flatrate Posted November 7, 2013 Share Posted November 7, 2013 Why do people think you need to send a engine across the world to be built properly?? I'm not understanding this at all.. Stay internal pickup wetsump. Find the gremlin!! Stick to the necessities.. There is enough info out there, i'm sure Rob will help guide you anyway you want.. People are make 500-800whp+ on stock block RB26's for xxx sake, stop reinventing the wheel guys... pistons/rods crank collar proper assembly and a good oil pump is all ya need to make reliable horsepower Obviously you have oiling issues, i would be removing everything, restrictor's plugs etc etc to ensure this one doesn't end up like the rest... Have the blocks mainline checked...i could go on and on, but any reputable machine shop building an unfamiliar engine should be ensuring this is all within exceptable limits.. Your oil pressure being as high as it is... that's an issue weather you agree or not.. more isn't always better.. sucking the sump dry worries me... all that extra stress on the crank and pump for no reason.. I'd like to see you stick with it.. it just wouldn't be as cool with a 2J in it Quote Link to comment Share on other sites More sharing options...
pat1 Posted November 7, 2013 Share Posted November 7, 2013 ^^^^^^^^^^ agreed 100%. Follow the K.I.S.S. Rule. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted January 13, 2014 Share Posted January 13, 2014 Sorry to see the bad luck. If you get desperate and want to do a contracted payment plan, we can talk numbers. You have my info. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted January 13, 2014 Share Posted January 13, 2014 Curious on the cage why you cut the diagonal bar and kept the harness bar solid? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted January 25, 2014 Author Share Posted January 25, 2014 Not required to have a one piece diagonal bar. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted February 2, 2014 Share Posted February 2, 2014 Not required by what? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted February 7, 2014 Author Share Posted February 7, 2014 HPDE, whatever they go by. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted February 17, 2014 Author Share Posted February 17, 2014 Hmmmmm number 7 main makes me nervous. Quote Link to comment Share on other sites More sharing options...
flatrate Posted February 27, 2014 Share Posted February 27, 2014 i believe thats still within factory specs, however i never run anything below .0015 on something that makes power are any of the journals or main line bores out of round? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted February 28, 2014 Author Share Posted February 28, 2014 Its been Aligned bored. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted February 28, 2014 Author Share Posted February 28, 2014 I would have swapped main bearing number 6 and 7. But what do I know... Quote Link to comment Share on other sites More sharing options...
flatrate Posted February 28, 2014 Share Posted February 28, 2014 On 2/28/2014 at 1:08 AM, ZT-R said: I would have swapped main bearing number 6 and 7. But what do I know... What bearings are you using? i normally measure bearing shells and they never vary that much how far out was the main line? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted March 1, 2014 Author Share Posted March 1, 2014 Im not sure. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted April 6, 2014 Author Share Posted April 6, 2014 This is the cometic exhaust gasket, what a pos.This is the tomei exhaust gasketCometicTomeiAlso on the crappy cometic gasket the rivets on the gaskets would need to be removed.So thankfully I have a mill so port match the big boy head ports.And for the grande finale Quote Link to comment Share on other sites More sharing options...
EF Ian Posted April 7, 2014 Share Posted April 7, 2014 Nice, hope it all goes well. Such a cool looking engine. I like the datalog and ant-lag swtiches, might do this on mine. Are you running AC or are you just using that panel to control the stock setup? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted April 8, 2014 Author Share Posted April 8, 2014 It has AC. Quote Link to comment Share on other sites More sharing options...
slowspeed Posted April 8, 2014 Share Posted April 8, 2014 Good to see you back in the game. Quote Link to comment Share on other sites More sharing options...
wrcbonk Posted April 9, 2014 Share Posted April 9, 2014 ZT-R, The "grande finale" is pure porn, thanks for the update. Bonk Quote Link to comment Share on other sites More sharing options...
flatrate Posted April 11, 2014 Share Posted April 11, 2014 Glad you stuck with it, find anything unusual? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted April 12, 2014 Author Share Posted April 12, 2014 Well the Rips lasted a lot longer. Unless noise and metal is usual for first change. 2.7 miles/9 minutes of running time. Quote Link to comment Share on other sites More sharing options...
