- Past hour
I am working on a 1972 240z (build date 11/71) with my son and we have hit a small snag with the combination switch. Everything about the switch is working well except the washer motor wiring. I press the button and nothing happens. Now, I know the pump works as it is new and I have tested it with a 12v battery. I have also tested the all wires on the switch both on the connector and an additional blue/white wire that resides outside the connector and is currently unconnected. As it turns out, this blue/white wire that is outside the connector, is the one that goes to 12v when the washer button is pressed (see pics with wire circled). I have no clue where it should be connected as there is no obvious connection point. BTW, the switch is unmolested and was fully reconditioned and works well. The car came to us largely as an unassembled project and we have made excellent progress to this point. I am sure I am missing some connection point for this wire but it is not obvious where to connect it. Any help is appreciated. Thanks.
- Today
I do sure love upgrades! But no the 280z wasn’t that small in comparison. But then again my boss drives a BMW M140i and the other one a VW ID.7 Tourer which is pretty big. Do remember I live in Europe and not the US so we rarely see pickup trucks ore large SUV’s. We rarely see cars bigger than a BMW X7, Audi Q8 or Volvo X90 (which are considered extremely big over here). Our parking spaces just aren’t that big 🤣 I mean just look at this picture for the size comparison between a normal family car / minivan and a Dodge RAM. The only people that buy pickup trucks here are people who like them, own a business (tax reasons) and tow a lot. And that’s only because it’s easy and cheap to convert and run them on LPG gas. -
flatout replied to Mitchel0407's topic in S30 Series - 240z, 260z, 280z
a project car is never "done" but we sure do love upgrades. You dont realize how small these old cars are until you park next to something modern. your bosses BMW was probably huge next to the Z -
Took the 280z to work yesterday as I have a 62km (38,5 mile) commute each way with both city and highway driving. She ran perfectly with a nice smooth idle, stable temperatures right at 180 Fahrenheit (US gauges), a nice oil pressure and the alternator charging nicely at a bit over 14 volts. The air fuel ratio was still fluctuating a bit running lean and then rich at idle but they where pretty stable while cruising. But more importantly she was an absolute blast to drive! The power was nice and smooth and felt amazing to stretch out to 6500rpm. Not to mention the reaction of the other people around you. I saw a lot of thumbs up out of the windows and people sneaking a picture of the car. Even more hilarious was me parking next to my bosses BMW. All that said I’m not fully satisfied with her yet. I believe the rear shock absorbers are currently nonexistent which isn’t too big a deal but the right rear can slam down with tremendous force when going over a pothole or bump which isn’t very comfortable. The alignment also feels a bit off as the car feels less stable then she did before. I will bring her to a garage that also does a lot of motorsports tuning close to my work next week to try and fix the alignment. I will probably also look at a set of BC Racing coilovers sometime in the close future to fix the worn out stock suspension. - Yesterday
For those whom have the earlier versions of their track attack, as they are I believe on the 3rd generation, I would recommend to have Dando's Automotive in Fremont, CA help you as they were able to get the earlier versions to work. Their earlier versions were NO WAY a simple DIY as I know for a fact that numerous custom modifications and fabrication work was needed to get the earlier versions to work. I can tell you then once they completed it, the car seemed to work well from what I was told. I am delayed on having the rear cross bar redone by a shop as the Apex one had a big gap and I do not want to use ugly spacers. From talking to Dando's I am not worried about this 3rd generation being a problem, but I bet there will be some modifications likely needed. The problem is they do not seem to listen and think they know more because they have engineering knowledge but as an example there is a difference between an early gen 240 and a later gen 240 which is probably why even on the 3rd gen the gap of the rear crossbar is so big, even though Dando's explained that and even pointed out a way to solve it by making it adjustable but did they listen? No. I think it can be a good and clearly has the cool factor but this is NOT a DIY unless you have good fabrication skills to fix whatever occurs in the install....
That JHK pan is a piece of $%(# If anyone wants my JHK pan as Up Garage refused to let me return it, let me know... Here is what is really needed for a big HP RB in a 240Z - Last week
Yes, he is; and he's looking into various solutions to address this and other issues we've been having with the site. He will let us know if there's a need for additional resources, due to any necessary changes in site hosting.
HideKuro joined the community
repkam09 joined the community
Is SuperDan aware of the problem? If not, someone should really contact him. I would think this is an easy fix.
Thanks for asking. It was equipped with a full cage and harnesses but after taking all of that out, I am going back to a "comfortable sporty". I am too tall to be in a full cage equipped car safely (don't wear a helmet all the time). The seals on the rear are so bad I feel like I am slowly dying even after 10min of driving. I am replacing the rear light and deck seals. Cleaning all the switches and electrical, replacing the interior and getting the heater controls working. I would like to drive it this summer to a few Datsun meets and then tear down the carburetors and front end for rebuilds this winter.
jeffer949 started following A tale of two Z's - NA vs Turbo
jeffer949 replied to MONZTER's topic in S30 Series - 240z, 260z, 280z
Was not implying that the only way to get work done on a project is to not have a wife and daughter!!! I can see how that could have come across. Mine is 14 and will be a freshman this year. Ive got 4 years..... Then who knows. As she has gotten older I've been telling the stories of her helping me in the shop when she was little. Her stepping into a drain pan full of oil in ugg boots that I promptly threw away with out telling mom, Me hearing a pppsshhhh noise and I turn around to see her with a my blow torch pointed at her face, Praise the Lord she didnt click the igniter She would have been around 2 also at those times. -
Using a VPN can also slow down network and website response times. If you're running a VPN, try turning it off and see if that helps the issue. Not an ideal solution, but worth a try...
74_5.0L_Z replied to Mitchel0407's topic in S30 Series - 240z, 260z, 280z
Congratulations. These old cars are a lot of work, but worth the effort. -
congrats sir, hopefully the weather in your area is nice this time of year and you get get out and put some miles, (or kilometers) on it (never been to Netherlands so unsure if you guys use miles or Km) -
Well that laser is pretty handy. you do great work. keep it up.
It took some time for an update but I am proud to say that I did it, the 280z is road legal again!! Aside from the car I have been very busy working in my backyard as the previous owners took out all the plants and then neglected the yard for 4-5 years. But back to the build log. One of the parts I still had lying around where the oil pressure sender and the coolant temperature sensor for the gauges in the dashboard. It really bothered me that both of them weren’t working and I had a feeling that it was just both of the sensors that were bad. So out with the old and in with the new. Or so I thought…. While installing the new temperature sensor into the thermostat housing the housing itself broke. As the break is a really weird one I suspect that the aluminum housing just became pours. Luckly one of the local Z club members had the correct version of the housing and send it to me. I gave that one a quick coat of paint and reinstalled all of the sensors. This time nothing broke and both the oil pressure and coolant temperature gauge finally worked! Now that that was fixed I started working on some of the smaller items on the list. I replaced the air filter, both exhaust gaskets, the horns, painted the front grill and installed the KNAC shield (translated: Royal Netherlands Automobile Club). As I had a bit of time left in the day I also replaced my pre fuel pump fuel lines and filter, installed the new speakers and fitted the fender mirrors. I expected the fender mirrors to be pretty useless but they actually gave me a way better field of view then my old door mounted mirrors! I believe these are the same metal reproduction mirrors as Zdepot sells. As I was in a bit of a time crunch for the inspection I unfortunately couldn’t finish the door cards and seats in time. Luckly the door cards weren’t mandatory for the inspection so I could just simply leave them off the car. As for the seats I reinstalled the covers for now and reinstalled them into the car. The aftermarket wheels the car came on where poking out a bit too much in the rear so to avoid any complications during the inspection I decided to install the stock wheels for now and switch them afterwards. I hindside this wasn’t necessary as they were allowed to stick out 3cm (1,2 inch) past the fenders. Then came the moment I had been working towards, inspection day! I dropped her of at the garage and they immediately started with the inspection and alignment. The only thing they found was they the washer fluid wasn’t spraying but the mechanic traced it back to a pinched line. Other then that the car was in great shape and both the mechanic as other customers were impressed with the car (S30 Z cars are pretty rare over here). Now I can finally enjoy the car and man she drives good! The only thing I noticed was that the rear shocks are gone but it isn’t a problem for now. -
Part 15- The Rear Suspension is finally attached to the Middle Body Section- The Video deals with attaching the Rear Suspension to the Middle Body Section. The Gull wing doors require additional reinforcement to the Middle Section of the 260Z. This is similar reinforcement when installing a Convertible Top on any production vehicle. With only a small center section of the roof that must support the weight of Two Doors and provide structural support for the Roof Area that will cut be out will be a nightmare. -
I also finished cutting the new Tar paper that will go on the interior floors and trans tunnel. I have a laser cutter at work. This is a Nissan part and still available as blank sheets. Unfortunately, even though it is correct, it is expensive at $100.00 USD per sheet. It took 6 sheets for the entire interior. This is the material on the laser After the metal is ready, I will epoxy coat it first then apply the sheets. Unlike OEM that had bare metal under it, this should be substantially better at keeping water from getting under it and rusting the metal
Another productive weekend. Unlike my Turbo chassis that has a late 71 build date, this car having a mid year build date has protection plates over the seat belt pockets. But of course they were used by the PO to jack the car and dented them up. I drilled out the spot welds and removed them, allowing me to straighten the dents and blast underneath them. Before: After: All sprayed with weld thru primer and ready for plug welding back on.
06-07-2026 ATLAS Z UPDATE: Continued progress on the engine harness wiring and installation. Starting to take shape....about 95% done. PICS:
john fuller joined the community
06-06-2026 ATLAS Z UPDATE: I put everything to the side and worked on engine harness wiring. Not hard, just VERY time consuming. I had opened up all the wiring, and now I am custom tailor-ing it to the setup here. Making good progress. Cutting the tie wraps connectors as needed to slide under bolt heads and tighten back down and had to make 2 large ones out of aluminum to put under a couple bellhousing bolts. The idea being keeping everything off the firewall and sides. they are shaved, and everything needs to look separate and tidy. I am putting the chrome wire looms over it and making steady progress. PICS:
yoel joined the community
- Earlier
Been a busy couple weeks but been chugging along. Got the fuel system started. mounted the ethanol content sensor, fuel filter and fuel pressure regulator. ordered line/fittings twice and still came up short on fittings and line. hopefully the last of it arrives today so I can finish it. Got the rear brake caliper bracket machined up from a high alloy steel. Due to the design i had to come up with i wanted a high alloy steel to be nice and strong. Got the clutch line made up and bled it. clutch seems to work even tho i just bled it solo. i'll get the wife out to get it perfect but it does work. I got the exhaust mocked up and tacked together. Need to come up with a nice tip to get it out just past the bumper. -
Since the frame rails were dented up pretty good from wrong floor jack positioning, I decided to replace them and this would also give me the opportunity to really get the original metal floors flat, and the metal shrunk and tight. They were surprisingly clean inside. This is the floor pan after removing the spot welds and frame rails. After some wire wheel work, and metal prep acid wash with Scotch-Brite, I worked and shrunk the metal with a shrinking rod and them smoothed it with a shrinking disk. Nice and flat getting it to what original would have looked like, leaving all spot welds and original deformations in place. I then lightly blasted the overlap areas and applied Weld-Thru paint. I then fitted the new frame rails, they took a bunch of work to get the correct shape and to match the original contour of the floor pans. I then copied all the original spot weld locations and drilled 3/16 hole to plug weld. I used several Cleco clamps to hold it in place and tight up against the floor pans. Next I used my MIG and plug welded them in place Finally I will grind smooth the plug welds More after the weekend
Who's Online 1 Member, 0 Anonymous, 226 Guests (See full list)
