Brad-ManQ45
7
No overdrive on 280 ZXT's. Here is an article about putting the Mitsubishi Starion/Chrysler Conquest AT in the 280ZX... http://www.zcar.com/articles/twheel/4spdauto/
some pictures of my new custom grill
Brad-ManQ45 replied to S30Z Bushido's topic in Body Kits & Paint
Schweeeeet! -
You pretty much only need spacers for the 280zx conversion - no setback plate needed/able to be used. (less distance from firewall to crossmember).
Jeff: I'll take a DP for my ZXT. (Already have 3" exhaust after stock DP - including 3" cat) LOVE your site. Eventually I WILL go to aftermarket ECU... Brad
need help with z31 swap "speed sensor"
Brad-ManQ45 replied to turbobluestreak's topic in Fuel Delivery
The speed sensor bolts to the speedometer. Haven't taken out my digital dash yet, but have swapped the sensor from the '82 analog to the '79 analog. -
Do not forget that Smokey specifically said to use a Two Gear drive and areverse-rotation camshaft. AIR, he said the three and four gear drives have design deficiencies (in his opinion). That said, I believe I will wait for our resident guru - Grumpyvette - expound on his setup and insights further.....I LOVE gaining knowledge from people recognized (rightfully) as authorities. Brad
If you have the BW T5 5 Speed, you can get the right angle drive adapter from JTR that has a .66:1 reduction ratio and then set the Speedo to KPH and be reasonably close w/stock tires and maybe even spot on w/larger tires. The speedometer cable from the firewall to the speedo is the same on the ZX for analog or digital (I knw because i am converting my '83 from Digital to Analog and my Auto A/C to Manual when the weather warms). Have all the parts and even got the 130MPH speedo from a '79 to replace the 85MPS 82 cluster's speedo. I have already replaced the speed Sensor on the '79 w/the one from the '82. Z Barn supplied all parts for conversion - hey - it's still cheaper than trying to deal w/the A**holes at Z Car Atlanta....and Roger is deifinitely a good guy w/a lot of knowledge. BTW he can get molded carpet kits, not the custom cut stuff....
I too would be interested. Perhaps some Jag HID's? I personally would like to have a removeable airdam/splitter as an option. I personally didn't much care for the 'squared off' look of the grill opening on ShowCars' effort, and thought the air dam a bit overdone.... FWIW - I called MSA and they said they had only one kit and it is missing the hinges - and they wanted full price. I'd pay MSA's price for a GOOD kit from you John.
I have the S-3 Trim compressor and clipped stock turbine in the stock housing. Spools quicker/lower and much better top end...
Plastic/nylon fan same for all z's. Just had to replace mine when pump bearing went bad.
Not according to the parts man # Nissan. All pumps the same.
what are the NHRA rules for suspension on fast 1/4 mile cars
Brad-ManQ45 replied to a topic in Drivetrain
I would think that for the purpose of safety the rule was designed for, that in the case of the Jag and Vette, the halfshaft serves AS a control arm to locate the rear hub lose one and the wheel goes every which way. In the case of the Z - the strut serves as the other, and losing an axle (heaven forbid) would not affect the orientation of the wheel in any plane, so should be ok. Of course, they probably don't want us stomping all over their current patrons, so I wouldn't be surprised if they say no - in spite of logic. -
I have an '83 ZXT w/177K on it. Had dealership replace Auto Climate control Head unit that they said was bad - probably wasn't but I had no place to troubleshoot tanything at the time. 134K replaced turbo w/water-cooled T3/T4. 3" exhaust. 140K Alternator - put in ForTaurus 130A for stereo I didn't have yet. Just put on new Nisan water pump ~$40. Will be replacing Digital Dash (speedo doesn't work but OD does) and at same time am swapping out auto climate control system. Mine still works even after an AC company hosed up the vac lines (thank god for my FSM!). I intend to rid myself of Nissan's worse ideas... I already have the wiring harness and Analog Dash kit. bought 120 MPH speedo and swapped out speed sensor. Waiting on Heater/AC stuff now... Oh well - It's still cold out so I'm buiding my basement HT....Eventually will build the rotisserie for my '75 project. Too many projects and not enough time.
heads (closed chamber vs open chamber)
Brad-ManQ45 replied to a topic in Gen I & II Chevy V8 Tech Board
closed chamber=better quench=less tendancy to detonate. I'd either mill the tops of pistons or get another set (JMHO). -
Anyone got the part $ for the "small" Bosch? Didn't Bosch make the Turbo fuel pumps? Brad
Starion/Conquest wheel sizes
Brad-ManQ45 replied to a topic in Brakes, Wheels, Suspension and Chassis
'88's and '89's also had 16X8 on front and 16X9 on back as an option. -
Sure you've got the right injectors? If you were running the SVO injectors I would expect you to be this rich all the time...
T3 automotive is the Infiniti specialist shop in the Atlanta area. They recommend the B&M Cooler pre-radiator, that way the cooler in the radiator has a chance to warm the T/O up before returning to the transmission. The way it is designed it doesn't cool as much when cooler temps are present. No moving parts. For the Atlanta area, they completely bypass the radiator T/O cooler entirely - it just doesn't get that cold that often here. They claim the T/O coolers add 1/2 to 3/4 more mileage to the tranny when associated with fluid replacement every 50K.
Good on Rob! I for one was a bit disappointed at your discovery, and am very glad Rob appears to be addressing the issues. Assuming he makes good on his product, I anticipate purchasing one also. I too, appreciate your acting as point-man in this endeavor....
I may be wrong BUT... I can't help but feel the reason for some pipes being longer in the first place is packaging consideration in the engine nacelle. If all pipes are the same length, then the pulses will arrive at the collector in the same order and spacing that they occurred. The difference in pipe lengths on the stated aircraft engine can conceiveably be tuned so that at one engine speed (cruise - where it spends th most time)the pulses arrive in the appropriate order and spacing. Be aware that spoolup is not an issue in aircraft applications. If you have a twin turbo setup, yes, you would want to have the two collectors get their pulses evenly, but on a single turbo with equal length primaries (not split turbine housing), they can't HELP but arrive in the proper order and spacing.
Okay guys - I've changed it to full size. I'll have to start reading about this web site stuff... Thanks for your patience w/me. Can anyone recommend a good package/packages for image editing and web site development. I'm not really into it, and don't want to put a great deal of effort into it. My only purpose for even putting up this site quickly was to share the knowledge... That said, I've just bought a digital camera and will taking pics of my project to aid in puttingit back together and hopefully be able to show off some of my work. I can assure you I am much better w/my hands than with websites...
I have an '83 ZXT with a decent system in it. Hafler Amp driving ADS speakers up front in custom enclosures in the doors. Simple Pioneer Coax's in the stock rear locations powered by a R/F Punch 45. These are only used for "fill" and are not played loud. Competition 12" Sub in 1.75 Cu. Ft. Box powered by bridged R/F Punch 100. Audio Control Equalizer/crossover working off the front channels. No, I don't go booming down the street, but it plays plenty loud and sweet in the car. Had top of the line Sony stuff - head unit and cd which both crapped out after 7 years and ~30K. Pioneer, here I come.
Right Click and Save Picture As xxxx. I didn't want to waste bandwidth for displaying the article. You can save it and then open it on your machine. If ya'll want I can increase the size so all you have to do is read...But the non-broadband people might take a while to load...
I have posted these on my website. Thanks Katman ITS Z-Car Roll Cage Article from Z-Car Magazine Don't expect anything fancy...Too many projects and not enough time. As soon as I have some pics of my car and stuff I'll post 'em on a more elaborate site. I kept them small for bandwidth reasons (I think), I can make them bigger, but if you right click and "Save Picture As" you will have it for posterity for viewing on your posteriors anytime from your own machine!. If I get enough calls for it I can display them large, but it takes longer to get to the page, and if people are just gonna copy them anyway, who cares? This is my first attempt, so be gentle...
I have posted these on my website. ITS Z-car Roll Cage Article from Z-Car Magazine Don't expect anything fancy...
