- Today
I am using the stock headers. They had to get cut short to make the turn around the frame rails. It is using an OEM ecu ( I believe it was manual) that is running UPRev. The mounts are Mckinney that were sold by ZFever. Not sure how they got them sinze McKinney went out of business a couple of years ago.
06-21-2026 ATLAS Z UPDATE. I started with installing my side view mirrors, and then poured in the engine oil....then decided it was time to get the R200 differential and swap pieces done and out of the way. I first had to clean up the gasket surfaces, then I installed a factory NISSAN gasket, and then filled it with 75W140 Synthetic gear oil. Then I masked off and painted the rear cover with silver engine block paint and then a coat of clear. Tthe case itself I wire wheeled clean,t hen wiped it down and gave it a coat of clear. After that, I painted up the 280Z mustache bar in gloss black and then after cleaning and wire wheeling it clean, I painted the front differential mount in gloss black as well, and then put all of it in the corner out of the way. Quite a bit of work to get it all ready for install. I will remove my existing R180 diff and then clean up the entire area like this before installing the rear end. I also have some TT3 Techno Toy Tuning axle shafts with the Porsche 930 CV joints to put in. PICS:
- Yesterday
06-20-2026 ATLAS Z UPDATE. I wired the firewall forward body wiring today. I managed to get it all done except for the fans. I also installed the turn signal surrounds and upper and lower grill. In doing this, I also started the run of braided line back to the water methanol tank from the nozzle up front. The electricals for the Boost switch was also wired today into the passenger footwell of the cockpit. I don't have a horn picked out yet, but I now have wiring ready for it. PICS:
- Last week
My journey with a Euro '73 240Z
manninen replied to MrQuiet's topic in S30 Series - 240z, 260z, 280z
beautiful car, nice rims and nice ride height -
so, i failed MOT. there was no brake lights. fixed that it was loose connector on brake light switch but i found that parking light fuse was burning hot, measured current draw it was 5.6amps, seems to be common problem to melt fuse box. i did my math thought aging pressed pins heat cycles might have added resistance between those two connection so i soldered every connection. as i said earlier every load has dropped voltage slightly, no load its 13.8volts, press brake and it drops 13.3V. lights on wipers on fan at full blast i remember seen under 12volts on lighter socket. lets see how it goes after this work, if that park light fuse still gets hot first aid is led bulbs
valentine8 joined the community
you cant see it well, but no, it is cut out so it clears as the hood sweeps up.
Are you going to have to take the intake off whenever you want to open the hood?
06-19-2026 ATLAS Z UPDATE. I picked up my gas pedal from the fab shop today. I got it home and wiped it down, masked it off and gave it a couple coats of Rustoleum 2x gloss black paint. Should be ready for install tomorrow. PICS:
06-18-2026 ATLAS Z UPDATE: Well, after having people tell me about the intake and issues I will have with the MAF meter, and then researching on it, I decided to just redo the intake from the MAF sensor forward. I ordered some 4" pipe, a coupling and clamps and dug in. I did a layout and then cut the hood to start the process of making additional room for a smooth long radius 90 in 4" along with a vortex air cleaner to give the MAF Meter what it needs. In just a couple hours tonight I got a good start on it.....but I will have to do a notch in the radiator support to get the pipe to where it isn't being forced up over it. I am still waiting on the Air cleaner, but the job is well under way PICS:
Thomas B. joined the community
I would like to get a gas lid for my GTO and wondered what size to use on the rear quarter panel. Doesn't look like anyones been here in a while. thanks
Thx for the comments. I have tested the switch and harness connection points and all is working as it should from what I can tell. I did install the honda wiper motor swap with relay so that might be causing part of the issue. However, the fact that the blue line goes to 12V when the button is pushed is still an enigma. I believe the wire should connect somewhere but it is not clear on my harness. I have replaced both the dash (used in great condition) and engine (new) harnesses along with the fuse panel to blade type so it could be a mismatch of parts that is creating the issue. For now, I intend to run the blue wire directly to the washer motor so I will at least have washer capability even if I have to manually activate the wipers.
The "rumor" about Silvermine comes straight from the Z Power Steering site, but it isn't necessarily wrong. I believe Silvermine uses an EZ-Steer kit to make their units. Those are designed for ATVs that weigh more than most Zs and experience a lot rougher roads than a car does. They likely don't have the factor of safety of an OEM automotive unit like the ZPS, but it's up to you if that matters. I have seen multiple people who run the Silvermine kit on track and have never seen a complaint, and the EZ-steer kits get used on street rods a lot. If there were an issue with the SM units, I would have expected to see some firsthand accounts of failure online, but I've never even heard secondhand of one having issues. Here's a discussion we had years ago about delay with these units. Interestingly, the only complaints were about force-sensing units. The GPS is also only necessary if your car is stock without an electronic speed signal. I'm not sure how your car is setup, but with a VSS signal, there would be no chance for lag. If you have an aftermarket ECU, you could even setup a custom assist curve if you wanted.
It’s an 8 groove, I got the pulley kit from CVF. I would think a standard rotation wp would be more common for the SN95, I mean a lot of people mod and race it 🤷♂️ -
Anyone wanting free FSM downloads for their S30, they're available free for all production years at: https://www.xenonzcar.com/s30/fsm.php This website also carries good reference data for other-year Z cars. @FJOVA, I took a quick look at the Body Electrical sections for several years; and could not find a definitive answer to your specific question....sorry. It may be worth posting up on ClassicZCars.com, as they have a big following of folks doing original restorations. Good luck with the rest of the project!! 👍
Is that a 6 groove or 8 groove serpentine? I wish I could find a forward rotation pump the works with the SN95 Timing Chain cover. That would simplify the belt routing. I would love to lose the upper pulley/tensioner on my set-up. I'm always happy to simplify and lose weight. I'll reach out to the FlowKooler folks and see if they can provide a forward rotation pump for the SN95 timing chain cover. -
I got the correct rotation, just by luck. I bought the water pump last year, before I got the pulley kit, didn’t really understand the difference at the time. Got the belt/pulley kit and since no other accessories, standard rotation was what I needed 😅. 100% of old wiring is gone, using sniper for EFI, got a lights/blinker kit/harness and I’m making/piecing together everything else. I discovered deutsch connectors the other week and bought a kit. These are great for wiring switches and other small wiring. This is a switch for my Wilwood electronic parking brake. I’m not ready to full on wire the car yet, just evaluating what I have and making a big picture plan so when I’m ready it should be a lot easier. - Earlier
I weighed the Z with the sr20det in it and it came in at 2395. The car has changed significantly since then. I plan to corner weigh the car later this summer. I have a spreadsheet where i track parts i've installed and removed with best guess weights. I believe the car is probably around 2521lbs, give or take. I'm not sure how much my rollbar weighs (i guessed 100lbs). I would like add a full leather interior with lots of sound deadening at some point. I have been eyeing the star road aluminum body panels. My dream is to make this car the Singer of 240z for me.
you ever weighed this? I always thought a Z with a k series would have a great balance.
Some updates. We installed a larger clutch master that was very easy to install. It solved the gear release problem with the cd009. We redid the steering shaft and motor mounts. I didn’t like the way it was installed before. Will know if it’s better in about a week or two. Installed a new Garrett intercooler to replace the eBay special I had. We reduced the intercooler pipe size down to 2.5” to see if it will help with spool. Installing a 14psi spring in the wastegate actuator to help hold boost. Will dyno again soon. We also removed the spacer from the skunk2 intake and modified the entry angle. Replaced all the intercooler pipe couplers with the vibrant hd clamps. The old pipes kept blowing off. installed dapper led seven lights. So much brighter than the halogens I had. We installed the rest of the rear t3 suspension bits. we also installed a new t3 steering rack and crossmember, along with BRE mirrors.
Love the way this is coming out. its been a challenging balance to thread between making everything neat and tidy and making sure I remember its a race car and needs to be functional. decided to polish the intake manifold and turbo, which looks great but upkeep is gonna be a challenge. exhaust is mostly done and welded. need to make a fancy tip for the back. wrapped the downpipe and mid pipe. need to pull the manifold and wrap that too. originally made a open dump wastegate but then changed it up to recirc it because we have a couple tracks with some noise restrictions. I'll order another v band and wastegate outlet so i can cap the exhaust and run it open if the track doesn't have a dB restriction. Fuel system is done. bulkheaded thru the floor. 3d printed some mounts and have it mounted along the floor. injectors are in. got most of the turbo lines made up. opted for the turbosmart oil pressure regulator for the turbo. i've never dealt with a turbo this small and man its a challenge to fit everything. drain is really tight. hits v band and clamp but think i may have the puzzle solved to make it work. fuel fill is welded up. went with stainless to mitigate the risk of corrosion with ethanol. -
Do you have a forward rotation water pump? Most are reverse rotation with serpentine belt. If you try to run a reverse rotation pump forward, you won't be circulating water through the engine. Also, I would start fresh with the wiring. Don't try to reuse the original fuse block or any of the under dash wiring. -
Replacement Distributor Options
Mitchel0407 replied to FJOVA's topic in S30 Series - 240z, 260z, 280z
Sometimes the “original” works the best. Part for these cars are quite expensive and although there is a lot of information out there a lot is still missing or people just haven’t posted online, especially electrical. So please if you find things out that you had a hard time finding information about post it in one of the forums. I had trouble with my AFM (Air \Flow Meter) on my ’77 280z a while back and it was absolutely impossible to find information about the workings of them. Being from Europe also made it pretty hard as everybody just said to go on Ebay or another US supplier and buy a new one, not really an option for me. So I went on a big research spree and with some help of the Australian Z car and Land Rover forums I managed to find a suitable replacement AFM of a 90’s Ford Probe / Mazda 626. These where sold plenty over here and used parts for those are pretty cheap. In the end the 280z just uses a generic Bosch L-Tronic injection system and parts can, for the most part, be interchanged between brands and cars from that same era. I’m even running a few Porsche 944 parts. 🤣 -
Try and see if you can find a wiring diagram online. Unfortunately I only have one of a 197 280z which I will upload just in case as I suspect not much has been changed regarding something like the washer motor over those years. Try and follow the wiring with a multi meter and see where the power stops once you press the button. Also try and check the fuses, one might be blown or has a bad connection. It might be a stupid tip but try and activate the washer with the ignition switch in different positions. I was once lead down a rabbit hole thinking my blinkers weren’t working while in fact I needed to turn the ignition switch all the way to the on position (accessory position didn’t work). N77ZCAR-WIRING.pdf
06-14-2026 ATLAS Z UPDATE: I started the day by cutting and prepping a new throttle to be welded up, keeping the angles for leverage, but removing and bends to make it straight. the one I did before did not work. It needs the bends to create leverage, and a spring mounted throttle foot pad to work correctly. the factory one is bent, so pie cuts were used to straighten it, then chopping and shortening it was required. It now heads to Wagner Fabrication to be welded up and then I will paint and install later. Then I Mounted my dual catch cans. I then mounted up my front blinkers and then went back to the catch cans....tying all the lines in, One line is black braided, and as you can see, I masked off a portion of it and painted it with silver engine block paint to help it match the others. Better than not at all! I also wiped down my forward metal dash piece and set it in then and then touched up some fittings in silver to get away from too much black. I then took my blinker surrounds that have been repaired and sitting in primer forever and sanded them up smooth with some 320 grit sandpaper, and painted them with gloss black rustoleum 2X, and then a few coats of Krylon clear. Also of note, I did cut and place a PCV valve in the breather line coming from the intake back to the catch can. So....a lot of little things today, to include tying it all up and cleand up under there. Definite steps forward today! PICS:
Who's Online 1 Member, 0 Anonymous, 456 Guests (See full list)
