- Yesterday
Paint design selection. opinions wanted
calZ replied to A to Z's topic in S30 Series - 240z, 260z, 280z
Your car is already going to be pretty bold with the picture frame hood and the fully polished engine bay, so maybe it would be good to lean into that and go bold everywhere with the two tone. It might be on theme. -
I like the first picture where the hood and flares/skirts are black and the rest of the car is a color. I really dislike the top/bottom two tone in the other pictures. To me, it looks like those cars where guys put muscle car-style wheels, a cowl induction hood, and metal flake paint on a 240Z and try to make it look like a Camaro. That's a paint job for a classic pickup imo. I don't think it fits the car at all. That said, it's just my opinion. We all have different tastes. It's your car and you're the one that's going to see it every day. If you like the look and it makes you happy, then that's what matters. -
Zyzzel joined the community
Good day Have anyone here bought anything from Patrick Reynolds? From a Facebook page called "Datsun spare parts for sale and swap? Regards
New All Aluminum Body Panels of Datsun240Z manufactured in Japan
This You Tube Video shoes the actual conversion of this Aluminum Panel 240z in a home garage. -
This You Tube Video goes over the conversion of a regular 240z to one with mostly all Aluminum Exterior Panels. The work seems to done at a home garage located in California. The owner never said level or how much his experience with aluminum panels. However, most of the panels are bolted on to the original sheet metal structure. The aluminum roof, both rocker panels and rear quarter panels were probably attached using a special aluminum to sheet metal epoxy. I worked with Japanese after market body panels and found their fitment was very good. Most of the corrosion damage found on the 240zs was actually caused by rust starting on the exterior panels. Then it spread into internal structural parts. So using these Aluminum Panels ,new Seam Sealers and Rust Preventive Methods will make these 240s last a long time. -
Ok, I posted about this earlier.....but now I have put together the pics that I have been using for inspiration on painting my 260Z the last is a drawing where everything X'd out is black with the highlighted being blue from the top......the sides being blue and the flares either black or blue. I am asking for any and all opinions of idea to think about. there the car is red int he pics, on mine it will be light metallic blue like me engine compartment. Thanks
- Last week
I have struggle to find a cap for my 1972 240z and I refuse to spend $200+ for a new one. I did find this one on Amazon and it appears to fit well -- https://www.amazon.com/dp/B07GZP12SW?ref=ppx_yo2ov_dt_b_fed_asin_title. My fuel door closes fine and the bayonet mount appears secure. For about $12.00 for two caps it seems like a good value. Now, I am restoring the car and I have yet to run the car with the new cap so standby for an update.
12-16-2025. Picked up some more items from the powdercoaters....headlight buckets, inspection doors, dash plate and gutter trim....all gloss black
Gasket link. The site kept pasting an old file. https://www.rockauto.com/en/catalog/nissan,1978,280z,2.8l+l6,1209260,engine,intake+&+exhaust+manifold+gasket+set,10220
RTZ seems to do good work. I'd trust the dimensions that guy above used, which he got from the RTz post that he linked. Or, the gaskets are probably correct. If you have one around.
12-16-2025. Drum Sander. I have been advised to use a drum sander, as it is easier on the sheet metal than a flap disc on an angle grinder. Well, yes it is! However, even at 40 grit, I finished the roof, started on a rocker and a few other spots and wore that drum half way out! Pics follow, you can see the difference comparing both methods side to side. I also took a couple pics to show how it will look ran over with a DA on 80 grit to prep it for filler. DUSTY! closer to starting the blocking.
L28ET Intake Manifold Flange Dimensions
Toiletduck34 replied to Luke280turbo's topic in Nissan L6 Forum
Sorry for posting on 5 year old thread... but I am looking to 3d print this for testing. I see the last response stating the injector spacing is wrong. has anyone gone through this to test at all? -
Got it off Amazon: https://amzn.to/4aS32Br And picked up a male pigtail off eBay: https://www.ebay.com/itm/134129914749 I actually replaced the wiper arms too. I used 93 miata arms which bolt up to the stock datsun wipers mechanism. Passenger arm is a little long so I may shorten it. For wiring, I followed this guide: https://www.electronixandmore.com/resources/automobiles/datsun/index.html Note this is very specific to the later wiring for 1978(maybe 1977 too) and would not be applicable to earlier years.
Best looking convertible I've seen https://bringatrailer.com/listing/1971-datsun-240z-345/
MONZTER started following Turbo Intake Plenum
Last week my order from Apex Engineered came in so now I can start stripping down the car and prepping her for the body shop. Money is a bit tight right now so I’ll install all my suspension parts first and probably send the car of to the shop in February. In the meantime I decided to strip out the interior and see what’s hidden underneath. It doesn’t look that bad but for a car that has been quote on quote “restored” only 10 years ago they sure did a shitty job. Lots of surface corrosion sports throughout the interior, lots of missing bolts, fasteners and rubber plugs and unpainted parts from shotty repair work. I cleaned up the surface rust and sprayed a generous amount of rust converter on everything. I will order some more rust converter, primer and color matched paint soon to clean up and protect the inside parts. I’ll also look at some spray wax to protect the hidden parts and crevasses of the chassis. A guy on YouTube I follow (M539 Restorations) uses one from Liqui Molly I believe which seems pretty good so I will give that one a try. It's not all bad news though. It looks like that in all these years the wiring harness stayed unmolested by all the previous owners. I also found out that the car has 4 pretty big and new looking JBL speakers! They didn’t all work when I tested the radio but I believe that might be the head unit itself. I will probably replace it with a Bluetooth capable retro looking one in the future. I also found a full and intact box of original Nissan glass 10amp fuses in the trunk! -
Got a little bit of work done, ran brake lines to the rear, waiting on a fitting for the front to plumb up my line lock and should be done. Also fuel cell, gauge and black box surge kit/pump came in. -
DAT26OZ started following Speed Forme Kit
12-13-2025. I installed my new water pump, repainted pulley and new hardware, and then re-installed the tensioner bracket and the aluminum plate needed for the additional of an idler pulley to make it all work right. I was able to use a drill bit to hold the pulley in place and measure for the spacers needed and the length of the longer bolt needed. I went to install the alternator, but the kit I got sticks out just a tad too far, and thus the alternator hits the rail.....so I will have to grind down the bracket to bring it in closer to the engine and then it will be fine....also found that my new drive by wire throttle body does not clear in standard configuration, So I was able to get it to work by turning it 90 degrees. Here's to hoping that will work. Then I quickly installed my new 4 core radiator and dual fans to check the fit. because my engine has the radiator spigots on opposite sides, I will be taking my radiator to my fab guy to cut the hose ports and welding on tight 90's with a length of pipe to the other side and then another 90 to make it a nice-looking remedy. I will make some nice aluminum brackets to hold the piping stationary. At any rate, I was able to verify that my radiator height is sufficient to maintain its place as the highest point in the system. After this, I cleaned out the garage, and went through a lot of boxes and prepped the car by covering the engine and front end to begin the sanding and block sanding, to get the rest in paint. I pulled the windshield, but after 51 years, it just didn't want to let the windshield go, and so it came out broken and in pieces. Not a crisis, as I wanted a new windshield anyway....just thank good ness the rear hatch glass came out just fine. I pulled the old hatch off, gutted it and to the dumpster with that rotten thing. I was also able to get a bit closer on the front blinker restoration, getting the housings painted white with rustoleum white. spray paint Only thing left is to lengthen the wires. I tri4d to wire wheel the headlight buckets, but decided they really just need to be sandblasted out. My mobile welder didn't make it today, so welding the clothes hangers in pieces to the front edge of the doors to close up a big gap will have to wait. Here comes sanding and blocking.
I have two Datsun 240Z cars both with stock body running 245 45's on 16" x 8" rims with no flares. I find it funny where people flare their car yet do not make use of the extra space. I also like Z cars with flares but why do it unless you get the right offset to maximize the tire size?
- Earlier
I purchased some gauge mounts from a seller on eBay for mounting the new Speed Hut gauges in the middle of the dash. They are 3D printed items. The design is pretty good. The plastic seems sturdy. And they incorporate metal thread inserts. The screws have a taper head, so they self center, and fit of the various parts is very good. However, I found that the gauges were loose when fitted to the housings with the backplates (which hold them in the housings) bolted tightly in place. The gauges rotated easily in the housing as there was no clamp force against the back of the gauge to hold the gauge forward against the "stop" portion that the bezel of the gauge is supposed to fit up against. After thinking about solutions for a bit, I pulled out some ancient Gore-tex I have. Basically, it is rubber gasket material with an adhesive on one side. It comes in handy for a lot of things. In this case, I cut a strip and ran it around the back of the bezel on the gauge. I fit the gauge into the housing and then pressed the backplate against the new Gore-tex rubber gasket to seat it into place. I then briefly removed the gauge from the housing and took this second picture (below) which shows how the new gasket deformed under "crush". Third pic shows that as well as the metal insert in the gauge housing. Another issue to overcome though was that the backplate only has two screws to clamp it to the housing, 180 degrees from each other. After I put the gasket in place and assembled the gauge in the housing, the backplate only pulled tight against the housing where the screws bolt up to the housing. See the first and second pics just below. I realized that I could take the aluminum mounting brackets I had already made during an initial attempt to mount the gauges in the dash, and flip them (back to front) and use the Speed Hut gauge mounting rings to resolve the situation however. See the third pic (above). While I thought I wouldn't need them any longer, these aluminum brackets ended up coming in handy. I simply screwed the Speed Hut mounting rings tight against the aluminum brackets... and this pushed the edges of the aluminum brackets against the plastic backing plate at the points which were not seating against the back of the housing properly. So, with this distribution of force at the non-secured parts of the backing plate, I was able to resolve the issue. I see now that I didn't take a picture of the other part of the gauge mounts. There is an arm that attached at the top and the bottom of the housing in the same way that was done on the stock 240z gauges. I hope I won't have any issues with that part bolting up, or with the gauge housings fitting in the dash holes. I will probably check that out this weekend.
I was talking about the dashboard frame, that the dash pad attaches also to. It's HEAVY. 12-11-2025. I got a nut and bolt run in today, got some painting going, ended up with a run on one side of the cowl, so once dry I will sand it out and repaint that side. I also started on a restoration of my front turn signals. PICS:
dont swiss cheese your frame bro. the weight savings is not worth the time and you need that strength. Hell, with the atlas power your going to need more frame rigidity. look into some rectangle tubing for frame to rear body of car frame rail extension. i dont know what its called but theres a lot of info on the frame rail upgrades on these cars. i bought bad dog frame rails but by the time i did it all and the time spent on fitting etc, your better off just fabbing your own imho you may want to have some 8-10" long angle iron welded to the front sway bar mount area for extra support. thats an easy mod. just a piece of angle with 2 holes drilled in it.
you may want to look into sourcing new Spal or Maradyne fans to replace those. I bought a similar setup for my c10 ls swap and the fans did not perform good enough. i was running 220+ and then temps climbing in traffic. This was dead of summer in Cali central valley heat so 105 hot as ballz. If it doesnt get as hot where you live you may not have that problem. I ended up going to the wrecking yard and getting slightly larger spal fans and enlarging the shroud holes a little larger to fit the fans. The Spal fans sucked WAY more cfms then those off brand. They dont pull/push to the specs they claim. I will be running dual pass 2 row on my z build. i currently have the 4?3? pass on the truck and i'll be redoing that again in the future. more passes is not better imho. bigger tubes for more heat displacement is what i'll be going for. live and learn lol. The powder coating looks great! if you dont mind me asking, what did that set you back? Powdercoating is expensive where i live. i have often considered this amazon setup. https://a.co/d/6zwvorr I think a turkey deep fryer base with a metal disc blade with grooves plasma cut into it to use as a heat deflector and then a metal trash can wrapped in rockwool, for the oven may work! idk. ive got all kinds of whacked ideas. Seems like that gun setup works best for budget setup though. i also seen where a guy used a shop diesel heater and then blew that into a metal duct into a box and that worked also. you only need to hold 400 degrees for 20min to set the powder coat. I was thinking sheets of plywood wrapped in tinfoil would work also. i've seen pigs roasted in those for hours and thats similar temps. also was thinking that if door hinges were used on the corners to hold it together you could just pull the hinge pins to dismantle and store all the pieces. still would need to wrap in rockwool i think. anyways, sorry to ramble at you, i just got a lot of parts i want to powder coat also lol i like the color you chose.. Rustoleum has a similar spray can color called "dark steel". ive been using that a lot to. i did my engine block and motor mounts in that so far.
I picked up my bellhousing and serpentine bracket for the 4200 engine today from the powdercoaters. The finish is called "polished aluminum". I had them done because frankly both pieces were ROUGH....really rough. R&S Powdercoating in Colorado Springs came through for me again. Sandblasted it out, masked off the gasket surfaces and did their thing.
Who's Online 0 Members, 0 Anonymous, 997 Guests (See full list)
