    33359
    5167
    globeclk
    globeclk
  1. Yesterday
  2. Super common with the L series engines. When setting the distributor spindle by mounting the oil pump the drive gear turns the spindle as it engages the crankshaft gear. Suggestions: - Yup, verify TDC with a piston stop - easiest way. Remember that the piston movement slows at the top of the crank arc so the crank can travel quite a few degrees with little movement shown on the piston. If you're really good you could probably ferret out TDC with a straw, pencil, screwdriver, etc. down the #1 spark plug hole, but piston stop will nail it when used correctly. Mark it correctly on the pulley if actual TDC doesn't match the indicator. - The pictures in the FSM of correct spindle alignment cause more confusion than enlightenment. Also rarely do you get a good picture at a proper angle from anyone else. I've found it easier to set the approximate spindle position (with the top angled slightly left) and then set the distributor on temporarily and see where the rotor points. You can mark the distributor cap #1 wire position on the distributor body. At TDC, the rotor should be coming in contact with that #1 cap position. Notice that there is a wide arc to the rotor contact and quite a bit of adjustment in the distributor so what you think may be "close enough" may well be the exact thing you need. I'm usually dyslectic about which way to adjust the spindle when putting up the oil pump and it generally takes me several tries so I never bolt it down with a four bolts. I use one bolt, snugged into position, until I'm pretty sure the spindle lines up correctly. There it helps to have a helper who knows how you want it to look after you've pushed it up...
  3. Just ordered. $12 but shipped "free" - so... I'd like to source the rubber boots - they don't last here in Arizona.
  4. can't believe its been almost a month since an update. got the exhaust done, made a tip from stainless. Got the wastegate tube recirculated, header and downpipe wrapped. Have been wiring away. Running an ecumaster emublack ecu and a hardwire electronics PDM25. Both of which are new to me. Got the engine harness done and chassis harness started. thinking thru everything has been a challenge but so far so good. Have the PDM powering all the lights and the ECU functions. Have the factory blinker stalk controlling the blinkers, and high beam functions. Factory brake pedal sensor for brake lights and Blink marine 12 button can keypad controlling some other functions. A couple days ago i did get it to start and that was a huge relief after this long process and "freshish" engine. oil pressure is great. engine is quiet. so very motivating. 20260707_210144.mp4
  5. @senna21, how about these? https://jdm-car-parts.com/products/fuel-sender-wire-connector-2-pc-set-for-datsun-240z-260z-early-510-620-720?variant=29670929727597&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&srsltid=AfmBOorswWtJKDRvuU-hfe5UDlY1phSIFSARxMWNfFZ-r4scgyYypB9VdXI When I've needed new connectors for mine, I've usually just fashioned them from standard female blade electrical connectors. Not the most elegant solution, but they haven't failed yet.
  6. 07-09-2026 ATLAS Z UPDATE: Installed the intake piping. You can see the inspection door covers on the car from ZOCIETY, still just laying there I haven't bonded them down yet. Time to finish caulking in the carbon panels and then clear coat over the blue patina paint. PICS:
  7. Last week
  8. 07-08-2026 ATLAS Z UPDATE. I picked up my intake pipe and MAF Meter cover plate from my polisher, J&S Polishing here in Colorado Springs today. int he pics, I just laid it in place, not installed yet. His ability to take my cobbled together crap and make it look fantastic is true magic. PICS:
  9. 07-07-2026 ATLAS Z UPDATE: I picked up a set of carbon fiber covers for the hood inspection doors from ZOCIETY. Many ways to attach them, I will try silicone first. Since my inspection doors are powder coated, I will do a light scuff and then bond them on with pure silicone, taped down overnight. By the way, they are TOP QUALITY. $360 bucks.
  10. 07-05-2026 ATLAS Z UPDATE: I finished feathering out the remaining blue paint, got it nice and smooth, then blew the car off and taped up the front fender and went ahead and caulked the seams. 260Z Fender Badge placement on the fenders looks good. Poppy's Patina Gloss arrives tomorrow, so we continue on! PICS:
  11. 07-04-2026 ATLAS Z UPDATE. HAPPY 4TH OF JULY! I removed the front bumper and traced out and cut some spots in the carbon fiber to allow it to fit properly and re-installed the bumper. The edges will be hidden under a thin line of black silicone caulk. I also cut some aluminum stock I had and placed it under the intercooler and Tek screwed it down. it is basically just helping to support the weight. The 260Z fender emblems are on, taped to sit overnight and let the silicone cure. The rest of the day was spent fixing the other Z car I have. PICS:
  12. I stopped by the CAT scales to finally weigh this thing. 2680lbs It's an early 74 260z I weigh ~205lbs Full tank of gas, and all other fluids obviously 240z bumpers Full carpet, interior, and full butyl matted (except for doors) No compressor, blower fan, or any HVAC components in dash This is an L28et swap, no emissions stuff, mostly everything stripped out of the engine bay that doesn't need to be there Full painless wiring harness Aluminum radiator Braille 15lb battery No spare tire 2 Acura RSX seats (I think the still have the side airbag modules in them, woops) BC racing coilovers 4runner front brakes, Maxima rears TL70 6 speed swap 16in konig wheels w/ 250 55 tires 3in aluminized steel exhaust w/2 resonators only I have probably another 10lbs in random tools, my laptop, etc..
  13. Earlier
  14. I just put a Sanden 508 on my 1976 280z. I ended up using a slightly thinner Belt that fits the AC Compressor pulley properly. This thinner belt sits deeper in the Crank AC pulley, but doesn't bottom out. I used the Z Car Depot bracket. I'll see if I can find the Belt Part Number. I had to go down a little in size as well. Think I ended up with a 4L-340mm Belt
  15. I looked on your site but I didn't see a product like this listed. Is there a benefit to this setup besides just not needing to change the rack? Is there a feel difference?
  16. PART 18- GULL WINGS DOORS RUNS INTO A PROBLEM The Gull Wing Doors run into a problem with the Roof Shape turn into the Vertical Window Shape. That Tight Shape creates additional fabrication work. Another problem coming up will be how to seal the Gull Wing Doors with weatherstripping and create enough gapping around the Wing Doors.
  17. 07-01-2026 ATLAS Z UPDATE: Well in between working on my other Z, I am still working on this Z car. I went ahead and started working on getting the blue painted portions of the body ready for clear coating, and caulking the border of the carbon fiber pieces. Initially I had planned to paint on a fresh coat of factory blue before clear, but I think I may go with the patina finish that is left after smoothing out the paint and getting it ready for the next step. Using "Poppy's Patina" in a high gloss finish....2 coats.....apply and then the next day apply again for 2 coats is the plan for now. This car is meant to just have fun with. It's the project car while I have the other Z anyway. my 240Z is giving me some timing issues to contend with so I have plenty to do. Also put my water meth pump on some steel to start getting the ideas flowing. PICS:
  18. As far as i know from being in the 240sx world is the s15 6 speed is geared better for performance driving but is weaker than the s14 5 speed but i think the nismo one is advertised as fixing some of the weak points.
  19. Last weekend I went to my first classic car event with the 280z which was a lot of fun. To my surprise I wasn’t the only Datsun at the event. A bit later a one owner Datsun 1200 coupe (talk about rare) and an early 300zx also showed up. On my way back home in the Z cruising along at approximately 75mph she decided I didn’t spend quit enough money on it yet and turned my 5 speed into a 4 speed transmission. What probably happened was the main shaft nut backed off. Guess this is another nice surprise left behind from the previous owners “restauration”. Surprisingly the car still shifts into reverse and doesn’t pop out, 5th gear just acts as an extra neutral now. For now I will need to find a replacement FS5W71B gearbox or modify another 71 series gearbox to fit the Z. I know a guy who bought a 280ZX 5 speed as a spare 25 years back and is willing to sell it to me for €800. It’s ether that or trying to find the correct parts for a pre 80’s 71B and rebuilding mine myself. There is a local shop that builds rally cars out of S30 Z’s who can sell me a rebuild ZX 71B or modified S14 71C close ratio transmission but those cost €4k-€6k. For that price its more interesting to swap in a modified brand new NISMO S15 6 speed from Japan. Escort makes them to fit the L series engines complete with mechanical speedo connection and CNC transmission crossmember. Anyway I guess that’s just the life with a classic car…..
  20. @74_5.0L_Z thanks for the pick of your radiator frame, I had thought you maybe had an intercooler stacked up from previous pic. I ended up going with a dual pass radiator so I had have both inlet and outlet on the same side. I’m thinking of going with 20AN fittings, so I’ll 90 off the radiator and cut to the driver side.
  21. It looks like the radiator in your picture has the lower outlet in the wrong side. I use a Griffin 24x19 P/N 56202-XS with the driver's side lower outlet. I had them make it with the inlet angled straight out of the core rather than angled. The radiator snugly fits into an aluminum frame that is bolted to the frame rails, and is retained by the hood when it is closed.
  22. Radiator came in, made a mistake on sizing it, but I think it still works just fine sitting on the frame rails, thoughts? Or should it get something skinnier that fits between the frame rails. I like the built in tray on this bumper, I’ll add some ducting that just continues this on to that bottom rail and continue it past to the end of the radiator.
  23. Hi, resurrecting this post as I'm in need of the connectors as well. Were you able to find another source for them and if so, where? Thank you in advance, Cw
  24. Yeah, I’ve already got the next size up and I’ve been happy with it.
  25. 06-28-2026 ATLAS Z UPDATE. The amount of work done today was hampered by work I needed to start on my 240Z, but I then made time to knock out a few things on the ATLAS Z today. The way my MAF meter sits in the piping is functional, but looks bad. I decided to take some left over 4" tubing, and cut it in half and form it to fit over that area, which will make it look like one solid piece, I will get it polished along with the last piece which is finished (I jsut need to go pick up and then drop off at the polishers). I then did the hood pin for my "window frame" hood. I am using one hood pin, and I bought it off of amazon, with the striker plate in black versus chrome. I then took the number decals I ordered for the car and lightly taped them on there to see what I think. They are supposed to be adhesive, but they have a weird clear coating over them I have to figure out. PICS:
  26. i've had good luck with that exact husky tool box. I don't think for the money you can do better.
  27. No sir. The ZPS prototype was fitted in 2011. That EZ setup is similar, but it doesn't use torque sensors or an ECU. It's also substantially more expensive. There IS a company that "copied" our design, but they use an inferior motor that isn't for automotive use. Found it odd that they ordered two of our units back in 2014. We've also developed an electrohydraulic system for those wanting to retain a hydraulically-powered rack, but don't want a traditional PS pump hanging off their engine. Ours uses an electric PS pump with remote reservoir (not as popular as the original ZPS kit, but a number of V8 swap S30 guys have bought one. Hope that's all helpful!
  28. Got a new tool chest, been accumulating a lot of tools with this build and ran out of room to store everything. Space is limited in my garage so this will get a pile off the ground. Took a break from the heat and built two panels in the nice A/C. First panel is for anything not tied to emergency cut off like locks/lights/signals, with cut off solenoid on bottom to feed the second panel. Second panel has 3 250amp relays to power a relay box, fuse box and distribution block each running off of ignition 1, 2 or accessory position of push button start. Not sure if that’s the right way to do it, but that’s what I’m going with for now. I’ll get back to the garage and work on some other projects next.
  • Who's Online   0 Members, 0 Anonymous, 452 Guests (See full list)
