- Past hour
Michael replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
Good progress! I continue to be amazed about how what prevents our cars from hitting the streets, is not some quandary of engineering (how to weld-in the roll cage main hoop, how far to set back the engine, how to tuck the custom exhaust into the transmission tunnel,...), but rather quotidian aspects of turning and the caring for old cars. Were I to have had a Chevelle or Caprice or something like that, with the same engine as my Datsun, it would have been mired in the same impasses and frustrations. Why won't it start? Why is it fouling the plugs? What's wrong with the carburetor? And to your point, is the distributor rotor pointing to the #1 plug when the #1 piston is at TDC or BDC? These problems feel so trivial compared to the engineering of a "hybrid" (in the old school sense), and yet, after multiple decades of struggle, they are what keeps our cars stuck in the garage! - Last week
Help! SF Bay Area - new to Z's, fresh build tuning
Michael replied to vrmilionzx's topic in S30 Series - 240z, 260z, 280z
Unfortunately I have nothing actionable to contribute, other than a philosophical observation. Too often, our projects become interminable, not because we fighting rust or reinforcing the chassis or doing any ambitious custom engineering, but because the engine doesn't run properly. This is true for a Chevy V8 (where many of us got our start in, you know Hybrid Z's) and one supposes also for the "original" inline-six. So, a fellow gets all clever with tubular control arms or welding-in frame rails or a roll cage, and maybe that's going swimmingly. But if the engine keeps wiping cam lobes or mixing coolant and oil, or just not metering fuel correctly... well then, those years of sedulous work and five-figure sums paid for a custom paint job (hey, it happens!) seem like a waste. In sum, we need to learn things like tuning carbs and setting timing, before we learn chassis engineering. Doing in backwards, is a recipe for frustration. Don't ask me how I know (27 years later...). -
JTR's solution for their v8 swap was a non-AL GM radiator for six cylinder Camaros. This radiator is a perfect fit, even with AT cooler side tank. An old school Lincoln Mark VIII radiator (it's a genuine two speed with two circuits) with shroud that is a perfect fit for the Camaro radiator. By perfect I mean it covers the entire GM radiator...not 1/4" too short nor 1/4" too wide. No bling here: looks boringly stock; but it moves 3000 CFM on low and 5000CFM on high. I understand the Volvo fan is a Ford corporate unit. (Didn't Ford own Volvo/Jaguar at one time.) z If some is good, more is better and too much is just about right.
I considered that actually, but it seems like it's genuinely just that my distributor is effectively flipped as a result of the crank rotation after the chain tensioner pushed out slightly. I'm not too worried about running it on sequential vs cop wasted right now though. Sometime this winter I want to pull the engine out and reseal. I'm really liking the cam and despite knowing it's not making huge power it feels pretty responsive just on Richard's base tune and some tips he's given me for my own tinkering. It feels like it's running well, but I'm also constantly chasing leaks in different areas in one form or another. I'm tired of constantly monitoring it. It feels good to not blow out white smoke every time I start up and as I get to stop lights now that the valve stem seals are replaced, but I really want to reseal the whole thing and maybe install the flat tops while it's out. Yesterday had a whole separate issue - my speedo wasn't working. I've yet to inspect, but I'm really hoping it hasn't torn like my first one. I made an effort to not have it turn at an aggressive angle coming off the transmission but I think it might not have been enough -
DuffyMahoney replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
Sometimes during cranking, you don't have enough rpms for the engine to fire on sequential. -
video of timing chain slack popping right out! V1.MOV
11-15-2026. Did a little work today on the 5 banger project. I insntalled the intake and throttle body, installed the turbo header, and then the turbo and the wastegate. Then I popped the oil filter off (it was FULL) and drained whatever was left in the oil pan from just sitting....and it's good thing I did! Then I flipped the engine over and removed the pan....18 13mm bolts, and 5 10mm bolts! I was happy with what I found. Firstly, the balancer shafts are not open to the crankcase.....there are oil drain holes, but that's it. So, I measured and will now drill the hole for the turbo oil drain in the pan, and get it welded on. The clearances are such you can't have any threads sticking in, so it has to be welded flush over the hole drilled. Lastly, I put a breaker bar on the engine and turned the engine just a bit, and all the slack in the chain snapped right out! I backed it off and SOME of the slack returned, but then I found, if I just barely go to turn the engine and the chain snaps straight. So, the timing chain is NOT stretched and in need of a new one! I will put the video of this after the pics.
- Earlier
11-13-2026. Today I picked up the valve cover from my fab guy.....he got it all welded up and sanded down the timing area where the oil filler plug was welded in. I already dropped it off at J&S Polishing here in Colorado Springs for a sanding and polishing up to near perfection. We move forward with the rest. PICS.
Sandy455 started following 7" 240Z Power Brake Booster
Looking for one that's been rebuilt. Thanks!
Nissan L-Series Cylinder Head Flow Bench Testing and Development
DuffyMahoney replied to MONZTER's topic in Nissan L6 Forum
I have been chasing software bugs all week, basically going from a bare bones Haltech Elite 750 to their fancy R3' Hopefully it starts today -
11-11-2026. I Picked up the intake for my ATLAS 5 cylinder turbo build from the powder coaters. it is "polished aluminum" color .
Been a while any updates ?
MONZTER replied to MONZTER's topic in Nissan L6 Forum
I don't think so, it's going to be a wonderful street / track car. To make 300hpb you would have a good looking dyno graph and a pain in the ass car to drive. From the math, all your parts are really well matched to your head and it's purpose. When will it be running? Again, it's just a dyno simulation, so we will see -
Thanks. I’m excited to start working on the interior. Hopefully I can get this motor in soon, then on to the inside. -
Gosh 240hp would be pretty bad for the amount of time put into my motor:) I guess time will tell -
Hi Duffy, here's some more of the info I promised. Looking at your port size and flow numbers, I think your engine is pretty well suited to a 7,000 RPM power peak. Going with a much larger cam might shift the powerband higher without gaining much peak HP, especially given the head's airflow limitations. For a street-driven car, I'd favor average horsepower over chasing a higher RPM peak. I built my cam calculator around Kameari's range of cam profiles, with a dropdown for Street, Sport, Track, or Race to help determine the intended powerband. I originally had your engine set to Sport, which recommends the Kameari 70A at 241° @ 1 mm, or 232° @ .050" . Switching to Track changes the recommendation to the 73A at 253° @ 1 mm, or 244° @ .050". Your Bonk cam is 240° @ .050", putting it right between those two recommendations. So far, I'd say you made a pretty good cam choice. here is the cam recommendation tab in my calculator cam.pdf Next I'll show you the EAP simulated dyno curves for the different cams so you can see how they compare. I loaded all the engine parameters into my analysis program to compare the cams Here are the results. Of course some assumptions as usual, as I did not put the Bonk cam on my cam stand to actually measure its profile, so it is a educated guess where the Kameari cams are documented. As expected a little more top end a little less midrange but all in a good range for what you are building As a final note, in the calculator the simulation assumes ideal conditions, and these are engine numbers at the flywheel. so I would be very surprised to see these actual number, especially on a chassis dyno. What's important is the shape of the plot and getting the power where you want it and how you want it. This last one is my best guess of what your car should be around on a chassis dyno, 12% drivetrain loss and some reduction for real world conditions -
Very nice work (everywhere, on all components). I like the cool vintage-look inserts on the seats! 👍 -
11-08-2026. I finally got the broken exhaust manifold bolt out, got the new studs installed and then got the turbo header from Forever Fabrication mocked up on there, and re-clocked the Turbo and have it mocked up on there as well. PICS.
PART 20- WHAT HAPPENED TO THE SEMA SHOW 2026 260Z WITH GULL WING DOORS? wee, That is a good question. The Last Show they were still working on the Gull Wing Doors. Now the Here is the latest video from them but there was alot of unfinished customer cars in different stages of restoration but not completed. Let hope that 260z will somehow be completed and not just trashed. Please Comment about any unfinished project 2 cars that you might know of so other people can learn of the all of potential outcomes of their Dream Cars. -
11-07-2026. Today was devoted to just the valve cover. I cut off all the tabs and brackets not needed, then trimmed off some of the "stubs" for wire ties, etc. and drilled out the 2 back breather ports for weld in female threaded -10 ORB fittings. I already have the screw in fittings, so that will be great. I also went ahead and drilled out the back portion for the oil fill bracket. To do this drilling, I had to carefully remove the baffles, which are VERY thin aluminum. I then chopped off the factory oil fill port ont he front chain cover and ground it down flush, and then took a piece of aluminum I had and made a plug to fit. Everything will now welded up, sanded smooth, and then the cover will go for a complete polishing at J&S Polishing in Colorado Springs. I had planned on cutting the chain cover potion down, but after taking measurements, the clearance is needed, ....I needed what was there so it will stay at this height.....it is different, as with the 6 cylinder cover, I had to take out approximately 3/4 inch. Progress pics follow. Cheers!
For round ports like ours, these do alright, find the smallest location, and then measure this telescoping gauge with calipers , But remember diameter is different than area. With the diameter you can calculate area with an easy online calculator if you forget how to do it. -
ihavearustedz replied to MONZTER's topic in Nissan L6 Forum
Super interesting read! Thank you. Today I learned about MCA (minimum cross-sectional area) in the port and how it relates to choosing a bottom end. Love it. What's the easiest way to measure the MCA in the port? -
11-06-2026. Today I picked up the intake and fuel rail and thermostat housing. I then dropped off the intake to get powdercoated in "polished aluminum" finish. The fuel rail, work was simply turning and refitting the pipe to work better when hooking up the fuel line. Thermostat housing was for clearance. PICS
Super cool stuff
Who's Online 1 Member, 0 Anonymous, 2120 Guests (See full list)
