- Today
inline6 changed their profile photo
Well while the z was in the back garage I pulled the exhaust off . I had tried something that I won’t do again but I used a square port gasket ( Nissan ) on my mn47 head with my square port header . I was getting some small leaks when I pressurized the exhaust during leak checks . I went back with the gasket to match the head which worked fine before . Also stared at the ITBS for a long time trying to figure out why #3 was sucking more air . As you can see in the pics the linkage was digging into the side of the ITB . Shining a light into the ports before hand did seem to show 3 open a hair more . It was such a small difference I can’t swear I did anything , but I’m betting it’s enough . I ended up just filing the tab on the linkage down . I also figured a way to run my coolant bypass on #6 . I’ll run it under my ITBS on top of the heat shield . Might also try again to run air for a remote IAC . It’s actually getting too busy under the ITBS . Also on the to do list is to find some different cooling fans . I want to run brushless for the versatility and power since I want to install AC . AC is ordered from AC solutions but that’s a month out at least . Cold air box got glued tonight . 75mm Stacks are getting printed out and I’m getting close to finalizing this long project !
- Yesterday
Help me evaluate this car for sale
A to Z replied to z_noob's topic in S30 Series - 240z, 260z, 280z
Buy the nicest one you can afford. Trust me. -
The video shows the best method of Removing paint and rust from your 240z in preparation for restoration. This Chemical Wash is the most complete method of stripping all paint and corrosion from the vehicle. It will even get inside every nook and cranny of the metal structure. Even, Abrasive Blasting can not get inside of the interior of the boxed metal. Also, after the chemical wash, a rust inhibitor is sprayed completely on the metal surface. This inhibitor will prevent even surface rust from forming for couple days to a week depending on the humidity of your area. But, Chassis Epoxy Paint should be appied as soon as possible to prevent surface rust from forming. The only Downside of this Cleaning process is Cost and Location of these Dipping Plants. The prices cost over $1500. The location of the Plants are few and far away( check Web for the closest one to you).
IF YOU GOT THE $$$$, CARBON SIGNAL can do the Complete Restoration.
240Z Restoration done in Indonesia-20 min video Look how many workers that are working on the restoration at the end. Just like a Army of Ants.
I'll take the scan if you still got it, appreciate you doing this. I have a scanner at work but its difficult to justify bringing home a $50k+ piece of equipment for the weekend XD
Another weekend of work has gone by, with my efforts spent on mounting the radiator. Time spent thinking of bracket design was more than I would have preferred. However, I did come up with something that will work well. Had I to do it again from scratch, I would use thicker sheet metal. What I have done here instead is fabricate up some brackets using some .032" (.8 mm) sheet. After test fitting them, I found it necessary to double up the part that bolts to the lower box channel of the radiator support. For the lower bolt hole in the bracket, I installed a rivet nut in the frame. For the upper hole (drilled after mounting the brackets using a bolt in the lower hole), I drilled through where the back face of the lower frame is spot welded to the front U section and used 6 mm x 1 mm bolts, washers and nuts. Being two layers thick at that part of the original frame box, it is pretty solid there. The lower brackets will handle the weight of a full radiator as well as g forces from bumps and braking. The rubber cushions support the radiator from the underside. To keep the radiator from shifting forward and back, or left and right, I came up with the idea to attach these brackets with holes that positively locate on the rubber mounts. Even with a lot of care when taking measurements, I ended up with holes needing to be offset toward the front instead of centered. Oh well. With this set of pictures showing the single top mount bracket, you can see a bit better how this design works. The bracket with the hole is 1/8" thick aluminum. That is riveted to the U channel at the top of the radiator. Another bracket which will bolt to the radiator support using an already existing welded in nut (7 mm with 1 mm thread), has a third rubber bumper bolted to it. This bumper positively locates the radiator via the hole in the bracket which is riveted to the radiator. The bumper in this upper bracket sandwiches the radiator (between the two lower bumpers and the upper bumper). I have also made the upper bracket with a rear, downturned flange. I will glue a piece of rubber insulator inside the back lip of this upper bracket. This will prevent the radiator from moving backward, as it might otherwise when the car is at high speed and air is pressing hard against the front of the radiator. I may need to come up with a similar type of flange to add at the bottom of the radiator for the same functionality. My clearances are so tight at between the fans and the front of the engine, that I need to ensure no rearward movement of the radiator can occur.
- Last week
People's Choice at a small cars and coffee in town this weekend. Brakes feel really good. It's weird feeling how firm the pedal is compared to the originals now that it's all stainless hoses and the rear has been upgraded. Even the parking brake is better than I expected! Getting wheels balanced today - I know for a fact one had a couple weights knocked off, I can see where the adhesive was, and I'm still upset about how many weights they used to balance one corner. Someone wasn't doing their job right when they mounted the tires I think, because there's no way you need two long strips on opposite sides to get a wheel balanced. -
Part 3-More Bodywork- In this version, the Mig Welding is also utilized in the restoration process. Part4-
Yet another LS 260z swap :)
christianmoller replied to christianmoller's topic in Gen III & IV Chevy V8Z Tech Board
Good evening gents I got my first inspection cleared with some minor things to fix so now i have five years to finish the build (he wanted to see me at the end of August ) . With that done i was able to pain all the weld, start interior work and mount the Datsun back up again, sooooo, it's done just waiting for my half shafts. The half shafts is actually the only thing that keeps me from a test run. Brakes, clutch are bled, emergency brake mounted, it's pretty much only interior work that has to be done Cheers Christian -
The car I had planned to do this on was going to run very low, so all the suspension pick-up points were raised 2+ inches. The upper mount was a plate that bolted into the upper strut mount and used an 8-inch-long jack bolt with a clevis for the top of the shock to bolt to. The tube holding the jack bolt would have a sheet metal bracket supporting the end of the threaded section, or I'd extend the cage tubes directly into this to make the mount stiffer. That was work still left to do. I have some Penske 7350 Base valve shocks (eBay specials) that I planned to revalve. These have 7 inches of travel, but I didn't plan to use all that, and are very long. This has now been on the back burner while I try and deal with some back health issues. I also have a street car that I want to finish and I have been looking at doing a-arms but using a bolt-in solution to not destroy any value the car may have. So I have been thinking about this more lately, which is why your post has piqued my interest.
07-19-2025. Well today was a day to get the car ready for it's updated radiator and fans, and do some other small work. I took both SPAL fans and tested them to ensure they work and that they spun in the right direction. Then I began the process of pulling the radiator out. I found that I needed some different bolts for the water pump pulley, and so while there I went ahead and got all new hardware for the radiator when it gets here. I bought some thick rubber washers to isolate the aluminum radiator fromt he car, to keep corrosion of the radiator at bay. After that I swapped out my radiator thermostat from the factory 180 temp to a 160 temp and then installed a new Speedo cable. I spent a little more and got one from the Z car Depot, partly because it comes with a new firewall grommet. Ready for more new parts to arrive! PICS: -
Well much rain is forecasted so I’m taking her off the road to attend to issues as in exhaust leak somewhere and # 3 port pulling more air than the others . Of course the only way to see the butterfly in the ITB is to remove it . I think the exhaust leak is at the header flange so that’s a remove project - ugh . I also think I might have pulled off my air box scheme . Taking me a while to get better at forming the plexiglass but the new buck is spot on for the most part . Hopefully I get all these issues resolved during the downtime . The engine is really running good but I’m hoping longer stacks will bring me into the sweet spot . A friend is printing out the 75mm stacks and I’ll probably also do a set of 90’mm . I think I have plenty of room to fit 90’s without impeding flow around them .
I agree, I reached out to Apex earlier this week asking about feasibility using the existing shock stroke with 400-450# springs. Yes, loading the outside tire on burm and then hitting an imperfection on the track seems like it would decimate one of these shocks (same with hitting kerbs/rumble strips) unless I find a way to get more travel. If I could get 5inches of travel I would be very happy but I will try for a full length (~6.5") shock design if I end up copying MMI's Mod 2. Very interesting, would definitely prefer welded to bolt-on but if everything fits up right I could end up using it as a way to test different upper wishbone lengths. The Griggs conversion looks like a pretty strong structure but I don't want to jump to conclusions quite yet. Do you have any photos of your work? Interested to see what your mounting solution looks like. If I can avoid trimming the strut tower and still get the full stroke shock I will.
I'd probably start in the 400 to 450 range given the tires then. The struts were stock-style reinforced 280Z bodies. Spring rates were for springs but if I remember correctly MR should be 0.97 or close. I can't find my notebook at the moment. It's all detailed in buried threads on this site. There's a lot of it in the shock/unsprung weight FAQ I think 5 inches should easily be enough for a track car. By burm do you mean a banked corner? I know a few people on this site run their cars at tracks with high oval-style corners, and perhaps they can chime in on what they see for travel. My wife has a '65 Mustang. That's a sweet kit from the look of it. My mock was very similar, except it used a Joe's style front 2-piece a-arm. So you only needed to have two holes for the A-arm to poke through. I was doing the upper mount similar to what Griggs uses on their Fox body conversion. It comes down from the stock Datsun upper strut mount.
Tire selection is Nankang CRS 200TW 245/40R17 front, 275/35R17 rear, I would use their AR-1 100TW however they do not offer a 275 section tire for that model. Car will be almost exclusively a track car but despite my spine's best interests it'll probably see a very occasional Sunday drive. Were these rates with OEM-style strut type suspension? What were your wheel rates? Maier's issue with the shock travel was that unlike an autoX/hillclimb car, a road course car would see burms and 3.5" total shock stroke just isn't enough. Great insight still, thank you. The kit just shipped about 3 hours ago (for better or for worse), when it arrives I'll be able to get those measurements to see. When you say "adequate travel" I'm assuming a that refers to just enough travel for the ~3 inches of travel you've needed for your own car? I'm assuming if I want something closer to 5-6" travel, the upper arms would need to be closer to a foot long. That's what I'm finding as well just looking at Maier's Mod 2 front axle suspension kit. Complete replacement of the front strut towers moving the pickup points slightly upward and a few inches inward to increase clearance between the coilover and upper control arm. I'm not opposed to doing this and I could even keep most of the Apex kit except for probably both the wishbones. Ah yes, old stockcar components on eBay, a true goldmine for (hopefully) decent parts. Definitely have looked at sourcing a fuel cell and oil coolers from there. Luckily I have access to rapid prototyping equipment and fabrication tools so I'm good to go. Not the best welder or anything but I know a few. Thanks for your help tube80z. Only other gripe I have with this design is on the rear subframe; the differential and control arms mount on the same structure and that seems like an exceptionally suboptimal design choice. Time will tell I suppose.
Car is finally back on the ground after waiting entirely too long on mismatched parts and alternatives when the flare on one brake hose broke. I was worried about the E brake capability based on some reviews but it seems like it's plenty capable on even a gentle hill after adjusting. at worst it's comparable to the original parking brake ability, but with less adjustment to do not. Not that drums were terribly complicated, but adjusting them properly was tedious. -
Hi Carlton, A lot of this has been hashed out over the years. There are some helpful stickies available in the FAQs for selecting damper and spring rates that you may want to refer to. Before you get too far into recommendations about springs, etc., would you tell us what you intend to use this car for (track only, dual purpose, autox, street, etc.) as this will help give you better recommendations. It would also be helpful to know what you intend to use for tires, as this is one of the most important factors to know. Low-profile radials will require softer springs than a higher sidewall racing tire (such as a slick, R-compound, or HP 200 TW). The more grip the tires can generate, the higher the spring rate needed to be able to deal with the forces that take up suspension travel. I'd agree with Mike Maier's criticisms of the Apex upper A-arm on the front suspension. It is going to always limit the amount of available suspension travel that can be used. With regards to how much travel you need, that will depend a lot on tires and the use of the car. On my autoX/hillclimb 240 that weighed 1850 or 2050, depending on class, I ran Hoosier bias-ply racing slicks and some of their radial slicks. The spring rates I typically used were 400 to 600 lbs/in on the front and 400 to 550 lbs/in on the rear. This car was droop limited, and front suspension travel on the roughest hill was typically less than 2.75 inches in the front and 3.5 inches in the rear. I experimented with softer and stiffer rates but found this range worked best. A friend's street legal dual-purpose car running on 200 TW or R comp low-profile tires weighed 2400+ (LS and T-56). This car was happier with 375 on 450 spring rates. It was also droop limited and I found out how horrible this made the car ride on normal street drives. So if you go down this path I'd recommend a quick disconnect when not needing the limited travel. My personal feelings on the Apex upper a-arm are that it should be about 7 inches long to get adequate travel. On my a-arm mock ups, the only reliable way I could see doing this was to use holes or pockets on the inner fender that allowed moving the inner pickup to the center of the frame rail. Then it looks more like a '90s to 2000s Mustang strut to a-arm conversion. The parts to do this are that bad if you use circle track components, and you can source used parts from eBay for trying out different ideas. This requires you to have access to fab equipment, so if you don't, this isn't a road to go down. Cary
Got an alignment done after adjusting everything. Front: 1/16 toe in -1.4 camber +5.5 caster Rear: 1/16 toe in -.5 camber
TestaRossa joined the community
Spoke to Mike Maier today seeing as the front suspension is most similar to that of an old Mustang. I wish I could write notes faster because holy hell that man is a wealth of knowledge. Suggested the reason for high spring rates is to prevent the upper control arm from camming over (poor arm design) and that the 3.5" of travel is definitely not enough for a road racing/track car (burms). Looks like my next steps are installing an adjustable upper ball joint that can move up/down to change the coilover angle and shock pot it at ride height looking for the lowest load value. If no substantial gains can be made there it's either back to the drawing board to make a push/pull rod cantilever or cut out the shock towers entirely and try to copy MMI's own Mod 2 strut tower modifications as well as new control arm(s) to gain the ability to mount a full length shock to the lower wishbone. This is becoming more and more of a fully custom project by the day.
TR's 260z L28 Build Thread
Tisk, late again! Back in early June I took the plunge and ripped out MS2 and EDIS, to completely rewire for MS3 Pro Mini with LS3 COP, a dedicated relay box, flex fuel, dizzy signal from a Jeep CAS for sequential fuel, and more sensors. I ran into some interesting issues. On the MS3 1.6 firmware I found a bug where Fan Control would not work properly on the PWM-Idle output, so I had to run 1.6.2 beta2. Oddly, having swapped to directly feeding MS3 from my crank VR sensor (instead of EDIS), triggering the fan was causing a phantom RPM signal to fire the injectors and coils thinking the engine was starting. I suspect my troubleshooting of that may have fried the firmware on my LC1, so I ended up upgrading to an LC2 which reads much smoother! I still need to figure out what's causing that, but so far I'm not seeing noticeable effects when the fan kicks on and the engine is running. To get my E85/Flex going I still need to cut bend and replumb my engine bay fuel lines through the new sensor, and I haven't wrapped the harness so no pics just yet. Eventually I also need to modify the Jeep CAS to fit the L28 slotted drive so I can get going with sequential. Still, it's running so much smoother on semi-sequential rather than batch mode. The AFR and fuel pressure safety features are also a godsend! -
What is your Rear End Gear Ratio? You probably should be running 4:11 or lower. Also, what size slicks do you have?
A simple solution for door slamming problem? I finally finished my 8.8 Super Duty 8.8 Differential Conversion so I had time to handle all those small detail work. During my restoration work, I used Precision Weather Stripping to my worn OEM ones. But the Precision Weather Stripping always seemed too stiff for its job. So anyway, I gave them about 4 months but still had to slam the door to seat the weather stripping. It never got better so I know some members used late model KIA weather stripping from Amazon and good results. So I tried the Kia weather stripping. It was a lot softer but still had to slam the door. I decided to remove the Door Latch and study its operation. After removing it, I cleaned it and lubricated it with White Grease. Everthing seemed tested fine when it was out of the car. But after installation, the problem was still there. The Door Latch seemed like it still needed a little more inward movement to function properly. So with the Door Latch installed, I watched the Locking Mechanism operation. As the Door Glass was not installed yet, you have a good view of the Locking operation. this is when I noticed that one of the Latch Mounting Phillips Screws( 6mm x 1.0) was hitting the Linkage. This Screw is 4MM too long. The Easy Solution was to cut off about 4MM of the threaded end of the screw. Pic of the Long Phillips Screw-Inner Bottom Mounting Latch one. ". , Pic of "Corrected Phillips Screw" I really don't know when the Phillips Screw was mistakenly replaced with a Longer One. Owning the 240Z for 54 years, I am sure I removed the Door Latch at least 4 times. Anyway, if you are having Door Slamming Problems, check the LATCH MOUNTING SCREWS. It was a Simple Solution for me, maybe for you, too.
Update From Apex: Front • Motion ratio: 0.92 : 1 (wheel : shock) • Wheel rate: 0.92² × 600 lb/in ≈ 510 lb/in • Wheel travel with 3.5" shock stroke: ≈ 3.2" Rear • Rocker motion ratio: 1.00 : 1 • Wheel rate: 700 lb/in • Wheel travel with 3.5" shock stroke: 3.5" Some confusing design and hardware choices here. Using a bellcrank/rocker with a 1:1 motion ratio doesn't take full advantage of the system. I will end up designing and having manufactured a new billet bellcrank/rocker with a lower motion ratio to get more shock travel. Highly likely I'll source a Hyperco spring at a different rate but that'll be handled during the bellcrank redesign and is a straight forward task. The front axle is giving me some headaches. The lack of suspension travel could be fixed by adding a bellcrank/rocker, but there isn’t enough space to fit one between the top of the strut tower and the hood. Making room would require major cutting and fabrication to the strut towers. Mike Maier Inc.'s solution to a similar problem was to completely replace the original shock towers with a custom design, allowing a full-length shock to mount higher and further inboard. On the Z, moving the strut tower further inboard could create enough clearance between the upper control arm to let a coilover mount to the lower control arm. But by that point, I'm only a few steps away from designing a fully bespoke 1:1 double wishbone kit, making the OTS kit a useless purchase. I've been drawing up some concept sketches on how I could possibly do a pull rod but that would render the OEM strut tower essentially useless. Alternative to implementing a front axle rocker would be to modify the upper wishbone where the bottom of the coilover mounts to be further inboard which would lower the motion ratio more but I'm not keen on trying that solution. I think I need a sanity check, I'm used to working on strut-type suspensions that have decently high shock travel to the point where coil-bind is a more pressing issue at low ride heights. Is there another solution to a short shock stroke and high spring rate I'm not considering? Or is this a case where the problem is all in my head and having 3-3.5" of shock stroke isn't that big of a deal? I've spoken to Rob Fuller from ZCarGarage regarding this problem who had some great insights on Z suspension, unfortunately he wasn't able to help me much past confirming that the wheel rates are ludicrously high. I'm aiming for a front axle wheel rate in the range of 300# to 450# and even then 450# still seems extremely high for the front axle.
Who's Online 2 Members, 0 Anonymous, 886 Guests (See full list)
