1 tuff z Posted March 28, 2015 Share Posted March 28, 2015 Andy, I have to say that you're posts certainly rank up there as most interesting and detailed [without being overly verbose]! Quote Link to comment Share on other sites More sharing options...
98blackbell Posted March 29, 2015 Share Posted March 29, 2015 Nice work. Have patience. Rpm not being recognized in tuner studio, or are not getting timing signal from the pickup? Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted April 15, 2015 Author Share Posted April 15, 2015 (edited) On 3/28/2015 at 8:26 PM, 1 tuff z said: Andy, I have to say that you're posts certainly rank up there as most interesting and detailed [without being overly verbose]! David, thank you for the wonderful sentiment. The kind words are thoroughly appreciated. If it doesn't read easy, no one (myself included) will read it. On 3/29/2015 at 2:04 PM, 98blackbell said: Nice work. Have patience. Rpm not being recognized in tuner studio, or are not getting timing signal from the pickup? Thank you, I am only getting a moment of RPM reading through tunerstudio on cranking. The most rpm I've seen and logged was around 160-170 rpm before the signal was lost...I, admittedly, have taken a small break from the efi portion and have swapped gears...I'm going to venture out there and check some wiring stuff, once again. Patience is indeed a virtue, however after 8 years of working on the car by myself, patience is sometimes on short supply. I've had to build this car twice because I'm teaching myself every step along the way. I'm ready to drive it. Okay. To date, I've only shown a couple pictures of my door panel progress. Here's the rundown of the process.... Took these pieces of garbage... And turned them into these plugs.. *Ignore the blue silicone/clay here - that was there initially as a molded vacuum channel while making molds, but we opted against it. * Tossed some of this junk on here. Surface coat of the mold. Dry cloth tacked in place. Infused. Popped, and trimmed. Release applied. First test door panel. Driver's appears to fit, I'm stoked. Made the passenger's today, and won't be able to test until Friday as I won't be going to work tomorrow. Almost a prototype! So much freaking work went into those damn door panels, I'm really happy to see them come to life. So at least I have that going for me. Edited April 15, 2015 by OldAndyAndTheSea 1 Quote Link to comment Share on other sites More sharing options...
Brendanm71240z Posted April 16, 2015 Share Posted April 16, 2015 Wow nice job! Any chance these will ever go up for sale? Quote Link to comment Share on other sites More sharing options...
150 Posted April 16, 2015 Share Posted April 16, 2015 I second Brendan.... My doors are falling apart Looks great though! Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted April 21, 2015 Author Share Posted April 21, 2015 ^^ Perhaps ...Lets see how they fit first. Front brakes arrived today. It's not often that I can just order a kit for this car..I'm really thankful for moments like these. More Techno Toy Tuning goodies.300mm slotted rotors. Two piece. Billet hats. Comparison of OEM 2-pot caliper to Wilwood Superlite 4-potThickness difference, between the previous setup and now.And because I'm that guy...Exciting! My laundry list of parts is getting smaller! Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted April 23, 2015 Author Share Posted April 23, 2015 (edited) Front OEM hubs - Early Scalloped style. (Before)Typical..Pull em...Clean..Powder: ENGAGESome goodies in the mail!ARP GM style long wheel stud bolts and replacement steering boots. Fancy!Here's the comparison from OEM stud length to the new ARP studs. Knurl was definitely comparable. I love how long they are too.And a quick, terrible, picture of the rotor assembly mocked.Looks delicious. Update/EDIT: Packed some wheel bearings tonight.Yay!I'll clean up the caps and pop those on tomorrow. This feels good.Chalk one up for Andy. Suck it car. Edited April 24, 2015 by OldAndyAndTheSea Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted April 25, 2015 Author Share Posted April 25, 2015 Mounted the calipers tonight.Here are the brackets.Bolted those onto the calipers.Loaded with Wilwood Sport pads.Awwwsheet...Pictures do no justice.Also installed my steering boots.Old - BaaaadNew - Good...And a sneak peak of what Monday/next week will bring. Exciting.Confidence is slowly returning with each successful task. Baby steps. Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted April 28, 2015 Author Share Posted April 28, 2015 (edited) Here's a composites update.Since I was able to successfully produce a skin that appears to fit the door(s), I needed to make a separate part for the felt window strip to attach to on the inside lip of the door panel.......So....another plug...I only care about the "square" edge and the top edge. I molded these plugs directly off the glass panels I have shown previously. These will make more sense in a minute. Made a mold from that..Then...... I infused the carbon driver's door panel and some glass top flange pieces to start testing the fitment.Lovely!Here's the top flange piece, roughly trimmed.Flange piece, tabbed in place. This inner edge is what the OEM window trim/felt attaches to.It also helps hold the door panel in place.Which brings me to fasteners........Instead of messing with interior clips, that just break, I opted for a slightly different approach.I enlarged four of the door panel clip holes to accept a 1/4-20 nut insert.Insert vs OEMTested on Ol' Crappy.The theory works. Awesome. Time to drill some holes into fresh carbon. I like. Edited April 28, 2015 by OldAndyAndTheSea Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted April 29, 2015 Share Posted April 29, 2015 Me like too! Quote Link to comment Share on other sites More sharing options...
seattlejester Posted April 29, 2015 Share Posted April 29, 2015 Me three! Looks real good sir Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted May 1, 2015 Author Share Posted May 1, 2015 (edited) Thanks guys, I am very happy with how they are turning out. More door panel goodness.It was an anxious day. Not only did I infuse the passenger carbon panel, which is always somewhat strenuous, I managed to actually fit the carbon door panel to my car. Had to hack into that beautiful laminate. Again, scary...But necessary.Pictures explain the rest. Needless to say, I'm pretty happy. Still need to locate, and drill hole for the door lock pull, and attach the inner window felt and it's done. Aside from a custom pull strap.Tomorrow I see if that panel looks, and fits, half as well as this one does.Progress! Edited May 1, 2015 by OldAndyAndTheSea Quote Link to comment Share on other sites More sharing options...
ryant67 Posted May 1, 2015 Share Posted May 1, 2015 Wow, you're getting really good with carbon fiber, man - those door panels look very professional! Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted May 1, 2015 Share Posted May 1, 2015 Those door panels really came out nice. Nice work. Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted May 3, 2015 Author Share Posted May 3, 2015 On 5/1/2015 at 2:08 AM, ryant67 said: Wow, you're getting really good with carbon fiber, man - those door panels look very professional! On 5/1/2015 at 6:08 AM, rturbo 930 said: Those door panels really came out nice. Nice work. Thanks guys. Although I ran into some trouble today... Long story short, the passenger's side doesn't fit in a way that allows the door to close easily.....sucks. I jinxed myself. This is the problem area. Stupid corner.... But I had a backup plan, should something like this arise. I never expected to nail fitment right out of the gate. ( I never do ) The driver's side truly shocked me. PLAN B: Two tone, using the OEM top. This is what I will most likely run on MY car. Except with alcantara wrapped around the OEM top piece, not the 42 year old vinyl. So my question to you guys, which do you prefer? The one piece? Or the two tone? Regardless, since I have a perfect driver's side (fitment wise) I'll modify the passenger's plug..etc.....to rectify the mistake. So looks like there are going to be two potential options. Nothing wrong with that...I guess. Quote Link to comment Share on other sites More sharing options...
ryant67 Posted May 3, 2015 Share Posted May 3, 2015 Actually, I'm really digging the two tone. The contrast really completes the look, and makes the carbon seem a little less showy. Understated, in a good way. Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted May 3, 2015 Author Share Posted May 3, 2015 Agreed. I always believe less is more. I love subtleties. This was always the plan for my car, but as mentioned with alcantara instead of vinyl.. But I figured, shoot for the moon (1 piece) but design in a fail safe (the two piece, which I knew was "easier" from the start). Thanks for the input. It is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
OldAndyAndTheSea Posted May 4, 2015 Author Share Posted May 4, 2015 Today I had some fun. Went to Jo Ann's fabric and bought some faux suede to wrap my OEM top sections.This is mostly some practice for the inevitable alcantara that will happen down the line.All I know is I couldn't be happier with how this is going to look. Exactly what I had imagined for so long. Very pleased, even just mocked in place, unattached, it looks great. And yes. That is the same fender welting that I've used on my flares and various other places on the car. Simple clean solution.I really like doing interior stuff like this. Very fun.Til next time. Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted May 4, 2015 Share Posted May 4, 2015 Amazing! Quote Link to comment Share on other sites More sharing options...
fyanrudger Posted May 4, 2015 Share Posted May 4, 2015 Would buy. Please sell. Quote Link to comment Share on other sites More sharing options...
