19762802+2 Posted November 20, 2009 Share Posted November 20, 2009 Digging the rims, they look great all polished if you lowered the car a inch or two i think you would be set. also i'm surprised on the mpg thats pretty good, plus dibs on the rims if you ever decide to get rid of them Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 20, 2009 Author Share Posted November 20, 2009 19752802+2 said: Digging the rims, they look great all polished if you lowered the car a inch or two i think you would be set. also i'm surprised on the mpg thats pretty good, plus dibs on the rims if you ever decide to get rid of them Yeah I'll eventually change rims for something that will let me run a smaller sidewall... These rims sure are light though! The car is already sitting on tokico springs ... It could be a little lower but it's way better than stock. Probably leave it as is for now. Quote Link to comment Share on other sites More sharing options...
cd1105 Posted November 21, 2009 Share Posted November 21, 2009 blackice280zxt said: I could of sold you a new tail panel piece. Cheap pm'd Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 21, 2009 Author Share Posted November 21, 2009 fstbckgt said: can't wait to see it with the body work done, did you decide if your going to get rid of those little round vents? Probably... still thinking about it. Dropped the gas tank to remove that stupid bumper support. Wasn't really that bad. Drained the remaining gas in the tank first.... Had about 2.5 gallons left in it. Funny cause it was already sputtering and driving crappy like that. The pick up for the external pump is pretty high. Tank was very easy to drop, two straps and the filler neck, along with some small hoses and the level sensor. The tank is amazingly 100% rust free inside, still has the coating 100% intact! amazing. No hidden rust behind the tank or anywhere. happy about that! In fact I had the carpet out and the floor boards are also totally rust free! Here is a picture of the bumper support gone. You'll also notice the areas of rust removal and primer Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted November 22, 2009 Share Posted November 22, 2009 Sketch_hs said: Yeah I'll eventually change rims for something that will let me run a smaller sidewall... These rims sure are light though! The car is already sitting on tokico springs ... It could be a little lower but it's way better than stock. Probably leave it as is for now. Tokico blue series? I cut a coil out of my HP springs and they dropped it from stock about 2-2.5" and its perfect, I really wanna drop my tank and get the rear bumper off, do you have any tips about dropping the tank at all? or is it just drain, pinch, un-bolt, and get the damn shock out and just mount it back up or is it more of a pain Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 22, 2009 Author Share Posted November 22, 2009 Two80z4me said: Tokico blue series? I cut a coil out of my HP springs and they dropped it from stock about 2-2.5" and its perfect, I really wanna drop my tank and get the rear bumper off, do you have any tips about dropping the tank at all? or is it just drain, pinch, un-bolt, and get the damn shock out and just mount it back up or is it more of a pain how much of an increase in ride harshness/bounce did you experience? Any benefits or issues with handling before/after? Dropping the tank; Drain it completely Remove hoses (front) Unplug level sensor Remove passenger rear wheel Remove passenger rear wheel well removable section Loosen hose clamp for filler tube place jack or support under tank remove straps carefully lower the tank slightly and just move it away far enough to get to the bumper shock. The rear vent hoses don't need to be removed Remove the bumper shock... Three bolts on the bottom, three nuts on the top, you'll need to move the tail light cover out of the way inside the car. Take the bumper shock out completely - I was able to pull it through the hole pretty easily but it's a bit tricky to work it out I guess. Plug the holes left by the studs going into the cabin Put everything back together! I used a new hose clamp on the filler neck cause mine was a bit rusty - Getting that filler neck tube on was a bit tricky. So get it to slip mostly on the filler neck and then use your jack or buddy to hold the tank in the right spot. Loosely secure the tank with the straps, make sure the filler neck is proper and all the hoses are in the right place... I had to pull on the rear vent hoses from inside the car to get it lined up right. From there, just put it back together.... pretty easy job took me about 30 min Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted November 22, 2009 Share Posted November 22, 2009 I had them on for a test ride and it seamed to be a more "civic" type of handling, it wasn't amazingly comfortable at times, but it handled great. my wheel wells are rhino lined so thats the only problem I see myself having, Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 22, 2009 Author Share Posted November 22, 2009 Two80z4me said: I had them on for a test ride and it seamed to be a more "civic" type of handling, it wasn't amazingly comfortable at times, but it handled great.my wheel wells are rhino lined so thats the only problem I see myself having, Any quantifiable results? How was the before/after in terms of harshness? What do you mean by "civic" type handling? Bouncy like a ricer with cut stock springs or tight and responsive like a properly modded one be specific... I dont want to regret this if I do it Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted November 22, 2009 Share Posted November 22, 2009 Sketch_hs said: Any quantifiable results? How was the before/after in terms of harshness? What do you mean by "civic" type handling? Bouncy like a ricer with cut stock springs or tight and responsive like a properly modded one be specific... I dont want to regret this if I do it depends on the strut/shock choice, civic type, meaning its stiff, but forgiving at times. Id still strongly suggest avoiding all pot holes. the top coil or two tend to sag on Tokico HP blue springs because of the "ride" they try and give it, so when you drive regularly the stock hp springs would be soft and forgiving, and when you take that progressive coil out, expect a stiffer less comfortable ride, you have a nice supra, im guessing you've been into the tuner crowd, the only thing I have on tap to compare it to is an Integra with DC2 coilovers that I rode in. Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 24, 2009 Author Share Posted November 24, 2009 Would you say the handling was improved or changed after cutting a coil or did you drive it with stock tokico coil length at all? Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted November 24, 2009 Share Posted November 24, 2009 Sketch_hs said: Would you say the handling was improved or changed after cutting a coil or did you drive it with stock tokico coil length at all? I didnt with the stock tokico, bought them that way. Id imagine it to be stiffer and quicker response due to eliminating the "progressive" top coil sag on regulart Tokico springs. Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 24, 2009 Author Share Posted November 24, 2009 Any pics showcasing your ride height? Quote Link to comment Share on other sites More sharing options...
Two80z4me Posted November 25, 2009 Share Posted November 25, 2009 Sketch_hs said: Any pics showcasing your ride height? The stock suspension is on there now because of winter, but I have one that I photoshopped along time ago that is relatively close. http://www.pinkbike.com/photo/4258156/ its a little higher than that, about .5-1inch higher. Quote Link to comment Share on other sites More sharing options...
Z lion 71 Posted November 27, 2009 Share Posted November 27, 2009 It did clean up nice.Welcome to the Z world.Where you'll be frustrated,overwhelmed,and satisfied all in one.These cars are pretty special.Keep us up to date with pics and write ups.Have fun Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 28, 2009 Author Share Posted November 28, 2009 Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 28, 2009 Author Share Posted November 28, 2009 Rear bumper is on. Made some simple brackets - looks nice! The spoiler needed a lot of work. It had some pits and cracks, runs in spray paint etc. I sanded it all down and am filling the cracks and pits. Then i'll need to sand it all down again and primer + paint, then install Pics will be up later! Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 29, 2009 Author Share Posted November 29, 2009 sorry no spoiler yet: Quote Link to comment Share on other sites More sharing options...
Inferno 08 Posted November 29, 2009 Share Posted November 29, 2009 Looking great! Quote Link to comment Share on other sites More sharing options...
MAG58 Posted November 30, 2009 Share Posted November 30, 2009 HUGE Improvement in the month or so you've had it Quote Link to comment Share on other sites More sharing options...
Sketch_hs Posted November 30, 2009 Author Share Posted November 30, 2009 I got the spoiler on Some notes: Noticeably more stable at freeway speeds. Seems to have more grip on 70-80mph on ramps... might just be my confidence with the car improving though Here is something interesting for those suffering from bad exhaust smells: Driving around with stock bumpers (75) I noticed some smell, not too bad. With NO rear bumper I noticed LESS smell - hardly any. With the thin (240z) bumpers and no spoiler I noticed TERRIBLE exhaust smell at about 35-40mph... it was bad! After I added the spoiler the smell was greatly reduced again. About the same as no bumper or spoiler - not so bad at all for a catless car. Quote Link to comment Share on other sites More sharing options...
