- Yesterday
Quite a few updates since 2025: - re-installed my re-surfaced cylinder head with new valve seals and springs, OEM head gasket. No more oil leaks. - Installed a brand new fuel tank from s30.world. Great marksmanship, looks original, sturdy. This cured all my previous issues with running lean conditions. There was some rust at the bottom of the tank, and I am sure, around the fuel line sock creating fuel delivery problems. It is too bad it took me a while to find it out. I was visually checking my external Fram fuel filter for any debris and it didn't have any. My assumption was that the fuel tank was clean as well. Now the fuel pressure is solid, the car is fun to drive. My old '76 fuel tank is for sale. - still tinkering with fuel VE table and accel enrichment settings in Microsquirt. If anyone is interested in my latest tune/log files, they are at: https://www.msextra.com/forums/viewtopic.php?t=83416&sid=a50f6a4d099311ccc633f94cab012ebe I thought setting up closed-loop idle was hard, the accel enrichment is definitely in the same category.
10-11-2026 ATLAS Z UPDATE. CLUTCH AND BRAKE BLEEDING. So, I drug out my Motive Power Bleeder, and hooked it all up and filled it with DOT 5 fluid to "charge" the new brake system, which is all dry. I started with the clutch, which went VERY fast, and It's crazy how stiff the clutch pressure plate is! Then I went to the brakes. It's pretty involved when everything is new, and compeltely dry. So, after playing around for quite a while with it, I then settled on doing it all one step at a time......a bled the master cylinder out with it's drains, both cylinders, then started the process....using the 15 psi, I was able to get the rear brakes bled out, and the passenger front wheel.....but then found the driver's front wouldnt drain unless I pumped the brake pedal AND used the pressure, so something is wrong. I can push the pedal to the floor. not completely dead, pedaled but still...... After getting chat GPT to help me, I went through the line from the brake caliper back step by step and found that no fluid was coming out of the factory port. So, I will have to get a T fitting and go off the port for the passenger front wheel and then it will be like the rear brakes are, both off the rear brake port. VERY close, but challenging. Dot 5, I love the stuff.....it doesn't eat paint, doesn't hold water like dot 3 or 4 does, and for regular street driving will work fine. PICS:
New parts arrived. Valve stem seals replaced. Several weren't even fully seated anymore and one was torn! Glad I suspected them for the oil burning when I realized just how much oil I was going through but the compression tested good. Aside from replacing the rear main seal, I think this is officially the most involved work I've done on an engine. Got the old cam out this morning and new cam in. Managed to get it out without removing the hood fortunately. Tested wipe pattern on the first two valves. Will try swapping the lash pads to see if it's better or worse. But if it's about the same I'm gonna just send it. - Last week
Got the engine on the hoist, doing some test fitting. Looks like I need to notch the driver side bracket, it interferes with steering shaft. Clearance is really tight with oil pan too, I hope I don’t need to find a different one. I’ll trim the bracket a little, then give it another go in a weekend or two, hopefully it’ll fit, then I can weld the cradle on. -
calZ replied to flatout's topic in S30 Series - 240z, 260z, 280z
The location and cleanness of the break almost makes me think the heat treating of the splines made the axle brittle. -
well...first failure happens to be an axle shaft. kind of surprised by this. I ran lots of bottom 10 second passes in my 240sx with stock axles and this technotoys kit is supposed to be a "upgraded" and shortened shaft and stock 240sx joints. well it broke on the street. it was under power but in 3rd gear without any wheel hop or tire slip. luckily didn't do any other damage. just the shaft and the boot. I have sent them an email as its the weekend to see if I can get another and if they have anything to say about that. -
5 cylinder GM ATLAS 3700 build with 4L60e transmission
A to Z replied to A to Z's topic in Other Engines
10-10-2026. I finished cleaning the block and then painted it silver with engine enamel. Then I pulled the valvecover off, and did an initial cleaning on it. PICS: -
280 joined the community
Added an Atlas Z badge to the cover plate on the passenger foot plate. Funny....it looks crooked in the pic, and but straight in person. (shrug). You can tell the foot plate needs to be cleaned.
IMSA GTU vintage racer build
74_5.0L_Z replied to clarkspeed's topic in S30 Series - 240z, 260z, 280z
Hey Clark those look like very nice pieces. I like the idea of attaching the sway bar to the arms. That will increase the motion ratio of the sway bar significantly. I have a set of bump steer gages if you need to borrow them for fine tuning. -
Sometimes life changes my priorities, but I never lose the dream. Being a single father has its challenges and my shop time has been reduced. But the good news is the car is very close to complete. Been waiting on these custom machined steering arms for quite awhile. In the meantime I am over halfway through renovating my race car trailer with living quarters and some heavy maintenance on the 2500 tow vehicle. Anyway here is a shot of the new steering arms. I think I posted about the need earlier. With 8 deg of caster and my circle track steering rack, stock arms just did not work anymore. At least if I didnt want a ton of bump steer. Since I needed new arms anyway, I incorporated an inner threaded boss to mount the sway bar linkage rod end directly to the arm. If anyone has increased their caster to the point of needing similar, let me know, they can be reproduced and sold. Special thanks to my buddy Jim at Native Manufacturing for turning a big piece of barstock into many chips. -
10-08-2026. I got the driver's side cleaned tonight. The oil pan and valve cover will be cleaned off the engine. One step closer to paint! -
10-07-2026. I had a few moments today, So I took some measurements to get started on the DMZ intake DIY kit. Because of the intake, the original alternator location won't work, So I will make my own bracket and move it down to about the halfway mark. Plate steel or plate aluminum, M10X1.5 all thread screwed in to the threaded holes there, and start drilling holes and get it on there, and then slot holes as necessary to get belt alignment just right. PICS: -
ruizblanco40 joined the community
DougieDeee joined the community
The S2k is special in the world of cars. The feelings of driving and interacting with it have similarities to the S30 experience. I can see and feel the enthusiasm that the team put into it, given they were both passion projects for a company that otherwise focuses its energy on churning out well-sorted but relatively vanilla products when compared with their competition. The S30 and S2000 both hold a special place in my heart, in a way very few cars do.
Esmeraldosfdw started following '78 280Z Charging Issues
Good idea, I think I might have 2 tubes that would work for the front bolts, I think the rear bolts will be ok with the radiator bracket stiffening it up. - Earlier
Through bolting the sway bar is definitely a good idea. On mine, I ran a thin wall tubes through the holes in frame rail and welded them at the holes in the frame. The tubes allow me to fully torque the sway bar bolts without crushing the frame rails. -
I always thought an S2000 would be fun to own
New turbo cam from Steve Bonk arrived this weekend! Excited to see how it changes the responsiveness on the turbo and hopefully I'll get much earlier spool and more pleasant street driving. I've started disassembling for the installation and checked everything. It looks like previous builder used different lash pad sizes for intake and exhaust, which wouldn't seem that odd on a "proprietary" grind, except every one of the shorter pad sizes had the wipe pattern pretty far to the pivot side of the rocker arms and the taller ones were nearly perfectly centered. I know the one time I did a valve adjustment a while back wasn't perfect with my limited experience, but I find it hard to believe I'd be that far off with how paranoid I was about using the right feeler gauge for intake and exhaust. One of the intake rockers and the lobe it was on were fairly damaged but everything else looks good. Got some advice from Steve on the lash pad sizing based on my current specs. I'll be ordering new pads tomorrow and hopefully two new rockers to replaced the damaged ones I found. Also ordered some new valve stem seals. Figured now was the best time. -
10-04-2026. I took some time today, and went ahead and removed the wiring harness, the intake manifold and some other parts bolted to the block. The stuff still attached, all the bolts are now broken loose and will be easy to deal with as we go. The parts I removed either got tossed, or put into a pile.....I then cleaned them up and took a couple quick pics. Engine looks a lot smaller once you get all the "junk" off! PICS -
10-04-2026 ATLAS Z UPDATE: Well, I found out the hard way that my water methanol container had a crack in it. I ended up having to get a replacement container and a new braided line from it to the pump. I smothered the thread in pipe dope and assembled it. Then I got the whole deal back together. After that I began the install of a gas vapor filter, I went with the 8 inch long version. Just need some hose and that will be done. I spent the rest of the day on other projects. PICS.
A little progress this weekend. Painted the engine cradle and started making some brackets for the front sway bar. Going to mount the sway bar mounts by through bolting through the frame. Someone had already done that, but bolt holes were all wonky and not vertical, so made new holes and going to weld some plates for extra support. Going to use the angle iron as part of my radiator mount, and will also support sway bar bolts. -
Best ways to prevent chassis /frame warping
primaz replied to Joe0690's topic in Brakes, Wheels, Suspension and Chassis
The ones from Cap Metal Works look like they are only the bottom rails. To me what I did which is much stronger as it uses that "U" channel on the bottom and the same "U" channel inside the car to create a fully boxed frame rail and the thickness of the "U" rail is very heavy duty. I am sure those do help but if you create a fully boxed version then it really is as s strong as a full cage for chassis rigidity. -
I went ahead and worked on the 3700 today. I removed the balance shafts, and used the Badlands Industries delete kit. I then cleaned up and re-sealed the rear plate, installed the flex plate with a few bolts in case I want to do a compression test later, and then got it on the engine stand. Int he pics you will see the 4 speed automatic trans for it, a lockup unit GM "4L60e", that I will rebuild with all the tough parts and probably a 3000 RPM stall, unsure at this point. PICS:
Who's Online 0 Members, 0 Anonymous, 2270 Guests (See full list)
