan, the oil was able to move forward, away from the pick up, un restricted (with out a container around the pick up) which allowed the oil pressure to drop off until the momentium changed again moving the oil rearward toward the pick up fitting. That pan could be touched up by a welder to work great. I just did not have any oil pan sumping experience when I received it bare, with nothing on the inside... Quote Link to comment Share on other sites More sharing options...
Wedge Posted June 14, 2009 Share Posted June 14, 2009 What is goin to happen to your thagard pan i would like to have it Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 27, 2010 Author Share Posted January 27, 2010 what do you think the reason for the thagard pan's starvation issue was, based on how you set up the pickup and all that jazz, what do you think you did incorrectly. this would be good to learn from for ppl deciding to have a go at it. Digging up a old post. To me, this would help alot with the oil containment. My pan had to large of area around the P/U. Quote Link to comment Share on other sites More sharing options...
PA240 Posted January 27, 2010 Share Posted January 27, 2010 So the top two fittings are oil returns? and the bottom is the pickup? What are the advantages to this setup? Quote Link to comment Share on other sites More sharing options...
Hoover Posted February 4, 2010 Share Posted February 4, 2010 I have a Thagard pan from 5 years ago. I've been doing a ton of oil pan work and will probably re-baffle it before install. Quote Link to comment Share on other sites More sharing options...
EF Ian Posted September 18, 2013 Share Posted September 18, 2013 Old post but: Do you still like your sump? No problems? How many litres does it hold? Does it hang any lower than the crossmember? What advantages do you get running an external pickup? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted September 19, 2013 Author Share Posted September 19, 2013 Still doing great with it. It holds 6qts in the pan. I did the external p/u originally in the Alum Thagard pan, out of ease of not having to make a custom p/u. It is flush with xmember. Hope this answered your questions ok. Joel Quote Link to comment Share on other sites More sharing options...
EF Ian Posted September 19, 2013 Share Posted September 19, 2013 That answers my question perfectly, thanks very much. I'm hoping I can get one made that holds more oil than that. Something like 7.4 quarts would be good. Quote Link to comment Share on other sites More sharing options...
Fairlady240Z Posted October 1, 2013 Share Posted October 1, 2013 I have been searching to find a rubber oil pan gasket, to no avail. Looks like you have one there on your oil pan wondering where you located that gasket. Thanks Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted October 2, 2013 Author Share Posted October 2, 2013 Sorry, no gasket. I used a Nissan brand gasket maker / silicone.... Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 6, 2013 Share Posted November 6, 2013 "Right Stuff" gasket maker. Quote Link to comment Share on other sites More sharing options...
stony Posted October 13, 2014 Share Posted October 13, 2014 Found it Joel, but it looks like half the pics don't work anymore? Quote Link to comment Share on other sites More sharing options...
