Roll bar (main hoop) - Tubing Bender from ebay
I found this bender on eBay and I gotta ask everyone for their opinion!!
http://cgi.ebay.com/ebaymotors/1-3-4-Tubing-Tube-Bender-SandRail-Rock-Crawler-Baja_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem2555e46bebQQitemZ160354823147QQptZMotorsQ5fAutomotiveQ5fTools
I mean $260.. its a TUBE bender and not a pipe bender..
Im planning on 1.75" 0.120" DOM tubing.. and according to this diagram a 7" radius bend is all I need!!
(thanks 74_5.0L_Z)
Beats the $300 JD2 bender.. plus the $300 for a flippin die!!
A bigger radius bend requires more room and tubing length to complete. The gap between the bend and the corner of the roof will be a bit larger then with a tighter bend. Conversely, a larger radius bend will be a bit stronger then a tighter radius bend.
If you're going to make more then just one roll bar or cage and can only afford one die, you'll probably want a tighter radius then 7". I use a 5.5" radius bend with 1.5" tubing and a 6" bend with 1.75" tubing.
FYI... Most race sanctioning bodies don't allow bends any tighter then 3 times the tube OD. So the tightest approved bend on 1.75" tubing is 5.25".
That looks like the same die that came with my Speedway bender. I had a roll bar fabricator bend up the main hoop based on Dan's .gif you have there and it worked out perfectly, and then I did all the other bends with a basically similar bender:
http://www.speedwaymotors.com/3rd-Generation-Hydraulic-Round-Tubing-Bender-Assemby,6614.html
I checked some measurements on my 260 and the Roll Bar pictured above will not fit.
I have been looking at previous posts for weeks and have not been able to find a set of drawings or dimensions for a SCCA legal Roll Bar/ Cage. Does anyone know where I can find a set of drawings or plans?
John(Mongo)
Dan, aka 74_5.0L_Z, is the guy who made the drawing. As you can tell by his screen name, it should fit a 260.
Maybe this will help to show where he installed it:
Yes. Just a little triangular box that sits on the floor. Mine came out a bit tighter and I attached it to the rockers and did a similar triangular box underneath the tubes as a result of people on another forum telling me it wouldn't pass tech with the bottom of the tubes left open:
Im seriously all over the place right now..
I can't decide if i should spend the ~$450 for a Kirky cage.. or spend nearly $350 for a tubing bender.. and then $9.99 per linear foot for DOM tubing and make my own.
Especially if I dont really see myself using the bender for anything else. arrggg
If you're paying $10 bucks a foot for DOM then you better shave your butt because someone wants to bend you over. Right now 1.75 x .095 wall DOM is around $4.50 a foot if you buy it by the stick.
BTW... you don't need .120 wall 1.75 tubing, go with .095 wall.
Edited by johnc
I have one of these benders and have 1.75 die and the 1.50 die. The build of this product is great. It works very well, a very tiny amount of grease on the die works well. This is a very simple and very easy to use product. When bending the main hoop you may find that a tubing indexer is a great tool to have. It allows you to have the bend in a perfect plane to each other. I found the indexer on a rock crawling web site.
The style of bender you linked will work okay, but I've never been a fan of bending vertically due to the practical overhead space available for clearancing cage hoops etc. If you like that style though I would look at the One Shot from Pro Tools (www.pro-tools.com) which is setup horizontally. Like many tools, you get what you pay for and they have a nice product. If I were to recommend a bender for entry level cage building, I'd be looking at the PT 105.
Also, I highly recommend Bend Tech software. Either EZ3D or preferably Pro is great for doing cage work and really takes the guess work out, especially for a first timer. Take a look at www.2020ssi.com. You wouldn't believe how much faster and easier it is to build a cage - even I can do it and I'm no wizard.
As for bend radius (CLR or centerline radius), a 7 inch CLR is bigger than you need for a 1-3/4"x0.120 tube cage. Unless you are planning on doing thinwall bending with the same dies, you will be happier with a tighter radius (maybe 5.5-6in) for that size tube. The diameter will shrink a little in the bend area, but not much and with that thickness there shouldn't be any problem with wrinkling.
I found a local place who will bend roll cage tubing for $25 per bend..
so 4 bends on the main hoop.. 2 bends on the rear harness bar.. plus materials for the diagonal.. etc
I can easily do the main hoop, harness bars and diagonal for ~$240-ish!
not too bad.
PS - Bandit.. thanks for the great info!!
crap 25 per bend whatever happened to by the hour??? someone that knows what there doing should be able to bend a blueprint in less then a hour!!!!
Now building one from scratch with a shell is a different story but geez, your supplying all the info just kinda figured it would be cheaper
Jon, you bent your halo with this bender, correct? Did you use .120 wall tube? I just noticed that the bender cannot bend .120 wall DOM or 4130, well that is what the description says. I am trying to bend .120 wall 1.5" DOM without spending an arm and a leg on a bender, but if I can get a complete bender for $399 I'll get it.
Thanks
Seemed to work just fine for me. It was a little tough to start bends at the end of a tube, but really worked fine. I would imagine 1.75x.120 is a lot tougher to bend than 1.5 x .120.
If you're building to SCCA specs I think you can go 1.5 x .095 now. I found a couple different specs in the rulebook and erred on the side of caution, and then they reduced the requirements. Bad timing on my part...
