    33447
    6296
    slashfivetoaster
    slashfivetoaster
  1. Yesterday
  2. 11-28-2026. I added a 90 degree fitting for my turbo oil feed from the oil filter boss and re-routed the feed line, I have the 90 on top as well, but I am still waiting for the drill bit I need to open up the restrictor to the correct size before I can finish that. I then went ahead and installed my braided heater hose on the driver's side water port to wrap around and clamp on to the water line on the back passenger side to give the engine the cooling path it wants to run cool. I then installed the Derale #15748 remote oil filter kit I got, and a PH8A filter. Also went ahead and did some more work on the upper idler bracket I made. After welding, I will clean it up a bit more and paint and re-install. I installed the new O ring and radiator thermostat I had modded and welded, and lastly I went ahead and cut up the driver's side motor mount and marked it up so the universal motor mounts I bought can be welded on to them. I will work on the passenger side mount later.
  3. hard to compete with that. it get so much attention everywhere. I've driven it on the street a few times and its crazy the attention it gets.
  4. So I’m scrapping the engine cradle. In order to get the engine low enough, the cradle interferes with the additional bracing for the apex subframe. I’m going to try some plates that come off the stock engine mounts. The plan is to trim them to fit then weld back some supports to the frame. I replaced the rear main seal I had to buy this pulling tool to get the old one out, I was getting nowhere with a flathead. Then I got the lightweight flywheel on. I’ll get back to figuring out how to mount the engine.
  5. Sounds like an awesome day! You might have some competition for coolest car in the family with your uncle.
  6. Last week
  7. 11-24-2026. I picked up my oil pan from the sandblaster. I had him go ahead and blast it clean. it was so nasty, and I just wanted it nice for once. next is for welding the turbo drain bung.
  8. We had an unseasonably warm day last weekend for us in Connecticut so i decided to get to the last track day of the season. Signed up for a Lime rock park HPDE. Lime Rock is an iconic north east circuit in western Connecticut. Luckily for me my uncle was on board as well so we loaded both cars in his trailer again and made the 1.5 hour drive Saturday morning. it was 29ºF when we arrived but the sun was out and warmed up quick. it got up to low 60s and was so nice. Car did amazing. I had the boost turned down a little bit still compared to how i have it on the street just to make sure I don't hurt anything and work on my driving rather than chasing lap times with HP. Coolant temps never went over 190ºF, oil temp under 200. Put 98.6 miles on the car on track and like .1 in the grass, haha. car took 20-25 minute sessions flat out without skipping a beat. Was able to bring passengers so took the wife for one of the afternoon sessions. She was impressed and had fun so that was extra special moment. I wasn't in the fastest run group but it sure was satisfying passing a couple Porsche GT3's, a couple Z06 corvettes, a new acura NSX, a fancy looking lotus, some sort of Mclaren and a whole bunch of BMW's.
  9. For those of you who are interested in the Unlimited Performance Modification to your Datsun 240Z-SUPERCHARGING. DiscoverNissans If interested, Go to -- V8Z Forums to---GenIII & IV Chevy V8Z to----Heavy Duty Frame Rails to----November 24,2026 Supercharging 240Z The installation process to follow-
  10. NEXT STAGE TO MY 240Z-SUPERCHARGING- Sorry for me not posting for 4months or so but Iwas busying with my next stage of my 240z-SuperCharging. There are many ways to performing this-Exhaust Turbos or Centrifugal Superchargers are presently the most popular. Both versions has their advantages and disadvantages. In my situation, I decided on Centrifugal superchargers. The One that I pick was the Procharger brand which is ,in my opinion, the best because their quality and good customer serve. But they are the most expensive. So,I decided I would have take on side jobs and sell some of garage treasures that i amassed over the years( a moped, cart parts and a bunch of automotive tools. Here is some information of the PROCHARGER: The REDLINE indicates the Installation Kit that I decided to purchase. I studied the Dimensional Drawings(Front , Side and Top views) and measuring the 240z Engine Compartment. I checked all the OnLine photos of tihis kit to check estimated clearances for this kit. My conclusion is that this kit should fit but I would probably have fabricated new alternator and air condition mounts. But like any Custom Installation, you never can forsee every problem that will occur but just solve the problem. This photo shows the Installed kit but the vehicle was a 50s truck and not a 240Z which is closer to Corvette than a pickup truck. So wish me Luck and if you are interested in my latest charter in my 240Z Build, Follow my posts.
  11. Good progress! I continue to be amazed about how what prevents our cars from hitting the streets, is not some quandary of engineering (how to weld-in the roll cage main hoop, how far to set back the engine, how to tuck the custom exhaust into the transmission tunnel,...), but rather quotidian aspects of turning and the caring for old cars. Were I to have had a Chevelle or Caprice or something like that, with the same engine as my Datsun, it would have been mired in the same impasses and frustrations. Why won't it start? Why is it fouling the plugs? What's wrong with the carburetor? And to your point, is the distributor rotor pointing to the #1 plug when the #1 piston is at TDC or BDC? These problems feel so trivial compared to the engineering of a "hybrid" (in the old school sense), and yet, after multiple decades of struggle, they are what keeps our cars stuck in the garage!
  12. Earlier
  13. Unfortunately I have nothing actionable to contribute, other than a philosophical observation. Too often, our projects become interminable, not because we fighting rust or reinforcing the chassis or doing any ambitious custom engineering, but because the engine doesn't run properly. This is true for a Chevy V8 (where many of us got our start in, you know Hybrid Z's) and one supposes also for the "original" inline-six. So, a fellow gets all clever with tubular control arms or welding-in frame rails or a roll cage, and maybe that's going swimmingly. But if the engine keeps wiping cam lobes or mixing coolant and oil, or just not metering fuel correctly... well then, those years of sedulous work and five-figure sums paid for a custom paint job (hey, it happens!) seem like a waste. In sum, we need to learn things like tuning carbs and setting timing, before we learn chassis engineering. Doing in backwards, is a recipe for frustration. Don't ask me how I know (27 years later...).
  14. JTR's solution for their v8 swap was a non-AL GM radiator for six cylinder Camaros. This radiator is a perfect fit, even with AT cooler side tank. An old school Lincoln Mark VIII radiator (it's a genuine two speed with two circuits) with shroud that is a perfect fit for the Camaro radiator. By perfect I mean it covers the entire GM radiator...not 1/4" too short nor 1/4" too wide. No bling here: looks boringly stock; but it moves 3000 CFM on low and 5000CFM on high. I understand the Volvo fan is a Ford corporate unit. (Didn't Ford own Volvo/Jaguar at one time.) z If some is good, more is better and too much is just about right.
  15. I considered that actually, but it seems like it's genuinely just that my distributor is effectively flipped as a result of the crank rotation after the chain tensioner pushed out slightly. I'm not too worried about running it on sequential vs cop wasted right now though. Sometime this winter I want to pull the engine out and reseal. I'm really liking the cam and despite knowing it's not making huge power it feels pretty responsive just on Richard's base tune and some tips he's given me for my own tinkering. It feels like it's running well, but I'm also constantly chasing leaks in different areas in one form or another. I'm tired of constantly monitoring it. It feels good to not blow out white smoke every time I start up and as I get to stop lights now that the valve stem seals are replaced, but I really want to reseal the whole thing and maybe install the flat tops while it's out. Yesterday had a whole separate issue - my speedo wasn't working. I've yet to inspect, but I'm really hoping it hasn't torn like my first one. I made an effort to not have it turn at an aggressive angle coming off the transmission but I think it might not have been enough
  16. Sometimes during cranking, you don't have enough rpms for the engine to fire on sequential.
  17. video of timing chain slack popping right out! V1.MOV
  18. 11-15-2026. Did a little work today on the 5 banger project. I insntalled the intake and throttle body, installed the turbo header, and then the turbo and the wastegate. Then I popped the oil filter off (it was FULL) and drained whatever was left in the oil pan from just sitting....and it's good thing I did! Then I flipped the engine over and removed the pan....18 13mm bolts, and 5 10mm bolts! I was happy with what I found. Firstly, the balancer shafts are not open to the crankcase.....there are oil drain holes, but that's it. So, I measured and will now drill the hole for the turbo oil drain in the pan, and get it welded on. The clearances are such you can't have any threads sticking in, so it has to be welded flush over the hole drilled. Lastly, I put a breaker bar on the engine and turned the engine just a bit, and all the slack in the chain snapped right out! I backed it off and SOME of the slack returned, but then I found, if I just barely go to turn the engine and the chain snaps straight. So, the timing chain is NOT stretched and in need of a new one! I will put the video of this after the pics.
  19. 11-13-2026. Today I picked up the valve cover from my fab guy.....he got it all welded up and sanded down the timing area where the oil filler plug was welded in. I already dropped it off at J&S Polishing here in Colorado Springs for a sanding and polishing up to near perfection. We move forward with the rest. PICS.
  20. Looking for one that's been rebuilt. Thanks!
  21. I have been chasing software bugs all week, basically going from a bare bones Haltech Elite 750 to their fancy R3' Hopefully it starts today
  22. 11-11-2026. I Picked up the intake for my ATLAS 5 cylinder turbo build from the powder coaters. it is "polished aluminum" color .
  23. I don't think so, it's going to be a wonderful street / track car. To make 300hpb you would have a good looking dyno graph and a pain in the ass car to drive. From the math, all your parts are really well matched to your head and it's purpose. When will it be running? Again, it's just a dyno simulation, so we will see
  24. Thanks. I’m excited to start working on the interior. Hopefully I can get this motor in soon, then on to the inside.
  25. Gosh 240hp would be pretty bad for the amount of time put into my motor:) I guess time will tell
  26. Hi Duffy, here's some more of the info I promised. Looking at your port size and flow numbers, I think your engine is pretty well suited to a 7,000 RPM power peak. Going with a much larger cam might shift the powerband higher without gaining much peak HP, especially given the head's airflow limitations. For a street-driven car, I'd favor average horsepower over chasing a higher RPM peak. I built my cam calculator around Kameari's range of cam profiles, with a dropdown for Street, Sport, Track, or Race to help determine the intended powerband. I originally had your engine set to Sport, which recommends the Kameari 70A at 241° @ 1 mm, or 232° @ .050" . Switching to Track changes the recommendation to the 73A at 253° @ 1 mm, or 244° @ .050". Your Bonk cam is 240° @ .050", putting it right between those two recommendations. So far, I'd say you made a pretty good cam choice. here is the cam recommendation tab in my calculator cam.pdf Next I'll show you the EAP simulated dyno curves for the different cams so you can see how they compare. I loaded all the engine parameters into my analysis program to compare the cams Here are the results. Of course some assumptions as usual, as I did not put the Bonk cam on my cam stand to actually measure its profile, so it is a educated guess where the Kameari cams are documented. As expected a little more top end a little less midrange but all in a good range for what you are building As a final note, in the calculator the simulation assumes ideal conditions, and these are engine numbers at the flywheel. so I would be very surprised to see these actual number, especially on a chassis dyno. What's important is the shape of the plot and getting the power where you want it and how you want it. This last one is my best guess of what your car should be around on a chassis dyno, 12% drivetrain loss and some reduction for real world conditions
  27. Very nice work (everywhere, on all components). I like the cool vintage-look inserts on the seats! 👍
  • Who's Online   0 Members, 0 Anonymous, 2285 Guests (See full list)
