280zNHChris Posted December 8, 2009 Share Posted December 8, 2009 I'm down for one. Any one else? Don't want to waste the winter with the car in limbo. Quote Link to comment Share on other sites More sharing options...
attyoung911 Posted December 10, 2009 Share Posted December 10, 2009 i will take a set. PM me and i will send payment Paypal. Quote Link to comment Share on other sites More sharing options...
Derek Posted December 10, 2009 Author Share Posted December 10, 2009 i will take a set. PM me and i will send payment Paypal. I'm just getting a list of people interested so I can see if it's feasible to make another run. Derek Quote Link to comment Share on other sites More sharing options...
tech9 Posted December 23, 2009 Share Posted December 23, 2009 Anyone have megasquirt working with this? Trying to setup my COP setup but can't figure out all the timing issues, COP and this EDIS mount are giving me such a challenge. For some reason I think the timing is WAY off. Quote Link to comment Share on other sites More sharing options...
Derek Posted December 23, 2009 Author Share Posted December 23, 2009 Well it's working on mine but that probably doesn't count! Does the COP use the ford edis control box or just the sensor? If it doesn't and you have the edis wheel set up like the picture in my instructions http://forums.hybridz.org/showthread.php?t=153367 then the problem is in the Megasquirt. If it does use the EDIS brain then it sould run in limp mode with the Megasquirt disconnected. Derek Quote Link to comment Share on other sites More sharing options...
tech9 Posted December 24, 2009 Share Posted December 24, 2009 Its just the sensor, running direct fire COP. Are you using the sensor only? If so can you send me a pic of your trigger wheel / ignition settings just for reference? I set it up as your instructions provided just haven't touched it in months and forgot what I was doing It's "working" but the timing is just way off, not sure if it was my error or just settings. Thanks! Quote Link to comment Share on other sites More sharing options...
Derek Posted December 24, 2009 Author Share Posted December 24, 2009 Its just the sensor, running direct fire COP. Are you using the sensor only? If so can you send me a pic of your trigger wheel / ignition settings just for reference? I set it up as your instructions provided just haven't touched it in months and forgot what I was doing It's "working" but the timing is just way off, not sure if it was my error or just settings. Thanks! If you set up your edis wheel like this illustration the timing will be very close. If it isn't then the problem is in how you have Megasquirt set up. The key-way which lines up with the damper bolts is at the 12 o'clock position and notice the relationship between the missing tooth and the sensor. You can mount the wheel backwards and this would throw things out of whack. I can't rember. are you using a laser cut wheel or did I modify an ford wheel for you. Derek Quote Link to comment Share on other sites More sharing options...
tech9 Posted December 25, 2009 Share Posted December 25, 2009 Its a lasercut wheel, I will check and make sure its on correctly. But i'm assumsing its the MS settings, I was kind of confused with the wheel offset settings. Quote Link to comment Share on other sites More sharing options...
tech9 Posted December 26, 2009 Share Posted December 26, 2009 Ok wheel is setup PERFECTLY, i double checked everything today. I set MS to 50 degrees BTDC for the #1 tooth (i'm assuming this is correct, 5 tooth * 10 degrees each tooth). I set MS to fixed timing of 10 degrees, get the timing light on the wheel and the mark is nowhere to be seen when the engine is idling. I can play with the tooth angle to get the TDC mark to line up, but the math is not correct somewhere. Quote Link to comment Share on other sites More sharing options...
tech9 Posted December 29, 2009 Share Posted December 29, 2009 Gap was a little too far away, moved the vr sensor in a little, after modding it. Perfect sync now. Quote Link to comment Share on other sites More sharing options...
EvilC Posted December 30, 2009 Share Posted December 30, 2009 Glad to see it worked out for ya Quote Link to comment Share on other sites More sharing options...
ashintar Posted January 19, 2010 Share Posted January 19, 2010 Hope to see another set of these made soon. Quote Link to comment Share on other sites More sharing options...
Derek Posted April 16, 2010 Author Share Posted April 16, 2010 Hope to see another set of these made soon. Your wish is my command! Alright I'm going to be knocking out another 8 setups. Those with the first dibs are according to the date they contacted me. PrOxLaMuS EvilC  280zNHChris attyoung911 ashintar ModernS30 If your on this list please let me know your status. Derek Quote Link to comment Share on other sites More sharing options...
ModernS30 Posted April 17, 2010 Share Posted April 17, 2010 How much is it again? I have cash but I will pretty much be blowing it all if I buy this setup. I need to have my car running by the 7th. Right now it is bare. Not sure it's really in my greatest interest. I wanted it, I still really do, but its what, 175 plus 15 for the timing mark bracket thing? I have a deal that will work my timing advance/retard etc. I would need coil packs, heck I even have a VR sensor if I can get use for it. Would really help clean up my wiring mess. HMMMMM... How long will it be before the sets are finished/taking payment? I am going to need to buy some doors and they are 50 a piece at the yard I plan to go to. Quote Link to comment Share on other sites More sharing options...
attyoung911 Posted April 17, 2010 Share Posted April 17, 2010 Thank you for update, I will pass on mine, I am going SDS system, this will hopefully make room for next guy, Thank you making these for us Datsun guys ote name='ModernS30' date='16 April 2010 - 07:38 PM' timestamp='1271471931' post='860812'] How much is it again? I have cash but I will pretty much be blowing it all if I buy this setup. I need to have my car running by the 7th. Right now it is bare. Not sure it's really in my greatest interest. I wanted it, I still really do, but its what, 175 plus 15 for the timing mark bracket thing? I have a deal that will work my timing advance/retard etc. I would need coil packs, heck I even have a VR sensor if I can get use for it. Would really help clean up my wiring mess. HMMMMM... How long will it be before the sets are finished/taking payment? I am going to need to buy some doors and they are 50 a piece at the yard I plan to go to. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 19, 2010 Share Posted April 19, 2010 Im still interested! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 28, 2010 Share Posted April 28, 2010 jeesh, sourcing a 2 groove pulley is tough! Quote Link to comment Share on other sites More sharing options...
280zNHChris Posted April 28, 2010 Share Posted April 28, 2010 I should be all set. I bartered some powdercoating and Z-Ya is helping me with the EDIS and megasquirt. Thanks Chris Quote Link to comment Share on other sites More sharing options...
wondersparrow Posted October 20, 2010 Share Posted October 20, 2010 Sorry for the necropost, but I am curious if this is still available. I would like to edis up my track car over the winter, but sourcing a damper with a reluctor is a little tricky. It is a race engine, so I only need 1 pulley. Quote Link to comment Share on other sites More sharing options...
Derek Posted October 20, 2010 Author Share Posted October 20, 2010 Sorry for the necropost, but I am curious if this is still available. I would like to edis up my track car over the winter, but sourcing a damper with a reluctor is a little tricky. It is a race engine, so I only need 1 pulley. I have them in stock but don't forget they only fit this damper. Derek Quote Link to comment Share on other sites More sharing options...
