- Past hour
02-02-2026 UPDATE. Happy Groundhog Day! Well, it's time to get that transmission in! It is a completely remanufactured GM / Aisin AR5 for a 2003-2009 Chevy Colorado 2WD pickup. These are TOUGH and the bonus is, it bolts right up to the ATLAS engine without an adaptor plate. The 6 cylinders never came with a manual trans, and so I am doing this. I got my powder coated bellhousing on and torqued down, installed a new Hydraulic throw-out bearing with the spacer from Emtech, which is needed with their flywheel. Then I took the flywheel, which comes from Emtech, but are made for them by RAM and held it up and used a couple bolts to hold it on. 29.1 lbs., so pretty heavy, but the ridge in the center of the crank helped hold it up while I got the 2 bolts started. Thanks to RAM for putting a sticker on the flywheel that does NOT want to come off! next is install my Pilot bearing, torque the flywheel on at 70 lb/ft with the blue install fluid on the threads, which is considered necessary by ARP hardware for their fittings. I added 2 pics that show where I will have to make a new hole for my shifter, as this trans is 4-5 inches shorter, and a pic showing the factory trans mount ears in the trans tunnel I have to chop off and grind smooth. not bad for 2 hours work. BIG jump forward.
- Today
Ahazel01 joined the community
I sat in those tillet seats at PRI this year and was very impressed with the hold and comfort despite not looking like it would be either.
While working on modifying the engine compartment wiring harness, I bolted up the factory Nissan gear reduction starter that I have been using. While it cleared the dry sump oil tank, I was not happy with the location of the solenoid. It was quite close to the oil tank. I didn't recall it being that far away from the block. I looked for other versions of the gear reduction online, specifically hoping to find one with the solenoid located closer to the block. However, I was not able to find a factory one that was different. I was able to find this one however: https://www.classiccarperformance.com/products/datsun-240z-260z-280z-high-torque-starter?srsltid=AfmBOopbvBP16wSs5tvniJbqMb9CK2Kds63KS8RAjuCAWd7ZupU4Lbwm Because it features the ability to change the "clocking", I went ahead with buying one. After receiving it, I compared it to the one I already had: As you can see, the solenoid is in a very different location. In fact, out of the box, the solenoid bumped up against the block and the starter would not bolt up as it was delivered. I moved the mounting plate one hole location counter clockwise (referencing the picture above). In this position, the solenoid no longer interfered with the block. However, one of the mounting bolts had to be placed into position before re-attaching the mounting plate, as there was not clearance to put the bolt in after clocking to this position. That made installing the starter to the transmission MUCH more difficult. It was possible, however. Another issue that isn't great is that the positive terminal, where you bolt the positive battery cable, as well as some of the other items that have to be powered by this terminal (radiator fans), is on the underside of the solenoid, quite close to the engine block. It is just another inconvenience. So, I was able to achieve the overall objective - improving the clearance between the starter and the oil tank, but it was with some sacrifice of convenience in mounting and bolting up main power cables. In other news, I received the real oil lines that I had made. These are XRP Pro Plus hoses. I spent a lot of time and effort figuring out the routing, making "mock up" lines from pool hose, and waiting for them to be crimped and sent back to me. Yesterday and today, I worked on routing the two that cross just at the front of the engine. I have fabricated a plate out of 6061 T6 that mounts with some spacers at the front of the cylinder head. I have drilled holes and bolted rubber insulated P clamps to locate the lines precisely so that they do not rub against each other or anything else. The tank return line runs quite close to the water pump pulley. But, it is well located to eliminate interference. I also have little clearance between the studs in the water pump (holding the fan pulley one) and the Spal electric fans. Today, I removed the studs, and switched to the use of bolts instead to gain a bit more clearance there. It was super cold here on Saturday, and I wasn't feeling 100%, so not much time in the garage this weekend. In coming weeks, I plan to do some floor pan repairs. I will likely be pulling out the engine and transmission and differential... and mounting the car body on a rotisserie to facilitate that effort. I have a couple of patch panels (due to prior rust) that I'd like to redo, and I need to install mounts or anti-submarine straps (for the 6 point safety harnesses). Plus, I need to finish welding in the custom brackets I made to mount the Tillet carbon fiber seats.
- Yesterday
Part 6- -
Awesome! This validates what I was thinking, and also what ChatGPT said (lol) Thank you soo much.. I'm going through your thread as we speak.. Have a great day, Thank you.
01-31-2026 UPDATE: I cut and modded the rear taillight panel and fitted some new reproduction euro style 240Z taillights and some factory covers I bought a while back that I had powdercoated gloss black. After that I attached the second hatch shock by drilling and tapping for it and then attached the MSA fiberglass rear spoiler. Then I cut the hole needed to access the fuel line hookups on the Evil Energy 10 gallon fuel cell. I turned it 90 degrees, as there wasn't enough rwork room underneath to have it facing back, and its much better as I now have a ton of room under there for setting up my whole fuel pump and filters setup. Then I wired the back half of the car, I will go back and make up the connections on the end later. I rustoleum primed the areas in the spare tire well and floors that needed it and then filed out the remaining holes on my dash center section so the gauges would sit in it the way I wanted them to. The rear taillight surround was the item that really fought me today. In particular the center section for the license plate. I ended up having to spend quite a bit of time modding it to make it look the way I wanted it to. The fuel cell isn't completely level yet as my 3/8" All Thread hasn't arrived yet. The all thread will attach at the feet on he bottom of the fuel cell and the bottom of the spare tire well. then at the top I have some 3/16" thick steel plates I will drill holes in for the all thread to level the tank up and drill holes to attach it through the floor on the ends. Pics follow.
- Last week
Got a few things done and checked off the list. made some modifications to the throttlebody and an adapter on the firewall to run a motion raceworks throttle cable. Made the firewall adapter have a 17mm hex to get it good and snug. This may be mostly a race car but decided to go with a small heater to make sure if inclement weather came up id atleast have a defroster. bought a maradyne universal heater to stuff under the dash. The JZ has the coolant lines on the driver side so decided to make this fancy billet firewall bulkhead. I have a couple aluminum fittings ordered and then i'll try and find some pre molded 90º hoses to fit up. The fuel rail that came with the engine appears to just be a cheapo ebay piece and the ends are cross threaded so i'll replace it. I went with a high flow 90 but may need to go with a banjo style as its close to my adapter. Started on the cage. but have been doing seat research before i go any further to make sure i can get the harness bar in a good spot. I am friends with a local youtuber so i took a ride down to his shop and sat in a bunch of his drift cars to get an idea of what seats i liked. now just to commit and hope i can make it fit in this tiny cabin. -
New All Aluminum Body Panels of Datsun240Z manufactured in Japan
jpndave replied to toolman's topic in Body Kits & Paint
@1969honda and I are going to pop our own carbon hood and fenders. The roof and doors however, I really like the idea of those aluminum parts. That envelope needs more crash protection and the aluminum would take care of all of that. We'll see how cost and availability is. -
240Z Wiper Blades Problem The problem with the 240Z Wiper Blades is their availability. As these cars go older, their parts tend to almost impossible to find. When found, they cost about $200 on Ebay. Those Universal Wiper Blades use a Plastic Universal Adaptor. However, these Adaptors don not hold the Wiper Blades to the OEM Wiper Blade Arms. Mine came off during a rain storm several times. The last time It scratched my windshield glass but fortunately it was polished off. So I decided to see if I could create a better design. Most Late model cars use a "J HOOK" design Wiper Arm. So I went to the Junk Yard and got two arms. As I was a regular customer, the owner said "just take them, I got hundreds of them". After carefully measure the distance between the Wiper Nut and the End of the Wiper Blade Tip. I just cut the donor arm about 3" off. The Univerisal Wiper Blade was installed on the J Hook. Then, slide the J Hook piece on the OEM wiper arm until the measurement was acheived. A Visegrip Plier was used to hold the two pieces together. These two pieces were tackwelded together. The newly form wiper arm was installed and tested thru its full arc. When that was achieved, I fully welded the two overlapped pieces together. A Simple Fix for the Wiper Problem. Very Low Cost and ended up with a Wiper Blade that will always be Available. Those those of you who want the original Blade-just keep the OEM one in a safe place and make one for every day use. Unless you can afford $100 when your blade wears out. -
I have an RB26 260z running EMU Black and PMU-16. You can find my thread here... https://www.gtrlife.com/threads/my-new-toy-1974-rb26-powered-260z.324573/page-12?post_id=4210907#post-4210907 That spot looks correct for the oil reference per the attached pic of my setup.
That type of fuel cell is only good for drag racing and mild street driving. I had something similar in my car when I first built it. When I started auto crossing the car, I found that the fuel had to be kept almost full to prevent starvation during braking and cornering.
10 gallon fuel cell from evil energy arrived. it fits! very nice quality. Last pic is from the Skillard site, but I just bought this floor and will be using it with this fuel cell and a battery box.
I don't know the RB that well but it looks like a coolant block drain fitting. its possible it oil but id guess coolant drain.
wexplorew started following twin turbo setup for L series
73Ed started following What is this port used for on an RB26
I have a 73 240z with an RB26, ECUMaster Black ECU and SpeedHut Guages for Oil Pressure, Oil temperature. The ECU needs oil pressure and temperature as well, so I have 2 of each sensors. I am running the mishimimoto thermostatic oil sandwich plate/cooler which only has 1 1/8"NPT port. How or where can I install all these sensors? Does anyone know what this port is for, between cylinder 4 and 5 on the intake side of the 50U block?
SEMA 2025 Chinese Version of Assembled Toyota A806 examined
This video is the Second Video concerning the Toyota A86 reproduced assembled body. They have several individuals that discuss the quality, licensing, and infor about this car body. In my opinion, the more detailed pics of the alignment and welds show that this body was not assemblied properly. If even used for the street, the body would require closing the panel gaps and alot more proper welding. Unitized bodies require proper panel alignment and sufficient amount of welding to provide a safe cafe. Please give your comments about this car body. Remember this same company manufactures the 240Z assembled body also. -
01-28-2026. Productive day. I got the remaining valve cover bolts cleaned up and painted, then installed. I then also got the fitting for the catch can installed. I drilled the access hole and got the engine wiring stand along harness laid out on the engine a couple things plugged in and fed the large end into the cabin and then set the electrical panel on tint genreal area of where it will be installed later. I also went ahead and installed the injectors and rail and pulled the header off, installed the stud kit from Atlas Industries..... installed the wastegate on to the header along with the down pipe and then got it all back on to the engine and torqued down. I took the bolts I have for holding the turbo down and turned them into studs and now I just need another turbo gasket and I can install it and be done with that. I was able to re-clock the center section, so when I get to it, I can get the oil feed and drain installed. I had enough time to get the holes cut out for my dash center panel, and with the gauges and toggle switch I can get that all assembled after I give the panel a coat of paint. Pics follow. Cheers!
I got out to the garage for a couple hours today, and I fixed the valve cover. My original baffle for the port feeding my catch can wasn't clearing....I put off fixing it forever. Well, I am now at the point that I need it fixed now to keep working forward. So, Today I grinded it all out & cleaned it up and got the valve cover down now permanently. The location when I installed the port was against the cam and cam tower. So, What I am doing to fix it, is JB welding a steel plate on the tip of my threaded and cut down bung. Once the JB Weld is cured, I will grind it down to the same diameter as the threads, and bevel the tip, and then drill a few small holes in it. Enough to hold the oil back but the vapor can get through. My catch can is such it is easy to unscrew, pour the oil back in and screw it back on anyway.
- Earlier
I wish I would have dynoed my 2.4L with ITB, but sadly I broke my oil pressure bung mount. I will be taking that block, stripping it down and finding an expert to weld it.
Got a few minor things done today. Front and rear sway bars are on. Got the steering column mounted and quick release steering wheel installed. Also plumbed up the line-lock, just need to clean it up a bit and the fronts are ready for fluid. -
01-25-2026. Winter weather continues! And so, the work I can do inside for the 4200 swapped 260Z.....continues God willing. I flipped my electrical "Central Station" over and sanded the aluminum around each nut and sides of the nuts down to make it so the JB will stick and then coated them to make the nuts permanent. The idea being, I don't want to have to lift this back off once installed. PICS:
Ok, so according to TRE the numbers I mentioned are static and Dynamic values for each injector, and are used by the tuner. Cyl Static Dynamic 1 - 600 103 2 - 606 104 3 - 588 102 4 - 594 103 5 - 594 104 6 - 600 103 Interesting. Glad I took the time to keep track of which one is in which cylinder.
Thanks for bumping this thread, good read and some good resources for me to follow up on. I will be getting to the aero parts of my build soon and this already has given me some new ideas. Balance is definitely the big thing that can be missed and tire sizing comes into play here too which I’ve already been thinking about. Most likely going with a wide square set up for the track, so increasing oversteer with just tire set up.
Part 5-Liberty Walk Body Kit Installation This video covers the preparation for the installation of the Liberty Walk Body Kit. The 2026 SEMA Build starts to take shape. -
Tim D joined the community
01-24-2026. Well, I went ahead and put my fuel rail together today. My factory rail I had the port for the fuel line hookup cut and custom welded on by Wagner Fabrication here in Colorado Springs, CO, for a cleaner look, and the wiring was custom made by Jemery at Lime-swap. Injectors are Siemens DEKA 60 lb EV6 injectors from TRE. You can see I put the chrome wire loom on as well and used some chrome tie wraps to make it look half decent. PICS:
Who's Online 3 Members, 0 Anonymous, 1055 Guests (See full list)
