    33447
    5167
    BIGBOSS240Z
    BIGBOSS240Z
  1. Yesterday
  2. I have been chasing software bugs all week, basically going from a bare bones Haltech Elite 750 to their fancy R3' Hopefully it starts today
  3. 11-11-2026. I Picked up the intake for my ATLAS 5 cylinder turbo build from the powder coaters. it is "polished aluminum" color .
  4. Last week
  5. I don't think so, it's going to be a wonderful street / track car. To make 300hpb you would have a good looking dyno graph and a pain in the ass car to drive. From the math, all your parts are really well matched to your head and it's purpose. When will it be running? Again, it's just a dyno simulation, so we will see
  6. Thanks. I’m excited to start working on the interior. Hopefully I can get this motor in soon, then on to the inside.
  7. Gosh 240hp would be pretty bad for the amount of time put into my motor:) I guess time will tell
  8. Hi Duffy, here's some more of the info I promised. Looking at your port size and flow numbers, I think your engine is pretty well suited to a 7,000 RPM power peak. Going with a much larger cam might shift the powerband higher without gaining much peak HP, especially given the head's airflow limitations. For a street-driven car, I'd favor average horsepower over chasing a higher RPM peak. I built my cam calculator around Kameari's range of cam profiles, with a dropdown for Street, Sport, Track, or Race to help determine the intended powerband. I originally had your engine set to Sport, which recommends the Kameari 70A at 241° @ 1 mm, or 232° @ .050" . Switching to Track changes the recommendation to the 73A at 253° @ 1 mm, or 244° @ .050". Your Bonk cam is 240° @ .050", putting it right between those two recommendations. So far, I'd say you made a pretty good cam choice. here is the cam recommendation tab in my calculator cam.pdf Next I'll show you the EAP simulated dyno curves for the different cams so you can see how they compare. I loaded all the engine parameters into my analysis program to compare the cams Here are the results. Of course some assumptions as usual, as I did not put the Bonk cam on my cam stand to actually measure its profile, so it is a educated guess where the Kameari cams are documented. As expected a little more top end a little less midrange but all in a good range for what you are building As a final note, in the calculator the simulation assumes ideal conditions, and these are engine numbers at the flywheel. so I would be very surprised to see these actual number, especially on a chassis dyno. What's important is the shape of the plot and getting the power where you want it and how you want it. This last one is my best guess of what your car should be around on a chassis dyno, 12% drivetrain loss and some reduction for real world conditions
  9. Very nice work (everywhere, on all components). I like the cool vintage-look inserts on the seats! 👍
  10. 11-08-2026. I finally got the broken exhaust manifold bolt out, got the new studs installed and then got the turbo header from Forever Fabrication mocked up on there, and re-clocked the Turbo and have it mocked up on there as well. PICS.
  11. Welded the AN fitting on the oil pan, and my seats came came in 💪
  12. PART 20- WHAT HAPPENED TO THE SEMA SHOW 2026 260Z WITH GULL WING DOORS? wee, That is a good question. The Last Show they were still working on the Gull Wing Doors. Now the Here is the latest video from them but there was alot of unfinished customer cars in different stages of restoration but not completed. Let hope that 260z will somehow be completed and not just trashed. Please Comment about any unfinished project 2 cars that you might know of so other people can learn of the all of potential outcomes of their Dream Cars.
  13. 11-07-2026. Today was devoted to just the valve cover. I cut off all the tabs and brackets not needed, then trimmed off some of the "stubs" for wire ties, etc. and drilled out the 2 back breather ports for weld in female threaded -10 ORB fittings. I already have the screw in fittings, so that will be great. I also went ahead and drilled out the back portion for the oil fill bracket. To do this drilling, I had to carefully remove the baffles, which are VERY thin aluminum. I then chopped off the factory oil fill port ont he front chain cover and ground it down flush, and then took a piece of aluminum I had and made a plug to fit. Everything will now welded up, sanded smooth, and then the cover will go for a complete polishing at J&S Polishing in Colorado Springs. I had planned on cutting the chain cover potion down, but after taking measurements, the clearance is needed, ....I needed what was there so it will stay at this height.....it is different, as with the 6 cylinder cover, I had to take out approximately 3/4 inch. Progress pics follow. Cheers!
  14. For round ports like ours, these do alright, find the smallest location, and then measure this telescoping gauge with calipers , But remember diameter is different than area. With the diameter you can calculate area with an easy online calculator if you forget how to do it.
  15. Super interesting read! Thank you. Today I learned about MCA (minimum cross-sectional area) in the port and how it relates to choosing a bottom end. Love it. What's the easiest way to measure the MCA in the port?
  16. 11-06-2026. Today I picked up the intake and fuel rail and thermostat housing. I then dropped off the intake to get powdercoated in "polished aluminum" finish. The fuel rail, work was simply turning and refitting the pipe to work better when hooking up the fuel line. Thermostat housing was for clearance. PICS
  17. Earlier
  18. I think both chassis are doable if you can get the engineering of the rear engine layout to work. If the rear engine layout doesn’t work out great then I suggest looking at a mid-engine layout in a 2+2. As a bonus the 2+2 is usually a lot cheaper as they are less desirable, at least here in Europe. I would suggest starting with a really good 3D model or scan of a S30 Z (model and year doesn’t matter to much) and try and work out the engine and transmission placement as much as possible while leaving the rear taillight panels in place. The rest doesn’t matter for now. This is an ambitious project but I’m really excited to see how you’ll handle it.
  19. Duffy thanks, this lets me complete most of the analysis. Lets have a look at the basics first, I've adjusted details too better match your set up. I've also set it to track given your cam choice as it is better suited for higher RPM power and the resultant port sizing based on what you told me (Intake) Exhaust Intake Valve Exhaust valve Bowls so far all your specs align quite nicely with the workbook prediction for an optimal engine for trackish use with a 7000rpm peak power band. Ill get you runner length specs tomorrow and simulated dyno run numbers
  20. 11-05-2026. CHANGE OF PLANS. I am no longer going with the 4L60e automatic transmission. I got a 5 speed AR5 manual transmission for this build. 62K original mile unit inbound. Just couldn't get excited about the auto no matter how modified I was going to build it.
  21. I am getting roughly 294.5mm +-.25mm total length from head flange to velocity stack bell. Throttles with the stacks are =153mm Phenolic spacers =10mm Intake = (harder to measure since it isn't straight at all, center of bore to center of bore is 131.5mm Stacks have a max opening of 80mm, they taper down to 50mm at the throttle opening, then 48mm throttle blades, then 45mm at the intake to throttle flange. Then slowly taper to the port size of 37.08
  22. Thanks Mitchel, great tips, and the 250 GTO comparison made my day. Since the 2+2's extra length is in the doors, I'm thinking of using the shorter two-seater door and moving the rear wheel wells forward to take up that space. The car stays the same length. Does that sound doable from a chassis standpoint? I'll also take your advice on the radiators and fuel cell up front, water-to-air intercoolers, the front air dam and ducktail, and the cage. I'll check out Haltech too.
  23. I could be wrong but I believe the extra length of the 2+2 sits mainly in the doors and middle of the car. That should make the rear wheel hub to rear body distance the same as a 2 door 280z. As the extra length of the 2+2 sits in front of the rear axle would it not be more beneficial to rotate the assembly and consider a mid-engine layout? I’m no 2+2 expert so I can only use my 2 seater ’77 280z as a reverence but this might give you more room to work with and eliminate the rear weight bias. Also consider adding some aerodynamic improvements to the car (especially the front) as the S30 Z’s naturally gain lift add speed. A front spoiler or air dam in combination with a ducktail spoiler should be enough for most Z’s. As for your other questions, if you brace the subframe good enough and also add a roll gage then I wouldn’t be that afraid of rear body twisting. Just extend the roll cage toward the rear and trinucleate the rear quarters. As for cooling I would keep the radiators in the front together with a good size fuel cell and use water to air intercoolers for the turbo’s as you still want to increase front weight. As for ECU’s it’s mainly up to (the tuners) preference, I personally like halltech as they have a lot of support and pre made aftermarket engine harnesses. But the most important thing is just doing what you really want to do and making your dream a reality. I really like the idea of this project and love the renderings, the front arches reminds me a bit of a 250 GTO.
  24. Hi Duffy, I calculate it from seat to bell mouth end but I already know port length, so Intake runner length from Head flange to Throttle body. (I was guessing 110mm), TB Length of 88mm long, another guess, and 65mm velocity stacks a third guess, so it will be good to know exactly, thanks
  25. How would you like intake runner length? Total from the stacks to the head? Cam is .525" lift and duration of 240 @ .05 valve lift
  26. Thanks for the honest feedback, everyone. rturbo, flatout, I hear you on the weight bias. flatout, your packaging math is exactly what I needed. I'm planning to move the rear axle line forward with a shorter 2-seater door so the transaxle outputs line up and the halfshaft angles stay under 15°. That should pull more of the VR30 inside the wheelbase. I know it'll still be tail-heavy, so I'm planning a reinforced rear subframe, a cage, and coilovers tuned for it. On budget and experience, I'm going in eyes open and doing as much of the work myself as I can. Still hoping a 2+2 owner can share the hub-to-bumper measurement so I can firm up the numbers.
  • Who's Online   0 Members, 0 Anonymous, 1811 Guests (See full list)
