* * * * * 2 votes
Ford 8.8 IRS swap v2.0
  • Please log in to reply
38 replies to this topic
#1 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 104 posts
  • LocationDayton Ohio
Posted 16 May 2016 - 12:23 PM
Well with wfritts911 gone MIA, I've been left to develop my own Ford 8.8 Swap kit. This thread is the progress of the design and production.
Design is based on a 2002 Ford Explorer's 31 spline 8.8 inch independent rear diff.
I'm using drive shaft shop stub axles, they're not currently listed on their site, however you can call and order them.
*Note* though the ford cobra rear is almost the same, the axle seal diameters are different, and are not interchangeable.
At the moment I am prototyping the parts. I have yet to source materials or get quotes from machinists.
In the end these should be 6061 Aluminum.
Rear mounts.
Using Energy Suspensions Urethane bushings for the 240z.
3D printed the prototype to check fitment. There a great bar here in dayton called Proto BuildBar, they have a wall of 3D printers, a 3d scanner, soldering stations and all sorts of electrical supplies, its a geek's heaven.
Designed up the mustache bar specifically to the ford explorer's cover. (not the cobra sorry) Then had it cut out on my friend's router table.
The front mount is a modified ron tyler mount. I dont have images or photos of it yet.
Thats about the progress I have made so far, will keep you all posted!
Edited by spitsnaugle, 16 May 2016 - 04:28 PM.
1971/2 Datsun 240z, Currently swapping in a mild-built carb'd LS1.
Daily Driver: '09 Jetta Sportwagen TDI - Malone Tuned,  45+mpg
#2 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • PipPipPipPipPipPipPipPip
  • 5332 posts
  • LocationFlorence, Alabama
Posted 16 May 2016 - 12:45 PM
That's the freakin' balls!
1972 240z, purchased in 1991 for $900. Bone stock LS2/T56/DBW from 2006 GTO, swap completed in 2011. 400rwhp/435 rwtq. 2400# minus driver. JCI swap, Mantic ER2 clutch kit, JTR headers, single exhaust, Borla muffler, MGW shifter, M2 Differentials shortened Z31 CV axles, Z31 CLSD R200, Chequered Flag Racing billet stubs and companion flanges. MSD 2-step, Hurst roll control, both operated from switches on clutch pedal. 9" Hoosier drag slicks on Weld Draglites, 245/45/16 Hoosier A6/R6 on 16X8+10 Rota RBR. 225/250 sectioned coilovers, Koni 8610-1437RACE shocks, DP and EMI camber plates, MM shortened rear control arms, TTT front control arms, poly and aluminum bushings. Top speeds: Ohio Mile 174mph, C/GMS class record holder, best 1/8 mile 6.96 at 100mph, best 1/4-mile 11.0 at 126mph, best 60' 1.43, best 1/2-mile 148mph at GA 1/2-mile. Home Track-Jake's Dragway, Moulton, AL. SCCA autocross club - TVR, Huntsville, AL. Lets race!
#3 rturbo 930
rturbo 930
    Porschephile
  • Donating Members
  • 1488 posts
  • LocationNJ
Posted 16 May 2016 - 02:35 PM
I think you mean Ford 8.8 Diff swap. Anyway, I'll be following this one. I didn't care for the amount of things you have to change out to use Fritt's conversion. My plan was the following:
8.8 Diff, mounts, etc.
DSS stub axles
930 CVs
Custom length axle shaft
And an adapter to go between the 930 CV and the factory stub axle, like you'd use to convert to Z31 CVs.
Chequered Flag Joe actually makes that adapter, but only in 39 spline, I believe, and he sells it as part of a kit. I'm interested to see what you come up with. Something a little less spendy would be nice.
Owen | 1976 280Z | 1988 325is | 1986 Jetta | 1953 CJ3B
A car is a hole in the air, suspended there by four rubber doughnuts which you can not eat.
Into this hole, you throw money, which you will never see again.
#4 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 104 posts
Posted 16 May 2016 - 04:46 PM
Diff was implied. (there's two more threads by other users on the swap and neither uses diff in the title :P )
I am only making a front and rear diff mount for it. Everything else can be bought elsewhere if anyone really needs.
Zcardepot has a 27 and 39 spline companion flange. I thought Joe was the source. They also have a much cheaper billet aluminum adapter if you're risky.
#5 sectumsempra
sectumsempra
    Newbie
  • Donating Members
  • Pip
  • 19 posts
  • LocationAtlanta
Posted 16 May 2016 - 10:33 PM
Cool. I was gonna do the same thing. But if you're already working on them, I'll gladly buy your mounts instead.
#6 sectumsempra
sectumsempra
    Newbie
  • Donating Members
  • Pip
  • 19 posts
  • LocationAtlanta
Posted 16 May 2016 - 11:05 PM
I'll add, I think you should go with Delrin. But if not, I can machine some myself.
#7 lewydeeayy
lewydeeayy
    Newbie
  • Members
  • Pip
  • 4 posts
  • Locationchicago
Posted 25 May 2016 - 04:08 PM
THANK GLOB, any ETA?
#8 TrikeZ
TrikeZ
    Newbie
  • Donating Members
  • Pip
  • 23 posts
  • LocationYuba City, CA
Posted 30 May 2016 - 12:21 AM
Yeeeeeesssss!! Another chance! Stay strong, brother. Very interested.
#9 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 104 posts
Posted 31 May 2016 - 05:33 AM
No ETA yet, designing the dogleg/drop mounts right now, the originals are in the way of the diff. If the explorer rear cover's mounts were as narrow as the Z car it wouldnt be a problem, but at roughly 14" apart they line right up with the drop mounts for the control arms. I think the cobra's cover would clear without issues, but I've seen enough broken cobra covers to want to avoid that route.
#10 05plsrt4
05plsrt4
    Moving Up
  • Members
  • PipPip
  • 40 posts
  • LocationOntario
Posted 01 June 2016 - 03:02 PM
What if you incorporate a rear diff cover brace into the design. Then you can use the cobra diff cover and not worry about breaking it. Or go with a Ford Racing cover.
#11 DeathByNissan55
DeathByNissan55
    Moving Up
  • Members
  • PipPip
  • 26 posts
  • LocationMilwaukee, wi
Posted 02 June 2016 - 01:34 PM
How would this compare with the 8.8 from 1993 Lincoln Mark VIII, I know 89-97 will work, but I mean is the differential housing the only thing you're using from the host vehicle?
And just for background, I wanted to do this in a 77 280z that I'm in the process of LS/T56 swapping.
I was planning on having a drive shaft made at a local axle/shaft shop to mate to my T56.
Interested to see where this is going to go.
#12 JakeWard
JakeWard
    Junior Member
  • Donating Members
  • PipPip
  • 32 posts
  • LocationChico, CA
Posted 02 June 2016 - 03:01 PM
Interested to see where this goes too.
#13 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 104 posts
Posted 16 June 2016 - 09:23 AM
Done a quick 180° in a different mount design.
Flat 1/4" plate, sandwiched between differential case and rear cover.  Should allow any ford 8.8 rear to be used regardless of rear cover design.
I've drawn it out, should get it off the waterjet next week.
#14 smokehouse_83
smokehouse_83
    Newbie
  • Members
  • Pip
  • 11 posts
  • LocationNew Mexico
Posted 18 June 2016 - 11:21 AM
Great idea. Should help strengthen the case too
#15 KRAYZ
KRAYZ
    Junior Member
  • Members
  • PipPip
  • 32 posts
  • LocationBowie Md.
Posted 20 June 2016 - 03:03 PM
following..
Im in for one!!!
SPEED TOO MUCH IS NEVER ENOUGH!!!!
#16 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • 5332 posts
Posted 20 June 2016 - 08:37 PM
I'm sure you already thought of this, but:
If you are gonna take the cover off to install or remove the diff, be sure that you have good access to the fill plug and drain plug. It sucks to install a dry diff only to realize that you have no way to fill it. I would never do such a thing.....
#17 gijohnny23
gijohnny23
    Newbie
  • Members
  • Pip
  • 16 posts
  • LocationTn
Posted 04 August 2016 - 06:26 PM
Following
#18 donnydatsun
donnydatsun
    Newbie
  • Members
  • Pip
  • 6 posts
  • LocationManitowoc Wisconsin
Posted 13 August 2016 - 07:31 PM
I'm in for sure 100% for whatever u make!!!!! been waiting like 1 year to here from will
#19 yellowoctupus
yellowoctupus
    Member
  • Members
  • PipPipPipPip
  • 308 posts
  • LocationSilverdale, WA
Posted 20 September 2016 - 08:43 PM
FYI,
ZCar Depot 8.8   has put together a mount that is a perimeter cover mount, similar to what you mentioned making, I believe.
Still not 100% sold on their front mount though....
th_280z8.jpg?t=1288666770
Phil - 1978 280z + 4.6L SOHC DOHC Ford, just a 300hp Lincoln Engine Folks, nothing to see here....
#20 spitsnaugle
spitsnaugle
    Always Here
  • Members
  • PipPipPipPip
  • 104 posts
Posted 21 September 2016 - 05:28 AM
Sorry all, I'm extremely slow with remodeling my home at the same time.
I'm not sold on their front mount at all. And I dont like that it requires buying a new rear cover.
I was working with technoversions to revise their front mount for my use. I currently have my rear mount all designed up, but havent had a chance to make a test fit, check driveline angles to then figure out the proper height for the front.
I could use a couple measurements for a double check if anyone is interested.
I have a 71 240z, so I'd like to know if any later years vary- I want to know the distance from center line of the mustache bushing mount bolt to the center line of the axel. Accuracy is key.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
