Roll bar (main hoop) - Tubing Bender from ebay
I found this bender on eBay and I gotta ask everyone for their opinion!!
http://cgi.ebay.com/ebaymotors/1-3-4-Tubing-Tube-Bender-SandRail-Rock-Crawler-Baja_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem2555e46bebQQitemZ160354823147QQptZMotorsQ5fAutomotiveQ5fTools
I mean $260.. its a TUBE bender and not a pipe bender..
Im planning on 1.75" 0.120" DOM tubing.. and according to this diagram a 7" radius bend is all I need!!
(thanks 74_5.0L_Z)
Beats the $300 JD2 bender.. plus the $300 for a flippin die!!
A bigger radius bend requires more room and tubing length to complete. The gap between the bend and the corner of the roof will be a bit larger then with a tighter bend. Conversely, a larger radius bend will be a bit stronger then a tighter radius bend.
If you're going to make more then just one roll bar or cage and can only afford one die, you'll probably want a tighter radius then 7". I use a 5.5" radius bend with 1.5" tubing and a 6" bend with 1.75" tubing.
FYI... Most race sanctioning bodies don't allow bends any tighter then 3 times the tube OD. So the tightest approved bend on 1.75" tubing is 5.25".
That looks like the same die that came with my Speedway bender. I had a roll bar fabricator bend up the main hoop based on Dan's .gif you have there and it worked out perfectly, and then I did all the other bends with a basically similar bender:
http://www.speedwaymotors.com/3rd-Generation-Hydraulic-Round-Tubing-Bender-Assemby,6614.html
I checked some measurements on my 260 and the Roll Bar pictured above will not fit.
I have been looking at previous posts for weeks and have not been able to find a set of drawings or dimensions for a SCCA legal Roll Bar/ Cage. Does anyone know where I can find a set of drawings or plans?
John(Mongo)
Dan, aka 74_5.0L_Z, is the guy who made the drawing. As you can tell by his screen name, it should fit a 260.
Maybe this will help to show where he installed it:
Yes. Just a little triangular box that sits on the floor. Mine came out a bit tighter and I attached it to the rockers and did a similar triangular box underneath the tubes as a result of people on another forum telling me it wouldn't pass tech with the bottom of the tubes left open:
Im seriously all over the place right now..
I can't decide if i should spend the ~$450 for a Kirky cage.. or spend nearly $350 for a tubing bender.. and then $9.99 per linear foot for DOM tubing and make my own.
Especially if I dont really see myself using the bender for anything else. arrggg
If you're paying $10 bucks a foot for DOM then you better shave your butt because someone wants to bend you over. Right now 1.75 x .095 wall DOM is around $4.50 a foot if you buy it by the stick.
BTW... you don't need .120 wall 1.75 tubing, go with .095 wall.
Edited by johnc
I have one of these benders and have 1.75 die and the 1.50 die. The build of this product is great. It works very well, a very tiny amount of grease on the die works well. This is a very simple and very easy to use product. When bending the main hoop you may find that a tubing indexer is a great tool to have. It allows you to have the bend in a perfect plane to each other. I found the indexer on a rock crawling web site.
The style of bender you linked will work okay, but I've never been a fan of bending vertically due to the practical overhead space available for clearancing cage hoops etc. If you like that style though I would look at the One Shot from Pro Tools (www.pro-tools.com) which is setup horizontally. Like many tools, you get what you pay for and they have a nice product. If I were to recommend a bender for entry level cage building, I'd be looking at the PT 105.
Also, I highly recommend Bend Tech software. Either EZ3D or preferably Pro is great for doing cage work and really takes the guess work out, especially for a first timer. Take a look at www.2020ssi.com. You wouldn't believe how much faster and easier it is to build a cage - even I can do it and I'm no wizard.
As for bend radius (CLR or centerline radius), a 7 inch CLR is bigger than you need for a 1-3/4"x0.120 tube cage. Unless you are planning on doing thinwall bending with the same dies, you will be happier with a tighter radius (maybe 5.5-6in) for that size tube. The diameter will shrink a little in the bend area, but not much and with that thickness there shouldn't be any problem with wrinkling.
I found a local place who will bend roll cage tubing for $25 per bend..
so 4 bends on the main hoop.. 2 bends on the rear harness bar.. plus materials for the diagonal.. etc
I can easily do the main hoop, harness bars and diagonal for ~$240-ish!
not too bad.
PS - Bandit.. thanks for the great info!!
crap 25 per bend whatever happened to by the hour??? someone that knows what there doing should be able to bend a blueprint in less then a hour!!!!
Now building one from scratch with a shell is a different story but geez, your supplying all the info just kinda figured it would be cheaper
I was talking with an engineer who does pipe bends for cattle sheds, he says a light coat of reloading case and bullet lube lasts longer and works just as well.
Jon, you bent your halo with this bender, correct? Did you use .120 wall tube? I just noticed that the bender cannot bend .120 wall DOM or 4130, well that is what the description says. I am trying to bend .120 wall 1.5" DOM without spending an arm and a leg on a bender, but if I can get a complete bender for $399 I'll get it.
Thanks
Seemed to work just fine for me. It was a little tough to start bends at the end of a tube, but really worked fine. I would imagine 1.75x.120 is a lot tougher to bend than 1.5 x .120.
If you're building to SCCA specs I think you can go 1.5 x .095 now. I found a couple different specs in the rulebook and erred on the side of caution, and then they reduced the requirements. Bad timing on my part...
