Brad-ManQ45
8
Compression and cam don't require new injectors, and probably no change to AFM. Your octane requirement has changed though - you need more.
"Fly Yellow" and other yellows close?
Brad-ManQ45 replied to Brad-ManQ45's topic in Body Kits & Paint
Thanks guys. That Millenium yellow is just too hard for me - I want one of the brighter/paler yellows like an early/mid 70's vette or the Ferrari Dino. Anything with too much orange/red is too hard for my tastes. Actually, if you go to the following link you'll see the Sunspot Yellow that so far has come closest. http://autocolorlibrary.com/cgi-bin/search/searchpic.pl?1974-pontiac-pg02.jpg This has some of the PPG color charts online - supposedly getting Euro car charts all the way back to the 40's/50's eventually - then I'll be able to find the Ferrari color.... -
I'll bet he doesn't have to write another word - just edit all the posts he's been a part of - can you say thick reading????
Strotter - yours looks pretty close - you happen to know what year(s) that color was used? Can you send me some pics? t-tom - I have been looking at this one too. I'll have to look for some VW's I guess... Afshin - I've seen the chips for Sunflower Yellow and they don't come close to the pictures I've seen. '78 'vettes had a Bright Yellow that looks close. Thanks everyone. -
I had turned away and was talking w/friend and just turned back in time for some "titillation". I think I was the only one there to see it - no-one beleved me when I turned my head and said "WHOOAH". Even with this the halftime show sucked after the first singer and then the shot of Jessica... It's getting bad when the commercials are better than the show....
I have seen the following pics/sets of pics of a yellow I would like for my '75 when I finally get around to painting, but can't find it anywhere: "Fly Yellow" http://www.directcon.net/wander/AnsDino.html Unknown and having a hard time tracking it down: http://www.geocities.com/mr_fireman_sam/jackz/index.html "Sunflower Yellow" was a '72 Vette color...but seeing pictures of cars and looking at the paint chips aren't close... What I am looking for is something that is not as hard a yellow - very bright/light - almost electric when in the sun. Even a slight hint of green would work as opposed to the "Chrome Yellow" that some Mustangs had and the yellow in later Corvettes. "Saturn Yellow" was a color of the old VW Beetle that I remember was pretty vivid... Can anyone help in finding how to get these colors? Links to pics? Thanks, Brad
looks like they could be grilles from a BMW ar Jag...
It's easy to make assumptions when you are not given full info. Your original post aid you couldn't "here" a difference on the first 3 cylinders when you disconnected the spark plug wire from them, so I assummed you were saying the other three DID have a difference. You appear to have a wiring problem - your inability to be able to put the original system back in would indicate that, which is why I mentioned connectors before.
MobyTheVan has converted and has many posts under the Turbo/Supercharger forum....
You didn't say what happened when you take the plug wires off the back 3 cylinders... If only indivilual cylinders are affected then you have a plug wire problem, or a problem in your distributor cap, period. Thisis safe to say, because the coil is supplying ALL the cylinders the same, the only possible differences that would account for some cylinders not getting spark is something wrong in the dist cap or the wires. Have you put the spark plug wires to ground to see if there is spark from each of the wires? Have you checked the wires resistance with a V/O meter? You want to make sure all the electrical connections to the coil are good and tight, with clean wires. I am assuming the ring connectors are still on the ends of the wires - right?
Georgia considers banning evolution from schools
Brad-ManQ45 replied to auxilary's topic in Non Tech Board
Phil - I will admit that I knew we were very low but didn't remember we were last...I was thinking 48th or 49th, after all we DO have Arkansas as a state... (Thats the sate that produced Bill - right) I will take a bit of exception to your take on Lester Maddox though. Having known the man personally, he did have strong views, but as governor brought more changes and influenced more policies in the civil rights arena than a lot of people give him credit for. He was very big on individual rights and race was no part of that, and made sure that the state government saw the distinction. He treated fairly/caused to be treated fairly and hired more minorities during his administration in GA than previous administrations. Lester was a shrewd man - and being a politician, he did what he needed to do to get into office and brought his own sense of individual rights (applied fairly) to make some serious changes. All anybody wants to remember is the axe-handle though....NOT the way I choose to remember this gentleman. -
I guess they're really pulling out all the stops in order to raise the bar from the lowest 20% in the nation.... -
I'm with you Danno! I don't want the JTR stuff interfering with access/room to/around the engine either. Whether I do early/LT1 or LS1 as a basis, a new Xmember will be made... Look forward to seeing how yous works out. I'm in the process of building my rotisserie now...
How much for the rad?
What width tires do to handling/performance?
Brad-ManQ45 replied to a topic in Brakes, Wheels, Suspension and Chassis
Wider tires on the rear would make it more of an understeerer. I have an '83 ZXT T3/T4 3" exhaust, and I run 205/55/16 and 225/50/16 tires on it with biger bars, eibach and illuminas. I like the way it rides and handles - certainly capable of more than I would use on the street! If you are going to autocross or race, fine, but for a daily driver, I wouldn't go that big and expensive. On my V* Z ('75), I'm gonna go max around 235 width... -
I believe the 300ZXTT is 4.11...
Just got painted, opinions wanted on headlight covers, pic
Brad-ManQ45 replied to a topic in Body Kits & Paint
Unless you can really seal the back of the headlight bucket, don't. I have them on mine and dirt gets up in there. Of course I haven't tried sealing the headlight bucke yet. The ones I have seal pretty well around the edges of the bucket itself, it's just the stuff from behind the headlight that gets kicked up that collects... -
Read this: http://www.hybridz.org/phpBB2/viewtopic.php?t=30175
anyone know of a easy-swap hybrid turbo in place of stock?
Brad-ManQ45 replied to a topic in Turbo / Supercharger
Hi guys! Just a note on the AFM to Turbo pipe... You can remove the spring in the stock pip and cut it back some, then cut the boot itself and use it (after putting the spring back in. OK - ask me how I know... The shop that did the coonversion did this same thing, but cut the spring too far back, so that under high boost, the boot actually collapsed and split - this was after ~30K miles. The car would not idle for shxt, but ran ok above idle. I went looking for a vacuum leak and found it on the bottom of the boot next to the comprressor housing. I went and got another boot from the JY and did it the right way - no more problems. What makes this possible is that the inlet to the compressor is moved a little forward compared to stock (not much), and the bigger inlet will just match the trimmed boot. You don't have to replace the boot with another pipe and give up the other connections.... -
Tyurbonetics will know - tell them what you use the car for and what mods you will be making. The stock jpipe will work.. -
I got a T3/T4 hybrid (water cooled long w/ a installation kit for water cooling) from Turbonetics - the turbine was clipped and had an S-3 compressor trim. Works well. I used my stock turbine housing. Hits lower and stronger... Small modification to make the WG actuator work and a little time to cut down t he AFM to turbo boot and clock the turbo.... -
OK - Got it now. Couple more questions... When painting under the car, ie: wheelwells, should I be using a flex agent/additive? What single stage [aints would you recommend, and is it ok to put clear over these? Thanks for sharing your knowledge.
I found this site: http://www.itkillsrust.com/ What do you think?
Yep - it wasn't 'til the 300's that the bolt sizes changed. You may need to change the pinion flange.
255/60/15=27.1" diameter=too tall... stock~24.6" Want to stay near stock diameter. JTR says 235/60/15's will work=26.1" 245/50/16=25.1" 225/50/16 =24.9" 245/45/16=24.6" You sau you have 15" wheels - if they are 6", go 215/60/15=25.2" Lots of good ones to choose from in this size. If you have wheels wider than 6", say 7", you could run 225/60/15 =25.6".. I NEVER use the narrowest rim for a tire size in the manufacturers specs because handling is compromised. I stick to the middle, or preferably outer (largest width wheel). If this is a drag car only - no prob, if you like going around curves - do yourself a favor. JMHO of course....
