    33286
    5167
    john4
    john4
  1. Today
  2. 03-08-2026 ATLAS Z UPDATE: I got the rollbar in, a little interior painting around those areas, and then I cut the thick steel plates for my "cross bar" section going on the floor from the door jamb right in front of the seats, over the tunnel down the other side and to the other door jamb. Ready for the welder! I also did a little bit of interior parts painting, but the floor plates took quite a awhile. PICS:
  3. Yesterday
  4. Yeah, good point. It's a new feature we're trying out. We're still working out the kinks; so I apologize in advance if you're receiving duplicate notifications. Thanks for the feedback!
  5. That would be a good choice if you can't go center inlet/outlet. Displacement doesn't translate to sharper pulses like compression does...
  6. Low-ish compression, but very high displacement in my case. Current 461 cubic inches. Might eventually get one of those 598" short blocks and move my existing parts over. Would you recommend something like this: https://www.dynomax.com/mufflers/super-turbo-mufflers/super-turbo-offset-centered.html ? Maybe the 17769 model (3" in/out, largest in that series... I'd use two, of course).
  7. I liked the email reminder! I think annually would be sufficient.
  8. 03-07-2026. ATLAS Z UPDATE: I started with the intercooler piping on the turbo side, and have it ready for welding, sanding and polishing. I got started on the intake side, but ran out of parts. Since I had to pull the intake, I enjoyed the easy access to that side of the engine, and installed my new AC Delco starter, and wired the solenoid and main batt power on it. I also was able to plug in the harness points on that side of the engine, install the crank position sensor and both knock sensors, all new GM stuff. Started on the alternator bracket modifying, much more on that to do. Feel got cold, called it a day. PICS
  9. Welcome back. Let’s see some pics.
  10. Last week
  11. I have been here for long rime, just not lately. I have a nice 83 280ZX Turbo. Which started me on this site. I just modified ,restored a 71 240Z. Both are 5 speeds. I love them both.
  12. Part 7-More work on the Rear of the Hatch area to install the 370 Rear Suspension Subframe. The Entire Rear Deck and Frame must be removed to make it fit. The Workmanship is excellent and the Shop High Tech Equipment makes this big job alot easier. https://www.youtube.com/watch?v-EY6HaMiWFE48&t37s ----
  13. 03-06-2026 ATLAZ Z UPDATE. Well, today was Seat Belt Day! When the tub and walls need a cleaning, you go ahead and grab your 52 year old belts, some pliers and duct tape to hold them extended and grab a heavy duty brush, some dish washing detergent and get to it! The water going down the drain was a dark brown soup. Dirt, dust, skin, body oils, everything. You know they never get cleaned. Once dry I will have to paint the housing with the SEM Interior paint, but they will be nice. Oh and the tub is all clean and disinfected with Pine Sol! PICS:
  14. I agree, and once driving, it will be easy to stop at a muffler shop and put it up in the air and weld a plate or so on there. Well, it has gussets. I think a 4 inch wide, 1/4 thick plate front and back would be a good move. Thanks buddy.
  15. Long time no update. Got new wheels and tires and then got bored and made a straight pipe for it. Then shortly after broke my diff which leads to my next post. 87f15466ad6340caabd2639f552ed67b.mov
  16. Done. I merged your new account ("nixkarz") with your old account ("nixcars"); and kept the old account name. Try logging in/logging out to ensure that the new merged account is working correctly for you. I think that's what you were wanting; but if not, shoot me a PM and we'll get it sorted for you. Cheers.
  17. Hi, no I don't have it figured out sorry. I've had to create a new account just to be able to make contact with you. I'd like to get my old account back & log in with it please. Any chance you can sort this out for me? Account username is nixcars & email is nixcars@exemail.com.au Thanx
  18. Well look at this snazzy haltech s3 ecu mount by Galgo! All I can say is wow. I guess this means it’s time to finish my wiring from my 750 to my new S3. This is for the passenger kick panel on a 240z.
  19. Hello, @nixkarz, it looks like you got it figured out and are good to go. If you are still experiencing any issues/problems, please feel free to shoot me a Message and I'll help you get it sorted. Thanks.
  20. I know how to close the ads πŸ˜„. And I don't expect entirely ad free. I do as a user don't want 80% ads though. And agreed there is cost involved, not doubting any of that. There is no such thing as a free lunch as they say. Guess we are all constant problem solvers πŸ€”. My only thought isn't so much from a how do I block ads, but I know hybridz gets referenced all the time on Facebook groups and Reddit. If I was a new user and didn't happen to have adblock setup, I definitely wouldn't sign up because nothing looked legit. My .02, appreciate y'all listening and I'll go back to my own problems 🀣
  21. Hi, my username is nixcars, the email used for this account is nixcars@exemail.com.au but I'm having problems logging in, I tried the "forgot password" link but I'm not getting a reply email to change it... Plz help!
  22. Tap the arrow on the drop down ad and it will collapse. Then just scroll down. I too lament how prevalent ads are on the internet these days, but Dan has to pay for the server somehow. I like the membership idea. The merch campaigns always bring in a ton of money, but that takes a lot of work from whoever is organizing it.
  23. You might want to add some reinforcement to that trans mount. I know it's thick metal, but all the force is going through the weakest axis of the metal with the way you've got it.
  24. Not a bad idea. The 370Z forum shut down a few months ago, would drum up more traffic here.
  25. 03-03-2026 ATLAS Z UPDATE: Fuel system. I got 90% of it done. I just need some parts to finish. Evil Energy equipment. I love this stuff.
  26. I honestly don't know if we've ever tried anything like that; but it certainly sounds worth considering. I'm relatively new to the Admin group, so I'm happy to kick it up the chain of command for their consideration. Thanks for the suggestion! πŸ‘
  • Who's Online   0 Members, 0 Anonymous, 1031 Guests (See full list)
Γ—
Γ—
